Like Tree12Likes
 Old 02-02-2015, 01:29 PM   #41
OP updated!
 Old 02-21-2015, 09:15 AM   #42
clark-white02's Avatar
Posts: 18   (View Stats)
clark-white02 is an unknown quantity at this point
Ordering the Full Race FMIC next week
clark-white02 is offline   Reply With Quote
 Old 03-18-2015, 07:31 PM   #43
Fosy's Avatar
Posts: 37   (View Stats)
Fosy has a spectacular aura aboutFosy has a spectacular aura aboutFosy has a spectacular aura about
anyone have the treadstone core dimensions?
Fosy is offline   Reply With Quote
 Old 03-18-2015, 07:47 PM   #44
chrono996's Avatar
Posts: 88   (View Stats)
chrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the worldchrono996 is the leader of the world
Core Size, 7.8" X 22" X 3.5"
Overall length 28"
2.5" inlet/outlet
712 CFM flow rate
475 HP efficient
Less than 1.5 psi pressure drop
I googled it.
chrono996 is offline   Reply With Quote
The Following User Says Thank You to chrono996 For This Useful Post:
Fosy (03-18-2015)
 Old 03-18-2015, 08:26 PM   #45
Fosy's Avatar
Overall length 28"
2.5" inlet/outlet
712 CFM flow rate
475 HP efficient
I googled it.
I saw that too but that doesn't sound right. 7 inches in height to remove the crash bar??
 Old 04-28-2015, 03:44 PM   #46
Porterhouse07's Avatar
Posts: 221   (View Stats)
Porterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond repute
Groaned at 6 Times in 4 Posts
I was wondering which cores the JBR piping kit will fit and how to tell if it will. Or is it even beneficial to piece a kit together as opposed to buying a full setup? Also, with the treadstone TR8, does anyone know how strong their crash bar replacement is?
GT3071R | HTP 3" Intake | Magnaflow CBE | Grimmspeed EBCS | Bosch 3 Bar MAP | AP v3
CS HPFP Internals | CS Catted DP | CS RMM | TR6 FMIC w/ JBR Piping | HKS SSQV4 BPV
CS SSP | Swift Springs | DM Stage 3 OCC and PCV Plate | EBC Slotted Rotors w/ Yellowstuff Pads | NGK Iridium
Freektuned 350/365
Porterhouse07 is offline   Reply With Quote
 Old 04-28-2015, 03:57 PM   #47
Castillo817's Avatar
Posts: 745   (View Stats)
Castillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the worldCastillo817 is the leader of the world
Groaned at 44 Times in 12 Posts
A lot of people here that use the JBR piping kit use it with a TR6 and TR8. That's what I'm gonna piece together along with the brackets
2013 VRM MS3
Freektuned--BNRS3--HTP 3" Sri--COBB apv3 & springs--CPE catted dp & safe seals--TS dual bov--AT hpfp internals--CFM rmm--JBR pmm, tmm, ssb, ebcs, TIGs, full egr delete, rsb & fmic piping/tr6--DM occ--CS cbe & ssp--SPC camber arms--Bosch 3Bar map--RA mudflaps
Ambit RE82 18x9.5 +38 255/35
-v8 swap in progress-
1994 Miata
DGR coilovers-Hard Dog Rollbar-STR 506 15x7.5 +15
-Sold-
2003 Protegé5 w/Hiboost turbo kit ihi vf22 turbo 5 speed
-Sold-
89' FC Rx7 vert S5 13B turbo swapped
Castillo817 is offline   Reply With Quote
 Old 04-28-2015, 04:06 PM   #48
I was thinking of the TR8 because of eventually going BT. But I'm kinda worried about their crash bar modification. I dont want to die if I get in a wreck. haha. And not to change the subject, but i noticed you run a catted DP with Res and muffler delete. how do you like that? My CS catted DP should be going in next week and was thinking of what to do behind it.
Freektuned 350/365
 Old 04-28-2015, 08:24 PM   #49
Yea I'm just going to get the tr6 since it'll be a while until I go BT... I mean I don't mind it. If you don't like highway drone then don't get both cut off. It just depends on the owner. Just see how you like the catted dp with the oem cbe. If too quiet then get the res delete or muffler delete. If still quiet, get both off
2013 VRM MS3
1994 Miata
-Sold-
-Sold-
 Old 04-28-2015, 09:06 PM   #50
tastysi2004's Avatar
Posts: 1,063   (View Stats)
i have the TR825. its the length of the tr8L but meant for high boost like the tr8.
fills in the gaps that the tr8 gives the gen1's in the front.
had a buddy that works at treadstone make it for me. told him my needs/wants/and goals. he said he had something just for me. isnt in their website. call or email and they'll hook you up.
2008 MS3 gt mica black
EL NATOR DE Virginia/Florida
Update: getting that
Purple drank in my tank.
554whp/546wtq @ 30psi.
another build? maybe soon..
#CATBACKEXHAUST
 Old 04-28-2015, 11:09 PM   #51
How should I adapt the 80mm DP flange to the stock CBE size?
Freektuned 350/365
The Following 2 Users Say NO Thank You to Porterhouse07 For This Un-useful Post:
AwAfrican (05-18-2015), mize13 (05-18-2015)
 Old 05-18-2015, 05:40 AM   #52
AwAfrican's Avatar
Posts: 1,038   (View Stats)
This is an intercooler thread not an exhaust thread.
However read facts about the dp youre looking at on the product website it will tell you if it fits or not in the stock cbe and should come with the hardware
 Old 05-20-2015, 03:26 PM   #53
silver speed3's Avatar
Posts: 3   (View Stats)
silver speed3 is an unknown quantity at this point
How big of a core could I go without interfering with the crash bar ?
silver speed3 is offline   Reply With Quote
 Old 05-20-2015, 03:32 PM   #54
MBalik's Avatar
Posts: 500   (View Stats)
MBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the worldMBalik is the leader of the world
I believe the tr6. Somebody correct me if I'm wrong
2013 White Pearl Pu
Back to stock.... for now
MBalik is offline   Reply With Quote
 Old 05-20-2015, 03:36 PM   #55
acousticdefbot's Avatar
Posts: 319   (View Stats)
this may be helpful.
guzzlin' a guinness stout.
acousticdefbot is offline   Reply With Quote
The Following User Says Thank You to acousticdefbot For This Useful Post:
MBalik (05-20-2015)
 Old 05-28-2015, 11:08 AM   #56
speed3black87's Avatar
Posts: 75   (View Stats)
speed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud of
Groaned at 8 Times in 3 Posts
Tried searching..kinda lazy today. Does the Gen 1 have different mounting point then the gen 2 mazdaspeed for the TMIC. I am selling my streetunit TMIC from my Gen 2 to my buddy who has a Gen 1.. Should I tell him that shit wont fit or what?
2012 MAZDASPEED 3 BLACK MICA -COBB SRI - COBB TIP - STEBRO CBE -ULTIMATE RACING CATLESS DOWNPIPE- STREET UNIT TEST PIPE -AUTOTECH INTERNALS - STREET UNIT TMIC - CORKSPORT TRUNK BRACE- STREET UNIT RMM (BROKE) JBR 88A RMM - CPE PASSENGER MOUNT - CPE TRANSMISSION MOUNT -COBB ACCESSPORT -SNOW PERFORMANCE STAGE 2 BOOST METH INJECTION KIT- DAMOND OCC -XXR 531 18X9 HYPER SILVER 235/40/18 GFORCE TIRES- PIRRELI PZERO RACING SLICKS ON OEM RX8 R3 RIMS- KSPORT SPEC AR COILOVERS - TURBO SMART BPV-DENSO ITV22'S
STRATIFIED TUNE BY LEX
speed3black87 is offline   Reply With Quote
 Old 05-28-2015, 11:17 AM   #57
Same mounting points. Yours probably does not have a shroud (their fix for it hitting the firewall was to not re-design the shroud like others, they just did not include it) but Gen 1 did. Will it hurt? Dunno. Not my car, and fuck Street Unit.
 Old 08-18-2015, 08:03 AM   #58
patABQ's Avatar
Posts: 164   (View Stats)
patABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond repute
Maybe I missed it, but I wanted to make a comment on FMIC vs TMIC and the intended purpose. I chose a TMIC since I do not sit in traffic much and did not want to restrict the cooling capacity of the radiator.
I recently met a gen2 owner that had blown his motor do to overheating. After a rebuild, he was still overheating. He was tracking his car at altitude. I live at 7200 ft and cooling is a much bigger issue with altitude densities hitting well over 10Kft and little water in the air for heat capacity. I asked him what his mods were and he had Stage3 w/FMIC. I said "that's the problem". The FMIC is heating much of the air getting to the water radiator and leading to overheating.
The moral of the story is make sure you understand what conditions you will be running in and choose appropriately.
Silver 2012 MS3 , 2007 Corvette Z06 , 2008 Hayabusa
MS3 Mods
Sure PMM, DMM, REM (all TORQ S3 Street in Stealth Black), Sure Sway Bar, JBR Sort Shifter
Cobb - AP V3 SRI, TIH, 3-port Boost Controller, SS 3” DP
Corksport TMIC
CP-E full HPFP with warranty
All Freektuned with two tunes, one for 15psi and another at 20psi
patABQ is offline   Reply With Quote
 Old 11-19-2015, 12:39 PM   #59
cam0070's Avatar
Posts: 66   (View Stats)
cam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant futurecam0070 has a brilliant future
Default anyone heard of or use this?
I didn't see this treadstone TMIC in this article: Treadstone Performance mazdaspeed 3 Turbo Top Mount Intercooler Core CMS675 | eBay. I searched and didn't see another thread on this; if I missed it I'm sorry. Thoughts? Can you use the stock inlet and outlet and use this core?
Cobb - APv2
CP-E - Stage 1 RMM
JBR - Tru 3.5" intake, SSB, SSP, coolant bypass, EGR bypass, BSD
NGK iridium plugs
MT-90 fluid
M2 TP
autotech internals
FreekTuned 93+e40
cam0070 is offline   Reply With Quote
 Old 11-19-2015, 12:43 PM   #60
Looks like that needs to be added in.
cam0070 (11-19-2015)
 Old 11-19-2015, 01:05 PM   #61
cam0070's Avatar
if anyone knows HOW to use that core, It'd be much appreciated. I may have to jump on it if I can somehow use the stock inlet/outlet or get them cheaply.
Cobb - APv2
CP-E - Stage 1 RMM
NGK iridium plugs
MT-90 fluid
M2 TP
autotech internals
FreekTuned 93+e40
 Old 11-19-2015, 01:08 PM   #62
I just saw that is a top mount, not their ill-fitting FMIC kit.
All you need to do is weld up some end tanks and you are golden. So...
 Old 10-08-2017, 10:03 PM   #63
panaspeed3's Avatar
Posts: 68   (View Stats)
panaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to behold
Groaned at 23 Times in 11 Posts
How about the crash bar options for gen 2 ?
panaspeed3 is offline   Reply With Quote
 Old 03-02-2018, 09:34 PM   #64
jaimespeed's Avatar
jaimespeed can only hope to improve
I have a turbo xs fmic intercooler that i had on my gen 1. Will this work on a second gen? Also i noticed the piping is different from many of the other intercooler kits will i have trouble fitting a 3 inch intake?
jaimespeed is offline   Reply With Quote
The Following 2 Users Say NO Thank You to jaimespeed For This Un-useful Post:
Djohns (03-03-2018), JSmith (03-03-2018)
 Old 03-03-2018, 04:53 AM   #65
Djohns's Avatar
Posts: 3,944   (View Stats)
Neutral  :  -1 score
Sick first post.
2010 black mica speed3
Soon:built motor
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f427/official-gen-1-2-mazdaspeed-3-intercooler-106721/
gen 2 best tmic - Mazda 3 Quebec This thread Refback 07-29-2013 08:01 AM
Choix de next mod. - Mazda 3 Quebec This thread Refback 10-30-2012 05:52 AM
The MS6 Intercooler Thread RhoadBlock MazdaSpeed 3/6 - Turbo Induction 36 03-19-2019 03:44 PM
3/6 intercooler thread completed uncorked11 MazdaSpeed 3/6 - Turbo Induction 14 09-17-2018 12:16 AM
LTA Intercooler Concept Thread J-Liss Mazdaspeed3/6 General Discussion 164 02-24-2014 10:48 AM
MazdaSpeed 3 AEM Front Mount Intercooler KenAEM Mazdaspeed3/6 General Discussion 10 07-28-2011 09:41 PM
Page generated in 0.45506 seconds with 37 queries
