![]() Join Date: Mar 2012 Location: Radcliff, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score Anyways! Wanted to add that you can put a Trailer Wiring harness on it to give full functionality of the LED Strips... Trainer Wiring Harness Without the harness, the LED Strips can be Wired to Either your Brake Lights OR blinkers but not both. With the Harness you have full functionality.. ie Brake and turn signal at the same time.. One will be bright, other Blinking, etc.. Just do yourself a Favor and DO NOT use the inline splice clips that come with the LED kit.. Had to go back and re-wire everything due to bad splices using the clips. Let me know if anyone wants a Video of the LED strips working. |
![]() Join Date: Aug 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,823
| Not Ranked : 0 score The fuck are you on about? Alright I see. Why don't you write up a how-to
__________________ |
| The Following User Says Thank You to Spec For This Useful Post: | Alexander (02-21-2013) |
(Thread Starter) | Not Ranked : 0 score Still searching for the old one before I do. Possible I read it somewhere else. I just wish I would have taken pictures of everything when I did my install.. Rear bumper Removal is a pain!! But will have to at least draw out a wiring diagram for everyone. |
![]() Join Date: Sep 2012 Location: Shit Louis MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 411
Groaned at 43 Times in 16 Posts
| Not Ranked : 0 score Just do a write up. Even if there is another one it could probably use updating. I've had these led lights sitting in my dorm room for months, its about time I get to putting them on and I want to do it right
__________________ 2011 Mazdaspeed 3 Cobb v3 AP | Autotech CDFP | JBR Sri | JBR Balance Shaft Delete | JBR Rear Sway Bar | JBR 88 duro RMM | M2 Testpipe | Corksport Tip | Corksport Short Shifter | Corksport SSP | Corksport Shifter Bushings | Cobb Counterweight | H&R Lowering Springs | Joseph Koni Shocks/Struts | SPC Rear Camber Arms |
![]() Join Date: Aug 2012 Location: Ft. Bragg
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 52
| Not Ranked : 0 score i just installed mine today. i want to go back later and wire them into the brake lights
__________________ 2012 Velocity Red Mazdaspeed 3 Cobb Accessport / Cobb FMIC / James Barone Racing Chrome Molly RMM / Corksport OCC / Corksport SRI+TIP / Corksport LED reflectors / ATP Turbo 3" DP / SSP EGR Delete / Autotech FP Intenals / ARK Catback Exhaust |
![]() Join Date: Dec 2011 Location: Boston, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
Groaned at 25 Times in 9 Posts
| Not Ranked : 0 score I submitted the product to CorkSport as the only readily available ones were from some shady e-bay seller and the price was much higher (like $90 shipped I want to say). They put together good instructions and I added a few things before they posted it to their website for download. I didn't use the splice clip either, in fact my trial led reflectors didn't even come with them. I went straight to the license plate light and haven't had any problems in over a year. I'm curious if the blinker one would be sync'd up or if the lights would be out of time.. that would drive me insane. I didn't want to bother with it. Smoked reflectors with a plastidip'd valence is the way to go!!
__________________ Garage: 2014 Evolution MR, 1983 Volvo 242 Turbo Past: 2010 Mazdaspeed3 Do not donate to this fucking shithole. lol |
![]() Join Date: Apr 2012 Location: Los Angeles
Rep Power: 426 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 956
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: | |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
| Not Ranked : 0 score The best way to connect is solder and heat shrink. Not everyone has solder and heat shrink so the splices come in to play. The set we sell is wired so you can use them as markers and brakelights or turn signals. The response time on LEDs is really good so I dont see any sync problems with the lights. Do you have one of our calendars? There is a code in there to save 50% off with the purchase of another part on any of the LED products we offer. If you dont have one of the calendars get one, there is a deal each month. -Derrick |
| The Following User Says Thank You to CorkSport For This Useful Post: | DownSideFX (03-06-2013) |
![]() Join Date: Dec 2011 Location: Warren, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 86
| Not Ranked : 0 score Good call on using the trailer harness! I actually have one of these Curt Custom Fit Vehicle Wiring for Mazda 3 2010 - C56011 that I'm going to use when I pull my ATV ( along with the hidden hitch of course). I'll just get another end and solder it onto the bumper lights and plug it into that. And I'll just unhook them when I'm pulling the trailer. Can't wait for the weather to get nice so I can really start working on my car again...
__________________ [ 2010 Black Mica Speed3 w/tech package ] go | COBB AccessPORT | Autotech HPFP Internals | TurboXS Catless Downpipe | TurboXS Race Pipe | Ultimate Racing Catback w/Magnaflow Resonator | Corksport Urethane Exhaust Hangers | JBR Boost Tubes | cp-e Nviscid Pipe | cp-e XcelNANO SRI | cp-e HeliHose | cp-e Stage 1 xFlex RMM | JBR SSB | RDS-05 Rear Sway Bar | Torque Solutions Delrin Shift Knob | Block8Head Dual Defrost Pod | Aeroforce Interceptor | Prosport Evo Boost Gauge show | BC Racing BR Coilovers w/Koyo | SPC Rear Camber Arms | Avid.1 AV-06 18x8 +42 225/40 | 2011+ Tech Headlights | Corksport Tow Plate | Morimoto 5000k bi-xenon / 3000k fogs | 3BSpec Switchbacks | Corksport LED Rear Bumper Lights | S204 STi Lip [SIGPIC][/SIGPIC] |
![]() Join Date: Sep 2011 Location: Santa Ana,CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 274
| Not Ranked : 0 score I've had these sitting in my room for like 8 months I really need to get these lights on
__________________ Performance CobbAPCobbSRI/TIPAutotechInternalsDensoITV22 PlugsForgeBPVJBRDog Bone MountSpeed DaddyCatless DownpipeGreddyOCC Appearance DDM5000k Headlights/3000k FogsCobbShift KnobCorksportLED Bumper LightsDepoLED Tails E85 |
| Not Ranked : 0 score |
I've attached a diagram showing what wire would do what coming off of that Curt adapter.
__________________ [ 2010 Black Mica Speed3 w/tech package ] go | COBB AccessPORT | Autotech HPFP Internals | TurboXS Catless Downpipe | TurboXS Race Pipe | Ultimate Racing Catback w/Magnaflow Resonator | Corksport Urethane Exhaust Hangers | JBR Boost Tubes | cp-e Nviscid Pipe | cp-e XcelNANO SRI | cp-e HeliHose | cp-e Stage 1 xFlex RMM | JBR SSB | RDS-05 Rear Sway Bar | Torque Solutions Delrin Shift Knob | Block8Head Dual Defrost Pod | Aeroforce Interceptor | Prosport Evo Boost Gauge show | BC Racing BR Coilovers w/Koyo | SPC Rear Camber Arms | Avid.1 AV-06 18x8 +42 225/40 | 2011+ Tech Headlights | Corksport Tow Plate | Morimoto 5000k bi-xenon / 3000k fogs | 3BSpec Switchbacks | Corksport LED Rear Bumper Lights | S204 STi Lip [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to ahfunaki For This Useful Post: | The Nut (03-06-2013) |
| Not Ranked : 0 score Thats how i have mine. So much win!
| The Following 2 Users Say Thank You to chrisattack18 For This Useful Post: | DownSideFX (03-09-2013), The Nut (06-04-2013) |
(Thread Starter) | Not Ranked : 0 score Ok! Someone asked for a video of the tail lights and here they are. Ignore the water mark, had to convert the videos from m4v to mp4... phew! Anyways! First video is to give you a idea how they look during the day (both videos recored around 6pm Eastern) The 2nd Video I backed into the garage a little to give you a better idea how they look in the dark. Somewhat low quality to keep the file sizes down. Note: As I was saying before in the thread I had to use a trailer harness, but those of you that have normal bulbs may not have to. The directions that come with the LED strips say EITHER brake or Turn signals if I remember correctly, but could be wrong. One last thing.. If you do install the kit, DO NOT use the dam wire splices!! they will cause you a massive headache trying to figure out why its not working... (Yes.. Been there, and spent another hour or so redoing it all the hard but correct way) btw, I did a combination with lights on and off. left, right, left w/ brake, right w/ brake, and hazards. These are Not smoked.
__________________ 2012 MS3 w/Tech SURE SRI | SURE TIP | SURE RMM | SURE VENTUS BPV | COBB AP | AUTOTECH INTERNALS | SURE LESS MONEY | CORKSPORT LED Bumper Lights | Last edited by Redfor; 06-27-2013 at 06:03 PM. |
![]() Join Date: Jan 2012 Location: Salt Lake City, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
| Not Ranked : 0 score Can you do a video that walks through how you wired it up? Or at least showcase how you wired it up?
__________________ 2012 Crystal White Pearl Mazdaspeed3 - Cobb AccessPort // Cobb Short Ram Intake // Cobb Turbo Inlet Pipe // Autotech HPFP // Race Pipe // CP-E Stage 2 xFlex RMM // Hawk HPS Rotors and Pads |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Neutral : -1 score How are these different from the ones on eBay? I already got one from eBay and I'm not happy with the build quality. Some of the LEDs don't light up evenly or it's pointing downwards. Sole where's my chopsticks? |
| Not Ranked : 0 score I think you answered your own question bud.
(Thread Starter) | Not Ranked : 0 score Unfortunately I do not have a video or step by step directions, I wish I would have made one when I did mine. Doing one now would consist of me taking the whole rear end of the car apart which is hard to find time for. The Corksport LEDs do come with some very good directions, but will have to admit that the install is a pain and there's no short cuts. You WILL need to jack up the rear end and put it up on jack stands. The next step is to remove BOTH rear wheels (hence the jack stands). Think this is why most people buy them and save them for a day when they have a lot of spare time. ( Don't be a idiot.. USE Jack stands... ) The Biggest advise I can give is DO NOT use the spice kits that come with the LED strips. I figured i'd save myself time by using them and found that they were not making good connections / splices. Therefore had to go back and do it the right way.. a lot of wire cutting, stripping and re-splicing. Basically use the same splices you would use for stereos. As I stated before, using a trailer wiring harness will allow your LED strips to work as normal tail lights, brake, and blinker as in the video above. Link to the wiring harness is also above. I am not sure if you will need these if you have normal tail lights ( My tail lights are LED due to tech package ). I do not know anything about the e-bay version, but I have yet to have any problems with any of the LEDs on the Corksport ones. Im pleased with mine, minus the pain of the install. Some people say its a waste of money, me personally, I like'em. That and if you ever get rear ended (before you hit'em with a tire iron) you can ask them which of the 5 brake lights did they not see.. hehe..
__________________ 2012 MS3 w/Tech SURE SRI | SURE TIP | SURE RMM | SURE VENTUS BPV | COBB AP | AUTOTECH INTERNALS | SURE LESS MONEY | CORKSPORT LED Bumper Lights | |
| The Following User Says Thank You to Redfor For This Useful Post: | VooDreau (07-17-2013) |
![]() Join Date: Sep 2013 Location: Oklahoma City, Oklahoma
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 612
| Not Ranked : 0 score Wired up some quick disconnect plugs for my bumper lights, in case I ever have the need to pull of the bumper. 20150918_101454.jpg
__________________ Mod List: CORKSPORT : Shifter Bushings / Interior Led Kit / Hood Struts / Short Ram Intake / Coolant Tank / Ecu Relocation-Battery Box / Disi Silicone Boost Tubes / Mid-chassis Brace / Fog Light Kit / Mud Flap Kit / Underhood Led Light Kit / Disi Silicone Bypass Valve Hose / Turbo Inlet Pipe / Mazdaspeed MZR Bypass Valve / Leather Shift Knob / MS3 Race Rear Motor Mount /Adjustable Short Shifter / Strut - Spring Combo Set JBR: Tru-Torsion 3-Way Adjustable Rear Sway Bar / Transmission Side Motor Mount 80a Durometer / Passenger Side Motor Mount 80a Durometer / DIODE DYNAMICS: Interior Led Kit SPC : Rear Camber Arms Ebay: Race Pipe Optima: Red Battery MOOG : Front and Rear End Sway Bar End Links AutoTech : HPFP Internals 35% Tint -------------------------------Not done yet------------------------- Need More Parts -------------------------------Not done yet------------------------- |
| Rear Bumper | PushingRedline | 2010 MS3 - How-To's | 3 | 11-07-2012 11:27 AM |
| Product Release! Corksport 2010+ Mazda 3/Mazdaspeed 3 LED Bumper Lights | CorkSport | CorkSport | 8 | 02-15-2012 10:26 PM |
| Corksport Front Bumper | prenedo | MazdaSpeed 3/6 - Appearance | 11 | 05-15-2010 07:22 AM |
