  • 1 Post By bigriver
 Old 04-24-2012, 10:07 AM   #1
gearhead750's Avatar
Posts: 383   (View Stats)
gearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the worldgearhead750 is the leader of the world
Groans: 30
Default Todays FAIL What should I do?
So I decided to install my CS SRI/TIP today. Everything was going fine until I pulled the little tube off of the boost control solenoid. I guess I went in dry and it didn't bite the pillow. The nipple on the BCV broke off with the stupid little hose. So here's a pic:
So I continued my install fail and put everything where it needs to be and just left the hose hanging on the top of the TIP as I now have nowhere else to put it. I flashed the stage 1 OTS CS SRI/TIP 93 map and went for a drive. No issues no CEL so what should I do? Is this going to be a problem? I also took a 3rd gear log. FP drops only on line 88 (internals will be here Friday) Thanks for your help.
todaylog.xls
BTW anyone attempting this instal should be very careful with that little hose on the BCV. It didn't take hardly anything to just snap it right off..
Thanks 4G63 for the avatar!!!
Originally Posted by DarkHeartMS6 View Post
I didnt think there was a person on this planet as stupid as you... Congratulations, you proved me wrong. WTF is a Mazda RX-7 if not one of the best "tuner" cars as you put it.. out there. Jump off the honda dick, pull the Golf R cock out of your mouth... replace it with a gun and end this world of your stupidity! Please, before you cause a retard apocolyptic end to our world
gearhead750 is offline   Reply With Quote
The Following 2 Users Say Thank You to gearhead750 For This Useful Post:
EdgeAutosport.com (04-24-2012), Raider (04-24-2012)
 Old 04-24-2012, 10:22 AM   #2
bigriver's Avatar
Posts: 1,123   (View Stats)
There are tons of threads on this. Get a new part. Either oem or grimmspeed.
Removal of that hose is best done by slitting the hose.
kritz likes this.
bigriver is offline   Reply With Quote
The Following 6 Users Say Thank You to bigriver For This Useful Post:
gearhead750 (04-24-2012), JTMS3 (04-24-2012), kritz (04-24-2012), rfinkle2 (04-24-2012), trf5000 (04-24-2012), Vinnie (04-24-2012)
 Old 04-24-2012, 10:29 AM   #3
Groans: 30
Yup thanks. My lazy non searching ass just found that out. I suppose I shouldn't drive it anymore even though it's running ok?
 Old 04-24-2012, 10:29 AM   #4
evilgrin's Avatar
Posts: 77   (View Stats)
evilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant futureevilgrin has a brilliant future
Aargh! This EXACT problem was discussed prolifically in one of the most read sri install how-to's, dude did same thing. Pretty sure that's your wastegate solenoid valve, and I don't think it's good idea to drive the car like that (especially in boost). IIRC, the dude payed like 100 or so bucks for a new o.e. valve
MS3 iz no more!... Now haz HEMI Ram!...
evilgrin is offline   Reply With Quote
The Following 2 Users Say Thank You to evilgrin For This Useful Post:
gearhead750 (04-24-2012), Vinnie (04-24-2012)
 Old 04-24-2012, 10:33 AM   #5
Bob-o's Avatar
Posts: 1,312   (View Stats)
I drove my car that way. You'll be fine, just stay out of boost. I'd get the grimspeed cause it has metal nipples, which won't break, and is a better quality product.
The Following User Says Thank You to Bob-o For This Useful Post:
 Old 04-24-2012, 10:41 AM   #6
Jhornbrook's Avatar
Posts: 708   (View Stats)
Jhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the world
Groaned at 6 Times in 4 Posts
If your VIP get over too ms6 for sale thread and pick that kids up or call Eric or Jp from edgeautosport. Definitely get a grimmspeed as it will do everything you want and when you go big power it will help.
Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC//
Jhornbrook is offline   Reply With Quote
The Following 2 Users Say Thank You to Jhornbrook For This Useful Post:
EdgeAutosport.com (04-24-2012), gearhead750 (04-24-2012)
 Old 04-24-2012, 10:43 AM   #7
We just got 50 grimmspeed 3 ports in stock
deadlandxtreme (04-24-2012), gearhead750 (04-24-2012), Raider (04-24-2012)
 Old 04-24-2012, 11:02 AM   #8
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
@gearhead750 don't worry about it, you can drive your car fine that way. i bought my car used and had it for 3 months before i put a tip on. it turns out that hose was disconnected from the stock tip the whole time. plenty of hard driving. all that hose does is release a small amount of already registered air back into the intake. now, on your car, that air is getting vented, but it's such a small amount, i think it will hardly make a difference.
now, had you broken the other nipple, that connects to the wastegate, then you'd be in a more serious situation..
fwiw, i just gave my hose a little twist to get it off the bcs.. but i think the slit method is better, more foolproof, especially since i was replacing the too short stock hose with a longer one.
i'd just look around for a used/cheap oem
check:
Online Mazda Parts
Car-Part.com--Used Auto Parts Market
The Following User Says Thank You to tddvrrn For This Useful Post:
 Old 04-24-2012, 11:22 AM   #9
Groans: 30
OEM part ordered (got a deal) should be here in a few days. So two of you guys say don't drive it and one says no problem. I would really like to drive it, but I don't want to dick anything else up....... Frustrating. And I never thought to look here prior to install because I put a CS intake on my MZ3 a year ago and it was a breeze. CS should have had better instructions/warnings on this one, kinda disappointing. This install was one of life's pleasures I could have lived without. Oh well live and learn.
 Old 04-24-2012, 11:30 AM   #10
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
I did that too, same nipple. That one goes back to the TIP. If it was the other one that goes to the WGA I would say don't drive. I super glued mine back on til my nearest dealership got one in. I stayed mostly out of boost but you're fine. I couldn't get the old BCS out without ripping the TIP out, so at least you get to practice that install again.
 Old 04-24-2012, 11:29 AM   #11
Whiteboy's Avatar
Posts: 2,032   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Groans: 142
JB weld FTMFW!
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is offline   Reply With Quote
The Following User Says Thank You to Whiteboy For This Useful Post:
Raider (04-24-2012)
 Old 04-24-2012, 11:37 AM   #12
Pseud0logik's Avatar
Posts: 2,042   (View Stats)
Pseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the worldPseud0logik is the leader of the world
Groaned at 34 Times in 31 Posts
Are you hitting full boost without that tube? I forgot to reconnect mine once when I removed my TIP and I was only hitting 14psi until I hooked it back up.
Pseud0logik is offline   Reply With Quote
The Following User Says Thank You to Pseud0logik For This Useful Post:
 Old 04-24-2012, 11:42 AM   #13
Groans: 30
Yeah....look at the log I attached in the OP
The Following User Says Thank You to gearhead750 For This Useful Post:
Pseud0logik (04-24-2012)
 Old 04-24-2012, 11:48 AM   #14
Well OBVIOUSLY I could look at the log that you posted in the OP to answer my pointless question. Duh.
The log looks good, I wouldn't worry too much.
 Old 04-24-2012, 11:38 AM   #15
dantes5823's Avatar
Posts: 6,576   (View Stats)
dantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the world
Groaned at 52 Times in 48 Posts
I broke mine and drove it to a locals house to get a grimmspeed. On the way i schooled this WRX and pulled like 4 cars on em...targeting 20psi held 18 like this. Car drove just fine.
dantes5823 is offline   Reply With Quote
The Following User Says Thank You to dantes5823 For This Useful Post:
 Old 04-24-2012, 11:56 AM   #16
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
When I did my CS SRI/TIP install I am pretty sure I saw a warning in their instructions for that hose. Maybe I just knew about from here, anywho like others have said stay out of boost until its fixed.
Super fail, followed by epic win, followed by shit eating grin fail superskaterxes Mazdaspeed3/6 General Discussion 9 03-06-2011 04:12 PM
$125 of todays mods worth more than all of my mods put together. DCLXVI MazdaSpeed 3 - Engine, Transmission & Driveline 11 09-15-2009 06:25 PM
FAIL! TURBINETECH L/A IC FAIL! bioevolve MazdaSpeed 3/6 - Turbo Induction 50 07-21-2009 04:25 PM
Page generated in 0.36261 seconds with 32 queries
