> 2010 MS3 - Dyno Sheets/Discussions
Like Tree3Likes
  • 1 Post By Ray Danger 2020
  • 1 Post By Etipp98
 Old 10-27-2014, 07:48 PM   #1
Ray Danger 2020's Avatar
Posts: 768   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
Default New Big-Ass Turbo On Stock Fuel
Well guys, here's the results from last Thursday's (the 23rd) remote dyno tuning experience. I recently got a new big-ass turbo kit and I figured, it should definately be tuned on a dyno, if for no other reason than for consistency. All my mods are below, but the most recent additions to the car are the FJ Performance tubular manifold with vband ewg, vband screamer dump, vband down pipe, FMIC piping run under the motor, custom oil lines, Tial 44mm ewg, and the centerpiece, the Borg Warner S360 with .70 A/R single scroll hotside (normally comse twinscroll).
I decided to go with Powered By Purple Drank, one, because they're excellent tuners with a great reputation, and two, Ryan @2.0t03speed has the exact same kit and nearly all the same mods on his car (only exception being he has a meth kit and upgraded clutch I believe).
I can't even begin to describe this thing. I'm overall, simply blown away by how this turbo performs. I am currently on stock block and stock fueling, so I figured I MIGHT get 350whp on 93 and MAYBE 400 with an e85 blend (most people were telling me I'd be lucky to see 380 with e85). After only 2 revisions from the base map and being very conservative, my car put down 340whp/321wtq as a baseline pull on only 18psi, so natually i got very excited. We made several revisions on the 93 octane map and made 374whp/357wtq, but I was getting some KR so we had to dial it back a little and ended at 365whp/356wtq on my 93 octane map.
Then we moved on to my e85 blend map (3gal to a tank). He made up a base map from my 93 octane map with pretty much just the scalars adjusted for the additional fuel and the car put down 389whp/377wtq. After only 2 or 3 revisions, and running out of injector headroom, we settled at 421whp/392wtq.
I have to say I am absolutely ecstatic about the entire experience. Ryan is an absolute pleasure to work with and all the guys down at FJ Performance are a seriously awesome crew. I highly recommend doing business with either party involved. I'm not sure what his name is on here so if someone would like to tag him for me, that would be great. Also: I have no idea why some of those pictures are sideways.. lol
2.0t03speed likes this.
Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11
Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS
Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS)
K04 POWER FIGURES
277HP/325TQ SixTuned On 93
314HP/356TQ Rfinkle2 Tuned With 33% Corn
S360 POWER FIGURES
365HP/356TQ Purple Drank Tuned ON 93
421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX
NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING
Ray Danger 2020 is offline   Reply With Quote
The Following 10 Users Say Thank You to Ray Danger 2020 For This Useful Post:
2.0t03speed (10-28-2014), BLKSTIG (10-28-2014), Captain KR (10-28-2014), Cheapspeed (10-28-2014), Code Monkey (10-28-2014), Etipp98 (10-27-2014), Lbspeed (11-06-2014), rfinkle2 (10-27-2014), sho (11-25-2014), stockms3 (10-27-2014)
 Old 10-27-2014, 08:15 PM   #2
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
That is a nice little turbo you got there .
Nice numbers! I'm also working with purpledrank just need to sort out some issues with the turbo/exhuast but Ryan is pretty awesome.
How much did that set up run you if you don't mind me asking? I'm currently breaking in my forged motor and I'm really considering going BT in a season or two.
The Following 2 Users Say Thank You to stockms3 For This Useful Post:
2.0t03speed (10-28-2014), Ray Danger 2020 (10-28-2014)
 Old 10-27-2014, 08:18 PM   #3
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
SILVER BULLET!!! Any plans for more fueling??
@2.0t03speed;
The Following 2 Users Say Thank You to Etipp98 For This Useful Post:
 Old 10-27-2014, 08:23 PM   #4
Retail on this setup (mani, turbo, ewg, dp, screamer, lines, fmic hoside) is $3,799 and can increase from there if you, say, want a bigger turbo, because a 700hp capable turbo isnt enough...lol. Honestly, this setup is fucking fantastic. Everything fit like a glove.
@Etipp98; I plan on building my engine in the spring with some aux fueling and shoot for somewhere between 550-600whp. I figure that would be plenty of fun and still leave me even more room if I somehow manage to get bored with that power level. Lol
K04 POWER FIGURES
S360 POWER FIGURES
The Following 4 Users Say Thank You to Ray Danger 2020 For This Useful Post:
2.0t03speed (10-28-2014), BLKSTIG (10-28-2014), Etipp98 (10-27-2014), stockms3 (10-27-2014)
 Old 10-28-2014, 10:44 AM   #5
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
Awesome review Ray thanks! Glad you are happy with the power =D
The Following User Says Thank You to 2.0t03speed For This Useful Post:
MS3 2010 stock, Cobb AP, stock fuel pump OK? MammaFreed3 2010 MS3 - ECU Computer Tuning 21 11-15-2011 02:31 PM
NEEDED - Stock CDFP & Stock OEM In Tank Fuel Pump Haltech Mazdaspeed3/6 General Discussion 4 10-02-2011 04:24 PM
Page generated in 0.27500 seconds with 24 queries
