  • 1 Post By adconley95
 Old 08-06-2019, 10:59 PM   #1
adconley95's Avatar
Posts: 6   (View Stats)
adconley95 is an unknown quantity at this point
Default Transmission Rebuild
Hello everyone
My 2010 has suffered from the 2nd gear pop out issue. I'm at 88k. I have not done a fluid flush or any trans service, I've been holding off as I'd like to just rebuild the trans or at least inspect and replace the damaged parts.
With that, all I see if people say just rebuild it, why dont you rebuild it, rebuild time, etc..
But nobody has the info on a rebuild. Do I need to crack it open and then jim ellis the broken parts?
Not interested in buying a lower mileage used trans.
Thank you guys!
christianbarnes10 likes this.
adconley95 is offline   Reply With Quote
 Old 08-07-2019, 06:23 AM   #2
Posts: 2,237   (View Stats)
You could take it out and bring it to a transmission shop but it won,t be cheap.
a used one will be cheaper with an unknown status, the best is to get it from a salvage that sell it with a warranty.
i have a garage and usually do everything myself but a transmission is not easy. i made an attempt and gave up to finally bring it to a shop. there is special locks and clearances because of the conic bearing that you may easily screw up if you fail...
 Old 08-07-2019, 01:03 PM   #3
Bertospeed3's Avatar
Posts: 149   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
My 2nd gear has been popping out since the day i got it home from the dealership 4 years ago. Granted, it doesn't pop out often but I've been holding off since.
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
Bertospeed3 is offline   Reply With Quote
Transmission Rebuild - Halp Ingle MazdaSpeed 6 - Engine, Transmission & Driveline 14 12-19-2017 03:07 PM
transmission rebuild q's wyeto MazdaSpeed 3 - Engine, Transmission & Driveline 0 03-27-2015 08:15 PM
Transmission rebuild ciezczak1 MazdaSpeed 6 - Engine, Transmission & Driveline 0 06-08-2014 09:50 PM
Transmission rebuild Bombtek MazdaSpeed 3 - Engine, Transmission & Driveline 2 03-08-2014 04:26 PM
Manual Transmission rebuild manual Doc-1 MazdaSpeed 3 - Engine, Transmission & Driveline 5 07-07-2009 08:57 PM
Page generated in 0.23906 seconds with 22 queries
