> 2010 MS3 - How-To's
Like Tree5Likes
  • 4 Post By [R]usty
  • 1 Post By Haltech
 Old 05-22-2013, 11:24 AM   #1
[R]usty's Avatar
Posts: 2,204   (View Stats)
Default How to Install HPFP Internals 1080p HD Video
Hello everyone. I thought I would make a video of the install of my Autotech internals. This video was created to help guide others who are seeking to do the same modifications.
Video is a good guide but not perfect. This is something quick and dirty that I threw together to help people out. If you find something wrong with it (I'm sure some of you will) please let me know and I'll try to make a correction asap. If I didn't call something by it proper name or I was mumbling through something please don't bug me about it I was exhausted. This video was done late at night after a long day at work...
FYI:
Everything you see in the video is all I did for my install and everything is working perfectly. I've monitored my pressures every day since and it's holding like a champ (1780-1850psi).
Sorry for the length I wanted to be as detailed as possible so any person who want to do it can. Also, excuse the ads.
Update 12/27/2013 7000 miles later:
I have not touched these since they went in and they still perform the same way they did when new. I've followed the same guide with 3 separate sets of Autotechs and all work perfect.
The Following 30 Users Say Thank You to [R]usty For This Useful Post:
adrager622 (05-22-2013), Bap (06-10-2013), BigO (05-22-2013), biscuit003 (06-05-2013), dark_MS3 (10-04-2013), Dark_Signal (06-12-2013), Drive By Fire (02-25-2015), dsb_chicago (06-06-2013), GabbyChaves (12-25-2013), galens47 (05-22-2013), GARRETHEXTREME (10-24-2013), KiwiFlavor (03-18-2014), kmpeeps (08-01-2014), kolosok17 (12-27-2013), L3THAL6 (06-05-2013), mike w (05-22-2013), Miltron (09-17-2014), mrmonk7663 (06-05-2013), NCZ13 (06-06-2013), nighthawk358 (06-06-2013), nycMS3 (06-05-2013), omgvance (12-26-2013), Playaj (06-05-2013), Roddiy (06-06-2013), SkiddishNympho (06-05-2013), span (07-28-2013), speed3okie (12-31-2013), Spirit-RE (12-26-2013), XxSmarTz (12-26-2013), Z32_MS3 (02-15-2014)
The Following User Says NO Thank You to [R]usty For This Un-useful Post:
slowsp33d (06-27-2013)
 Old 05-22-2013, 11:31 AM   #2
Im sure this will help others.. Im moving this to the how-to section
citopz likes this.
nycMS3 (06-06-2013)
 Old 05-22-2013, 11:33 AM   #3
kpacker51's Avatar
Posts: 1,522   (View Stats)
kpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the world
Groans: 59
@Steve6;
-Abraham Lincoln
kpacker51 is offline   Reply With Quote
The Following User Says Thank You to kpacker51 For This Useful Post:
Steve6 (05-23-2013)
 Old 05-22-2013, 11:41 AM   #4
[R]usty's Avatar
Cool thanks!
 Old 05-22-2013, 01:26 PM   #5
JDMJOSH's Avatar
Posts: 642   (View Stats)
JDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the worldJDMJOSH is the leader of the world
Groaned at 8 Times in 5 Posts
Interesting technique, you did it without removing the battery or the intake!
JBR 3.0" WP // CS Racepipe // UR CBE // CS TMIC // CS SS Plate + Bushings // Autotechs // NGK's // Damond Oil Restrictor Bolt // Forge v2 // JBR RMM 88 // JBR .250 RSB // CS Springs/Struts // SPC Camber Arms //
JDMJOSH is offline   Reply With Quote
 Old 05-22-2013, 01:38 PM   #6
[R]usty's Avatar
Yeah was kind of tough getting that bolt off at first but it got easier.
 Old 06-05-2013, 08:57 PM   #7
biscuit003's Avatar
Posts: 83   (View Stats)
biscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond reputebiscuit003 has a reputation beyond repute
Thanks to the OP. One thing that I noticed on my 2013 pu is that there were two fuses labeled fuel pump, the engine did not want to run out of fuel until after I pulled the second one.
biscuit003 is offline   Reply With Quote
 Old 06-05-2013, 09:34 PM   #8
gigliotti175's Avatar
Posts: 750   (View Stats)
gigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the worldgigliotti175 is the leader of the world
Groaned at 25 Times in 15 Posts
You sound like the guy off Superbad. Not Jonah. The other guy. Great how-to though!!
gigliotti175 is offline   Reply With Quote
The Following User Says Thank You to gigliotti175 For This Useful Post:
nycMS3 (06-05-2013)
 Old 06-05-2013, 09:46 PM   #9
JgamB's Avatar
Posts: 2,566   (View Stats)
This might seem obvious, but for push button start - after you've re-installed the pump, push your start button twice (for accessory mode) with your foot on the gas and *off* the clutch. Tap it again to shut it off. Repeat twice. Start normally.
@rustysurfsa;'s video was the 3rd I've watched and my ass was still puckered while putting it back together (mostly due to the cam follower putting pressure on the spring and making alignment a bit feisty), but it really isn't that bad.
Thanks for the vid!
whtlitnin1 (02-21-2016)
 Old 06-05-2013, 11:47 PM   #10
[R]usty's Avatar
Hmmm... interesting. Never heard that before. I think i was just really tired, I filmed this late at night and after a very long day at work. Thanks for watching!
 Old 06-06-2013, 02:15 AM   #11
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
If you have an aftermarket tip and a stubby 17mm and 19mm wrench, you don't have to.
I found out that pulling the fuses and letting the car run out of gas caused more fuel to spray out when I disconnected the the 2 fuel lines. I found that leaving that shit alone causes little to no fuel to pour out.
Pickles Tune in progress
[R]usty (06-06-2013)
 Old 06-06-2013, 07:54 AM   #12
JDMJOSH's Avatar
Yes, I didn't pull any fuses at all or let the car die when I did my internals. When we pulled the fuel lines off, not a single drop of fuel was spilled. Maybe because the car was cold and hadn't been started in a day or so?
 Old 06-06-2013, 09:47 AM   #13
himurax13's Avatar
Groans: 255
I did that to cars that just pulled into my garage with a hot engine, little to no fuel spilled.
 Old 06-12-2013, 02:19 PM   #14
Dark_Signal's Avatar
Posts: 245   (View Stats)
Dark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the worldDark_Signal is the leader of the world
That's good to know.
Dark_Signal is offline   Reply With Quote
 Old 12-25-2013, 03:20 PM   #15
Alexander's Avatar
Posts: 841   (View Stats)
Alexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the world
Groaned at 43 Times in 16 Posts
just a question, is the 100 mile break in necessary? I remember reading a thread on here and people were saying once their engine was warmed up they were hauling ass and going wot right off the bat. that being said i can understand why a break in would be necessary. im just curious cause i'm going to be doing this install this weekend
2011 Mazdaspeed 3
Cobb v3 AP | Autotech CDFP | JBR Sri | JBR Balance Shaft Delete | JBR Rear Sway Bar | JBR 88 duro RMM | M2 Testpipe | Corksport Tip | Corksport Short Shifter | Corksport SSP | Corksport Shifter Bushings | Cobb Counterweight | H&R Lowering Springs | Joseph Koni Shocks/Struts | SPC Rear Camber Arms
Alexander is offline   Reply With Quote
 Old 12-25-2013, 03:50 PM   #16
moosehead's Avatar
Posts: 72   (View Stats)
moosehead has much to be proud ofmoosehead has much to be proud ofmoosehead has much to be proud ofmoosehead has much to be proud ofmoosehead has much to be proud ofmoosehead has much to be proud ofmoosehead has much to be proud ofmoosehead has much to be proud of
thanks for the video. If I keep her I'll be putting it to use.
moosehead is offline   Reply With Quote
The Following User Says NO Thank You to moosehead For This Un-useful Post:
Agent_Orange (12-25-2013)
 Old 12-25-2013, 04:05 PM   #17
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
I don't believe it's necessary. I installed mine, started up and idled for a few minutes while monitoring pressure and checking for leaks, drove around for about 10 minutes at partial throttle, then did several WOT pulls. Given how fast a CDFP cycles it gets used to it's home pretty quickly.
 Old 12-25-2013, 10:14 PM   #18
hihosilver's Avatar
Posts: 136   (View Stats)
hihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the worldhihosilver is the leader of the world
As stated above, not really. It's more to make sure that the internals are installed properly and that everything is in good working order before you start beating on it.
2012 Black MS3
CS SRI+TIP//CS Race RMM//Cobb AP (self-tune)//Autotech HPFP Internals//Catless UR Testpipe//GFB Respons//DDM HIDs//Prosport Halo Boost Gauge
Up next: Upgraded TMIC/FMIC, RichTune, NGK 1 Step Colder Plugs, other shit
hihosilver is offline   Reply With Quote
The Following User Says Thank You to hihosilver For This Useful Post:
[R]usty (12-26-2013)
 Old 12-26-2013, 09:28 AM   #19
mzr0818's Avatar
Groans: 221
Great vid. The only thing I would caution is an impact to remove. The electric would be better than air but still the threads are delicate. and easy to booger up.
EMWNM 2013
2008 mazdaspeed 3 true red
Tuned by Nishan
 Old 12-26-2013, 10:08 PM   #20
hihosilver's Avatar
Definitely agree with this. And sometimes the bolt isn't insanely hard to take off like it is for some people. If you don't have a breaker bar, at least take your longest ratchet to it and see if it will come off before you resort to impact tools. When I did mine, I took that bitch off with a standard 10 inch long ratchet.
2012 Black MS3
mzr0818 (12-27-2013)
 Old 12-27-2013, 12:11 PM   #21
[R]usty's Avatar
No, but you should always be cautious. I always make sure stuff works before I beat it up.
@hihosilver; @mzr0818;
I can see how an impact tool could hurt the threading but the Makita I was using is very weak. I think max torque on a full battery (probably half battery in the video) is 100 ft lbs. I've used it to change out 4 different sets of internals with no damage to speak of. If it were air or something a little more beefy I would have used a breaker bar instead but I know my Makita is generally more delicate with nuts and blots.
2010 Mazdaspeed3 w/tech
hihosilver (12-27-2013)
 Old 12-27-2013, 12:25 PM   #22
mzr0818's Avatar
Groans: 221
I used an air impact once and pulled the threads right out. Stainless steal will bind with an impact sometimes. Later I would 1 bump the impact and then take it out by hand.
EMWNM 2013
Tuned by Nishan
 Old 12-27-2013, 12:30 PM   #23
kolosok17's Avatar
Posts: 1,104   (View Stats)
kolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the worldkolosok17 is the leader of the world
Groans: 47
This video greatly helped me with my install on Monday. Thanks!
EDIT: I also used a 10-inch ratchet with a deep socket and the assembly came right out.
2012 CWP Non-Tech MS3
JBR SSB, Mazda Rear Bumper Guards, JBR Mud Flaps, JBR 88a RMM, Mazda All-Weather Floor Mats,
COBB AP V2B, JBR RSB with Tru-Torsion brackets, Autotech Internals, CorkSport SRI+TIP, JBR Stage 2 OCC,
Mazda Rear Cargo Tray, Stratified S-OTS+ Stage 1 Map, NATOR NorCal Sticker
kolosok17 is offline   Reply With Quote
The Following User Says Thank You to kolosok17 For This Useful Post:
[R]usty (12-27-2013)
 Old 02-25-2014, 08:25 AM   #24
nrankin01's Avatar
Posts: 1,782   (View Stats)
nrankin01 is the leader of the worldnrankin01 is the leader of the worldnrankin01 is the leader of the worldnrankin01 is the leader of the worldnrankin01 is the leader of the worldnrankin01 is the leader of the worldnrankin01 is the leader of the worldnrankin01 is the leader of the worldnrankin01 is the leader of the worldnrankin01 is the leader of the worldnrankin01 is the leader of the world
Groaned at 6 Times in 3 Posts
@Skierdood;
Sent while snappin' necks and cashin' checks
*JBR RMM88
*JBR PMM
*AUTOTECH HPFP
*CP-E CATTED DP
*SWIFT SPRINGS
*WhiteZilla GRILL
STOCKING OUT
nrankin01 is offline   Reply With Quote
 Old 10-11-2016, 12:14 PM   #25
SPEED3STEVEN's Avatar
Posts: 6   (View Stats)
SPEED3STEVEN will become famous soon enough
I used this video 2 days ago for my install. So far everything has been running perfectly! Next mod is going to be UR downpipe.
SPEED3STEVEN is offline   Reply With Quote
The Following User Says Thank You to SPEED3STEVEN For This Useful Post:
WetzMS3 (10-11-2016)
logs after hpfp internals install Harry Warden MazdaSpeed 3/6 - ECU Computer Tuning 0 09-05-2011 05:11 PM
Page generated in 0.46891 seconds with 36 queries
