> 2010 MS3 - How-To's
Like Tree6Likes
  • 6 Post By mczimer
 Old 07-29-2012, 11:04 AM   #1
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
Neutral  :  +2 score
Default HOW TO: Clean your valves - easy & cheap
Due to the nature of direct injection, these engines will accumilate a large amount of carbon build-up over time. The only way to remove it is manually scrubbing, or media blasting the valves. Using seafoam/engine cleaners/ect will not do anything measurable to this buildup, this cleaning is basic maintenance in order to keep your engine running at its best.
Do this every 40k miles, and I also recommend deleting the EGR valve, swapping your PCV valve, and installing an OCC kit at this time to keep the intake manifold clean
Guide to Preventative Maintenance and Modding
Links to info on DI and other DI cars, showing how common it is for the industry to clean:
Carbon Build Up Info
VW Golf
BMW
*Note: BMW/VW/COBB all offer valve cleaning at their dealerships, among other places- it is an industry standard to clean them
Why clean? Better performance (recovered flow), smoother idle, smoother driving, save money, and to learn about your car!
Here is the BEST method for cleaning your valves: before/after soaking/after a little blasting
Equipment needed: (noted below, with pics)
  • An air compressor setup
  • Media gun/abrasive gun (open/close valve-but not necessary)
  • Fine walnut media **Note: HF has a different categorization than other places for the grit on the media**
  • B12 -2 cans (1 could do, if you are tight on cash)
  • 1' section of clear hose from Home Depot - 1" ID, available by plumbing
  • A towel you can sacrifice
  • Two way fluid transfer pump
  • Masking tape
  • Safety glasses/gloves (IMPORTANT)
  • Camera- to brag once you are done
Brief Overview of procedure:
  1. Remove IM, followed @jbarone instructions (here)
  2. Ensure which 2 valves are TDC- top dead center/closed
  3. Soak those valves in B12 for at least 1 hour & cover other valves with masking tape
  4. Suck out majority of B12 using two-way fluid pump
  5. Air blast valve to remove remining B12, while using a towel around gun tip to catch carbon/B12 coming out (goggles/gloves on) (90psi for all air use)
  6. Blast valves with media in 2sec pulses for 30sec, vacuum on, repeat until happy
  7. Suck out media with small hose, then air blast for 10sec to remove anything else
  8. Tape over cleaned valves
  9. Proceed on other valves in same order (TDC/soak/suck/blast/clean)
  10. Photoshoot
TOTAL COST, without air compressor = only ~60 bucks, and you have 24.8/25 pounds of media left to help many others and clean again!
In order to achieve these results, the process goes as follows:
STEP 1
Soak 2 TDC-top dead center valves in B12 (maybe-substitute denatured alcohol/seafoam/methanol)
Top dead center is achevied by removing the passenger front wheel, then a little plastic guard which is held on by 3 plastic screw-you can't miss it, then you will see this:
The (14mm) tensioner pulley is on the left-turn this clockwise to loosen the tension on the belt before/after messing with the PS pump. You will need someone to remove the belt from the PS pump as you relieve the tension
The (21mm) crank pulley is on the right, turn clockwise to turn the engine, it will be at TDC when it gets toughest to turn (check valves are TDC by looking, then pouring some B12 in and see if it stays put)
**Note: Only 2 valves will be entirely TDC at a time. On mine, one valve was 90% closed, so take note for next time (ie- valves 2/4 and 1/3 are TDC grouped for me)
**Note: I do recommend removing the belt from the power steering pump before turning the crank pulley (before tilting the PS pump to the side during the Intake Manifold removal is even better), but it is not needed
STEP 2
After soaking the TDC valves either overnight (prep night before), or for 1+ hours, use either your shop vac (if you wish to ruin the filter and spend time cleaning it-trust me on this) or a two way fluid transfer pump (Here: 5 bucks at HF) to suck out as much B12 as you can into a container
Now take your gun, wrap the towel around the tip. Now insert/jam it into the valve to AIR blast all the leftover B12 out (it will shoot out, so wrap the towel in layers to make it thicker, and apply pressure)
**Note: Always use safety goggles and some gloves
STEP 3
Now, apply the one foot section 1" clear ID tube from Home Depot ($2) into the valve runner, as in this picture:
**Note: I soaked one valve for only ~1hr and got the same results, but it took a whole 2-3 minutes longer to clean!
I drilled a hole just small enough for my gun tip to fit into, roughly 1" from the base of the tube, then I stuck the gun/hose into the valve runner and apply the vacuum cleaner/shop vac to the open end.
I blasted at 90psi-the gun max operating pressure (BMW instructions say 6 bar, which is 116 psi BMW Link)
Blasting was done in pulses of 2sec for about 30 seconds total, then the valves were nearly spotless! Of course, I kept going to make them shiny and pretty, but honestly, this can be done on all the valves in under 10min.
**Note: I turned the vacuum on periodically to suck up excess media, since the tube collects much of the media. Keeping a vacuum on a "low" setting throughout the blasting could also be done, but you will use more media, as noted below. I also held the gun sideways (hood-style) to avoid any jamming, which worked best.
Unlike the prior write ups, I used a gun from harbor freight which had an open/close valve for the media. This allowed me to only blast air, which cleans very well on its own. This also allowed me to use less than 1 hopper of media for ALL the valves (out of the 25 pounds I got from Harbor Freight). Blasting only air into the valve periodically in essence reuses the media which is laying down there; think of it as a balloon which you let loose in a box-it smacks into everything. Another great point of using this gun was the ability to air-clean the engine bay, since 100% of the media is never going to be contained.
Gun used:
Gun has standard 1/4" air hose fitting and was sealed at the threads using tephlon tape (standard air tool procedure according tpo the neighbor)
This is what my setup looks like, note the vacuum attached on the end:
STEP 4
After blasting was to my liking, I stuck a small plastic hose attached to my vacuum into the valve to suck up any excess, then I blasted the valve with AIR for 10sec to clean anything remaining out (although it would just burn off, walnut is combustable).
**Note: cover the finished/remaining valves with masking tape to avoid any richochet media going in. I also taped the gun's hopper closed since I was holding it at all angles
That's it guys, let me know if you want clarification on anything. As a sidenote, you could probably acheive very clean valves simply by using the air and soaking (as noted in this thread, post #15) Props to @timjs for inspiration on this project. I think B12 does an identical job to the Mazda Zoom Zoom Cleaner, possibly in a less concentrated form; but, nonetheless, it is just as effective for a fraction of the cost. Zoom Zoom Cleaner is originally designed for rotary engine cleaning, link to RX8 forum info
I used the liquid B12, since it is cheaper and the spray does nothing we need
mczimer is offline   Reply With Quote
The Following 20 Users Say Thank You to mczimer For This Useful Post:
alien_sporez (03-04-2013), anavrinIV (12-16-2012), Atlanta (09-11-2012), AZSPEED3 (12-16-2012), Blingbeard (12-29-2018), BrianB6 (07-29-2012), DingoDave (10-06-2012), drg0708 (03-10-2013), England15j (12-16-2012), helmetface (07-29-2012), ibcrusn (05-10-2013), Mi06Speed6 (08-04-2012), skeurton (08-06-2012), trixms3 (04-23-2013), VulgarKyle (02-18-2013), wide.open.throttle (11-09-2017), Willofalltrades (08-05-2012), xxdjfate76xx (12-16-2012), ZetaDrift (05-08-2014), zxhoya (05-28-2015)
 Old 07-29-2012, 11:19 AM   #2
Blackrider's Avatar
Posts: 356   (View Stats)
Blackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the world
Groaned at 20 Times in 14 Posts
Good writeup! Really the only thing I did differently was I used pneumatic pressure to turn the crank, but I have a setup for that!
2008 MazdaSpeed 3
Exhaust - Mazdaspeed & Ebay Downpipe
Induction - MazdaSpeed CAI, Unknown TIP, JBR TIG's & CXR FMIC
Tuning - Auto Tech Internals, Cobb Accessport, Grimmspeed 3 port EBCS
Suspention - Koni FSD's, RX-8 Rims, Potenza RE - 11's 235 / 40 / 18's
Drivetrain - J-Speed Shifter Plate, Sure Anchors, SU RMM
Random - Pontiac G8 Horns
2013 Ford Edge Sport AWD, the family car...
Blackrider is offline   Reply With Quote
 Old 07-29-2012, 11:53 AM   #3
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
Tagged, thanks!
 Old 07-29-2012, 11:57 AM   #4
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
What was the mileage before doing it? Did you run an occ or egr delete?
 Old 07-29-2012, 12:01 PM   #5
Stickied and copied to how to section. Thanks for the awesome write up.
 Old 07-29-2012, 01:34 PM   #6
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Nice work man, it looks fairly clean too with the vacuum setup
2006 Mazdaspeed 6
 Old 07-29-2012, 01:38 PM   #7
theurgy's Avatar
Posts: 2,580   (View Stats)
This, especially the part about how to crank the engine is probably one of the most useful bits of information I needed.
 Old 07-29-2012, 02:46 PM   #8
mczimer's Avatar
Yes, with the combo I used, there was no cleanup
Car has 63k. Valves were cleaned 15k ago.... this is maintenance
Glad to help guys, I figured explaining the process in as much detail as possible with pictures will encourage more people do this
I also was trying to figure out where my thread had gone.... I guess it's here now. @Haltech, I did this on my MS6, so if you can put it into that area as well, I would appreciate it.
 Old 07-29-2012, 02:53 PM   #9
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
Nice write-up. Was easier for me to put the car in first gear and jerk it back and forth from the front until the valve I was working on was closed. I didn't want to take the wheel and splash guard and everything else off. Next time I'm going to use the walnut instead of the gun cleaning kit.
Thanks!
The Following User Says Thank You to crazyp For This Useful Post:
Alexander (01-28-2013)
 Old 07-29-2012, 03:00 PM   #10
mczimer's Avatar
Thanks!
I think it took me 5 minutes to take the wheel off, & turn the crank
 Old 07-29-2012, 03:20 PM   #11
crazyp's Avatar
Groans: 68
Hey man I'm sure its real easy but 5 minutes is pushing it. Take wheel off, take cover off, take belt off. Put belt back on. put cover back on, then wheel. sounds like 20 minute job to me
Just try it my way next time you'll see what I mean.
 Old 08-04-2012, 05:48 PM   #12
ztnedman1's Avatar
Posts: 338   (View Stats)
ztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the world
For the Gunpu there is NO need to remove wheel or belts.
Since we dont have to move power steering to remove intake mani just leave belt on and when you need to turn crank just grab the belt at the vertical part at the front and pull up. Walla! More reason to go Genpu!
2010 Velocity Red MS3 (140k+ miles) Intake/Exaust/AP selftuned(313/399 long time ago) - SOLD
2004 Corvette Z06
SCCA Bowling Green Match Tour - GS 1st place
SCCA Wilmington Champ Tour - GS 2nd place
SCCA National Championship - GS 3rd place
SCCA Grenada Match Tour - AS 1st place
ztnedman1 is offline   Reply With Quote
 Old 08-04-2012, 06:10 PM   #13
Mi06Speed6's Avatar
Posts: 154   (View Stats)
Mi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond repute
Thank you for this writeup. I'm dreading doing mine since I've got 92k miles, no OCC and haven't installed the EGR delete in my garage yet. Hoping to do both after a major cleaning like this. Def a bit of motivation to do this. Hopefully there will be a group that wants to do this in central FL soon.
'06 Mazdaspeed 6|| Cobb SF & AP Stage 1 | RPM Street Springs | SPC Ball Joints | SU Rear MM | SURE Dread | Whiteline RSB |18x8 Enkei EKM3 w/ 225/40 | JBR SSP & SURE Anchors | Rotora Blanks w/ EBC Red Stuff | 6K HID lights/fogs | V2 Pre-amp |
Mi06Speed6 is offline   Reply With Quote
 Old 08-04-2012, 08:18 PM   #14
3Gee Tee's Avatar
There is, check out the central FL NATOR section. We just had a meet in Tampa tonight.
 Old 09-11-2012, 12:16 PM   #15
manila's Avatar
Posts: 1,767   (View Stats)
Nice write up OP!
'12 MS3 Black Mica w/ Tech
 Old 12-04-2012, 08:40 AM   #16
BAT-man's Avatar
Posts: 719   (View Stats)
BAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the world
Groaned at 29 Times in 14 Posts
awesome write up, once I hot 30k miles - I'm coming back to this!
BAT-man is offline   Reply With Quote
 Old 12-16-2012, 01:51 PM   #17
Spectrum24x's Avatar
Posts: 276   (View Stats)
Spectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond reputeSpectrum24x has a reputation beyond repute
Would running some seafoam give you the same results with much less effort?
2007 TRUE RED MS3 GT
RX-8 WHEELS/DRILLED & SLOTTED ROTORS
KONI YELLOW/COBB SPRINGS/JBR RSB/HOTCHKIS FSB
COBB OTS STAGE 2 MAP
RMM/COBB INTAKE/COBB TIH/ETS TMIC
OBX TEST PIPE/AUTOTECH INTERNALS/FORGE BPV V2
Spectrum24x is offline   Reply With Quote
 Old 12-16-2012, 07:14 PM   #18
mczimer's Avatar
Sea foam does close to nothing
 Old 12-16-2012, 09:24 PM   #19
BAT-man's Avatar
It does do something but in this direct injection engine, the injectors do not spray the fuel (mixed with Seafoam) into the intake runners (and subsequently - indirectly onto the valves). The DI spray occurs within the combustion chamber, and the valves don't get washed as a result. Unfortunately, there is no way to get the Seafoam to do its job in our engines, unless you're worried about the oil passages, but I've always been apprehensive regarding putting anything but oil... into oil. Just thinking what a diluted mixture probably does to all the bearings/rings makes one cringe.
sil80
The Following User Says Thank You to BAT-man For This Useful Post:
DamagedGoods (12-17-2012)
 Old 12-17-2012, 03:12 PM   #20
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
Nice write up OP!
 Old 03-03-2013, 05:44 PM   #21
FrozenFloridian's Avatar
Posts: 572   (View Stats)
FrozenFloridian is the leader of the worldFrozenFloridian is the leader of the worldFrozenFloridian is the leader of the worldFrozenFloridian is the leader of the worldFrozenFloridian is the leader of the worldFrozenFloridian is the leader of the worldFrozenFloridian is the leader of the worldFrozenFloridian is the leader of the worldFrozenFloridian is the leader of the worldFrozenFloridian is the leader of the worldFrozenFloridian is the leader of the world
subbed
FrozenFloridian is offline   Reply With Quote
 Old 10-14-2013, 09:15 PM   #22
Brc187's Avatar
Posts: 330   (View Stats)
Brc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the world
Subbed.
Why walnut shells? Why not use glass beads or even soda blast?
Brc187 is offline   Reply With Quote
 Old 10-16-2013, 10:14 AM   #23
mczimer's Avatar
Originally Posted by Brc187 View Post
Subbed.
Walnut is soft, meaning it will not damage anything; it is also combustible, so if anything enters the head it will burn off without any repercussions.
 Old 10-16-2013, 10:16 AM   #24
Brc187's Avatar
Combustible, that makes sense now.
 Old 10-16-2013, 11:35 AM   #25
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
note that even though it IS combustible, if you have too much "wet" b12 and some walnut in there, the car may be a little more resistant to start... This happened when we did @NavySailorMS3;'s car. took about 30 cranks before it finally turned over and it stunk of burning walnut and zoom spray.
p057 is offline   Reply With Quote
The Following User Says Thank You to p057 For This Useful Post:
NavySailorMS3 (10-17-2013)
 Old 10-18-2013, 11:51 AM   #26
bsteimel's Avatar
Posts: 13   (View Stats)
bsteimel has a spectacular aura aboutbsteimel has a spectacular aura about
i'm subscribing to this thread. I have about 34k on the odometer and plan on doing this when I pass the 40k mark. Just so happens that my cousin bought a media plaster and it's in the box after buying it 2 years ago. That makes life even easier. This looks a little complicated but I'm ready to take on the task. I'll let you know how it works out after I do it. Sometime this winter probably.
Black 2012 MS3 with Tech, Jbarone shift plate, jbarone RMM - Purchased 09/2011.
"Personally, I don't like EVs, I love the sound of an engine and the smell of oil - I'm old fashioned like that, but now is a good time to be a stylist." Mazda chief designer = awesome
bsteimel is offline   Reply With Quote
 Old 10-19-2013, 04:24 PM   #27
glockman25's Avatar
Posts: 335   (View Stats)
glockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the world
Groaned at 8 Times in 5 Posts
I plan to do this soon and try to delete the butterflies and gasket match port and polish my intake and do Toyota diesel seals
glockman25 is offline   Reply With Quote
 Old 10-19-2013, 05:27 PM   #28
coopsspeed's Avatar
Posts: 155   (View Stats)
coopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond reputecoopsspeed has a reputation beyond repute
Nice write up, definitely gunna use this when i get to mine
2007 Black Mica Speed3
speedperf6rmanc3 built short block >> Manley H-beam rods >> Wiseco pistons >> BNR stage 1 >> Cobb sf intake >> Corksport TIP >> ISC coilovers >> Autotech hpfp >> Forge V1 BPV >> jbr stage 2 occ >> jbr 88d RMM >> UR tp >> CNT cat back exhaust >> Cobb AP >> Richtuned by Anthony
coopsspeed is offline   Reply With Quote
 Old 01-24-2014, 04:21 AM   #29
DrewGen2's Avatar
Posts: 16   (View Stats)
DrewGen2 has a spectacular aura aboutDrewGen2 has a spectacular aura about
Great write up! Very thorough. I removed my throttle body for my egr delete last weekend. With only 3200miles on car the back side of throttle body and intake plenum had already gotten a black film of residue on it. I can see why our valves look like this after 10k plus.lol
DrewGen2 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/how-clean-your-valves-easy-cheap-120232/
Valves cleaned, car starts, dies after rough idle. Thoughts? - Page 5 This thread Pingback 05-01-2013 06:10 PM
Who can do a MS3 Intake Valve cleaning in LA/OC? This thread Refback 02-20-2013 02:17 PM
HOW TO: Clean your valves - easy & cheap mczimer MazdaSpeed 3 - How-To's 56 05-11-2018 08:52 PM
HOW TO: Clean your valves - easy & cheap mczimer MazdaSpeed 3 - How-To's 77 04-16-2016 04:57 PM
how to: clean your valves vol 2 dooderek MazdaSpeed 6 - How-To's 36 09-12-2015 08:41 AM
how to clean your valves vol 2 dooderek MazdaSpeed 3 - How-To's 41 03-16-2014 08:03 AM
Cheap and easy exhaust TallKyle MazdaSpeed 6 - How-To's 77 02-25-2013 10:42 PM
Page generated in 0.51991 seconds with 40 queries
