![]() | | #161 | ![]() |
![]() Join Date: Jul 2013 Location: Austin, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 107
| Not Ranked : 0 score
__________________ 2010 Mazdaspeed 3 Tech Stocking out ![]()
![]() | | #162 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score The 45* coupler comes with the kit. You have to purchase a straight coupler. The benefit would be a more direct shot to the intercooler and slightly shorter plumbing. Not a huge deal but I also prefer how it looks and the access it gives to the dipstick.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
![]() | | #163 | ![]() |
| Not Ranked : 0 score I think that is the main reason people don't. Looks like the winning option though. That 45* bend was one of the things I was worried about with the kit but if the straight through option is available with an additional coupler, that makes this a pretty good piping option.
![]() | | #164 | ![]() |
![]() Join Date: Nov 2012 Location: College Park, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 154
| Not Ranked : 0 score thanks to the op and everybody who posted on this one. I wanted to go with CP-E or Cobb for a FMIC but the money is crazy for what you get. I saw the CX setup and it looks like solid piping with a crap core and bpv. Seriously considering the PG piping kit and a good core. Should be a similar outcome for a lot less $$$.
__________________ Gen1 - Built and sleeved block, some headwork, Gen2 6266, FJ turbo kit, JMF with PI. |
![]() | | #165 | ![]() |
![]() Join Date: Jul 2012 Location: phenix city, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
Groaned at 8 Times in 4 Posts
__________________ 2012 Mazdaspeed3 Columbus, Ga [SIGPIC][/SIGPIC] FJ Performance Built Block/GTX3582r | |
![]() | | #166 | ![]() |
![]() Join Date: Mar 2013 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 18
| Not Ranked : 0 score Nice bumper
__________________ 2013 SILVER PU CS SRI// CS TIP// CS SSP// CXRACING FMIC// Forge BPV// COBB AP// AT Internals// NGK Iridium Plugs// CNT DOWNPIPE// CUSTOM CATBACK// SOME CORN! |
| The Following User Says Thank You to Hess22 For This Useful Post: | JTMS3 (12-13-2013) |
![]() | | #167 | ![]() |
![]() Join Date: Aug 2013 Location: Denver,CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score Going to be honest with you, I just switched to the CX kit from my CP-E TMIC and I love this thing!
__________________ COBB AP V3, GT3071R,AUTO TECH HPFP, CPE Big Inlet,CPE XcelXL Intake, CNT DOWNPIPE, SWAPPED VVT, JBR 88 DURO , CX FMIC WITH TR8 ,3 Port EBCS JBR 88DURO RMM, JBR PMM PURPLE DRANK |
| The Following User Says Thank You to MHHC5280 For This Useful Post: | BAT-man (12-13-2013) |
![]() | | #168 | ![]() |
![]() Join Date: Nov 2012 Location: North East
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 261
Groaned at 29 Times in 14 Posts
__________________ I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems. "... if u can't find' em - grind 'em" - old Chinese proverb ![]() ![]() http://www.mazdamotorsports.com/ | |
![]() | | #169 | ![]() |
![]() | | #170 | ![]() |
| Not Ranked : 0 score Good write up |
| The Following User Says Thank You to nixon99 For This Useful Post: | JTMS3 (12-17-2013) |
![]() | | #171 | ![]() |
![]() Join Date: Jun 2014 Location: Logan, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
| Not Ranked : 0 score Yes I know this thread is old as shit but does anyone know if the stock bpv hose is long enough to work with the cxracing piping kit?
__________________ 2010 Mazda Speed3- Mods: Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell Next up: tune. |
![]() | | #172 | ![]() |
![]() Join Date: Oct 2012 Location: TAMPA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 962
Sent from my SM-N900P using Tapatalk 4
__________________ 2013 VRM MS3\ BNR S3v2\ 4GL E85 TUNED\ | |
![]() | | #173 | ![]() |
| Not Ranked : 0 score Thanks for the tip!
![]() | | #174 | ![]() |
![]() Join Date: Apr 2014 Location: Melbourne OZ
| Not Ranked : 0 score If you use the OEM bov on the CX bov flange, it will leak past the two inner bov holes. The oem bov has a large diamond shape seal, which doesnt seal againts the two inner flange bov holes. Epoxy putty the holes or similar if you use the oem bov.
__________________ Gen2 | SU Tip+Sri | Autotech | Ghetto TP | ITV22 | CobbAP Stage2 | JBR Trill 80 | MD OCC V1 |
![]() | | #175 | ![]() |
| Not Ranked : 0 score What about the cobb bpv?
![]() | | #176 | ![]() |
![]() Join Date: Jun 2014 Location: Reseda, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 206
Groaned at 27 Times in 10 Posts
| Not Ranked : 0 score Was looking to install mine last night. Everything looked good, set it up and took off the bumper, until it came to bracing the core. The brace I received makes 0 sense. There are 3 pre-drilled holes on the top/bottom of the core, but the brace does not accommodate ANY of them. It's like this piece was just thrown in there. Am i supposed to use this as scrap and bend my own braces/drill holes? Just curious if anyone else is having this problem... Something to note that I bought this from a guy on Craigslist, though it seemed to be in the original packaging and pretty much untouched. |
![]() | | #177 | ![]() |
![]() Join Date: May 2012 Location: Ottawa Ontario Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score Is it worth the upgrade from a streetunit top mount to the cx front? I like the idea of having the core at the front of the car but feel I would have a better quality core with the streetunit on top. Also, with the GEN 2, has anyone modified the grill so the intercooler is easier to see. I would want to show that shit off.
__________________ 2012 MAZDASPEED 3 BLACK MICA -COBB SRI - COBB TIP - STEBRO CBE -ULTIMATE RACING CATLESS DOWNPIPE- STREET UNIT TEST PIPE -AUTOTECH INTERNALS - STREET UNIT TMIC - CORKSPORT TRUNK BRACE- STREET UNIT RMM (BROKE) JBR 88A RMM - CPE PASSENGER MOUNT - CPE TRANSMISSION MOUNT -COBB ACCESSPORT -SNOW PERFORMANCE STAGE 2 BOOST METH INJECTION KIT- DAMOND OCC -XXR 531 18X9 HYPER SILVER 235/40/18 GFORCE TIRES- PIRRELI PZERO RACING SLICKS ON OEM RX8 R3 RIMS- KSPORT SPEC AR COILOVERS - TURBO SMART BPV-DENSO ITV22'S STRATIFIED TUNE BY LEX |
![]() | | #178 | ![]() |
Groans: 438
__________________ All good things must come to an end... | |
![]() | | #179 | ![]() |
| Not Ranked : 0 score Save your self some time and get a nice fmic if you go that route. I am already upgrading my set up after having it for 2 k miles because it won't support my power goals. Spend the money once so you don't waste money twice.
| The Following User Says Thank You to blake0521 For This Useful Post: | speed3black87 (12-16-2014) |
![]() | | #180 | ![]() |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
| Not Ranked : 0 score There are nicer options out there, but you can pair cx piping with a treadstone core for about half of what those nicer kits cost. Using bad grammar from my cell phone.
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
![]() | | #181 | ![]() |
| Not Ranked : 0 score The CX racing supports upto 400 ponies does it not? I would be happy to be anywhere near that ( planning on staying k04 ) I just find on the hot days the top mount really shows it's faults. Seeing the price point on the CX racing it's a bargain if it will out perform my current set up. Plus it cleans up the engine bay nicely. Fuck it, I will order it up. I can always snag a tr8 core in the future.
![]() | | #182 | ![]() |
| Not Ranked : 0 score I am moving from the tr6 with cx piping to jbr piping and a tr8l because my build should be around 500 plus whp with the pte5858. If you are stock block even if you go bt the tr6 should work. It's rated at 400 hp which IMO is a lot on a stock block. Then again I have only been in the game for a bit.
![]() | | #183 | ![]() |
Groans: 126
| Not Ranked : 0 score Stock block will hold 400, you just have to keep the torque at bay in the low to midrange. Its all in the tune. Using bad grammar from my cell phone.
| The Following User Says Thank You to ASHMS3 For This Useful Post: | Drive By Fire (12-17-2014) |
![]() | | #184 | ![]() |
![]() Join Date: Nov 2014 Location: Miami
Rep Power: 0 ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score @OP Hey man, I noticed your couplers and clamps are not the ones provided with the CX kit. Could you please provide the sizes for these? The ones I got with my CX kit are terrible and i'm leaking boost >< |
![]() | | #185 | ![]() |
![]() Join Date: Dec 2015 Location: Pensacola, FL
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score Sorry in advance for the reincarnation of the post lol. Great writeup! helped me install my fmic! But did anyone else not be able to put the plastic undershield that goes directly under the fmic back on? The main one is on, but the front "lip" one does not fit anymore. Is this just me, or is this normal? |
![]() | | #186 | ![]() |
![]() Join Date: Mar 2016 Location: Pittsburgh PA
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score |
![]() | | #187 | ![]() |
![]() Join Date: May 2016 Location: Owensboro KY
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score How are you liking it so far? I'm considering when the time comes going FMIC. |
![]() | | #188 | ![]() |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/cx-racing-front-mount-intercooler-install-81388/ | ||||
| Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 06-03-2014 12:34 AM | |
| xenon bulb replacement | This thread | Pingback | 01-13-2014 06:20 PM | |
| Cx Racing FMIC | BlackedOutSpeed6 | MazdaSpeed 3/6 - Turbo Induction | 17 | 06-16-2011 07:30 PM |
| CX Racing FMIC Test | CX Racing | 2010 MS3 - Turbo Induction | 20 | 04-05-2011 08:09 AM |
| Another WOT run after FMIC install | llescaflownell | Cobb ATR Support | 14 | 07-14-2010 08:33 PM |
