> 2010 MS3 - How-To's
Like Tree35Likes
 Old 03-24-2012, 12:48 AM   #281
Bosox's Avatar
Posts: 328   (View Stats)
Bosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the world
Groaned at 33 Times in 13 Posts
Originally Posted by gpower07 View Post
shit...today i did my autotech internal...but i didn't lop with motor oil on the piston and spring....am i going ok? i already start the car...warm up for 30 min. and drove for half mile!!!!!
Really??
i dipped the piston with the O ring into gasoline. will that kill the O ring? if so. i can take it out and redo everything again.
This cannot really be a serious post, right? I am the last guy to be a straight up asshole to someone but it looks like you didn't read any of this thread or any other thread and installed your internals. If I am wrong, I apologize, but come on.
2010 Liquid Silver MS3 - COBB SRI/TIH, AP, JBR 88 Duro RMM, JBR Bushings, JBR SSP, AT Internals, CP-e Catted DP/RP, Michelin Pilot Super Sports 235/40 18, Motorcraft MT Fluid, Step Colder NGK's
Wife's Car: 2013 CX5 AWD Grand Touring (It's slow but handles nice)
OBAMA SUCKS
Stratified Tune by Lex
Last edited by Bosox; 03-24-2012 at 12:49 AM. Reason: MSF Database - Automerged Doublepost
Bosox is offline   Reply With Quote
The Following User Says Thank You to Bosox For This Useful Post:
SpeedSixxx (03-31-2012)
 Old 04-29-2012, 09:46 PM   #282
Dubcnea's Avatar
Posts: 223   (View Stats)
Dubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond repute
is it best to go through Eric@edgeautosports to get the best pricing on these internals?
2012 CPW Mazdaspeed 3
Dubcnea is offline   Reply With Quote
 Old 04-29-2012, 09:51 PM   #283
Bosox's Avatar
I did and was happy
OBAMA SUCKS
 Old 04-30-2012, 08:01 AM   #284
bigriver's Avatar
Posts: 1,123   (View Stats)
Price and service. They will even talk you through the install if necessary.
bigriver is offline   Reply With Quote
 Old 05-08-2012, 08:23 AM   #285
soulglow's Avatar
Posts: 58   (View Stats)
soulglow is a splendid one to beholdsoulglow is a splendid one to beholdsoulglow is a splendid one to beholdsoulglow is a splendid one to beholdsoulglow is a splendid one to beholdsoulglow is a splendid one to beholdsoulglow is a splendid one to behold
So I did the upgrade with KMD internals yesterday, and I've got a few notes that might help people. This is on an MS6, so ymmv for a 3:
- Definitely remove IC cover, I ended up removing the IC too but that's not necessary (see note on blue line). I don't see any logical reason to remove the TIH or the battery, they do not restrict access at all. I did remove the SRI, mainly so I could get the big air hose out of the way of the fuel lines...this is the most useful prep.
- The blue fuel line clip...that shit is from another dimension. I ended up prying it completely off before the connector would come off the nip. I still don't understand it, and was pretty sure I was going to break it. Hopefully you're smarter than me.
- Rather than prying on the pump, I just used a flatblade against the vertical surface and tapped with a mallet. Slid right out.
- Don't worry about bending the metal fuel line out of the way before sliding the pump out. Once I slid the pump out and away enough, it separated on it's own with no grief.
- I ended up breaking my vice trying to get the main threads loose, forcing me to ride my bike through the rain to use my dad's vice. HAVE A GOOD VICE, and use some wood shims or rubber strips to hold the pump.
As far as the rebuild itself...just be wary and clean. The inside of the sleeve on mine had some pretty heavy crud. The instructions that come with the KMD internals are useless as far as the mechanical process, but fairly explicit as far as lubrication so follow that (grease internal parts, use oil on o-rings, don't forget the outer o-ring before re-installing.
In the process of threading the pump back in, a bunch of grit/corrosion from the housing would break loose and land in the body, forcing me to clean it out again. This happened a number of times, just be careful.
Primed it a few times and it fired right up...immediately hit 1700 PSI before eventually settling down. It's very clicky and noisy right now but seems to be working well. I let it idle for about 20 minutes then shut it off. After I put my exhaust on today I'll go for a long drive and see how everything goes.
2006 MS6 GT: CorkSport CBE and RP, TMIC / tubes; SURE Aeros v2 SRI w/AEM, Torq RMM, Short Cut, anchors; Cobb AP, TIP, XPE BPV; KMD HPFP; BC coilovers; SPC balljoints; JBR TIGs, EGR delete, OCC S2, spacers; Technafit SS lines; Hawk HPS; Iridium plugs
:::: STRATIFIED Lex tune on hold :::: Coming Soon: a few boxes of crap I haven't had time to install. ::::
2002 MP5 w/ HELLA RICEY BITS, Daily Driven with some embarrassment and lots of love.
soulglow is offline   Reply With Quote
 Old 05-10-2012, 10:01 AM   #286
J_Logik's Avatar
Posts: 129   (View Stats)
J_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the world
All, I did the internal install on the weekend gone by (@rghispanic88 thanks for the instructions) and I'm trying to determine what is the average fuel pressure people are seeing after the upgrade?
I was seeing almost 1700psi with the OEM internals, but after the install I'm currently seeing between 1700-1780psi, but this is with me only pressing the pedal to about 5psi of boost. I haven't gone WOT throttle yet as I'm concerned I'm not seeing significantly higher output.
Any suggestions, could it be installed incorrectly?
2010 VRM MS3
JBR RMM, AUTOTECH HPFP INTERNALS,
FORGE V2 BPV, DDM 6K LOWS, 8K FOGS, LED SWITCHBACK PARKING LIGHTS, RED CALIPERS
J_Logik is offline   Reply With Quote
The Following User Says Thank You to J_Logik For This Useful Post:
rghispanic88 (05-10-2012)
 Old 05-10-2012, 10:03 AM   #287
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
If it was installed incorrectly your fuel pressure would be in the 60's. As long as you don't go under 1600 at WOT, you're fine. Nothing wrong with having higher pressure.
The Following User Says Thank You to adlpb For This Useful Post:
J_Logik (05-10-2012)
 Old 05-10-2012, 10:53 AM   #288
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
no prob man
pressure under part-throttle is really not what we are really concerned about.
you want to focus on the pressure at full throtle or WOT. catch a log with the Ap strating at 2500 to redline, about 6300 RPM and makae sure that your pressure is not below 1600
2010 Black Mica
rghispanic88 is offline   Reply With Quote
 Old 05-12-2012, 10:13 AM   #289
Dumyz's Avatar
Posts: 402   (View Stats)
Dumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the world
Groans: 27
Groaned at 6 Times in 2 Posts
Can someone more thoroughly explain step #8.5....? The one with the zip tie.
2010 Mazdaspeed 3 - Sold
New: 2008 Toyota Tundra
Dumyz is offline   Reply With Quote
 Old 05-12-2012, 10:29 AM   #290
adlpb's Avatar
Groans: 669
Look at the bottom of the fuel pump where there a metal line. You need a 19mm wrench to take out the nut that attaches the pump to the metal line. When you remove that nut, it will fall down to the fuel line and be a pain in the ass to get back. That's why you put a zip tie to prevent the nut from sliding down the metal fuel line.
 Old 05-12-2012, 10:30 AM   #291
RobLoMS3's Avatar
Posts: 21   (View Stats)
RobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of lightRobLoMS3 is a glorious beacon of light
You wana place a zip tie bellow the nut on the bottom fuel line, so when u take it off it doesn't slide out of your reach. I just used some tape. Then after its all put back together u remove the zip tie
tapin
2008 MS3 AEM CAI, COBB TIP, HKS CB, TURBOXS BPV, COBB FMIC, JBR RMM, JBR OCC, CP-E CATTED DP, TB TIG, SnailD Tune E85
RobLoMS3 is offline   Reply With Quote
 Old 05-16-2012, 07:24 PM   #292
Dubcnea's Avatar
subbing
 Old 05-26-2012, 10:05 PM   #293
Werm's Avatar
Posts: 157   (View Stats)
Werm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond reputeWerm has a reputation beyond repute
Groaned at 8 Times in 3 Posts
anyone know if the stock fuel pumps on the send gens are the same as the speed6? thinking of just buying a new fuel pump and putting the internals in it and just swaping it out for mine. i know the part number for the speed6 pump and not the speed3 so I can't be certain im ordering the right part
Werm is offline   Reply With Quote
 Old 05-30-2012, 11:02 AM   #294
Acedelgado's Avatar
Posts: 39   (View Stats)
Acedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud of
Why? The hardest part of the install is taking the pump off and putting it back on the car. Why do it twice? Internals themselves are super easy to do and hard to screw up. Just make sure you wear some dust-free nitrate gloves to handle the parts, lube lightly and don't force anything.
2012 LSM Non-tech
Kensun 6000k HID / SURE 70a RMM \Cobb AP/ Autotech Internals\ Corksport SRI + TIP/ Synchronic BOV
Interior:
AppRadio 2 + ARLiberator + ScanTool Bluetooth OBDII Reader + Torque Pro = Win.
Acedelgado is offline   Reply With Quote
 Old 05-30-2012, 11:11 AM   #295
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
This makes almost no sense to me. Either way you are going have to disassemble a pump and put one back together. Its not like you are eliminating any chance of something going wrong. You are preforming all the same steps as someone that just simply swaps out the internals.
Why would you want a whole new pump assembly?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 07-04-2012, 08:19 AM   #296
pwned's Avatar
Posts: 762   (View Stats)
pwned has disabled reputation
I did my install last weekend.
Seen how too's that say remove the intake and batt box. Hmmm too much work for me!!
-Removed tmic
-shoved rag down by fuel line under nut
-took my 19mm wrench and loosened nut
-removed upper quick disconnect lines
-removed inverted torx
-removed pump
-placed pump on clean surface
-pulled out spring/rod portion
-air comressor filled up to 60psi(half of capacity so its not full power)
-used my 1/2in mac air gun to zip off nut while holding pump in hand
-removed bottom part of pump pay attention what sise is up and facing down
-lubed up oring on inside of nut you zipped off
-took shaft and slid in and out of oring(it did take convicing this was the most tedious part i thought i was going to fold the oring over or damage it at first
-reinstalled into pump itself
-hit the nut with the gun 2 times
-slid spring down over rod and installed keepers then pushed down to lock inplace
-lubed up main oring that slid into pump on car
-installing into car the fuel line top itself was in the way of sliding the pump back in so i took a long skinny screw driver and slightly pushed the line over to allow clearance
-all fell right into place with no issues
-tightened all bolts and reinstalled everything
-done!!!!!
Sold
-12' Ms3 // 305hp 336tq SAE
-13' CWP MS3
JBR 88a Trilogy // Full3 Aeros ID300 Intake // At Internals // UR Catless Tbe // JBR Occ // Forge V2 // Cobb FMIC // Ngk(6510)@.026 // Devils Own WMI // Freek Tune // Swift Springs // JBR Rsb
323hp/351tq SAE
Current..
02 Regal GS-Go fast stuff-286hp/314tq 12.8 @ 108.....248k original motor/trans(Broken........Trans failed at 249,334 12/6/15)
16' Mazda 6 GT (sonic silver)
pwned is offline   Reply With Quote
The Following User Says Thank You to pwned For This Useful Post:
DingoDave (07-04-2012)
 Old 07-12-2012, 03:37 AM   #297
Seaton's Avatar
Posts: 233   (View Stats)
Seaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the world
Thanks to OP for this,
Did my HPFP upgrade, very easy, i didnt have to pull anything off the car apart from the TMIC shroud to remove the pump
Seaton is offline   Reply With Quote
 Old 07-12-2012, 06:22 AM   #298
h0ckeyman's Avatar
Posts: 1,126   (View Stats)
h0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the worldh0ckeyman is the leader of the world
Groans: 32
Nice instructions, will be doing this soon.
h0ckeyman is offline   Reply With Quote
 Old 07-17-2012, 04:58 PM   #299
soaptray's Avatar
Posts: 138   (View Stats)
soaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond reputesoaptray has a reputation beyond repute
Thanks for the write up! Will be doing this to mine in the next few days!
[ 2010 MAZDASPEED3 - Crystal White Pearl ]
Lighting 6000k HID Bi-Xenon, Painted, LED Halos, HID Fogs, LED Interior | Autotech HPFP Internals | MagnaFlow CBE | CP-e DeltaCore FMIC | Cobb SRI, TIH, AP, Knob | TurboXS Hybrid BOV | UR Catted Downpipe, Test Pipe | Denso ITV22 Plugs | SURE Anchors, Counterweight, Shortcut | Rally Armor Flaps | AutoEXE Strut Bar | Speedline Hood Damper | Prosport Evo Boost Gauge, Evo Wideband AFR Gauge | JBR 80a RMM, 80a TMM Mount, Stage 2 OCC | Hella Supertones | Misc 30% Tint | Varrstoen 18 x 8.5 ES2 +35 | Koni Yellows | H&R Springs
In Garage: XSPower Exhaust Manifold, Garret GTX3076R EWG
soaptray is offline   Reply With Quote
 Old 08-02-2012, 10:02 PM   #300
kashbringer's Avatar
Posts: 514   (View Stats)
kashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the worldkashbringer is the leader of the world
This thread helped a TON today! Thank you OP.. Though as I was working I forgot to add a zip tie on the metal fuel line... Luckily a pair of pliers helped get the but back from the depths of hell!
I think it's been mentioned, but if anyone is looking around.. The E8 Inverted set is sold at harbor freight tools.. like 8 bucks for a set of inverted star sockets.
2012 MazdaSPEED 3 - Crystal White Pearl
Performance - Precision 5858 - Built motor (K1 Rods / Wiseco Pistons / ARP main studs / Stock head bolts) - Cobb V3 AccessPORT - PERM 5th port kit, PERM Plate - HTP 3.5" Intake (Powder Coated Pure Orange) - Autotech HPFP Internals – CPE Vband Exhaust Manifold - Kozmic Vband Downpipe, Dumptube, Oil feed / Return lines, Vented OCC, Primary EGR delete – Ultimate Racing Catback, FMIC modified for 5th port by Kozmic Motorsports - Turbosmart dual port , 45mm EWG - JBR Coolant Bypass, EGR Delete, Throttle body TIG, Dogbone RMM, Transmission Mount, Sealed OCC - Grimmspeed EBCS - NGK plugs - Bosch 3.5 Bar MAP w/MattJackson86 PnP Harness – Ported Intake manifold with VCTS delete, 1/8" Intake manifold TIG by Zack - Spec Stage 3+ Clutch and flywheel
Tuned by Voltwings
(OLD k04 SET UP ) 374.5 WHP 447.2 WTQ with stock K04 - 1-17-14 Dynocom dyno
(New BT numbers soon) ~487WHP 455wtq Virtual Dyno and out of fuel... moar injectors!
Looks - Pure Orange Powder Coated Gen Pu Stockers - Muteki SR48 Lugs - 5k HIDs / 3K HID Fogs
kashbringer is offline   Reply With Quote
 Old 08-02-2012, 11:01 PM   #301
Martinezs89's Avatar
Posts: 16   (View Stats)
Martinezs89 will become famous soon enough
Groaned at 8 Times in 2 Posts
This is a good write up! ill be doing this soon to my car a must needed mod
Martinezs89 is offline   Reply With Quote
 Old 08-03-2012, 05:43 PM   #302
punisherB273's Avatar
Posts: 181   (View Stats)
punisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond repute
Groaned at 9 Times in 7 Posts
Just did my install today and thought i would share a few things I found that make the install easier I haven't read about yet.
1. If you are installing auto techs the directions have you completely dissasemble the pump to clean. On the sensor part that has to be removed I left the pump bolted up and used a crescent wrench to loosen the sensor before removal. If you don't have a vice or don't like clamping soft aluminum in a vice this helps with removal as you can't get an impact on there with the sensor in the way. I used a 3/8ths impact for everything else. No vice needed.
2. Removing the TIP is a lot easier than trying to loosen the lower fuel line 1/16th of a turn at a time. I even have crows foot line wrenches but i didn't have any luck getting those to work.
3. Removing the intercooler makes no sense.
4. My TIP clamp was finger tight from the factory with only 6k miles on the car. I'd check yours As I've never even touched the thing for it to be loose. While your at it just replace the darn thing it's cheap looking plastic junk
5. The fuel line fitting has tons of red lock tight on it that flakes off when cleaning the pump. Spend extra time getting that clean as it can fall off and get in the pump when rebuilding
6. If you watch the video op posted in a link don't be like them. Wear gloves and use lint free cloth . They looked like a couple of monkeys humping a football especially when installing the piston retainers. Seriously push the piston all the way up, put the silver retainer on the spring, slide keepers in place and then push the piston down to lock into place
2011 Liquid Silver Mazdaspeed 3 - Cpe Nano Intake - Corksport Test Pipe - Cobb XLE -Corksport RMM inserts - Autotech HPFP internals - Cobb AP stage 2 tune in progress
punisherB273 is offline   Reply With Quote
 Old 08-03-2012, 10:54 PM   #303
DingoDave's Avatar
Posts: 764   (View Stats)
DingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the world
Groans: 43
Groaned at 8 Times in 4 Posts
Just installed an aftermarket TIP on a buddy's gen2 MS3 the other day and the clamp on his stock TIP was finger tight as well.
2013 Black Mica Mazdaspeed 3 - Current daily
2006 WWP Mazdaspeed 6 - Soon to be daily
2006 BCM Mazdaspeed 6 - Project
Tuned with by
DingoDave is offline   Reply With Quote
 Old 08-23-2012, 12:28 PM   #304
3starmagnum's Avatar
Posts: 348   (View Stats)
3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world3starmagnum is the leader of the world
Just did this today. Thanks OP for the nice write up!
Word to those who haven't done this yet and are planning to: get 'er done!! Don't be scared. Just read up
2011 Mazdaspeed3
Power Mods: JBR 3" intake//CP-e top mount IC//AT internals//CS testpipe//NGK step colder plugs
Other mods: JBR 88 rmm//Swift springs//RA mud flaps//JBR ssp
STRATIFIED TUNED by Lex
3starmagnum is offline   Reply With Quote
 Old 08-28-2012, 06:00 PM   #305
Adog35's Avatar
Posts: 309   (View Stats)
Adog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the world
Autotech internals still going strong.
2010 MS3
5% REAR 30% FRONT
DDM 5K HID
RMM
CS TIP/SRI
Dizzy Tuned
Autotech Internals
Swift Springs
JBR Rear Sway
Stoptech 309's
First Turbo Car and I love it!
Adog35 is offline   Reply With Quote
 Old 08-30-2012, 09:25 AM   #306
IHIERBal's Avatar
Posts: 144   (View Stats)
IHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond reputeIHIERBal has a reputation beyond repute
Gonna be doing the install hopefully this weekend. Thanks for the write-up OP. And wish me luck! lol
2010 MS3 purchased 02/11/12 (11,9xx miles) II Headlight Armor yellow fogs II CS RMM insert II CS SRI/TIP II DDM HID Kit low beams 4300k II Plasti-dipped rear valence II Eibach prokit II OEM Rear bumper guard II OEM roof rack II Thule 44" fairing II Privat Akzent 18x8.5+40 II 235/40 Falken Ziex II UltraGauge II Cobb AccessPort II OBX test pipe II AT Fuel Pump Internals II HKS bov VTA II CP-E TMIC II ATP Long Downpipe II CS Shift Plate II Koni Yellows II
Re-tune in progress!
Engine oil : Rotella T6
Oil filter : Motorcraft
IHIERBal is offline   Reply With Quote
 Old 09-10-2012, 01:52 PM   #307
strukoff's Avatar
Posts: 24   (View Stats)
strukoff is a name known to allstrukoff is a name known to allstrukoff is a name known to allstrukoff is a name known to allstrukoff is a name known to allstrukoff is a name known to all
Finished my AT internals install this morning. Very easy install, easier than my TIP install. Here's some notes from my experience:
-remove fuse and let the car die as you will have virtually no fuel spillage (may take a few minutes)
-just removed IC cover and valve cover breather tube
-removing IC lower tube and battery/ecu tray would be easier if you can't fit the open end wrenches in
-crow's feet do not work so don't waste your money/time
-blue clip on fuel line, just lift the blue clip out a bit with one hand and pull the line out
-yellow clip will release with a flat head screwdriver easily
-when putting pump back on, I just tightened the 3 bolts down evenly and the lower hard line clicked into place
-primed the pump and it fired up easily
Honestly don't be worried about this install!
Now on my way to getting Stratified!!!!!
strukoff is offline   Reply With Quote
The Following User Says Thank You to strukoff For This Useful Post:
Keko (09-11-2012)
 Old 09-11-2012, 05:46 PM   #308
manila's Avatar
Posts: 1,767   (View Stats)
Maybe I can get your guys opinion, I have a friend who was offered to switch his OEM internals with Autotechs (with roughly less than 500 miles). Here's the scenario the Autotechs were installed by a shop PTuning located in Manassas VA if your not familiar with them. Does this seem like a good/even trade? I saw that the internals required gloves, soaking in gas/fresh oil.
The reason for the swap the guy with the Autotechs is trading in his speed for a focus ST
'12 MS3 Black Mica w/ Tech
 Old 09-11-2012, 06:06 PM   #309
smoogs12's Avatar
Groans: 423
He would be an idiot not to. Seems pretty straight forward to me
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 09-11-2012, 06:57 PM   #310
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Have one of them log it and see how much fp it's holding.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 09-17-2012, 03:42 PM   #311
manila's Avatar
Can any of you shed some light on this question? I'm about to install my internals soon and my test pipe. I understand your suppose to drive easy for a good 100 miles or so with the internals in correct? I was wondering if I should install the internals first and let them set for a few miles and then install the test pipe, or would it be fine to install them simultaneously?
 Old 09-17-2012, 03:46 PM   #312
adlpb's Avatar
Groans: 669
Simultaneously is fine. And 100 miles is excessive. You don't need anywhere near that
anavrinIV (09-17-2012)
 Old 09-17-2012, 03:54 PM   #313
manila's Avatar
Ok sounds good appreciate your input!
 Old 10-06-2012, 06:30 AM   #314
Docnox's Avatar
Posts: 1,435   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
Installed autotechs yesterday, my impressions:
1. No need to remove battery and tip. You could, but I had no problem getting to everything with those still installed.
2. As others have said, be careful with that blue clip, it popped open easy for me but make sure you just grab that inner blue piece and put it some place before you drop it into your engine bay and have to fish it out.
3. The ziptie is an annoying sticking point for a lot of people. I just took someone's advice and rammed a piece of cardboard down there to keep the nut from dropping. Took 2 seconds, and serves the purpose of keeping the nut from dropping.
4. 18mm deep, thin socket is tough to find. I ended up buying an impact socket, which worked.
5. Pump should slide right in. I had to get in the car, gas/clutch to the floor and blip the key a couple times to allow the pump to go back in.
6. I didn't pull the relay and just primed the system by gas/clutching it to the floor but you only have to do it for a couple seconds. I had my AP hooked up and watched the pressure climb, but in case you don't have a way to monitor, no need to hold it there for too long.
I took it easy for about 50 miles. Noticeable difference though, very smooth. My pressure was always good on the stock one but I think the big difference is how fast the pressure ramps up and how high it holds up top at WOT. Here's a 3rd log (never seen 1900 before):
'06 Speed 6
Black Mica
Mazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe,
3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp
Altered Customs fmic, Autotech fp internals
Cobb AP, Stage 2+ 93 tweaked
Centric blanks, EBC red pads
Lotek center gauge pod: AEM wideband, Autometer boost and volts
Tints, blacked emblems, spec-v front lip, Shark fin
Redline MT-90, ITV-22s, Matt Damond OCC
13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap)
DO Meth kit waiting on install
Docnox is offline   Reply With Quote
 Old 10-19-2012, 09:12 AM   #315
RdotQelo's Avatar
Posts: 422   (View Stats)
RdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the world
Doing this today. I'll update! Thanks for the info to everyone who posted it.
2011 Mica MS3 - AP/Autotech Internals/NGK step colder plugs/UR TBE/CS FMIC/Forge BPV/CS SRI-TIP/JBR RMM 88a/JBR SSP w Bushings/JBR RSB/JBR OCC/Sonic Tuning S3 Coilovers/JBR Camber Arms
RdotQelo is offline   Reply With Quote
The Following User Says Thank You to RdotQelo For This Useful Post:
3starmagnum (10-19-2012)
 Old 10-19-2012, 12:51 PM   #316
tdjach's Avatar
Posts: 7   (View Stats)
tdjach will become famous soon enough
definitely gonna do this when im back stateside
tdjach is offline   Reply With Quote
 Old 11-05-2012, 03:36 PM   #317
G-Man's Avatar
Posts: 46   (View Stats)
G-Man is a jewel in the roughG-Man is a jewel in the roughG-Man is a jewel in the rough
Groaned at 17 Times in 4 Posts
Just installed my KMD internals and I have a few thoughts and pointers.
Removing the IC gave me the room I needed to easily remove the 19mm fastener and to reposition the metal fuel line at the end.
A rubber mallet is handy for getting the button off, and back on the assembly.
Popping the button back in was a pain - the KMD is supplid with a metal disc with a section cut out of it. You need to wedge this between the spring and the retaining clip thing and smack the button back in with a rubber mallet. I positioned the assembly in the vice to do this.
The pump did not go back in easily, so I turned the engine over a few times to reposition the cam lobe, then it went in easy enough.
'08 Speed3, '06 Murano, '95 S14 SR20DET
G-Man is offline   Reply With Quote
 Old 11-05-2012, 04:04 PM   #318
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
Didnt your new internals have a two piece retaining clip? I have done a fair share of internals and nothing required the use of force in regards to replacing the internal parts.
tappy-tap-tappytalk
Mods: stock
 Old 11-06-2012, 12:44 PM   #319
GreyGhost's Avatar
Posts: 315   (View Stats)
GreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the world
Im the Ultimate Newb to the Mazda platform...in fact my car only has 1300 miles on it and I just did the Autotech internals install in a little over an hour.
Fuel Pressure:
At idle: 400s
Cruising: 1600s
Underload: 1700s
Correct me if I'm wrong, but based on my thread reading I'm exactly where I need to be. 76 miles to go for break-in then I will be installing my dp and uploading my Stage 2 tune!
Never done this many mods on a car with only 1300 miles. Freakin awesome. Thanks to this thread install was a breeze. If you are wanting to this, get yourself a stunny 19mm wrench...make it even easier.
2013 Mazdaspeed 3:
Performance: Autotech Internals // COBB AP // COBB TIP // Cobb Intake & Air Box // COBB FMIC // UR Catted DP V1 // UR CBE // UR Testpipe // Go Fast Bits BPV // Stratified ECBS 2-Port Mode // NGK One Step Colder Plugs // JBR Coolant Bypass Kit // Rotella T6 5w-40 // CP-e Stage RMM // Cp-e PMM // CS Shifrer Plate // Sure Shift Anchors // Redline Plus Hood Struts
VD: 304hp / 333tq Stage 2 91 Octane Freek Tune
GreyGhost is offline   Reply With Quote
 Old 11-15-2012, 03:04 PM   #320
Volcomstone7's Avatar
Posts: 63   (View Stats)
Volcomstone7 has much to be proud ofVolcomstone7 has much to be proud ofVolcomstone7 has much to be proud ofVolcomstone7 has much to be proud ofVolcomstone7 has much to be proud ofVolcomstone7 has much to be proud ofVolcomstone7 has much to be proud ofVolcomstone7 has much to be proud of
Thanks for this awsome guide really is going to help me with my internal install. =)
Cobb SRI--Cobb AP--Cobb TIH--Autotech Internals--JBR All MMs-CS FMIC--CS CBE--CP-e catless Downpipe--NGK's One Step Colder--MB Battles--ETuned
Volcomstone7 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/fuel-pump-internals-install-76252/
HPFP fitting ? Mazda MPS Owners Club This thread Refback 05-09-2015 01:43 PM
Fuel Pump internals Install! - Mazdaspeed Forums This thread Refback 01-17-2015 03:58 AM
? Bekijk onderwerp - Insane J - Mazda 3 MPS - Fuelpump upgrade, Autotech besteld. This thread Refback 10-14-2014 05:56 PM
russiakansk air base 76252 This thread Refback 07-29-2014 09:34 PM
Anleitung: HPFP Internals tauschen This thread Refback 03-05-2014 08:09 AM
How-To 's und Nützliches - [ALLE] HPFP Internals tauschen This thread Refback 02-22-2014 10:06 AM
overview for azarashi This thread Refback 11-27-2013 04:51 PM
Picked this up yesterday. My new 2013 Mazda Speed3, fully loaded. Couldn't be happier. : mazda This thread Refback 11-25-2013 01:30 PM
mikey32235's ride thread - Page 2 This thread Refback 11-13-2013 04:56 AM
What am i missing? Stage2 OTS - Page 3 This thread Pingback 09-02-2013 08:52 AM
Need help on internal retainer - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 06-29-2013 08:52 AM
fuel pump internals install help - Houston-Imports.com This thread Refback 06-28-2013 11:35 AM
2010-13 Mazda 3/Mazdaspeed 3 Forums - View Single Post - Hybrid blow off valve, opinions! This thread Refback 06-11-2013 04:04 PM
CPE Fuel Pump Mazdaspeed 3 - Reverse Lookup Directory This thread Refback 05-19-2013 03:52 PM
MAZDA FRENCH CLUB - ?????????? ? Afficher le sujet - [Japanas] Mazda 3 MPS Gen.2 This thread Refback 05-18-2013 02:44 AM
Hybrid blow off valve, opinions! - Page 5 - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 05-13-2013 05:43 AM
Autotech Install Help? This thread Refback 01-04-2013 05:14 PM
Testbericht vom Hypertech für den Mazda 3 MPS BL - Seite 21 This thread Refback 12-18-2012 03:27 AM
mikey32235 everything is broken - Page 2 This thread Refback 12-01-2012 10:42 AM
mikey32235 everything is broken help me thread. - Page 2 This thread Refback 11-24-2012 11:04 AM
Fuel pump?? This thread Refback 11-22-2012 03:45 PM
Random MS3 Chat Thread - Page 131 This thread Refback 11-07-2012 12:56 PM
HPFP fitting • Mazda MPS Owners Club This thread Refback 11-06-2012 04:34 PM
HPFP fitting • Mazda MPS Owners Club This thread Refback 10-10-2012 12:29 PM
Mazda MPS Owners Club • View topic - GroupBuy 2nd Chance! AutoTech HPFP Internals - $375 - Round2 This thread Refback 08-23-2012 09:40 AM
Testbericht vom Hypertech fr den Mazda 3 MPS BL - Seite 21 This thread Refback 06-17-2012 02:17 PM
Mazda MPS Owners Club • View topic - Group Buy: AutoTech HPFP Uprated Internals - updated - £245 This thread Refback 06-12-2012 01:35 PM
Austausch Krst.-Hochdruckpumpe - Seite 7 This thread Refback 06-12-2012 05:39 AM
Ou acheter des internes pour la HPFP - Mazda 3 Quebec This thread Refback 04-18-2012 04:12 PM
Austausch Krst.-Hochdruckpumpe This thread Refback 04-05-2012 11:56 AM
Mazda MPS Owners Club • View topic - HPFP fitting This thread Refback 02-19-2012 11:24 AM
Testbericht vom Hypertech fr den Mazda 3 MPS BL This thread Refback 02-18-2012 06:50 AM
MAZDA FRENCH CLUB - ?????????? • Afficher le sujet - [Japanas] Mazda 3 MPS Gen.2 This thread Refback 01-28-2012 04:00 AM
NATOR TO unite! dp install anyone? This thread Refback 01-24-2012 09:49 AM
upgraded fuel pump internals This thread Refback 01-08-2012 10:34 PM
MAZDA FRENCH CLUB • Afficher le sujet - [Japanas] Mazda 3 MPS Gen.2 This thread Refback 08-27-2011 05:35 AM
KMD V2.1 Fuel Pump Internals AllLostThings MazdaSpeed 3 - Engine, Transmission & Driveline 9 05-23-2010 12:04 PM
oil in engine bay after pump internals install Realgib3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-24-2009 05:04 PM
Fuel pump internals cgburton12 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 43 08-11-2008 01:29 PM
Page generated in 0.62968 seconds with 53 queries
