> 2010 MS3 - How-To's
Like Tree4Likes
  • 2 Post By Raider
  • 1 Post By Sid3wayS
  • 1 Post By cbspd3flip
 Old 03-13-2012, 09:48 PM   #1
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
Default How-To: Gen2 mani install V2
Ok so first off i would like to say thanks to race built for a great mani. Very stong and well built. Even though it took a long time and many text back and forth it was worth it. Thanks again for a company stepping up to the plate to make parts for the speed 3 & 6.
Ok so agian this install was on a gen two and i have the V2 mani so it fit easier. I wanted to wrap the mani to keep the temp down and i am glad i did. I used a 1" x 50' roll of the lava wrap that i got off ebay. It was enough to wrap the whole mani. If you do plan to wrap it than make sure you soak the wrap first and bolt the mani to something that wont move at all like a work bench.
Ok now on to the install.. run your engine for a few minutes to warm up the stock mani. than shut off the car and PB blast the turbo and mani nuts.. Make sure you give yourself pleanty of time. It took me seven hour all by myself and with an install this involved you will run into issues.. So get all you tools together and jack the car up and put it on stands..
I was also doing an oil change so theres a few extra tools there. What i used 3/8 drive flex head ratchet, 14mm deep socket, 10mm socket, three different length extentions, breaker bar , 10mm 12mm 13mm 14mm cloesed end ratchet wrench, 3/8 E8 torx bit, 14mm stubby combo wrench, flat and phillip head screw driver, need nose pliers, never seize, PB blast, work gloves and other odds and ends i cant think of.
these are the tools i use 90% of the time. its all of my 14mm wrenches
What made it easy for me was take as much off as possible. Battery, sri, tip, brake booster hose, valve cover breather hose. Of coures you need to take off the tmic, the heats sheids and rear tmic bracket.
Once everything is off make sure to stuff a towel or rag in your turbo and tb cold side tube. Dont want anything falling inside..
Now your ready to remove the mani and turbo stud nuts.. your going to need all your tools to get to the nuts since some will work better than others at reaching. this took the most time. now once they are all off there is a bracket thats attached to the stock mani that holds one of the tubo lines that has to be taken off. Its a 10mm bolt. next slide under the car and unbolt the two bottom bolts that hold the turbo bracket in place. Your going to need a breaker bar for those bitches...!!! Now your ready to remove the stock mani. I didnt remove my cowl or have to tilt the engine but i did remove as many head studs that i could easily reach. this did make removing a little easier. So you will need that E8 torx bit for this job.
Now time to remove. its going to need some wiggling and it comes right off.
If you removed any of the top mani studs your going to need to replace them before putting the new mani back on. some of them you wont be able to screw back in with the mani inplace. I found that if you turn the mani with the top of it facing you and the head flage facing down its will slide back easy and than just rotate to get into place. I know i made it sound easy but you will need to wiggle and work it. putting in the new one is harder than take the stock off so take your time and breath.. once the mani is on the top nuts on the left need to be screwed on first. you need to slide the mani back some to install the nuts. screw down the center nuts first than start from the out side and work your way in.
next turbo nuts. i put some never seize on mine but you dont have to. the left two are easy but the right two are at a slow 1/8 turn at a time. you will need the stubby 14mm combo for this job. once those are done go back under the car and reinstall the two turbo bracket bolt. you may need a breaker bar or very large screw driver to realign the bracket.
so now you can start putting you car back together. but forget to hook back up your brake booster hose, all the hoses to the intake, bpv boost line, valve cover breather hose, maf sensor, tmic rear bracket, battery and tighten those clamps..
I would look into upgrading the hot side tmic tube to silicone bc it will get hotter under that hood and the mani is closer to the tmic now as well.
In closing the exhaust does sound deeper now and the turbo spools a lot quicker as well. Will be updating once i start my tune. Hope this helped and good luck.
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
The Following 9 Users Say Thank You to vrspeed10 For This Useful Post:
11cruzito11 (03-13-2012), MS3-a(sore)ASS-rex (03-14-2012), Oliverms3 (03-14-2012), RaceBuilt (03-14-2012), Raider (03-14-2012), rghispanic88 (12-04-2012), Sid3wayS (03-13-2012), speeed (12-05-2012), wankular (03-14-2012)
 Old 03-13-2012, 09:51 PM   #2
11cruzito11's Avatar
Posts: 824   (View Stats)
Groaned at 5 Times in 2 Posts
Can't see your pics man!
Cobb AP, 504whp 492wtq
The Following User Says Thank You to 11cruzito11 For This Useful Post:
thehead (03-14-2012)
 Old 03-13-2012, 10:11 PM   #3
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Subbed for pictures.
TEAM LUXURY
 Old 03-13-2012, 10:28 PM   #4
vrspeed10's Avatar
can you see me now??
 Old 03-13-2012, 10:34 PM   #5
Sid3wayS's Avatar
Groans: 97
Yes lil small but it works.
@Raider give this man some flow for a great how-to.
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
Raider (03-14-2012), vrspeed10 (03-14-2012)
 Old 03-13-2012, 10:37 PM   #6
How close is the last runner to the turbo coupler that connects to the intercooler pipe?
 Old 03-13-2012, 10:44 PM   #7
vrspeed10's Avatar
^^ very. i told race built about it all ready. i think all the speed 3 he has done where gen ones with the V1 and had a fmic. that why i said i am glad i wrapped it..@11cruzito11
sorry took them with my phone an am a noob when it comes to posting good vids and pics..
@kritz @RaceBuilt @MS3-a(sore)ASS-rex
Last edited by vrspeed10; 03-13-2012 at 10:44 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to vrspeed10 For This Useful Post:
MS3-a(sore)ASS-rex (03-14-2012), Sid3wayS (03-13-2012)
 Old 03-14-2012, 12:01 AM   #8
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
That looked tons easier than CPE lol
 Old 03-14-2012, 06:19 AM   #9
Moved to Gen2 How-To, and will be sending $$$$.
Nice how-To
TiGraySpeed6 and vrspeed10 like this.
 Old 03-14-2012, 05:28 PM   #10
vrspeed10's Avatar
Thanks @Raider. never really planned it as being a sticky but if you think it sticky worthy than thank you very much. After finding out i remember the thread you started about making more stickies for faster easier info. I think i would have taken better pic if i know it would have been a sticky..
The Following User Says Thank You to vrspeed10 For This Useful Post:
Raider (03-14-2012)
 Old 03-14-2012, 05:35 PM   #11
Sid3wayS's Avatar
Groans: 97
So duh go back uninstall everything and do it all over again and take better pictures. Just like everything else that takes hours to do on this car, the 2nd time around will only take 30min. TOPS. LoL
vrspeed10 likes this.
TEAM LUXURY
 Old 12-04-2012, 08:50 AM   #12
BAT-man's Avatar
Posts: 719   (View Stats)
BAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the world
Groaned at 29 Times in 14 Posts
I wonder if any DIY heatshield can be put on top of that mani...
sil80
BAT-man is offline   Reply With Quote
 Old 12-04-2012, 11:51 AM   #13
bstover17's Avatar
Posts: 586   (View Stats)
Groans: 228
Holy thread resurrection.
2010 MAZDASPEED 3
 Old 12-04-2012, 12:47 PM   #14
cbspd3flip's Avatar
Posts: 1,279   (View Stats)
cbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the worldcbspd3flip is the leader of the world
Groans: 405
Groaned at 19 Times in 16 Posts
sil80
No thank you for resurrecting this thread with a worthless post.
L3THAL6 likes this.
cbspd3flip is offline   Reply With Quote
 Old 12-05-2012, 02:55 PM   #15
BAT-man's Avatar
Anytime bud. At least my question was related to the topic, while you're just venting.
Oh look, now I'm doing it too. Or am I?
sil80
The Following User Says NO Thank You to BAT-man For This Un-useful Post:
cbspd3flip (12-05-2012)
 Old 12-05-2012, 03:31 PM   #16
cbspd3flip's Avatar
Groans: 405
You asked a pointless and dumb question on a thread that has been deceased for how many months. Faggot.
Why a DIY heat shield? Just wrap it and call it a day.
Also do some research on rape built.
p0069 and p0303 after race roots bat relocator and pnp mani install turd burglar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 24 03-27-2012 04:33 PM
Stage 2 Methanol Install on Gen2 using MAP wire(w Pics) BeeZaa 2010 MS3 - Fuel, Nitrous & Water Injection 51 08-14-2011 05:16 PM
My PG v.3 mani install JohnnyT MazdaSpeed 3/6 - Turbo Induction 49 09-10-2009 12:57 PM
Page generated in 0.37479 seconds with 28 queries
