Like Tree19Likes
 Old 09-27-2013, 01:57 PM   #81
tbcota25's Avatar
Posts: 1,542   (View Stats)
tbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the worldtbcota25 is the leader of the world
Anyone ever use the Napa Platinum oil filter?
Sent from my HTC One using Tapatalk 2
2012 Black Mica
Mods
CS catless DP, CS RP
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
CS Short Shit Kit and Shifter Bushings
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
JBR Reticulation Tube
Cobb AP v2
H&R springs
JBR Rear Sway Bar
Self Built 3 Port EBCS
maisonvi Shift Knob
Tuned on 93 and corn
tbcota25 is offline   Reply With Quote
 Old 11-01-2013, 02:27 PM   #82
LatinKraze's Avatar
Posts: 804   (View Stats)
Did my oil change today. Ran a PureOne filter (after reading this thread) last change that I chopped open today. I never knew about theses differences discussed here and have been running all types of filters in the past (without issues) and all seemed to have the rubber gasket that stuck to the plate like a mofo. Sure enough, my dremel went through the PureOne like butter and it was noticeably easier to remove due to the treated gasket.
I picked up a Bosch Distance Plus D3330. From looking inside I can see that the valve is silicone, the gasket is treated, and it comes with a coil spring instead of a leaf spring. I'll open this one up next time and post pics.
Thanks for the informative thread.
2016 CX-5 GT AWD
 Old 12-01-2013, 07:08 PM   #83
ihasmazda's Avatar
Posts: 1,011   (View Stats)
One thing I wonder about is the bypass psi value on these "equals" vs the oem filter which I havent found anywhere. In the subaru world this is critical as they have much higher than normal rates and a lot of the cross referenced filters published don't have the correct bypass psi value. I just ordered up a spin on conversion but without knowing what the correct bypass psi is, I'm a bit nervous about going with anything other than an OEM filter. Is it the normal 8-11 psi or is it higher for the turbo motor?
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
 Old 12-01-2013, 07:29 PM   #84
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Neutral  :  -1 score
6 years of using these products has proven that they work. No need to reinvent the wheel here.
403whp/451ft/lb Dry Shot
 Old 12-01-2013, 07:43 PM   #85
ihasmazda's Avatar
I dont doubt that they work but my concern is that using a filter with a lower than spec bypass psi will open the valve prematurely, say during a cold start or WOT for example, which causes a no-filtering situation. You'd never know it was happening. Not once that I've seen from all of the threads I've read lists what the OEM filter bypass valve psi value is... I may be nitpicking here a little but I find it interesting that no one seems to be concerned with this especially considering how prone these motors are to getting dirty oil fast.
 Old 01-07-2014, 11:16 AM   #86
[R]usty's Avatar
Posts: 2,204   (View Stats)
I tried the Napa Gold Filter per OP's recommendation. It does look as high quality as you say. It's a bit smaller than my last filter (K&N) but I change my oil every 3000 miles so that's no biggie. I've religiously used K&N since I respect the hell out of that company and can get them pretty cheaply. I don't mind changing it up to another quality product.
Also, after reading the OP I decided to inspect my K&N, I was expecting to see a rubber valve and leaf spring but when I looked inside I was surprised to see a coil spring and a silicone valve. Guess they've changed that since you wrote this. Might be worth noting.
2010 Mazdaspeed3 w/tech
andrewz17 (06-24-2014)
 Old 09-09-2014, 12:25 PM   #87
rocky1979's Avatar
Posts: 1   (View Stats)
rocky1979 is an unknown quantity at this point
guys what about Mann oil filters? they are good enough to my mazda 3 2006 2,3 engine?because they are for 3$ in rockauto in europe market they are very good but i 'm not sure their quality in usa market...i use amsoil signature series 5w30 and change after 10000 miles
rocky1979 is offline   Reply With Quote
 Old 09-09-2014, 12:45 PM   #88
btstarcher's Avatar
Posts: 4,852   (View Stats)
I'd use Google; nobody here would know what to use on a regular 3.
SnailTune in progress
jack_hammer (09-29-2014)
 Old 09-09-2014, 01:13 PM   #89
tbcota25's Avatar
Well then I would just use the amsoil oil filter...
2012 Black Mica
Mods
Magnaflow CBE
Autotech HPFP
NGK Plugs
CS RMM
JBR PMM
Cobb SRI and TIP
CS TMIC
SU Boost Tubes
Cobb AP v2
H&R springs
JBR Rear Sway Bar
maisonvi Shift Knob
 Old 09-09-2014, 02:57 PM   #90
Yatta's Avatar
Posts: 1,862   (View Stats)
Mann filters are good, been using them on my Audi/VW's for a long time, for those motors it is preferred.
 Old 09-25-2014, 04:10 PM   #91
Strom1's Avatar
Posts: 16   (View Stats)
Strom1 is on a distinguished road
Groaned at 11 Times in 3 Posts
Default LF05-14-302B filter wrench where?????????
Anyone know where to pick up the oil filter wrench for the stock Mazda LF05-14-302B oil filter?
Strom1 is offline   Reply With Quote
 Old 09-25-2014, 05:31 PM   #92
someguy's Avatar
Posts: 914   (View Stats)
Amazon
 Old 09-29-2014, 05:39 PM   #93
3wheeln's Avatar
Posts: 55   (View Stats)
3wheeln is just really nice3wheeln is just really nice3wheeln is just really nice3wheeln is just really nice
WIX is pretty good from what I've gathered.
3wheeln is offline   Reply With Quote
 Old 09-29-2014, 05:47 PM   #94
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
Buy one and cut that bitch open
it's fun to do bad things
 Old 09-29-2014, 07:57 PM   #95
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
What I've been using for the past 4-5 oil changes.
2011 Mazdaspeed 3 [Sold]
 Old 12-02-2015, 11:26 PM   #96
BACKYARDKUSTOMZ's Avatar
Posts: 51   (View Stats)
BACKYARDKUSTOMZ has a spectacular aura aboutBACKYARDKUSTOMZ has a spectacular aura about
I'm gonna go ahead and give the Denso oil filter a shot.
CP-E SRI & TIP, JBR boost tubes, GFB hybrid BPV/BOV Accessport V3
BACKYARDKUSTOMZ is offline   Reply With Quote
The Following User Says Thank You to BACKYARDKUSTOMZ For This Useful Post:
UnknownSuperhero (12-08-2015)
 Old 04-03-2016, 11:06 AM   #97
Wide tire man
dbrier's Avatar
Posts: 957   (View Stats)
dbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the world
In case anyone wants to see how much bigger the WIX 51516 filter is compared to the OEM size, here you go.
2012 Crystal White Pearl Mazdaspeed3
Cobb AccessPort, Autotech HPFP internals, Corksport Stage II intake with TIP and airbox, Corksport rear camber arms, Corksport catted test pipe, Denso ITV22 plugs, JBR rear sway bar and HD mounts, CP-e stage II rear motor mount, Mazda5 rear brake upgrade, Bilstein struts, Eibach pro springs.
Too many wheels & tires to list.
dbrier is offline   Reply With Quote
 Old 04-04-2018, 01:18 AM   #98
KooshaS's Avatar
Posts: 24   (View Stats)
KooshaS is on a distinguished road
Groaned at 6 Times in 3 Posts
Anyone know the part number for the NAPA gold oil filter for my MS3 gen 1? I got one numbered 7203 from the NAPA store itself but i read somewhere that its the wrong one.
KooshaS is offline   Reply With Quote
 Old 04-05-2018, 12:50 PM   #99
MoMS3's Avatar
Posts: 235   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
Do the spin on conversion if it doesn't have it already, and just use the wix/napa gold filters for a Mazda 3.0 V6 and never worry about it again. More oil and filtration capacity.
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
 Old 05-21-2018, 01:02 PM   #100
I've been using a MAHLE filter (OC338) , I like it, changed every 5,500K with ACDelco 5W30 Dexos1 GEN2.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f427/oil-covered-now-what-best-oil-filter-106998/
[NA] Best oil filter choice - Page 2 - MX-5 Miata Forum This thread Refback 01-29-2015 06:14 AM
oil question - Page 2 - Subaru Legacy Forums This thread Refback 01-28-2015 07:43 PM
What oil filter are you using thread? - Speed3/6 This thread Refback 04-07-2014 10:42 AM
MS3 Engine Oil Threads - Page 7 This thread Refback 08-31-2013 09:39 PM
What type of oil should i use. : mazda This thread Refback 03-19-2013 05:13 PM
Has anyone used a pure one oil filter on a ms3? This thread Refback 09-18-2012 08:35 PM
ETS has your suspension needs covered! ETS Michael [ETS] Extreme Turbo Systems 19 12-12-2015 02:39 AM
How to Deal With an Ice-Covered Car Haltech Automotive News 1 01-25-2011 05:39 PM
We obsessively covered Day Two of the... Haltech Automotive News 0 11-03-2010 07:30 PM
We Obsessively Covered Day One of the... Haltech Automotive News 0 11-03-2010 12:27 AM
Page generated in 0.41245 seconds with 37 queries
