![]() Join Date: Jun 2019
Rep Power: 0 ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score ![]() Sent from my iPhone using Tapatalk |
![]() Join Date: Aug 2018 Location: NYC
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score Sounds like a rear mount. Had the same thing not long ago when my stock mount went. Metal thud sound when shifting or right when the clutch engages unless you go out of your way to shift super smooth and baby the clutch. Replaced it with the JBR mount and all good. |
| The Following User Says Thank You to Quazz236 For This Useful Post: | markiespeed3 (06-27-2019) |
![]() Join Date: Aug 2012 Location: Middle Coast
Rep Power: 263 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
Groans: 126
| Not Ranked : 0 score Where's it sound like the thud is coming from? Engine bay? Transmission? Further back? Check your rear and passenger motor mounts, hopefully it'll just be one of those rather than some sort of clutch/trans issue. PMM is especially easy to diagnose...locate it on the passenger (obviously) side of the bay and if there's a gross colored fluid or residue covering anything in that area then you've found your problem.
__________________ Genpoo stuff |
| The Following User Says Thank You to sharksinspace For This Useful Post: | markiespeed3 (06-27-2019) |
I’m hoping that would be the ideal situation. I am not 100 percent sure but what you’re saying sounds pretty spot on. I’ll have to check once I get off work today. It’s like almost a thud by my feet unless I baby it like you said. Sent from my iPhone using Tapatalk | |
| Steering Wheel Thud Noise | Socal Ms3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 11-06-2012 12:40 PM |
| Loud thud over bumps | wtf lol | MazdaSpeed 3/6 - Suspension & Brakes | 17 | 10-01-2012 08:26 PM |
| All-Wheel-Drive thud help | blackstang54 | MazdaSpeed 6 - Engine, Transmission & Driveline | 29 | 10-23-2011 10:22 PM |
| Chassis Thud in Reverse???? | John F | 2010 MS3 - Troubleshoot/Diagnostics | 14 | 01-20-2010 06:18 PM |
| Rear Mount Thud | popecruz | Mazdaspeed3/6 General Discussion | 7 | 07-15-2008 05:38 PM |
