> 2010 MS3 - Dyno Sheets/Discussions
 Old 06-30-2015, 08:14 AM   #1
CHUNKYBOWSER's Avatar
Posts: 209   (View Stats)
CHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the world
Default GTX3067r Actual Dyno Numbers E33
I posted my vdyno numbers from my GTX3067r a while back, but here's an actual dyno I did this weekend. A few changes were made to my self tune, and I've kept torque lower to hopefully give the engine more longevity.
This run was actually my second run, so I probably had some heat soak since my meth isn't working at the moment. The tires spun on the rollers during the first run.
Here's a link to the video.
https://www.facebook.com/sean.diasda...2/?pnref=story
Engine
| GTX3067R | Cobb AP | Autotech Internals | HTP 3.5" Intake | M2 Long Downpipe |
| ATP FMIC | Forge V1 | Grimmspeed EBCS | 3 BAR MAP | NGK Iridium IX |
| Damond EGR Delete | JBR OCC | E33 Self Tune | DO7 Meth |
Handling
| Damond RMM | Damond PMM | JBR 88a TMM | JBR Shift Weight & Knob |
| JBR Rear Sway Bar | Cobb Springs |
CHUNKYBOWSER is offline   Reply With Quote
The Following 6 Users Say Thank You to CHUNKYBOWSER For This Useful Post:
09TrueRedGTX (06-30-2015), Code Monkey (06-30-2015), Jeremy M (06-30-2015), MSpeedDemon3 (06-30-2015), NCspecV81 (06-30-2015), Tifosi42 (09-09-2016)
 Old 06-30-2015, 10:56 AM   #2
09TrueRedGTX's Avatar
Posts: 127   (View Stats)
09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute
Nice numbers and a flat torque curve.
Great work!
09TrueRedGTX is offline   Reply With Quote
 Old 06-30-2015, 10:57 AM   #3
MSpeedDemon3's Avatar
Posts: 6   (View Stats)
MSpeedDemon3 will become famous soon enough
Good stuff. I think i've seen your car around.
Looks clean. And now fast!
MSpeedDemon3 is offline   Reply With Quote
stock dyno & Cobb v-dyno numbers garf 2010 MS3 - Dyno Sheets/Discussions 45 04-08-2016 11:51 AM
BNR S3 DYNO NUMBERS??? Speed3KG MazdaSpeed 3/6 - Dyno Sheets/Discussions 142 01-13-2016 01:34 PM
Dyno numbers seem low. nzjase 2010 MS3 - Dyno Sheets/Discussions 15 07-15-2013 11:16 AM
Stock dyno numbers Ace99899 Gen2 MS3 General Discussion 9 10-19-2011 05:36 AM
Results on an AWD dyno vs. a 2WD dyno: closer to actual power on the road? desperado callado MazdaSpeed 3/6 - Dyno Sheets/Discussions 10 05-18-2009 11:27 AM
Page generated in 0.23990 seconds with 23 queries
