![]() Join Date: Dec 2015
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Here is my gauge Wideband Digital Air Fuel Ratio Gauge-Amber display They have their own instructions but I couldn't figure it out on how to install the green and brow wire for the analog output. I have a ms3 2010 Sorry if there is a similar thread already about this. Thanks for the help |
![]() Join Date: Apr 2016 Location: Chowchilla, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score Did you ever figure it out? |
(Thread Starter) | Not Ranked : 0 score Yeah, I figured it out by my self lol. Works great |
| Not Ranked : 0 score Care to share what you did? I plan to install one in a few months |
| Not Ranked : 0 score Can I ask, since the Speed's have a wide band O2 from the factory, what's the goal of adding a second wide band O2?
Groans: 438
| Not Ranked : 0 score I removed my oem narrowband, and replaced with an AEM failsafe with o2 sensor. But if you already have an ap, really no need for just a basic wideband gauge.
__________________ All good things must come to an end... |
| The Following User Says Thank You to g00s3y For This Useful Post: | SofaKingAwesome (06-14-2016) |
(Thread Starter) | Not Ranked : 0 score I realized that after i installed it lol. I really dont use my gauge, i just use my ap. But i like the way it sits on my dash Last edited by DavidFerreiraa; 06-16-2016 at 06:54 AM. |
http://prosportgauges.com/instructio...alwideband.pdf I connected power wires to my fuse box using add-a-circuit. I used a voltmeter to find the fuses that i wanted to use cuz i wanted the gauge to turn on just when i turn the key. If u want i wll take a picture of my fuse box later. There is 2 wires that is just for the color of ur gauge, white (for white) and orange (for amber) i just connected the orange one for amber leds, if u want u can connect the other wire to ur headlights, so it will change colors at night. After u connected everything u r almost done, now u need to connect the sensor, which i had to pay $40 for a local shop to do it for me, I asked them to weld after the 2nd oem o2 sensor ( they ask u to install it 36 inches downstream so u dont kill the sensor too easy). After u do all of that just connect everything to the UEGO controller, turn the car on and let it calibrate, if it dont calibrate by it self, there is a little button on the uego that u can press for 3sec and it will calibrate for u. You dont need to connect the analog output, unless u want to datalog it. | |
| Wideband Gauge | ev0nstispanka | MazdaSpeed 3 - How-To's | 22 | 10-09-2009 04:12 PM |
| wich wideband more acurate? Stock wideband or dyno tailpipe sniff wideband? | gsrtype1 | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 7 | 02-14-2009 10:37 PM |
