| Approved MSF Vendor ![]() Join Date: Dec 2008 Location: Draper, UTAH
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 435
(Thread Starter) | Neutral : +2 score Eibach Pro-Kit Lowering Springs For more information on these camber arms, click here, or any of the images below! This weekend I got a chance to install the Eibach Pro-Kit Lowering Springs. In preparing Yurtle for winter here in SL, UT I wanted to pull the summer wheels, tires and coilovers off of the car to keep them from getting to beat up by all the salt that goes on the roads. I already swapped the summer wheels and tires for a set of 16" steelies and Firestone Winterforce tires. The next step was to pull the Pedders coilovers off and reinstall the factory struts paired with Eibach Pro-Kit springs. The Eibach Pro-Kit is designed to deliver aggressive good looks and high performance handling, without ever compromising safety or ride quality. By using their proprietary, progressive spring design, they are able to keep your car comfortable enough that your wife won't complain while reducing body roll, increase cornering ability and stop quicker. WARNING: If you are unfamiliar with the ins and outs of the MS3's suspension system, please have a professional install these for you. Part #: 5554.140 Return Policy: RallySport Guarantee Mfgr. Warranty: Million Mile Adjustable: No Drop Height Front: 1.0in Drop Height Rear: .6in Drop Height Front Metric: 25mm Drop Height Rear Metric: 15mm Includes Bump Stops: No Lets take a look at what Eibach includes. ![]() ![]() ![]() 1) First things first, get your car up on jackstands or better yet a lift if you have access to one. ![]() 2) The wheels need to be removed to gain access to remove the suspension. ![]() ![]() 3) In order to remove the front suspension there are just a few steps that need to be completed - Remove the clip holding the brake line to the strut: ![]() Disconnect the endlink and bracket securing the ABS line to the strut: ![]() Remove lower part of strut from the hub: ![]() ![]() Remove the 3 bolts securing the strut to the chassis: ![]() Remove both left and right side front strut assemblies: ![]() 4) With both front strut assemblies removed from your car we just need to mark the orientation of the upper perch in respect to the lower perch before disassembly. This orientation must remain the same with the installation of the Pro-Kit springs or unwanted noise may result while driving. The MS3 design is such that I don't think you could reinstall everything with the incorrect orientation but better safe than sorry. We grabbed a white paint marker to make the necessary reference marks. ![]() ![]() 5) Toss the factory strut/spring assembly in the spring compressor you have. This one may look different than what most end up picking up from their local parts store. The main purpose here is to compress the spring so that when you remove the top hat nut the spring doesn't come shooting off and hurt someone. With this particular spring compressor we had the ability to place the upper arms on the top of the upper mount and apply pressure there which kept it from spinning when removing the 17mm nut holding everything together. ![]() ![]() 6) With the top hats, springs and dust boots removed go ahead and clean up the strut and spring perch to get them ready for the new springs. ![]() ![]() For reference I snapped a picture of the factory 2013 MS3 front spring next to the Eibach Pro-Kit spring. ![]() 7)Reinstall the factory dust boot and bump stop assembly and slide the new spring over your strut. Set the top hat on and ensure that the marks you made earlier line up properly. Once you've gotten to this point install your new springs in reverse order that you removed your stockers and you are ready to install the assemblies back on your car. The piston rod nut factory torque specification is 43-56 ft/lbs. Also note that according to the instructions Eibach included there is no modification needed to the factory bump stops. ![]() ![]() Stock struts with Eibach Pro-Kit springs next to Pedders Coilovers. ![]() ![]() ![]() ![]() 8)Reinstall your new setup in the reverse order you used to uninstall them and ensure you properly torque all hardware back to factory specifications. ![]() ![]() Torque Specifications: Upper mount to chassis mounting bolts: 23-28 ft/lbs ![]() Endlink to strut nut: 32-44 ft/lbs ![]() Knuckle to strut bolt: 48-54 ft/lbs ![]() Rear: 1) Moving onto the rear suspension you need to remove the factory spring and strut which is I believe easier than the front. Get the rear springs ready for installation by removing the upper spring seat off of the stock springs and installing them on your Eibachs. ![]() ![]() ![]() ![]() 2) In order to remove the springs on the car you'll need to drop your rear swaybar by removing the nuts securing the endlinks to the lower control arm. Once the nuts are removed you can simply rotate the bar down and out of the way. ![]() ![]() It is hard to see in this next picture but you will want to support the lower control arm with a jackstand, screw jack or floor jack before removing the lower bolt connecting it to the hub. This will prevent the spring from popping out wildly as well as keeping the lower control arm from losing control and damaging your car or your hand. ![]() With the spring you had on the car removed reinstall the Eibach spring you've prepared and use your screw jack or floor jack to push the lower control arm back into place where you are able to reinstall the bolt attaching it to the hub. Ensure you torque the bolt down to factory specifications - 57-75 ft/lbs After the left and right side springs are installed you can now reinstall your swaybar by reinstalling the nuts and torquing them down properly - 33-44 ft/lbs ![]() ![]() ![]() 3) Normally you would be done with the installation at the last step and ready for an alignment but if you are removing coilovers like myself then you will still need to remove the rear coilovers and reinstall your factory struts. To remove the rear struts you'll need to remove the lower bolt and the 2 upper nuts and you can simply pull it out of place. ![]() ![]() ![]() 4) Grab your factory strut and install it by reinstalling the 2 upper 12mm nuts and 1 lower 17mm bolt. ![]() ![]() Don't forget to torque the upper nuts down to the proper specification - 17-20 ft/lbs ![]() And also torque the lower bolt down properly - 59-77 ft/lbs ![]() 5) You are now finished with the rear Eibach spring installation. ![]() ![]() Thanks, Tanner |
| The Following 23 Users Say Thank You to RallySportDirect For This Useful Post: | 3wheeln (04-02-2015), Amnesiac (07-27-2014), aromig (05-17-2015), Castillo817 (07-23-2015), CWP_MS3 (12-18-2013), dp3 (11-24-2017), emag remrofni (12-27-2013), Gixxer2k4 (07-28-2014), mbc4934 (12-29-2013), motoman (06-15-2014), Murcielago311 (02-11-2014), MZRSPEED (01-09-2014), necrophrenic (05-20-2018), OSN (12-09-2014), redvine (07-09-2014), Reggaeboy143 (08-27-2014), roguemazda (01-04-2017), tec_41 (01-25-2016), thehead (12-15-2013), TheProduct86 (04-21-2015), Tifosi42 (10-08-2015), TMOtester (09-12-2014), YABBAMZR (12-19-2013) |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score Wow thats a really good write..even has all the torque spec. Thank you
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned |
| The Following User Says Thank You to blackms3_71 For This Useful Post: | RallySportDirect (12-15-2013) |
![]() Join Date: Oct 2013 Location: Tyler, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 272
| Not Ranked : 0 score Thank you for this awesome write up! Will definitly be using this as reference when installing my H&R Springs that I have, along with my JBR Rear Sway!
__________________ 2013 Liquid Silver MazdaSpeed Installed Parts:: HTP 3" SRI, Autotech Internals, CP-e Catless DP, CP-e TMIC, FreekTuned, H&R Springs, JBR RSB, Cobb AP V3, JBR 88 RMM, JBR Battery Box, EGR Delete, various CorkSport styling parts, and other things Not Installed Parts:: JBR Stage 2 OCC Future Parts:: JBR 80 PMM/TSM, Coilovers, and much more [SIGPIC][/SIGPIC] ![]() |
| The Following 2 Users Say Thank You to swsmailman For This Useful Post: | RallySportDirect (12-16-2013), ZTune (05-12-2016) |
![]() Join Date: Dec 2013 Location: kville NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Nice does not look to hard to do thanks!! |
![]() Join Date: Sep 2011 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
| Not Ranked : 0 score Only thing missing is how to get the strut in and out of the lower control arm on the front. It can be a royal pain in the butt sometimes. I use an air hammer with 1" hammer bit to bang them out and then a floor jack to squeeze them back together. Also, on some cars the rear sway bar you need to remove the bushing brackets since the bar won't rotate far enough out of the way but at least you dropped the entire link rather than trying to get the bar off the endlink which never works. Also, it's worth while using some lube on those rubber top hats for the rear suspension to prevent squeaking. And to line up the fronts, you can just match up the two tabs at the top by the bearing with the one bracket that goes into the control arm at the bottom. No need to mark them. Otherwise, one of the best write ups I've ever seen with great pictures.
__________________ - 2010 Mazdaspeed 3 Black Mica - - Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 - - SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace - - CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint - |
| The Following User Says Thank You to someguy For This Useful Post: | RallySportDirect (12-18-2013) |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score Easiest way to get the strut out of the knuckle is to put a small, thin-ish piece of metal (like 2 quarters - if you only use one you'll punch right through it) in the pinch slot and then thread the bolt through backwards to spread it apart. Works like a charm.
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following 2 Users Say Thank You to Nliiitend1 For This Useful Post: | FistPump20fo7 (07-01-2015), RallySportDirect (12-18-2013) |
| Not Ranked : 0 score I've attempted that method a couple times but I find the bolt never threads backwards through the knuckle. Since the head of the bolt is tapered and doesn't pop out the other side when going in the normal way, the threads don't ever seem to be good at that end.
| Not Ranked : 0 score Hmmm. That's unfortunate. ![]() I've never had a problem doing it that way on my car or anyone else's, and we're talking 4 or 5 different cars at this point.
__________________ - 2010 Mazdaspeed 3 Black Mica - - Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 - - SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace - - CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint - | |
| Not Ranked : 0 score Yeah it's probably just rusty threads. All the cars I've done it on were either relatively low mileage at the time, or they'd had the suspension apart early in their lives before...
![]() Join Date: Jun 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score great write up. I would like to see the after pics of the ride height as well. |
| The Following User Says Thank You to smaeda For This Useful Post: | RallySportDirect (12-18-2013) |
| The Following User Says Thank You to RallySportDirect For This Useful Post: | someguy (12-19-2013) |
![]() Join Date: Apr 2009 Location: La Porte, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score Get a chance to get some pics yet? |
(Thread Starter) | Not Ranked : 0 score I am so sorry it's taking so long. The weather has been so crappy out here and so cold I haven't had a chance to wash the car to get pictures. But I am still working on it and will get them done asap. Thanks! Tanner |
![]() Join Date: Aug 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28
| Not Ranked : 0 score beautiful write up! but my only question is why go from coils to springs? |
(Thread Starter) | Not Ranked : 0 score The only reason I went from coilovers to springs was to try to keep the coilovers in good condition by not exposing them to the winter months. There is so much garage they put on the roads out here during winter that I don't feel bad exposing the stock struts and a set of lowering springs to all of it. |
| The Following User Says Thank You to jgarmo For This Useful Post: | RallySportDirect (01-09-2014) |
| Not Ranked : 0 score That's why I have stainless steel coilovers. Fuck swapping that shit twice a year.
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | RallySportDirect (01-09-2014) |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score I'm still curious to see pics. I'm looking for a 1" or *lesser* drop in the front, retaining OEM springs in the rear. These claim 1", which should still allow for 26" slicks, which is my intent.
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
| Not Ranked : 0 score Quick question: why are the tighter coils at the top when installing these?
This was just apart of the instructions from the Eibach kit. Everything was fine afterwards. Kind regards, Jeff | |
| The Following User Says Thank You to RallySportDirect For This Useful Post: | btstarcher (07-28-2014) |
| Not Ranked : 0 score Just curious because I installed my Swift springs using these instructions, assuming they would be similar, and found out later that they require the tighter coils at the bottom.
![]() | | #24 | ![]() |
![]() Join Date: Jul 2009 Location: Romania
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score All right...I am a bit late to the party, but I'll try my luck, nonetheless. I installed yesterday a Bilstein B12 Pro-Kit that contains the Eibach Pro-Kit springs. Well, the shop installed them, not me in person. Thing is that it has a stupid rubbing noise when turning the wheels at very low speed, but only at about max turn. It can be heard from both sides. Sounds like a submarine While driving I can hear some clunks when going over high bumps but that's all.I suspect the installation went wrong when they positioned the top of the assembly (flange/perch, whatever, I'm really noob with these things). Can anyone in here help me find out how can I see if that is the case? Tomorrow I will go back and they said they'll opend it up in one side and show me. They keep saying that the top of the spring "ends earlier than it should" )) and this means it is not the correct spring for the car. I'm pretty sure they had no idea how to do it correctly and they're just trying to put the blame on me or something.Seen the Step 4 of the OP and that made me think they didn't care about that but I don't know how I can prove it. Thanks a lot!
__________________ 2008 True Red Mazda 3MPS 2005 Black Mica Mazda 3GTA |
![]() | | #25 | ![]() |
| Not Ranked : 0 score @himurax13; didn't you have an issue with springs that were too "short?" Clunking at full steering lock.
![]() | | #26 | ![]() |
![]() Join Date: Mar 2012 Location: Erie, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
![]() | | #27 | ![]() |
| Not Ranked : 0 score No, were not rubbing against the fender (or whatever is behind the fender). The sound could be heard even with the car staying still and me turning the wheels close to max. Anyways, found the problem...the Bilstein front shocks have the bumpstops inside so the factory ones should be removed. The mechanics left them installed on the new shocks this resulting in too much pressure onto the top bearing. Removed the bumpstops and problem is solved. Thanks! Awesome thread, btw!
![]() | | #28 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
Cutting of the bumpstops is a great idea but would have absolutely nothing to do with the noises. Perhaps the Strut bearings were not aligned properly during the original install.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
| The Following User Says Thank You to himurax13 For This Useful Post: | btstarcher (09-12-2014) |
![]() | | #29 | ![]() |
| Banned ![]() Join Date: Mar 2015 Location: NE Ohio
Rep Power: 0 ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score Great write up! Plan on ordering these this weekend. |
| The Following User Says Thank You to AManWithNoName For This Useful Post: | OverBoosted (03-21-2015) |
![]() | | #30 | ![]() |
![]() Join Date: Mar 2012 Location: Grayson, Ga
Rep Power: 751 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,729
| Not Ranked : 0 score Thanks for the write up. Installed these today with some koni's love them.
__________________ |
![]() | | #31 | ![]() |
![]() Join Date: Apr 2014 Location: Ripley, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 78
Pics? I am about to do the same combo.
__________________ (SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc. 2017 Mazda CX-3 Meteor Gray | |
![]() | | #32 | ![]() |
| Not Ranked : 0 score ![]()
__________________ Last edited by OverBoosted; 03-30-2015 at 08:45 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to OverBoosted For This Useful Post: | JgamB (03-30-2015) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Thanks for the pics @OverBoosted; I'm also still considering these springs and that looks like a very modest drop in the front. (which is what I'm looking for)
![]() | | #34 | ![]() |
| Not Ranked : 0 score I love the drop of these springs. I previously had the H&R springs and they were too low for my liking. They ride very nice as well, with the Koni Str.T struts my wife will even ride in the car now.
![]() | | #35 | ![]() |
![]() Join Date: Oct 2013 Location: Ponder, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 454
__________________ Current 2017 Ford Fusion Sport - TT AWD V6 Upgraded LED lighting, Steeda Oil Catch Catch SOLD 2012 LSM Tech - 11/17/17 | |
| The Following User Says Thank You to El Beaner For This Useful Post: | btstarcher (03-31-2015) |
![]() | | #36 | ![]() |
![]() Join Date: Mar 2015 Location: Northern Virginia (Fairfax)
Rep Power: 0 ![]() ![]() Thanks: 2
| Not Ranked : 0 score What a great how to! Good job man!
__________________ Do you realize how high I was when I said that? |
![]() | | #37 | ![]() |
![]() Join Date: Jun 2012 Location: Houston, Tx
Rep Power: 0 ![]() ![]() ![]() Thanks: 2
Groaned at 14 Times in 2 Posts
| Not Ranked : 0 score Ordered my eibach pro kit with Kobi yellows for my gen 1. Sucks I waited this long (had car since 08) to upgrade the suspension. This how to is based on the gen 2 but the suspension look the same. Safe to say torque specs the same for gen 1 and 2 for suspensions? |
![]() | | #38 | ![]() |
| Not Ranked : 0 score I am running the Eibach's with STR.T Koni's as well and love it. Work great with the Progress RSB.
![]() | | #39 | ![]() |
| Not Ranked : 0 score Yes, first and second gen's are essentially the same. The spring rates and damping are slightly different with the OEM components between generations but it all goes together the same.
![]() | | #40 | ![]() |
| Not Ranked : 0 score what about the 3 strut mount bolts to the chasis.. shop manual says 20 ft/lbs max. Just curious cause I HAVE snapped 1 of those bolts before but this was before i actually owned a torque wrench lol. Last edited by lreyes66; 01-07-2017 at 10:17 AM. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/how-install-eibach-pro-kit-lowering-springs-160997/ | ||||
| Sprezyny Eibach Pro-Kit - prawidlowy monta? w Civic VII | This thread | Refback | 09-08-2015 10:50 AM | |
| Koni/Bilstein Shocks and Springs Group Buy! - Page 3 | This thread | Pingback | 08-19-2014 07:05 AM | |
| H & R Lowering Springs vs. Eibach Pro Kit | manofhonor24 | MazdaSpeed 3/6 - Suspension & Brakes | 18 | 12-15-2009 02:32 PM |
| Eibach pro kit lowering springs, what else should I get? | marcusdigi | MazdaSpeed 3/6 - Suspension & Brakes | 1 | 05-20-2009 06:40 AM |
