![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
(Thread Starter) | Neutral : +9 score Balance Shaft Delete Kit-https://www.gp-werks.com/products/GP...elete-Kit.html Baffle Kit-https://www.gp-werks.com/products/Du...peed-3%29.html Tool List 3/8 Drive Socket Wrench with short and long extensions 8mm socket 10mm socket 12mm socket 14mm socket 17mm socket short 8mm wrench Flashlight Funnel Oil Collection Pan Supplies List 3 12mm head bolts (thread and pitch unknown, I used a factory bolt and matched it at the store) Blue Loctite Red Loctite Grey or Black Gasket Maker Shop Towels for Oil Rubbing Alcohol to assist in cleaning gasket surfaces 7 quarts of oil (6.8) New Oil Filter New Drain plug sealing washer BSD Kit Baffle Kit 1. Open hood and remove bolt (8mm) holding dipstick in place under intake manifold. 2. Jack up car and remove belly pan. 3. Remove oil drain plug (17mm) 4. Remove Oil Filter with man strength...no tools needed 5. Remove 13 bolts (10mm) from oil pan. 11 are short, 2 are LONG. 6. Remove 4 bolts (14mm) that are parallel to ground that connect oil pan to transmission case. 7. Remove 4 bolts (8mm) that are parallel to ground that hold pan to timing cover. 8. Use small pry bar and pry oil pan off via a pry area that is located right next to oil filter location. Work pan free. ***NOTE*** There is a lip in the oil pan where it sits in the timing cover, so drop the side by the transmission first. Dipstick will slide out. 9. Remove 2 bolts (8mm) that secure the oil feed tube, ie the black plastic thing you will find, then set aside oil feed tube assembly in a clean area. 10. Remove 4 OBVIOUS bolts (14mm) that secure the balance shaft assembly. Oil will come out, so be prepared. Also, on the last bolt you will need to support the balance shaft with your hands or a jack, it weighs close to 18lbs...again, man strength folks. When last bolt is removed it will fall down and slide right out. 11. Install Balance shaft delete kit. Put the plug with o-ring in first, then put the plate over it, loosely install the large metric allen head, and then install the small metric allen head. Tighten the large allen head and then snug up the small allen head. DO NOT use man strength on the small allen head. Refer to pictures for exact location. Use a little red loctite. 12. Reinstall oil feed tube. 13. Clean block mounting surface and oil pan mounting surface of all gasket material as best as you can. 14. Remove stock oil baffle from oil pan via 4 bolts (12mm) 15. Install new baffle. New baffle has 6 bolt holes. Go to hardware store and get 2 more bolts the same length. I used blue loctite on these bolts. Make sure to do this on a soft surface and not concrete so you do not crack the cast metal oil pan. 16. With a clean mounting surface on the oil pan, put a bead of grey or black gasketmaker on oil pan mounting surface. (available at autoparts store, walmart, etc) Smooth bead with finger. Use sparingly. 17. Assuring the block sealing surface is clean, install oil pan. This will be tricky due to you having to first angle the pan in for the lip to clean the timing cover. Once you get the lip on, you will have to get the oil feed tube in the cutout area of the baffle. I used a flashlight and my spare hand to assist the feedtube into the baffle cut out. Once past, it seats easily. Make sure your dipstick is seated. It seats with orings that are attached to it. 18. Install a couple 10mm bolts on opposing ends. Snug them to hold the pan in place, but DO NOT tighten them. 19. Loosely install all bolts. Tighten the 13 10mm bolts in the pattern provided in the picture herin. 20. Install and tighten the 4 14mm bolts 21. Install and tighten the 4 8mm bolts (no man strength necessary on these) 22. Install oil drain plug and new oil filter. 23. Remove jack/ramps so the car is sitting level again. Reinstall 8mm bolt for dipstick. 24. Pour around 3 quarts of oil into block. Check for leaks. If no leaks, pour 2 more quarts in. 25. Start car and let it idle for around 20 seconds, then shut it down. 26. Pour in about 1.8 quarts more for a total of 6.8 quarts, and start car again. Check for leaks. 27. Prepare a plan on how you can entice your wife, friends and family to ever ride in your car again due to the massive vibrations that are now transmitted to the interior. The JBR triple pack to the 2nd power is what I call the new vibrations. 28. Drive car. Shit in your pants as your engine is now louder than fuck. Tell your loved ones sorry, but you can not simply uninstall this mod. Learn to live with the new vibrations and new found roar. Then learn to love it. 29. Drive through Walmart parking lot at 3k rpms and watch children run from your demonic sounding engine. 30. Kick the shit out of some Hondas. 31. WIN!!!
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN Last edited by mrmonk7663; 06-03-2013 at 11:56 PM. Reason: Links, Pics |
| The Following 86 Users Say Thank You to mrmonk7663 For This Useful Post: | 3mazdaspeed (01-07-2012), 3starmagnum (06-08-2012), ABolewski (12-10-2012), ABQ Speed6 (11-25-2012), Alexander (03-09-2013), alien_sporez (12-31-2011), AllLostThings (06-09-2013), allo80 (04-12-2013), Andjo (10-07-2012), Arnie1229 (01-12-2015), aromig (03-08-2014), ASHMS3 (01-03-2012), bayarea_pat (01-03-2012), bertrand_CX_7 (12-31-2011), BeyonceSpeed3 (04-15-2013), Block8head (01-03-2012), bmfms3 (08-26-2012), bspau45 (01-22-2012), ChimmyChong (02-11-2012), Code Monkey (12-25-2012), CrawlingMS3 (09-01-2014), crazyp (12-30-2011), Dahouse702 (12-30-2011), darchjohn (08-22-2012), DarkPasseng3r (12-31-2011), dereeek (01-11-2012), derek13p (02-09-2014), Donut (03-31-2014), Downmented (01-04-2012), DuoofDeath1 (01-06-2013), Easter Bunny (01-03-2012), Elusivellama (01-16-2012), Etipp98 (12-31-2011), fooqr (01-04-2012), FSRRM (07-07-2017), galens47 (03-12-2013), Guyverspeed3 (09-27-2013), helmetface (03-31-2012), iverson (02-14-2014), jambisgone696 (02-09-2014), josurr (01-07-2012), jracer (12-31-2011), kairojya (02-27-2012), keridil (09-13-2012), kevinblack (01-19-2014), Kfunk (07-27-2012), kylec_2003 (07-03-2012), LatinKraze (01-02-2014), littleloogy (05-21-2013), m249saw (03-18-2012), manu (11-11-2016), MATT DAMOND (01-18-2012), Miltron (01-30-2013), MS3CB (08-27-2013), ms3j (02-14-2012), MS6FL (01-16-2012), mterry660 (06-09-2014), MZR165 (12-31-2011), Nataphen (02-21-2012), neotide87 (08-23-2013), NinjaT1985 (01-11-2012), outshined (03-14-2012), Phoenix Speed3 (02-05-2012), rfinkle2 (01-05-2012), rghispanic88 (01-03-2012), rigor (04-15-2013), ruthless013 (03-21-2012), ScottyP (03-17-2012), Sid3wayS (01-03-2012), silvapain (03-14-2012), SKiZ0TT (03-04-2012), SLOWHATCH (12-31-2011), spdtrux (02-27-2014), Standsideways (03-18-2012), TexasSpeed3 (01-16-2012), Toymachinespeed (12-31-2011), turbo test (01-06-2012), Uberfly (01-17-2012), Vinnie (02-06-2012), WAHBAM (06-09-2012), wankular (01-04-2012), WetzMS3 (03-17-2014), wolly6973 (01-11-2012), xb2ms3 (01-03-2012), xxdjfate76xx (01-13-2012), YZF-R6 (12-30-2011) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
| Not Ranked : 0 score Informative and entertaining, i like it. Oh and nice touch with the FYHN in that pic
__________________ 2010 MS3 Liquid Silver: TRZ Poly RMM, Cobb AP, PERM (Load-Based FTW), CP-E HPFP, SURE Aeros, HTP TIP, Corksport TMIC, SURE Boost Tubes, Magnaflow CBE, Corksport T/P, JBR LE Shift Knob & Weight, Redline MTL, Swift Spec-R, TSW Nurburgring 18x8.5, Nitto NT555 235/40/18. If You Don't Like The Pu, Don't Play In The Pu. |
| The Following 4 Users Say Thank You to YZF-R6 For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score LOL, I was wondering if anyone would catch the FYHN. Glad you liked it, and hopefully it can help some of yall out.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() Join Date: Oct 2011 Location: Oracle, Az
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score SWEET!!!!!
__________________ 67 yrs young..2012 MS3 with Tech, Cobb AP, JBR 88 dogbone, JBR Rear Swaybar,Autotech Internals..JBR 88TMM & 80PMM, HTP 3" tip with a custom fab MAF housing, UR FMIC, TWM short shifter assembly, Sure SSP and Weight, UR CBE, UR metal catted DP, UR res. TP, Synapse DV, Grimmspeed EBC, Bosh 3 bar map sensor, Denso ITV22's, FoMoCo Trans Fluid, Corksport aluminum skid plate, Sonic ST8's 18X8.5X40 running PSS 245/40's, Nitrogen filled tires, GoPro Hero, Hero-2 (For those moments, adds 20+driverhp) TUNED BY: mrmonk7663 _______________________________ Team LBN BEERS--FYCN TEAM MUMFORD---FYCN |
| The Following User Says Thank You to shifter48 For This Useful Post: | mrmonk7663 (12-30-2011) |
![]() Join Date: Oct 2009
Rep Power: 269 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 173
Groaned at 22 Times in 8 Posts
| Not Ranked : 0 score sorry for the noobs but what are thos upgrade good for??
__________________ Dr_banano Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front ptp studs/seals pending mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car |
| The Following User Says Thank You to dr_banano For This Useful Post: | wolly6973 (01-11-2012) |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score Good write up!
__________________ [01:31 PM] SoAgg159: my dick is called "quarter mile" it's about 1/4" long and i can give about 14secs of pleasure [07:06 PM] DarkHeartMS6: yeah. I actually hope i catch my wife with another dude. gives me an excuse to open the emergency door and bail. LOL [09:13 PM] Pu Manchu: i like to take my gf through the drive thru so i can prove that i can pleasure a woman |
| The Following User Says Thank You to forcedinduktion For This Useful Post: | mrmonk7663 (12-31-2011) |
(Thread Starter) | Neutral : +1 score There is a 17lb contraption called the Balance Shaft Assembly that rides on your crank. It is operated by a gear that sits on your crank. The purpose is to remove vibrations that the motor puts out normally, basically so your car sounds and feels "classy" on the inside. Removing it frees up oil capacity within the oil pan, which helps the oiling problems for cylinder number 3 that these cars experience. It also takes a couple pounds of rotating mass from your crank, and removes static mass from the front of your vehicle. The baffle keeps oil from sloshing too much above the oil feed tube area. This mod is not for everyone, it is not without added vibrations and noise.
![]() Join Date: Nov 2010
Rep Power: 394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,114
| Not Ranked : 0 score Every one should give OP a like because if other users was doing their write up, this Forum will be an wonderfull e-library. thumbs up for the documentation OP
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. Last edited by bertrand_CX_7; 12-31-2011 at 02:32 PM. |
| The Following 2 Users Say Thank You to bertrand_CX_7 For This Useful Post: | 3starmagnum (06-08-2012), mrmonk7663 (12-31-2011) |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
| Not Ranked : 0 score Thread full of win. Good job OP.
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
| The Following User Says Thank You to ASHMS3 For This Useful Post: | mrmonk7663 (01-03-2012) |
(Thread Starter) | Not Ranked : 0 score Thank you. After driving on this mod for almost a week I will say it is not feasible to have IF IF IF you have the JBR PMM. I had the triple pack and after the BSD the car was not fun to drive. The vibes were so bad that all you could think about was pushing various parts of the dash/rear view mirror/steering wheel/gauge cluster, etc to make it quiet...while driving. I talked to Jamie at JBR and he told me to keep the 88 duro rmm and 88 duro TMM and put my stock PMM in...I did this and the vibrations have gone down considerably, to a level that is more than acceptable. So my advice...either don't do this mod if you enjoy a nice quiet car....or do this mod if you can accept modest vibrations and keep the PMM...I advise no one in their right mind to do this with the upgraded PMM. My PMM is for sale now if anyone is not interested in doing the BSD but desires and upgraded mount
(Thread Starter) | Not Ranked : 0 score Update, just went on a drive with the stock PMM, and JBR 88 tranny mount and 88 rmm, and BSD. The car feels great. Sounds great, and is fun to drive again. If any of you go down the BSD path please take what i've found into consideration. I know vibes are subjective but I promise you all they were horrendous. On a side note I installed a 88 duro TMM on a nator car this weekend that already had the dogbone 88. AFter the install the owner commented that the vibes felt the same as before. He noticed no difference really idling and reving. Directly after this, we installed the 80 PMM. When he started the car again he immediately noted that there was a large difference in vibes. The point of the above is to simply illustrate that out of the 3 mounts, the PMM seems to absorb the largest amount of vibrations, and this is backed up by Jamie stating to me that lowering the durometer on the TMM or the RMM really wouldn't help my car for the BSD vibe issue, but that the PMM back to stock should help considerably, which it did. This about wraps up my BSD info. Any questions for those of you who are going to go down this road feel free to ask.
| The Following 5 Users Say Thank You to mrmonk7663 For This Useful Post: | ASHMS3 (01-04-2012), atvfreek (01-04-2012), m249saw (03-18-2012), Pseud0logik (03-17-2012), rigor (04-15-2013) |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 977 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score have you felt any power improvement? < I doubt it... You mentioned sound; I know on my spec-v I noticed the exhaust sounded more aggressive< you notice this?
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite |
| The Following User Says Thank You to specvspeedfreak For This Useful Post: | Yousuf (07-15-2013) |
(Thread Starter) | Not Ranked : 0 score With the JBR mount yes it sounded way more aggressive. Now that I am back on the stock mount it sounds slightly more aggressive, but not much. A lot of the percieved sound from the engine and exhaust was due to resonant frequencies I believe. Power wise, can't really feel much, but knowing I removed 17lbs, a couple of which are rotating mass, and the increased oil capacity and increased oil to cylinder number 3 make this a worthwhile mod in my book. With the stock PMM I can not see any negative to this mod. You could put all stock mounts back in, trade the car in, and no one would ever know the balance shaft was gone.
![]() Join Date: Jul 2008 Location: Brockton,Mass
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,661
Groans: 206
| Not Ranked : 0 score GJ brotha...
__________________ [SIGPIC][/SIGPIC] O4 350z "Money pit" 06 MS6 "Gone" BOSTON STRONG |
| The Following User Says Thank You to Block8head For This Useful Post: | mrmonk7663 (01-03-2012) |
![]() Join Date: Apr 2010 Location: Miami FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,836
Groans: 263
| Not Ranked : 0 score Never knew about this mod, but its good to know. Good job
__________________ 2010 Black Mica 2004 EVO 8 Green Monster The "7up" |
| The Following User Says Thank You to rghispanic88 For This Useful Post: | mrmonk7663 (01-03-2012) |
![]() Join Date: May 2011 Location: Palisades Park, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 687
| Not Ranked : 0 score thanks been hoping someone would do this write up
__________________ 2011 Black Mica MS3 NJSPEED3 Ported IM + other shit NJ NATOR NY 316.52 hp / 352.12 tq 93 oct K04@ Nator DC Dyno Day 11.10.12 |
| The Following User Says Thank You to xb2ms3 For This Useful Post: | mrmonk7663 (01-04-2012) |
![]() Join Date: Feb 2011 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 189
| Not Ranked : 0 score Thanks man was looking for info on this mod -Jake
__________________ New: 2012 Mazda MX5 Miata True Red |
| Not Ranked : 0 score OP.. can you give us your view, know you're modded pertty well, after having all 3 motor mounts and driving with them and now going to stock PMM, how is the torque steer, wheel hop, head shake now that you've changed???? For everyone reading this I was the one that we installed the 88TMM and 80PMM...I am going to track this car later once I get it the way I want...but till then it's going to be a DD.. the PMM is an ezy change..also plan on a trip to Potland, Or. in may....mrmonk7663 your imput is well recieved. Gregg
(Thread Starter) | Not Ranked : 0 score With all 3 mounts in place headshake and torque steer were very limited. Rapid part throttle acceleration from a slow roll would yield torque steer some, but it was controllable. The addition of the tranny mount to complement the other JBR mounts was the part that really transformed torque steer. Wheel hop has not been an issue. Going back to the PMM and accelerating rapidly has yielded a small amount of torque steer, but really no more than I felt before. Again, the transmission mount in my opinion is what reigned in the torque steer on this car for me. To sum it up. RMM-helped launching, engine slapping, wheel hop, stiffen things up PMM-helped stiffen everything up by a large amount, transferring more power to ground instaed of wasting energy abosorbed by mount TMM-helped control/eliminate torquesteer, stiffen things up BSD Potential Upgraded RMM (your choice of duro), stock TMM, stock PMM=Good to go with BSD Upgraded RMM (your choice of duro), Upgraded TMM, stock PMM=Good to go with BSD Upgraded RMM (your choice of duro), Upgraded TMM, Upgraded PMM=FAIL with BSD
| The Following 10 Users Say Thank You to mrmonk7663 For This Useful Post: | atvfreek (01-04-2012), Brennan (04-29-2012), JDR767 (03-15-2012), kylec_2003 (07-03-2012), mazdaspeeding (01-11-2012), mterry660 (06-09-2014), rghispanic88 (01-05-2012), shifter48 (01-04-2012), wankular (01-04-2012), wolly6973 (01-11-2012) |
![]() Join Date: May 2011 Location: Orlando, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,305
Groans: 386
| Not Ranked : 0 score Good write up and interesting.
__________________ BNR3-FREEK-PU-398HP I lost track of the mods in my car. |
| The Following User Says Thank You to dereeek For This Useful Post: | mrmonk7663 (01-04-2012) |
![]() Join Date: Jun 2010 Location: Mirabel, Quebec
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 605
| Not Ranked : 0 score Good write up and interesting, but I see a lot of work for 18lbs. But the oil pan Baffle kit is a must for Lapping or Auto-X.
__________________ Sold 2010 Speed3 Black Mica tech pack, JBR RMM 80 duro, Cobb SRI, stupid horn fixed with low tone add on. New 2012 Mazda2 GS Aluminum Metallic Mica, Corksport rear torsion bar, Corksport H11 Led fog bulbs, Piaa H4 x-treme white bulbs, AWR rmm 70duro....more to come Wife's car 2011 Mazda2 True Red GS (Touring in the US), wifes car, no mods so far but she want a Corksport CBE, Corksport SRI and a drop in the futur. <----- ![]() [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to Scoobs For This Useful Post: | mrmonk7663 (01-05-2012) |
(Thread Starter) | Not Ranked : 0 score Really, its only a 3 hour job, and that is going slow and doing it on ramps. The 18lbs is only one benefit. The largest benefit is the increased oil capacity and increased oil flow to cylinder number 3.
![]() Join Date: Mar 2011
| Not Ranked : 0 score may have to do this mod at some point sounds interesting. is it a common problem with a cyl 3 in these motors all i heard was it won best motor for a few years i know the trannies fuck up in 2nd and 3rd but i havent heard anything bad about the motors. |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score There have been various reports that the balance shaft caused cylinder number 3 to recieve less oiling than the other cylinders on multiple platforms that share the 2.3 motor, not just our turbo motor. It might not be a huge problem, but it is a documented problem I have seen nevertheless.
![]() | | #25 | ![]() |
| Not Ranked : 0 score I'll do the shaft if I do the Baffle, while being there. I'll look into it, but it will be in 2013-14. But I saved up in my favorite this Thread, I save all the good stuff in my How to MS3 folder.
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score To do the baffle that I used, it is required to remove the balance shaft.
| The Following User Says Thank You to mrmonk7663 For This Useful Post: | wolly6973 (01-11-2012) |
![]() | | #27 | ![]() |
![]() Join Date: May 2009 Location: Scottsdale, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,450
| Not Ranked : 0 score So the vibes with the BSD are constant, unlike motor mount vibes which fluctuate depending on RPMs?
__________________ 2009 MS3 sport MGM |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score Honestly, since removing the JBR PMM and putting the stocker back in, leaving the JBR dogbone and JBR 88 duro tranny mount on the car, I can not feel the vibes...vibes are LESS with these 2 mounts and BSD than they were with no bsd and all 3 mounts.
![]() | | #29 | ![]() |
![]() Join Date: May 2011 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
Groaned at 340 Times in 107 Posts
| Not Ranked : 0 score Not very concise, but there is no such thing. When speaking of a rotating mass, it is true that as the diameter increases, so does its inertia and momentum. A 17 pound rod has very low inertia compared to a 17 pound disk. Reason that flywheels are very large, and can have very high inertia and momentum. The idea that removing the BS would increase rev response seems, to me, to be more hope than science. I've never heard anyone say, after BSD that the car revs faster or feels faster. btw... are you removing the whole housing, or just the shaft? I can't beleive that this wthing is 17lb--> Major balance shaft probs Any indication that bsd can be damaging to your engine? LOng term? Good thread. . Last edited by crtguns; 01-06-2012 at 10:09 PM. |
| The Following User Says Thank You to crtguns For This Useful Post: | mrmonk7663 (01-07-2012) |
| The Following User Says NO Thank You to crtguns For This Un-useful Post: | Easter Bunny (01-13-2012) |
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score As you can see in my photos, one picture shows the complete assembly, the next picture it is gone. You remove the entire thing. Only thing that is left is a gear on the crank. Trust me, it weighs almost 18lbs, no exaggeration. The balance shaft was designed for the masses to allow comfort in engines that naturally have harmonics which translate to buzzing, rattling, and high frequency noises. There have been numerous folks on this platform and many other platforms that remove these with no issues short or long term. This is popular with the Ford Ranger crowd that uses the 2.3 duratech motor. Scion owners do it, engine builders, etc etc.
| The Following User Says Thank You to mrmonk7663 For This Useful Post: | crtguns (01-07-2012) |
![]() | | #31 | ![]() |
![]() ![]() Join Date: May 2011 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 336
Groaned at 33 Times in 10 Posts
| Not Ranked : 0 score The same website actually has a BSD with baffle kit as a set that saves a little money... For $90 shipped, saves 18lbs of weight and costs a lot less that a ricey carbon hood... Good write up OP and thanks, this will prolly be next for me
__________________ 2012 Toyota Tacoma Last edited by NinjaT1985; 01-11-2012 at 07:56 AM. |
| The Following User Says Thank You to NinjaT1985 For This Useful Post: | mrmonk7663 (01-11-2012) |
![]() | | #32 | ![]() |
![]() Join Date: Mar 2010 Location: Lewistown, PA (State College)
Rep Power: 1938 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,144
| Not Ranked : 0 score Once this is out it can't be re-installed right?
__________________ 2010 MS3 - Sold 2015 CX-5 GT AWD - Current ![]() |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score Some say yes, some say no. Others say yes as long as you "time" it. Honestly, I see NO reason what so ever to ever put it back in. Car drives great. Just KEEP PMM and all will be fine.
| The Following User Says Thank You to mrmonk7663 For This Useful Post: | trf5000 (01-11-2012) |
![]() | | #34 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score Did you have the 70 or 80 duro pmm? Did you discuss trying the 70 duro with Jamie? |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score I had the 80. I had no problem paying for a custom duro mount but Jamie told me that even using a custom lower durometer bushing would offer no advantage, and that the stock pmm was the best idea.
| The Following User Says Thank You to mrmonk7663 For This Useful Post: | wolly6973 (01-12-2012) |
![]() | | #36 | ![]() |
| Banned ![]() Join Date: Aug 2011 Location: Springfield/Union NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,560
Groaned at 52 Times in 48 Posts
| Not Ranked : 0 score I was thinking about this on my next oil change, im running 88rmm and 70 TMM and PMM. But after reading your experience im not so sure. If someone with this setup does it please chime in. Oh and if anyone is interested SURE just released their BSD. And they do state that the engine revs easier and what not. |
![]() | | #37 | ![]() |
Groans: 386
| Not Ranked : 0 score You still need the baffle though. I wonder if that's what the "Oil Rig" will be... |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score Sure does not disclose any mount information when advertising for their BSD. On all stock mounts i'm sure you feel almost nothing. On TMM and RMM like I stated, all is well. PMM was horrible. Jamie told me out of all his mounts the PMM is the only one that would likely remedy the vibrations by removing it, and he was right. Car is great now.
| The Following User Says Thank You to mrmonk7663 For This Useful Post: | wolly6973 (01-13-2012) |
![]() | | #39 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
| Not Ranked : 0 score I had the BSD on my old 07 Mazda 3. Vibes increased by a bit, but was not very noticeable with all stock mounts. Engine may seem to rev more freely, but the power gains are all bullshit. The main reason I did it was to increase oil capacity and to head off potential problems with the oiling to a cylinder or two. I still have the old balance shaft somewhere around, that sucker is 15 - 17lbs, no joke. Also, I read up for over a week (a year ago) on the purpose of the balance shaft, and consequences of removing it. Short summary: the balance shaft's acronym is highly accurate. It's just some fucking bullshit part that is installed purely to make the car seem more premium at the cost of weight and potential oiling issues, a classic example of marketing/touchy-feely winning out over good engineering.
__________________ [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to Elusivellama For This Useful Post: | wolly6973 (01-17-2012) |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score Agreed...no noticeable performance gains, but the oil capacity is what makes this mod gold.
| The Following User Says Thank You to mrmonk7663 For This Useful Post: | wolly6973 (01-17-2012) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/balance-shaft-delete-baffle-kit-gen-2-a-100943/ | ||||
| Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 06-07-2014 06:56 PM | |
| Sure - Page 3 | This thread | Pingback | 07-28-2012 12:01 AM | |
| Cosworth balance shaft delete/F2 oil pan baffle installed | whoosh@Realtune | MazdaSpeed 3 - Engine, Transmission & Driveline | 41 | 02-21-2011 11:08 PM |
| Balance Shaft Delete and Oil Baffle Kit | 11cruzito11 | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 08-14-2009 11:15 AM |
| F2 Balance Shaft Delete Kit & Oil Sump Baffle Kit, UPDATE WITH PROMO CODE - Package deal through F2 | sbspeed | MazdaSpeed 6 - Engine, Transmission & Driveline | 6 | 07-09-2008 08:19 AM |
