> 2010 MS3 - Dyno Sheets/Discussions
Like Tree3Likes
  • 1 Post By atvfreek
  • 1 Post By BigJimMs3
 Old 01-11-2012, 01:01 PM   #1
atvfreek's Avatar
Posts: 7,787   (View Stats)
Default My Freektune
So I had the day off and decided to swing to the local dyno and see where my tune is at. Pretty happy with with the results. 2nd run was the best and made 300hp/340tq uncorrected and on pump gas(93 octane). Corrected #'s were a little lower due to it being 60 in the shop.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 15 Users Say Thank You to atvfreek For This Useful Post:
2011speed (01-12-2012), BigJimMs3 (01-11-2012), charlesfist (01-11-2012), ckMS3 (01-11-2012), Dahouse702 (01-11-2012), helmetface (01-12-2012), jrlms6 (01-11-2012), JTMS3 (01-11-2012), ms3bamf (01-11-2012), Oliverms3 (01-11-2012), redblur (02-26-2012), rfinkle2 (01-12-2012), rghispanic88 (01-11-2012), Teethkikr (01-12-2012), uncorked11 (01-11-2012)
 Old 01-11-2012, 01:11 PM   #2
charlesfist's Avatar
Posts: 281   (View Stats)
charlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the worldcharlesfist is the leader of the world
Nice curves and numbers you got there man.
What did u change between the two runs?
Also, would you happen to have a log of that run
charlesfist is offline   Reply With Quote
The Following User Says Thank You to charlesfist For This Useful Post:
atvfreek (01-11-2012)
 Old 01-11-2012, 01:15 PM   #3
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
very nice, no meth nor e85 right?
2010 Black Mica
rghispanic88 is offline   Reply With Quote
The Following User Says Thank You to rghispanic88 For This Useful Post:
 Old 01-11-2012, 01:19 PM   #4
ms3bamf's Avatar
Posts: 745   (View Stats)
ms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the worldms3bamf is the leader of the world
Look how smooth that turbo spools up!
2011 Ford Mustang GT Premium - 6spd manual, brembos, 3.73, Roush Axle Back, JLT Oil Seperator, Air Raid intake
Previous - 2011 Mazdaspeed3 - Corned out FREEKTUNE
ms3bamf is offline   Reply With Quote
The Following User Says Thank You to ms3bamf For This Useful Post:
 Old 01-11-2012, 01:20 PM   #5
atvfreek's Avatar
That run with the lower numbers was a tune I was running a couple weeks ago that ran awesome, so between the 2 maps I added roughly 2 degrees of timing.
I feel like the dyno is missing some top end power though. My log on the dyno has wgdc maxed and only 16psi, where on the street my wgdc maxes at about 90% and holds 17+psi.
datalog 75 is on the dyno, and 77 is shortly after I left
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 01-11-2012, 01:22 PM   #6
atvfreek's Avatar
Nope, no e-85 near me, and my next mod will be meth, so I am going to rent some dyno time to tune for that.
Thanks Scott! Once you get those internals in, we can get your car up there in power.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 01-11-2012, 01:25 PM   #7
ms3bamf's Avatar
That's exactly what mine did on the dyno. The wgdc maxes out 100% from 5300 or so on up ad boost drops to 15 psi. Max MAF flow was a good 20g/s lower. Must be hard to get optimal flow on these cars on the dyno
 Old 01-11-2012, 01:25 PM   #8
BigJimMs3's Avatar
Posts: 4,859   (View Stats)
BigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the worldBigJimMs3 is the leader of the world
Groans: 76
Groaned at 22 Times in 20 Posts
You sexy fuck
atvfreek likes this.
2006 Mazdaspeed 6
BNR S4 and supporting mods
2007 Mazdaspeed 3
Bolt on's and tune
2015 Taurus S.H.O
Intake/Tune
2016 Ford Explorer Sport
Stock
BigJimMs3 is offline   Reply With Quote
The Following User Says Thank You to BigJimMs3 For This Useful Post:
 Old 01-11-2012, 02:59 PM   #9
chintastic's Avatar
Posts: 299   (View Stats)
chintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the world
nice numbers ! I hope to get close to the results with similar mods besides the TMIC
2013 CWP Mazdaspeed 3 : COBB TIH, COBB Intake, COBB AP, GFB BPV, SURE Shortcut, counterweight, and shifter bushings, Rally Armour mud flaps,
chintastic is offline   Reply With Quote
The Following User Says Thank You to chintastic For This Useful Post:
 Old 01-12-2012, 07:39 AM   #10
atvfreek's Avatar
The intercooler may hold you back slightly, but from what i've seen so far is that the gen2's do very well with the stock intercooler. @2011speed has stock intercooler and down pipe and he's still putting down great #'s.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
2011speed (01-12-2012), rfinkle2 (01-12-2012)
 Old 01-12-2012, 10:44 AM   #11
Ya, your generating slightly more boost and flowing about 10g's more for the street log.
How much of that difference would you attribute to the ~20 degree boost air temperature difference between the two (cooler street log)
Cooler air -> easier to make boost.
 Old 01-12-2012, 10:53 AM   #12
atvfreek's Avatar
Some of it is cooler air, but I think some of it has to to with the load on the dyno as opposed to the street. I have been running the same boost curve since the summer time and on the hottest days it would hardly ever hit 100% wgdc.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
charlesfist (01-12-2012)
 Old 02-19-2012, 08:01 AM   #13
atvfreek's Avatar
Updated OP with dynofile rather than shitty phone pic.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
charlesfist (02-19-2012)
Page generated in 0.32550 seconds with 25 queries
