> 2010 MS3 - How-To's
Like Tree21Likes
 Old 10-17-2014, 04:27 PM   #81
ButtholeRedMS3's Avatar
Posts: 784   (View Stats)
ButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the worldButtholeRedMS3 is the leader of the world
Did this today and it worked perfectly. Thanks.
2007 BM MS6 - Sold
2010 VRM MS3 Tech - Sold
ButtholeRedMS3 is offline   Reply With Quote
 Old 03-17-2015, 10:01 AM   #82
SnailSpeed3's Avatar
Posts: 278   (View Stats)
SnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond reputeSnailSpeed3 has a reputation beyond repute
Sorry for the thread revival, but I tried this yesterday and it did not work for me...
I first tested the green wire and found that I was getting some current through it with the headlight/foglight switches off (dim glow on my indicator light), then once the switches are engaged the indicator light brightens up fully, like it should. So this seems off from what OP said should happen...
The orange wire test results were as they should be.
I then used the clamp-on style t connectors (pics below for reference) to jumper the green and orange cable together. I did not cut either cable, I just used the clamp connector things like shuebox mentioned in post #76 .
Thing is, after jumpering the two cables together, the fog lights still do not work independently of the headlights... The system only acts like it does in OEM configuration.
Does anyone have any idea why this may be? I'm certain I found the correct wires and I know current is able to flow through the clamp connectors and my "t'ed" in jumper cable as I tested all for continuity...
2013 Liquid Silver MS3
Mods so far:
FUNCTIONAL-
Cobb AP
HTP 3" Intake
C(u)NT 3" Catless Downpipe
JBR OCC, EGR delete, Under Engine Piping
Treadstone TR6 FMIC and brackets
Damond RMM, PMM, TMM
JBR SSP & BUSHINGS
Autotech HPFP Internals
AESTHETIC-
DIY Mudflaps, DDM 55W HL/35W FL
SnailSpeed3 is offline   Reply With Quote
 Old 03-17-2015, 11:01 PM   #83
workdaddy's Avatar
Posts: 15   (View Stats)
workdaddy will become famous soon enoughworkdaddy will become famous soon enough
This may sound dumb - but my buddy tried this and when I looked at it i found he used the wrong orange wire.. You used the green from the upper grey harness and the Orange from lower blue harness correct?
If so I'm not sure what happened but I've done 4 gen pu speed 3 and they all are still working great.
Double check the wires and see if mistakenly used wrong lead.
Good luck with it ��
2013 MS3
-CorkSport STG2 Intake w/inlet
-CorkSport RMM
-CorkSport CatBack Exhaust
-GoFastsBits BPV
-TSW wheels
-Mazda THULE Roof Rack
-RAGE Roof Basket
-"LOWES" Lip / Skirts
-Misc "Built not Bought" appearance mods
~WORKDADDY
workdaddy is offline   Reply With Quote
 Old 03-18-2015, 07:18 AM   #84
Yeah I am almost positive they are the correct wires, 6 down on the right column of the top connector is the green wire and top right of the bottom blue connector is the orange wire...
Did you cut the wires or just jumper them together?
I will check and test the wires again after work today, but I am damned near 100% sure that I'm on the correct wires...
If this doesn't work I was thinking about trying the under the glove box method in this link, has anyone tried out this other method and run into issues or anything?
Mods so far:
FUNCTIONAL-
Cobb AP
HTP 3" Intake
JBR SSP & BUSHINGS
AESTHETIC-
 Old 03-18-2015, 07:32 AM   #85
ataggart's Avatar
Posts: 62   (View Stats)
ataggart is a jewel in the roughataggart is a jewel in the roughataggart is a jewel in the roughataggart is a jewel in the rough
I believe you need to cut the wires or use a wire splice like someone else did above and said it worked.
And your link appears to be for the Juan not the pu
ataggart is offline   Reply With Quote
 Old 03-18-2015, 07:47 AM   #86
I did use a wire tap connector, similar to what was used. The one I used is the blue, 2 piece with the spade connector, like the pictures I put up. And yeah that link is older, and for the genone, but I believe this trick has also been noted to work on first gen's or maybe I'm just making that up...
I did have a thought that maybe the wire taps I used aren't getting a good enough bite on the stock wiring. I used the blue ones meant for 14-18g wiring. Anyone have any thoughts on this?
I don't know what gauge the stock wiring is, but I know that when I tested the contacts on the wire clamps, there was current passing through as it illuminated my test light when the headlight/fog light switches were in their appropriate orientations...
Mods so far:
FUNCTIONAL-
Cobb AP
HTP 3" Intake
JBR SSP & BUSHINGS
AESTHETIC-
 Old 03-18-2015, 08:26 AM   #87
Guys, I appreciate the help so far, but I started another thread specific to my issue so if there are any more suggestions, please put them in that thread (link below) so there is no double posting and jumping back and forth, thanks!
Independent fog light issue
Mods so far:
FUNCTIONAL-
Cobb AP
HTP 3" Intake
JBR SSP & BUSHINGS
AESTHETIC-
 Old 05-20-2016, 07:21 AM   #88
LAlicea's Avatar
Posts: 34   (View Stats)
LAlicea is a name known to allLAlicea is a name known to allLAlicea is a name known to allLAlicea is a name known to allLAlicea is a name known to allLAlicea is a name known to all
Groaned at 8 Times in 4 Posts
This is excellent...! going to try this out this week end.
LAlicea is offline   Reply With Quote
 Old 04-20-2019, 09:27 PM   #89
GenPuNoob's Avatar
Posts: 2   (View Stats)
GenPuNoob has a little shameless behaviour in the past
So out of curiosity how would I wire this same setup to run with no lights on at all? I've looked everywhere online for a true independent mod while using the stock switch. Would be forever grateful for the knowledge.
GenPuNoob is offline   Reply With Quote
The Following User Says NO Thank You to GenPuNoob For This Un-useful Post:
Db09ms3 (04-25-2019)
 Old 04-24-2019, 07:17 PM   #90
Suzkuz's Avatar
Posts: 10   (View Stats)
Suzkuz will become famous soon enough
Wait, what are you trying to do? This post already is how to manually control the fog lights...
Suzkuz is offline   Reply With Quote
 Old 08-28-2019, 06:13 PM   #91
GenPuNoob's Avatar
I want to be able to use the factory switch without having to use the parking lights.
 Old 08-29-2019, 06:39 AM   #92
Posts: 2,830   (View Stats)
Why would one want the fogs on completely by themselves?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/how-independent-fogs-108897/
What Did You Do To Your Car Today? - Page 324 This thread Refback 09-15-2014 07:47 PM
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-26-2014 09:13 AM
GENpU HOW-TO: Independent fog light mod This thread Refback 03-26-2014 06:05 AM
Independent Fog Lights - Page 4 - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Refback 07-03-2013 07:30 AM
Foglight en tout temps? - Mazda 3 Quebec This thread Refback 01-23-2013 05:34 PM
Independent Fog Lights - Page 4 - 2012 Mazda 3/Mazdaspeed 3 Forums This thread Refback 11-04-2012 10:29 PM
2010 Mazda 3/Mazdaspeed 3 Forums - View Single Post - Independent Fog Lights This thread Refback 07-23-2012 10:33 AM
Independent Fog Lights - Page 4 - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 06-22-2012 09:11 AM
08.5 MS3 GT Independent Fogs ZsSpeed3 MazdaSpeed 3/6 - Car Audio & Electronics 18 08-23-2011 12:01 PM
Independent fog lights mrFanel 2010 MS3 - Car Audio & Electronics 4 03-18-2010 06:17 AM
Porsche and VW expected to keep NA operations independent? Haltech Automotive News 0 08-17-2009 03:00 PM
Independent People Haltech Celeberty Smut 0 07-04-2009 03:10 AM
Bertone design division goes independent Haltech Automotive News 0 04-25-2008 07:30 AM
Page generated in 0.33858 seconds with 28 queries
