> 2010 MS3 - Dyno Sheets/Discussions
 Old 06-24-2016, 03:44 PM   #1
2010REDMS3's Avatar
Posts: 46   (View Stats)
2010REDMS3 will become famous soon enough
Default Stock dp, stock cbe, pd tuned 304whp
been re working the tune with pd and pulled a whopping 304whp! mods in sig, no clue how i did it but im good with it!
2010 VCM Mazdaspeed3 w/Tech 304whp/354wtq - Autotech hpfp internals, Corksport stage 2 intake, HKS SSQV full recirc, CXR FMIC, CFM 9 peg RMM, Cobb V3 AP, LTR7IX-11 plugs, Purple Drank tune @21psi 93 octane
2010REDMS3 is offline   Reply With Quote
 Old 06-24-2016, 04:16 PM   #2
Why did you lower the redline?
Cheapspeed (06-24-2016)
 Old 06-24-2016, 04:58 PM   #3
2010REDMS3's Avatar
I just didn't go to red line on the pulls
 Old 06-24-2016, 07:16 PM   #4
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Why not?
Most K04's drop off towards redline. I was confused by your graph initially because I thought it was odd that your HP stayed steady by the end of the log, k04's drop off towards redline.
 Old 06-24-2016, 07:46 PM   #5
2010REDMS3's Avatar
Idk just didn't go to red line lol I figured roughly 6k would be good enough to collect data off of
 Old 06-24-2016, 09:52 PM   #6
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
Damn son; I thought 300hp took a a downpipe at least, and usually also e85 or meth.
 Old 06-25-2016, 09:27 AM   #7
2010REDMS3's Avatar
Right?!! I think there may have been an error with Vdyno or something lol this just doesn't seem feasible to me lol
 Old 06-25-2016, 05:46 AM   #8
MRR
MRR's Avatar
Posts: 95   (View Stats)
MRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to behold
With a better turbo and a DP it should take you close to 400 hp
MRR is offline   Reply With Quote
The Following User Says Thank You to MRR For This Useful Post:
2010REDMS3 (06-25-2016)
 Old 06-25-2016, 05:49 AM   #9
Mmahan3510's Avatar
Posts: 93   (View Stats)
Mmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of light
Groaned at 19 Times in 6 Posts
those are some pretty sweet numbers, im not making but a couple more hp and tq with full bolt ons and e85!
2012 Mica Black Speed3, 3" CS intake/TIP, CS MZR bypass valve, CS hpfp internals, CS 3 port EBCS full interupt, NGK 1 step colder plugs, Ebay catless DP, 2nd cat delete, resonator delete, Custom Magnaflow axle back, CS OCC, EGR delete, throttle body coolant bypass, CS 70 duro RMM, firehawk indy 500 225/40/18, DM SSP, rear adj control arms, 3.5" shift extender, MofiyStreet 450oz ball shift knob, Purple Drank Tuned 93 map/Purple Drank Tuned E30 map, 295/337 dyno jet heatsoaked at 150 BAT, 314/362 vdyno at 100 BAT
Mmahan3510 is offline   Reply With Quote
 Old 06-25-2016, 09:39 AM   #10
2010REDMS3's Avatar
we had an oddly cold day here in FL last week when I did the pulls, my BAT's were mid 70's which helped out ALOT. lol
 Old 06-25-2016, 06:11 AM   #11
DC2
DC2's Avatar
Posts: 26   (View Stats)
DC2 is a jewel in the roughDC2 is a jewel in the roughDC2 is a jewel in the roughDC2 is a jewel in the rough
Thats just great !
2007 Mazda 3 MPS
Cobb accesport v3 Freektuned
Corksport SRI - TIP - HPFP internals - Racepipe
FMIC
Downpipe
Shortshifter
H&R -4cm springs
DC2 is offline   Reply With Quote
 Old 06-25-2016, 06:39 AM   #12
texasboy21's Avatar
Posts: 559   (View Stats)
texasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the world
VD dyno, take the numbers with a grain of salt.
2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks
2003 A4 1.8TQ
APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars.
texasboy21 is offline   Reply With Quote
The Following 8 Users Say Thank You to texasboy21 For This Useful Post:
2010REDMS3 (06-25-2016), Boost_creep (06-26-2016), Gerbilo (06-30-2016), KiwiFlavor (06-30-2016), MD1032 (06-30-2016), memin (07-01-2016), shaneski (06-27-2016), Vansquish (06-30-2016)
 Old 06-25-2016, 10:44 AM   #13
Groans: 126
Even so, CF is 1.01 and smoothing 3, so it should be fairly well in line with most of the figures we see, shouldn't it? I haven't used VDyno too much yet, so please enlighten me if there's something I'm overlooking.
 Old 06-25-2016, 07:26 PM   #14
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Slightly down hill would be my guess.
The Following 2 Users Say Thank You to blackms3_71 For This Useful Post:
 Old 06-29-2016, 01:07 PM   #15
2010REDMS3's Avatar
No, just the straightest flattest road I could find lol, there could've been an error in the datalog or the program I honestly think im between 275-285whp
 Old 06-30-2016, 02:59 AM   #16
shaneski's Avatar
Posts: 505   (View Stats)
Sometimes what looks to be a dead flat road can be anything but. There's a google height data page you can click on any road at different intervals and see if it is decline or incline. I used it on a few roads i thought was flat and ended up with it having a steady incline of 6ft over 500 meters
The Following User Says Thank You to shaneski For This Useful Post:
2010REDMS3 (06-30-2016)
 Old 06-30-2016, 03:31 AM   #17
MRR
MRR's Avatar
It looks like the best way to get a more accurate log is to take a log on both direction (forward and return) and average the result.
 Old 06-30-2016, 05:50 AM   #18
Police - Grammarhead
Vansquish's Avatar
Post the datalog for that pull.
 Old 06-30-2016, 12:22 PM   #19
2010REDMS3's Avatar
i think its these ones, ive been emailing datalogs back and forth with my tuner and I haven't been labeling them so these might be them but they might not be lol
 Old 06-30-2016, 07:13 AM   #20
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Meh, it is what it is. Vdyno is never going to be 100% accurate but it's good enough to see coarse differences between maps, for example, the shit OTS maps versus the real deal custom tune. At the end of the day an optimized tune with x level of hardware is always going to generate somewhere in the realm of a certain level of power. When you roll race, usually that's when the hardware differences show up. For example even a catless DP car, otherwise identical hardware, tuned at the same power level, would eek out a win a roll race because the turbo spools slightly faster.
@2010REDMS3; did you set all of the throttle position cells in the csv file to 75 before importing into vdyno? It looks like there's interference from throttle fluctuations in your vdyno, caused by the load system pulling throttle position during turbo spool-up.
2007 Mazdaspeed3 GT
 Old 06-30-2016, 11:48 AM   #21
2010REDMS3's Avatar
I sure didn't I'll try doing that then run it through Vdyno again
 Old 06-30-2016, 02:37 PM   #22
Vansquish's Avatar
Sorry, bud. I don't believe your numbers at all. I plugged your logs into VDyno with the same weight, correction factor, tire size, gearing, and car, and the results were completely different.
 Old 06-30-2016, 02:38 PM   #23
2010REDMS3's Avatar
Lol looks like something went wrong on my end then eh lol those numbers look low as fuck too lol
 Old 07-01-2016, 03:14 AM   #24
shaneski's Avatar
Not low at all considering your engine is no longer new and stock exhaust etc is probably around 210-215whp with OEM tune
Vansquish (07-01-2016)
 Old 06-30-2016, 03:00 PM   #25
Vansquish's Avatar
If you really did just input the data directly into Vdyno, then the only thing I can think of is that your version of VDyno (1.3.1) and mine (1.2.7) are different. I can't seem to download the newer version (the website appears to be down), so I'm not sure how to test that theory.
 Old 06-30-2016, 08:45 PM   #26
Gerbilo's Avatar
Posts: 612   (View Stats)
Gerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the worldGerbilo is the leader of the world
Tested it for ya on 1.3.1, same story.
2010 CBM Mazdaspeed3
Freektune 93
CorkSport SRI, TIP & Race Pipe
CP-E Stage 2 RMM & TMIC
Cobb Accessport V3
Autotech HPFP Internals
Pilot Super Sport 235/40/18 - Stock Pu
Pilot Alpin PA3 215/50/17 - Sport Edition CE
2016.5 MGM Mazda CX-5 Touring
Gerbilo is offline   Reply With Quote
 Old 07-01-2016, 11:56 AM   #27
texasboy21's Avatar
Time to edit the sig.
2003 A4 1.8TQ
The Following 2 Users Say Thank You to texasboy21 For This Useful Post:
broda (07-01-2016), Vansquish (07-01-2016)
weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? labikesrcool MazdaSpeed 3/6 - Wheels & Tires 21 11-30-2015 03:32 PM
stock genpu vs tuned 04 Mach 1 ArcticSpeed3 Street Racing Stories ( Bench Racing ) 5 08-27-2011 10:12 PM
Page generated in 0.44327 seconds with 33 queries
