 Old 04-11-2018, 10:00 AM   #1
thatbluespeed's Avatar
Posts: 6   (View Stats)
thatbluespeed can only hope to improve
Default Sputtering at idle.
What's up y'all got a question. So I just purchased my 2010 speed3 in Feb. I'm a noob when it comes to how these things work and operate. I do know from reading that there very intricate when adding parts. The only thing I have so far on the car is a hella long injen Cai. Not sure if I got HPFP yet but will be checking this weekend. Waiting on my AP to come in the mail. So me takin precautions I went ahead and had my spark plugs changed out with ngk step colder. They were not gapped to .026 because the shop I take to said that gapping works best for cars with tunes. I also got new coil packs to be on the safe side. Car does have 118k but I got it for like 6k with all the maintenance receipts and one owner who was an older couple. Vvt got checked and it's perfect compression test numbers were good across the board. Just wanna figure out this damn sputtering when I'm sitting at idle. I can't load the video of the sputting but if you need more info I'd be happy to give it. Also there's no CEL and car drives great. Idles at what I'd believe is between 750 -800 rpm. And the noise is clearly audible in cab when the radios off.
Sent from my Pixel 2 XL using Tapatalk
thatbluespeed is offline   Reply With Quote
The Following 2 Users Say NO Thank You to thatbluespeed For This Un-useful Post:
SIXual Panda (04-11-2018), Thor Hammer (04-11-2018)
My 2008 Speed 3 will not hold an idle and rides rough at low rpm and low idle Dgms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 11-23-2016 03:42 PM
Sputtering(maybe mis-firing) at idle and bad hesitation with any type of acceleration Zmcg1995 Mazdaspeed3/6 General Discussion 6 06-01-2015 07:35 AM
Rich AFR, Hesitation, Rough Idle, Sputtering Exhaust BrandonRKD MazdaSpeed 3/6 - Troubleshoot/Diagnostics 20 09-29-2014 12:28 PM
Car sputtering tchase CX-7 > Issues & Troubleshooting 21 01-07-2014 05:37 PM
Sputtering at idle? small_luffa 2010 MS3 - Engine, Transmission & Driveline 40 11-20-2011 08:05 PM
Page generated in 0.28908 seconds with 25 queries
