 Old 03-25-2018, 07:19 PM   #1
Mr. Felt's Avatar
Posts: 19   (View Stats)
Mr. Felt will become famous soon enoughMr. Felt will become famous soon enough
Default Notchy Shifting
I'm new to this forum but not new to working on my own cars. I recently bought a 2010 MS3 and the shifting was notchy from day 1, definitely not a smooth shifting car. I installed a JBR short shift kit with metal shifter plate bushings hoping to improve my shifting. Nope, JBR kit actually made the shifting stiffer.
Today, I flushed the coolant system and changed the transmission fluid with Redline full synthetic MTL 75W80. I went for a quick run, I can't believe how much smoother my MS3 shifts.
Bottom line, if your MS3 shifting is a little stiff and/or notchy try changing your transmission fluid it may make a huge improvement in how your car shifts. It did on my MS3.
Mr. Felt is offline   Reply With Quote
 Old 03-25-2018, 10:53 PM   #2
Amplified's Avatar
Posts: 71   (View Stats)
Amplified has a spectacular aura aboutAmplified has a spectacular aura aboutAmplified has a spectacular aura about
RMM, changed mine yesterday and noticed a huge difference in shifting feel.
Amplified is offline   Reply With Quote
 Old 04-01-2018, 08:46 AM   #3
Sonofnothing's Avatar
Posts: 33   (View Stats)
Sonofnothing is on a distinguished road
RMM and PMM made the difference for me. I flushed and filled with the popular Ford Trans fluid, didn't help the clunkiness between gears as much as I'd expected.
Sent from my Pixel 2 using Tapatalk
'13 ms3 * 72k * FREEKtuned * Accessport v3 * COBB SRI/TI * Autotech HPFP * ETS TMIC * CS fully mounted * CS short shift plate/bushings * Goodyear Eagle F1 Asymmetric 3 * dash designs suede * weather tech floor mats.
Sonofnothing is offline   Reply With Quote
 Old 06-21-2019, 08:10 AM   #4
Whitebullet's Avatar
Posts: 24   (View Stats)
Whitebullet has a little shameless behaviour in the past
What fluid before the change? I ah e the Ford XT-M5-QS full syn, very clunky, hate it. Will i see a improvement with a change to Redline?
06 MS6 GT
SP63 Stage 1, bnr s3, hpfp, cai, cs tmic, southbend stage 2, E30 tune
Whitebullet is offline   Reply With Quote
 Old 06-21-2019, 07:01 PM   #5
Mr. Felt's Avatar
I bought the car used so I don't know what the PO had in the transmission. IMO, I would go with the Redline MTL trans oil.
 Old 06-28-2019, 09:45 AM   #6
Jayzon's Avatar
Posts: 103   (View Stats)
Jayzon has disabled reputation
This car just has a notchy shifter, you can minimize it, but I never really got rid of it. I saw the largest improvements from RMM and counterweights. I had the full shifter replacement from TWM which made the shifts much more precise, but if anything it made the notchiness a little more apparent. Still worth it though =)
Try the Redline, a lot of people swear by it
Back to Stock
Jayzon is offline   Reply With Quote
13' - Shifting is Notchy / Bitey squeaky369 2010 MS3 - Engine, Transmission & Driveline 12 08-18-2017 02:38 PM
Why does shifting feel so sloppy and notchy Noodlesincup Gen2 MS3 General Discussion 45 05-10-2012 12:58 PM
JBR SSP - Notchy / Grinding 2nd gear? minger JAMES BARONE RACING 19 08-23-2011 08:45 AM
Anyone else's transmission notchy when cold? WRX_Fan_0717 2010 MS3 - Engine, Transmission & Driveline 51 02-28-2011 08:10 PM
twm sts feeling notchy in 1st 2nd 3rd djrivera MazdaSpeed 3 - Engine, Transmission & Driveline 3 10-14-2009 01:23 AM
Page generated in 0.26594 seconds with 24 queries
