 Old 07-22-2010, 10:45 AM   #1
akabickle's Avatar
Posts: 30   (View Stats)
akabickle is on a distinguished road
Groaned at 9 Times in 6 Posts
Default Rear motor mount
Id like to take a poll. I guess my first upgrade is going to be a rear motor mount. Looks like CP-E is the most popular. But what about the CorkSport inserts? I DO NOT want alot of vibration at idle but i want to feel the gain of having one.
Is there enough gain out of a 60 duro RMM?
Would the inserts be just as good?
Thanks guys! Ill order as soon as i get everything sorted out
2010 MS3 (Tech Package, CP-e RMM)
2008 Civic Si (Vibrant header with HFC, Skunk2 70mm CBE, AEM SRI, P2R TBS, Comptech Short Shifter)
Harley XR1200
akabickle is offline   Reply With Quote
 Old 07-22-2010, 10:54 AM   #2
treyclash's Avatar
Posts: 592   (View Stats)
treyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond repute
Groaned at 321 Times in 98 Posts
Street Unit seems to have a decent one but no first hand experience and so does trz
2010 Mazdaspeed 3 Liquid Silver.
Performance: -K&N SRI. -CP TP. -Forge BPV.
Interior: -DashDaq.
Exterior: -Rally Armor Mud Flaps. - Xenon 35w 6000.
treyclash is offline   Reply With Quote
 Old 07-22-2010, 11:31 AM   #3
indianaryan's Avatar
Posts: 496   (View Stats)
Groans: 39
You will use the search button because there are tons of threads on this topic already.
2010 Silver Mazdaspeed3
indianaryan is offline   Reply With Quote
 Old 07-22-2010, 11:34 AM   #4
ckahler666's Avatar
Posts: 212   (View Stats)
ckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the worldckahler666 is the leader of the world
+1 for TRZ
Eat glass nigga!!!!
ckahler666 is offline   Reply With Quote
 Old 07-22-2010, 01:30 PM   #5
mghtymouse380's Avatar
Posts: 1,182   (View Stats)
mghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the worldmghtymouse380 is the leader of the world
Groans: 58
TRZ is awesome that is what I have on but you get some vibes. But it is awesome.
2013 CWP (DD)
COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP
TUNE IN PROGRESS (RFINKLE2)
1999 Mazda Miata (PROJECT) (blown motor)
BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8
mghtymouse380 is offline   Reply With Quote
 Old 07-22-2010, 01:58 PM   #6
charlesfist's Avatar
Posts: 281   (View Stats)
charlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the world
Look around, theres a lot of info on this..
Heres my quick take.. (Gen 1)..
I've had the CS inserts first (for almost a year), then a CPE 60, and then a CPE 75.
Inserts are best for NO increased vibrations and a stiffer feel.
The stiffness seems to get less over time (i would say this for all mounts i've used actually).
For me it was about 10 months where i realized i needed something better than inserts (seemed to be getting softer).
CPE 60 was quite a bit better than the inserts (comparing insert stiffness after being used for almost a year).
A little vibs initially, which settled down to nothing over a few hundred miles.
I broke this, so went with the stiffer one.
CPE 75 was a litlle better than the 60.
Obviously more vibs than both (which is really not that much), but down to minimal after a few hundred miles and still a pretty good stiff feeling.
FYI, my car is my DD and a/c is almost always on.
I would say that for the price those inserts are really good. I was low on cash when i first started with my car, so went with them and an intake, instead of just a RMM. I never regretted my decision.
charlesfist is offline   Reply With Quote
The Following User Says Thank You to charlesfist For This Useful Post:
akabickle (07-22-2010)
 Old 07-22-2010, 02:28 PM   #7
cesaros's Avatar
Posts: 1,261   (View Stats)
cesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the world
Groans: 106
Groaned at 53 Times in 41 Posts
CS inserts tend to increase vibes a bit.
TRZ is by far the best RMM, but it also the harshest. It has a 0% fail rate, and has the best design for strength.
Street Units RMM is a bad design because its a 2 piece.
CPe is good but ive seen the rubber bushing begin to tear after only 8 months.
Since you don't want vibrations, CPe is probably your best choice. But if you can handle a little vibration at idle, then TRZ is miles better than any other RMM.
cesaros is offline   Reply With Quote
The Following User Says Thank You to cesaros For This Useful Post:
 Old 07-22-2010, 04:52 PM   #8
akabickle's Avatar
the bottom 2 replies were exactly what i was looking for!! thanks guys. I was afraid the inserts would wear out. I do not want vibrations and i guess after a few hundred miles the 60 duro would be the best for me. I Always drive with the AC on especially now in the oklahoma humidity. looks like ill go with the CPe. thanks guys for help with my first mod!
Harley XR1200
 Old 11-07-2010, 08:17 AM   #9
dr_banano's Avatar
Posts: 502   (View Stats)
dr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the world
Groaned at 22 Times in 8 Posts
can any body link me to to the trz rmm page
thanks
Dr_banano
Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front
ptp studs/seals pending
mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car
dr_banano is offline   Reply With Quote
 Old 11-07-2010, 10:56 AM   #10
redblur's Avatar
Posts: 1,083   (View Stats)
redblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the world
Groans: 46
thanks
Found it:
Protege Garage - TRZ "Dog Bone" Rear Motor Mount - Mazda3 and Mazdaspeed3
Anyone know what the torque specs are on the bolts when retightening?
|2010 VRM Speed3|
|CS SRI/TIP/TMIC|UR CBE/TP|CP-E HPFP|COBB AP Stg2 FREAKTune|SU BPV|TRZ MM|ITV22's|
Last edited by redblur; 11-07-2010 at 10:56 AM. Reason: MSF Database - Automerged Doublepost
redblur is offline   Reply With Quote
rear motor mount jb1118 MazdaSpeed 3 - Engine, Transmission & Driveline 11 06-05-2014 05:10 PM
Rear motor Mount Franconemo MazdaSpeed 3 - Engine, Transmission & Driveline 13 09-26-2009 10:47 AM
another SU REAR MOTOR MOUNT armarine04 MazdaSpeed 3 - Engine, Transmission & Driveline 4 04-23-2009 06:45 AM
Page generated in 0.31144 seconds with 28 queries
