 Old 07-20-2012, 10:35 PM   #1
moonrider_99's Avatar
Posts: 185   (View Stats)
moonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond reputemoonrider_99 has a reputation beyond repute
Groaned at 46 Times in 14 Posts
Default Oil advice 2012 MS3
Greetings,
I purchased a brand new 2012 MS3 and after looking over my manual it says to only avoid aggressive driving for the first 600 miles and do an oil change at 5000 miles.
5000 miles seems like a long time to keep the oil from the initial break in, in fact it's a long time for any oil change on a turbo car. On my WRX, 3000-4000 miles and Rotella T6 was the best way to keep the engine happy (Blackstone labs data). These cars would shear a crappy 5W30 down to a 20 in no time.
Any comments/recommendations? What oil does the MS3 come with from factory? Is it really safe to keep the factory oil for that long? What oil/OCI do you guys recommend from thereafter?
Thanks.
2017 Ford Focus RS - Stock
2004 MSM
- AEM Intake - BEGI - FM Turboback - Turbosmart BPV - Hallman Boost Controller - ...
"I'm a Turbo addict, I know."
SCCA Philadelphia: (http://www.phillyscca.com/solo/)
2012 MS3 Silver w/ Tech Package - sold in '17
2009 WRX Stage 2- sold in '12
moonrider_99 is offline   Reply With Quote
 Old 07-20-2012, 10:52 PM   #2
FastHatch's Avatar
Posts: 27   (View Stats)
FastHatch will become famous soon enoughFastHatch will become famous soon enough
Welcome! I'm sure there is already a thread about this. I have no idea what the stock oil is but I'm sure it's nothing nice. I've changed mine every 3 to 4k depending on how I've been driving. I've always used 5quarts 5w30 royal purple 1quart Lucas synthetic oil stabilizer. Runs like a champ.
2011 MS3 liquid silver CS SRI/TIP-- CS air box--CS TMIC--CS catted DP--CS CBE--CS SSP--CS OCC--CP-E stage2 RMM--AT Internals--COBB AP
FastHatch is offline   Reply With Quote
 Old 07-20-2012, 10:59 PM   #3
Matt H.'s Avatar
Posts: 137   (View Stats)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
I would agree on 5000 miles. It just doesn't seem right in many turbo applications. For our cars there is a must for a oil catch can. As the miles get put on a oil change interval there is more and more chance of oil vapor to circulate though the engine. As far as what type of oil i have also read very good things on the T6. I have personally used Moble 1 0w40 this is the same oil used in the Nissan GTR and it will simply thin out very fast. i am currently using amsoil 5w40 if you can foot the bill i highly recommend. You will probably get slamed and get tolded to search but this toppic is always a good one to have fresh and out in the open.
Matt H. is offline   Reply With Quote
 Old 07-20-2012, 11:16 PM   #4
manila's Avatar
Posts: 1,767   (View Stats)
Rotella T6 5w-30
/thread
'12 MS3 Black Mica w/ Tech
 Old 07-20-2012, 11:35 PM   #5
franz's Avatar
Posts: 1,258   (View Stats)
franz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the world
Originally Posted by manilaMS12 View Post
Rotella T6 5w-30
/thread
5w-40. There might be better if you plan on running e85 too. Look for the thread talking about sticky spill valves.
Pennzoil platinum/ultra 5w-30 is also good for these engines. That is what I run and change it every 3000k.
Sent from the ether.
2007 MS3 Black Mica. Stock. 235whp/244wtq Dynojet
FREEKtuned 277/316 Dynojet
Corksport SRI/TIP/FMIC/GFB BPV/AT Internals/EBCS/Gutted 2nd Cat
Bilstein B8/Swift Spec-R/ST120s/Nitto 555
JBR 70dur. RMM-TMM-PMM/SSP+Bushings/TIGs/OCC
franz is offline   Reply With Quote
 Old 07-20-2012, 11:50 PM   #6
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
I run mine strictly on ky and cum as a stabilizer.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
breakfstincluded (07-21-2012)
 Old 07-21-2012, 12:07 AM   #7
cesaros's Avatar
Posts: 1,261   (View Stats)
cesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the world
Groans: 106
Groaned at 53 Times in 41 Posts
soo many threads already cover this. search.
rotella T6 is good to use.
cesaros is offline   Reply With Quote
The Following User Says Thank You to cesaros For This Useful Post:
 Old 07-21-2012, 12:09 AM   #8
franz's Avatar
So your running that new biodegradable G-Oil then?
 Old 07-21-2012, 01:19 AM   #9
pstpolamalu43's Avatar
Posts: 148   (View Stats)
pstpolamalu43 has a reputation beyond reputepstpolamalu43 has a reputation beyond reputepstpolamalu43 has a reputation beyond reputepstpolamalu43 has a reputation beyond reputepstpolamalu43 has a reputation beyond reputepstpolamalu43 has a reputation beyond reputepstpolamalu43 has a reputation beyond reputepstpolamalu43 has a reputation beyond reputepstpolamalu43 has a reputation beyond reputepstpolamalu43 has a reputation beyond reputepstpolamalu43 has a reputation beyond repute
Pennzoil Ultra with a change every 3-4K with a Bosch Distance Plus filter.
'12 Liquid Silver Metallic MazdaSpeed3 w/ Tech Package | JBR RSB | JBR 70a RMM | JBR SSP | Continental ExtremeContact DW | 55/35 Tint | JL Audio 12" W3V3 | Alpine M500 | CS LED Kit | CS Towplate | Red G2 |
pstpolamalu43 is offline   Reply With Quote
 Old 07-21-2012, 01:23 AM   #10
kashbringer's Avatar
Posts: 514   (View Stats)
kashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the world
I run pure marvel mystery oil.
2012 MazdaSPEED 3 - Crystal White Pearl
Performance - Precision 5858 - Built motor (K1 Rods / Wiseco Pistons / ARP main studs / Stock head bolts) - Cobb V3 AccessPORT - PERM 5th port kit, PERM Plate - HTP 3.5" Intake (Powder Coated Pure Orange) - Autotech HPFP Internals – CPE Vband Exhaust Manifold - Kozmic Vband Downpipe, Dumptube, Oil feed / Return lines, Vented OCC, Primary EGR delete – Ultimate Racing Catback, FMIC modified for 5th port by Kozmic Motorsports - Turbosmart dual port , 45mm EWG - JBR Coolant Bypass, EGR Delete, Throttle body TIG, Dogbone RMM, Transmission Mount, Sealed OCC - Grimmspeed EBCS - NGK plugs - Bosch 3.5 Bar MAP w/MattJackson86 PnP Harness – Ported Intake manifold with VCTS delete, 1/8" Intake manifold TIG by Zack - Spec Stage 3+ Clutch and flywheel
Tuned by Voltwings
(OLD k04 SET UP ) 374.5 WHP 447.2 WTQ with stock K04 - 1-17-14 Dynocom dyno
(New BT numbers soon) ~487WHP 455wtq Virtual Dyno and out of fuel... moar injectors!
Looks - Pure Orange Powder Coated Gen Pu Stockers - Muteki SR48 Lugs - 5k HIDs / 3K HID Fogs
kashbringer is offline   Reply With Quote
 Old 07-21-2012, 02:05 AM   #11
emag remrofni's Avatar
Posts: 1,594   (View Stats)
emag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the worldemag remrofni is the leader of the world
Groans: 209
Groaned at 92 Times in 38 Posts
Here's a useless image to go along with a useless thread.
// 09 CWP // Cobb SRI // SURE Race RMM // eBay double penetration DP // SU BPV // ITV22's // JBR SSP // KMD Internals // VTAK GAUGE // Cobb FMIC V.1 //
4 Gallon E85 by Stratified
My Photography - DarkSidePhotoshoot.com
it was a mexican
whoever said they are lazy is a stupid dumb fucking idiot
and they can do ANYTHING...they prolly got the wheels off with a branch and some hedge clippers
Originally Posted by FreeFlyFreak View Post
The dick bone is not connected to the asshole... Mind over matter, learn to control them both.
emag remrofni is offline   Reply With Quote
The Following 3 Users Say Thank You to emag remrofni For This Useful Post:
breakfstincluded (07-21-2012), MS3Shadow (02-03-2016), WetzMS3 (02-03-2016)
 Old 07-21-2012, 03:21 AM   #12
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
What the fuck? You guys changed your oil? WHOA! Guess you didn't get the memo Mazda is shipping these babies with oil that only needs to be changed every 100k!
Spoofmastafly is offline   Reply With Quote
 Old 07-21-2012, 04:47 AM   #13
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
Rotella or Pen Plat/Ultra, they hold up well to fuel dilution from DI.
 Old 07-21-2012, 08:26 AM   #14
Thanks for the information, I did search first but nothing came out specifically regarding factory oil and how long people kept it. For those who bought their cars new, how long before the first oil change?
I guess I'll be getting more T6 soon. :-)
2004 MSM
 Old 02-03-2016, 10:25 AM   #15
BACKYARDKUSTOMZ's Avatar
Posts: 51   (View Stats)
BACKYARDKUSTOMZ has a spectacular aura aboutBACKYARDKUSTOMZ has a spectacular aura about
I used Eneos 5W-30 for a wile, I just recently switched to Liquimoly Longtime High Tech 5W-30.
CP-E SRI & TIP, JBR boost tubes, GFB hybrid BPV/BOV Accessport V3
BACKYARDKUSTOMZ is offline   Reply With Quote
The Following 5 Users Say NO Thank You to BACKYARDKUSTOMZ For This Un-useful Post:
ANITIX87 (02-03-2016), g00s3y (02-03-2016), MS3Shadow (02-03-2016), robbspeed (02-03-2016), WetzMS3 (02-03-2016)
 Old 02-03-2016, 10:28 AM   #16
ANITIX87's Avatar
Posts: 1,394   (View Stats)
ANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the worldANITIX87 is the leader of the world
Groans: 93
Groaned at 27 Times in 16 Posts
@BACKYARDKUSTOMZ; just because your avatar is a caveman, doesn't mean you have to resurrect a 3-year-old thread about a topic that's been covered ad nauseum.
TOTS
2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5
alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml"
ANITIX87 is offline   Reply With Quote
 Old 02-03-2016, 11:05 AM   #17
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Join date of Jan 2009, cmon dude you know better than this......
You giving brownies a bad rap.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 02-03-2016, 11:09 AM   #18
I enjoyed the revival, simply for longcat.
 Old 02-03-2016, 11:23 AM   #19
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
 Old 02-03-2016, 11:45 AM   #20
sent from my Nexus 6P
 Old 02-05-2016, 03:36 PM   #21
eliwwjd's Avatar
Posts: 518   (View Stats)
This has been discused and proofed by many members. There are only 3 oil brands that work the best on this disi platform: rotella, penzzoil platinum and royal purple.
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
 Old 04-04-2019, 08:10 AM   #22
LOL @ RP! That shit is garbage!
Looking for purchase advice on 2012 Veniversum Gen2 MS3 General Discussion 56 11-03-2012 09:02 PM
Need Advice JCSPEED3 MazdaSpeed 3/6 - Big Turbo Builds 2 12-18-2011 03:35 PM
Need some advice 2gr84u MazdaSpeed 3/6 - Turbo Induction 5 08-26-2011 10:07 AM
Page generated in 0.43149 seconds with 38 queries
