> 2010 MS3 - How-To's
Like Tree18Likes
 Old 06-06-2012, 07:02 PM   #41
Gringo East's Avatar
Posts: 198   (View Stats)
Gringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the world
Originally Posted by JTMS3 View Post
ok update... volume & station change toggles as well as the "mode" button do not work on the steering wheel but everything else does. All wires are secure, soldered & heatshrunk and the switch works as described by OP (well except for turning off the car to turn SWAS on).
Not a big deal but anyone have any ideas why this would be?
Any updates on these issues or do you just live with it?
I notice someone later on posted about cutting the yellow wire anyone know if this would work on gen 2 to eliminate the above problems
I pick up a soldering iron a few weeks and looking to do this soon.
Gringo East is offline   Reply With Quote
 Old 06-06-2012, 07:13 PM   #42
nindoja's Avatar
Posts: 2,395   (View Stats)
I don't think cutting the yellow wire will help with that. I believe the yellow wire is the power wire on gen1s, so you should cut the power wire for the gen2 sensor (blue).
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
Gringo East (06-06-2012)
 Old 06-06-2012, 08:04 PM   #43
aggierandy's Avatar
Posts: 2,241   (View Stats)
aggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the world
Groaned at 18 Times in 14 Posts
Originally Posted by topset View Post
nice write up. im going to seek out an oem mazda switch and add it to the cluster that the AFS ans TCS switches sit in.
Any follow up on this?
Sent from my DROIDX
2010 MS3 Mica Black Tech
Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals
CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch
aggierandy is offline   Reply With Quote
 Old 06-07-2012, 06:41 AM   #44
Mase's Avatar
Posts: 1,282   (View Stats)
Mase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the world
Groans: 143
Groaned at 14 Times in 14 Posts
This guide was written for a Gen 2. This issue was the only person thus far that has reported any issue with the walkthrough. Just my .02
2014 Mazda 6 Grand Touring. Bone stock...
Old car: 2011 Speed 3 /w Tech Pkg. Cobb AP, CPE DP & CBE, JBR Whale Penis Intake, SSP, Motor Mount Trio, and Heavy Shift Knob /w silver vein!, Autotech internals, KSport Konrol Pro Coilovers, Corksport Interior LED's, LED Foglights and LED Rear Bumper Lights. Freek Tuned 50/50 e85
Mase is offline   Reply With Quote
The Following User Says Thank You to Mase For This Useful Post:
Gringo East (06-07-2012)
 Old 06-07-2012, 06:54 AM   #45
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
Hell, I used the walk though for the genone, so I would say this is a very good walkthough
2008 MS3 gt
470hp/463tq on GT35r at 29psi
burn813 is offline   Reply With Quote
The Following User Says Thank You to burn813 For This Useful Post:
Mase (06-07-2012)
 Old 07-08-2012, 02:29 PM   #46
Flow's Avatar
Posts: 3   (View Stats)
Flow is an unknown quantity at this point
Does this just turn off the SWAS or can you also use it to deactivate the DSC?
Do all the warning lights go off on once you restart the engine with SWAS activated or do you have to delete any errors in the ECU?
Nice trick, I'm probably gonna have a go at it too soon.
Flow is offline   Reply With Quote
 Old 07-08-2012, 04:43 PM   #47
lulz @Raider
burn813's Avatar
From what I understand it disables both swas and dsc...... And yes you will get a code and no you can't delete the code.... That is part of the reason I chose to make a swas switch...... Then I can selectively disable it
2008 MS3 gt
Mase (07-09-2012)
 Old 07-08-2012, 11:48 PM   #48
Above ^^^^^
Plus, after flipping the switch back to the ON mode the steering wheel icon on the dash will go out, but the traction control won't reset for about a mile or two of driving than that light will go out and your DSC will be fully operational again.
No one mention this and when I finished installing I thought I did something wrong and redid it, to find out it was normal..... (this may or may not be my car specific its a 2011 no tech)
The Following User Says Thank You to Gringo East For This Useful Post:
Mase (07-09-2012)
 Old 07-09-2012, 07:05 AM   #49
Mase's Avatar
Groans: 143
Just an fyi...once you turn it back on the code will remain in ECU. However, you can clear it with AP and it wont return until you disable SWAS again.
 Old 07-09-2012, 06:27 PM   #50
lulz @Raider
burn813's Avatar
Or when you restart the car and reenable it.... No codes
2008 MS3 gt
Mase (07-09-2012)
 Old 07-14-2012, 07:01 AM   #51
Flow's Avatar
Ok, thanks guys.
I'm gonna have to give that a try some time soon.
I've been looking for some way to switch off the dsc for ages!!!
 Old 08-04-2012, 03:48 AM   #52
Sweetsandman's Avatar
Posts: 334   (View Stats)
Sweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the worldSweetsandman is the leader of the world
Sub'd
Sent from my DROID BIONIC using Tapatalk 2
'08 Cobalt SS - 334whp- SOLD
'09 WRX - Stage 1 - SOLD
'12 Mazdaspeed3
Sweetsandman is offline   Reply With Quote
The Following User Says Thank You to Sweetsandman For This Useful Post:
Mase (08-04-2012)
 Old 08-19-2012, 02:58 PM   #53
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
@Mase you mentioned you got the lights on your tech pack. Are you suggesting you wont get all the lights if you don't have tech? I need to get this done, very helpful write-up.
What kind of difference in handling have you felt with the SWAS off?
Mase (08-24-2012)
 Old 08-24-2012, 07:42 AM   #54
Mase's Avatar
Groans: 143
Been on vaca...sorry for the slow response. I honestly don't know what lights the Gen2 speed 3 has with or without the tech pkg. In either scenario I am confident you will have a christmas tree of lights if you disable swas. The difference is pretty big when turning under heavy power. With SWAS on you cannot accelerate hard through a turn...
 Old 03-14-2013, 12:15 PM   #55
Todd98SE's Avatar
Posts: 1,077   (View Stats)
Finally installed a SWAS switch in my Gen2 last night. Light blue wire worked as instructed but I'm wondering if we can find the actual SWAS signal wire instead? If we can keep power we wont have any of the power steering, steering wheel radio control, etc. problems that come with cutting power. I'm assuming by toggling the signal wire the car would just assume the wheel is always straight?
I might try using a multimeter to measure voltage changes across the wires in that harness as I'm turning the wheel and see what I find.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline   Reply With Quote
The Following User Says Thank You to Todd98SE For This Useful Post:
Mase (03-14-2013)
 Old 03-14-2013, 12:16 PM   #56
Mase's Avatar
Groans: 143
Let me know what you come up with. Might be difficult as I believe it only begins signaling over certain speed.
 Old 03-14-2013, 12:18 PM   #57
Todd98SE's Avatar
Ah that would suck, but thanks for the tip.
www.MOTOIQ.com
Beater Titan
 Old 03-19-2013, 05:32 PM   #58
AustinK's Avatar
Posts: 175   (View Stats)
AustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the worldAustinK is the leader of the world
Maybe a label maker to properly label On=Normal off=Vtec just kicked in yo
AustinK is offline   Reply With Quote
The Following User Says Thank You to AustinK For This Useful Post:
Todd98SE (03-19-2013)
 Old 03-20-2013, 06:34 AM   #59
Mase's Avatar
Groans: 143
Shit...yeah...let me add that quick
 Old 03-20-2013, 11:28 AM   #60
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Not sure if this helps at all, this information is correct for a 2011 MS3, not sure if others will vary. To print just print in landscape instead of portrait.
The Following 4 Users Say Thank You to El_Diablo For This Useful Post:
ganque (03-20-2013), ibcrusn (10-13-2013), Mase (03-20-2013), Twofer (04-04-2013)
 Old 03-20-2013, 11:32 AM   #61
El_Diablo's Avatar
Groans: 769
Looks like by cutting the blue wire you guys are actually killing the center postition of the switch. If you can regulate 0.25-0.75 to the purple, green & yellow you should be good.
Mase (03-20-2013)
 Old 03-21-2013, 07:33 AM   #62
El_Diablo's Avatar
Groans: 769
I was thinking that we could pull from the 2D (pink) line, however, seeing as how its 1v or less I'm worried it may not be consistant enough. If you could pull 0.25v from that 1v or less you would be good unless it drops below 0.5v at any time. in which case your output would be out of spec.
Can anyone test to verify that the 2D (pink) wire stays between .5v-1v at all times?
 Old 04-04-2013, 02:06 PM   #63
Flight_SkoolSpeed's Avatar
Posts: 44   (View Stats)
Flight_SkoolSpeed is a glorious beacon of lightFlight_SkoolSpeed is a glorious beacon of lightFlight_SkoolSpeed is a glorious beacon of lightFlight_SkoolSpeed is a glorious beacon of lightFlight_SkoolSpeed is a glorious beacon of lightFlight_SkoolSpeed is a glorious beacon of light
So I was pretty excited to follow this guide, but then I noticed a difference..
I don't know if this was pointed out but I have a 2010 genpu with no tech package and cutting the light blue wire does not disable it.
Actually none of the blue wires disable it, does anyone remember if there is a How-To for non-tech genpus?
*Edit, nevermind, I realized I ended up cutting the wrong clip set -_- dummy me.
Last edited by Flight_SkoolSpeed; 04-04-2013 at 05:56 PM. Reason: i cut the wrong clip set
Flight_SkoolSpeed is offline   Reply With Quote
The Following User Says NO Thank You to Flight_SkoolSpeed For This Un-useful Post:
Mase (04-05-2013)
 Old 04-04-2013, 05:53 PM   #64
Ray Danger 2020's Avatar
Posts: 768   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
I just did this literally just now in my 2012. First off, my model year...the wire's white (actually none of the wires are the same color as the ones in your picture). Second, I have big, clumsy-ass ham hands so I had a hell of a time with that wire initially...lol. Also, you apparently have to clear the DTC code every time you hit the switch. A problem, no. Annoying, yes.
Update: Got the whole thing back together and the code kept popping up over and over. Guess what.....switch fell the fuck apart. So I had to spend an extra hour undoing all the work I just did because I don't have another switch to put in there. FML.
Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11
Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS
Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS)
K04 POWER FIGURES
277HP/325TQ SixTuned On 93
314HP/356TQ Rfinkle2 Tuned With 33% Corn
S360 POWER FIGURES
365HP/356TQ Purple Drank Tuned ON 93
421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX
NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING
Ray Danger 2020 is offline   Reply With Quote
The Following User Says Thank You to Ray Danger 2020 For This Useful Post:
Mase (04-05-2013)
 Old 08-16-2013, 01:05 PM   #65
pingaboo's Avatar
Posts: 188   (View Stats)
pingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the world
Groaned at 30 Times in 4 Posts
Has anyone done this with a rocker switch that has LED? This would have 3 prong instead of 2. I'm trying to figure out the wiring.
I eat rice for breakfast
pingaboo is offline   Reply With Quote
 Old 08-16-2013, 01:07 PM   #66
lulz @Raider
burn813's Avatar
I do, wire the two leads to the wire coming from the cars harness, wire the other to the line off the sensor
2008 MS3 gt
The Following 2 Users Say Thank You to burn813 For This Useful Post:
Mase (08-19-2013), pingaboo (08-16-2013)
 Old 08-16-2013, 01:16 PM   #67
pingaboo's Avatar
Not sure I understand. Does the switch get power from the fuse box?
 Old 08-16-2013, 01:28 PM   #68
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
It gets power from Jackie Chan. Just unplug your SWAS until you cut wires and figure it out. No SWAS=like finding out Super Size is coming back to McDonalds
Silver 2007 Speed3 GT
 Old 08-16-2013, 01:29 PM   #69
lulz @Raider
burn813's Avatar
There are two "in" lines and one that goes to the "out", pigtail the two in wires together to the supply line, wire the out to the line that goes to the steering wheel.
2008 MS3 gt
 Old 08-27-2013, 12:56 PM   #70
Brc187's Avatar
Posts: 330   (View Stats)
Brc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the worldBrc187 is the leader of the world
Ou should have power in and power out just like the two prong switch everyone is talking about. The third prong is a ground to make the led work.
Brc187 is offline   Reply With Quote
The Following User Says Thank You to Brc187 For This Useful Post:
pingaboo (08-29-2013)
 Old 08-29-2013, 07:04 AM   #71
pingaboo's Avatar
So I'm not tapping into the fuse box to get power? I keep thinking that I do for the light on the switch. This is much easier now thanks.
 Old 08-29-2013, 07:08 AM   #72
Brc187's Avatar
No fuse panel. You have keyed power running to the swas. Your using that to power the led on the switch. And to get the led to work, like anything, you need a ground, so run a wire down along side the column or the harness to something metal under the dash and ground it.
 Old 09-04-2013, 05:23 PM   #73
Tribalic One's Avatar
Posts: 7   (View Stats)
Tribalic One will become famous soon enough
Hi all, first post here!
I picked up a new to me 2010 MS3 last weekend. The first thing I noticed was the DSC kicking in at very inopportune times. Like turning left out of a gas station to jump into the middle lane, and the car decides to fall on its face! I've been lurking around the forum here for the last few days trying to read up all I could. After everything, it appears the SWAS switch mod is what I need to do. Why Mazda would make the SWAS so damn sensitive is beyond me. Seems unsafe to me!
I've read a lot of conflicting info with pushing/holding DSC, and it appears that does not work on the 2010. My question is if this How To was done on a 2010? If not, what wire should I splice into? I also have the tech package. Has anyone else confirmed the problem with steering wheel controls not working after this mod?
Tribalic One is offline   Reply With Quote
 Old 09-04-2013, 07:23 PM   #74
Mase's Avatar
Groans: 143
Hi! Nice to meet you! Welcome to our humble forums! I am honored you chose my thread as your first post...though if I may recommend some more generalized reading before posting further....This entire thread and guide was built for the Generation 2 (2010-2013) car. My specific car which I did this guide with has the tech package as well. I would recommend reading it from the start and then reposting if you still have any questions
bhamitgeek likes this.
Mauro_Penguin (09-05-2013)
 Old 09-04-2013, 07:46 PM   #75
Thanks for the quick reply!
I see now in your sig that you have a 2011. My biggest concern was that I came across a thread earlier that mentioned the white wire was the power in a 2012, idk if this is ture or not. I wanted to verify the SWAS power was on the blue wire for the 2010. I did find a thread after posting where someone with the tech package issue found they had knocked a fuse loose. I'm not to concerned with that anymore.
The Following User Says Thank You to Tribalic One For This Useful Post:
Mase (09-05-2013)
 Old 09-05-2013, 08:50 AM   #76
El_Diablo's Avatar
Groans: 769
If you donate you gain full access to wiring diagrams as well as the full factory service manual.
The Following 2 Users Say Thank You to El_Diablo For This Useful Post:
Mase (09-05-2013), socaltouch13 (01-27-2014)
 Old 09-07-2013, 01:14 PM   #77
Brennan's Avatar
Posts: 220   (View Stats)
Brennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the world
Done today. Light blue wire, 2010 with tech, steering wheel controls work fine. Thanks for the write-up!
'10 Velocity Red Mica MS3 with Tech
Performance: JBR SSP + Bushings, JBR 80a RMM, Ebay TP, CS SRI + TIP, AP (Self Tooned @18.5 PSI), MD OCC, CP-e HPFP, ITV22s, EGR delete, Forge V1 BPV, Ford Motorcraft Tranny Fluid
Other: DDM 6000k HID Lows, CS LED Fogs, CS Interior/Plate LEDs, RallyArmor Flaps, 34/17 Tint, Heavy Knob, Rockford Fosgate PRIME R500-1 Amp + Alpine SWR1242D 12" Sub + PAC AOEM-MAZ2
Future/wishlist: Driver mod, CS TMIC (on the way!), CS turbo-back, H&R Coilovers
Check out the Gen2 "ECU Computer Tuning" sticky on software that will trim/highlight your AP datalogs!
Brennan is offline   Reply With Quote
The Following 2 Users Say Thank You to Brennan For This Useful Post:
Mase (09-07-2013), Tribalic One (09-07-2013)
 Old 09-07-2013, 03:29 PM   #78
Awesome, thanks for your reply! I have no problem modding my bike on the fly, but the MS3 is my daily driver.
Plan to take care of mine next weekend when I have some time
 Old 09-07-2013, 11:33 PM   #79
Brennan's Avatar
If anyone's curious, I needed a few bucks on amazon to get free shipping and just slung
thisthis
in.
 Old 09-08-2013, 06:06 AM   #80
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
If anyone's curious, I needed a few bucks on amazon to get free shipping and just slung this in.
Awesome. Post up pics of the install. Do you plan on hooking it up near the TCS button?
Pickles Tune in progress
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/how-install-switch-swas-enable-disable-102406/
Club323F ? View topic - Bj DSC This thread Refback 09-21-2015 01:37 PM
Reedy's Engine Rebuild Bonanza! - Page 25 This thread Pingback 09-15-2015 10:03 PM
swas switch ? Mazda MPS Owners Club This thread Refback 03-18-2015 12:43 PM
SWAS switch This thread Refback 05-27-2014 01:20 PM
Mazdaspeed 3 2nd gen !!!!!!!! This thread Refback 11-21-2013 05:41 AM
Elektronik und ECU - [3 BK] DSC, Tracktionskontrolle komplett ausschalten This thread Refback 06-27-2013 02:39 AM
Elektronik und ECU - [3 BL] ESP deaktivieren This thread Refback 02-25-2013 07:23 AM
[3 BK] esp komplett off - Elektronik und ECU - mazda-mps.de This thread Refback 11-02-2012 06:20 AM
[3 BL] ESP deaktivieren - Elektronik und ECU - mazda-mps.de This thread Refback 10-21-2012 08:50 PM
Mazda MPS Owners Club • View topic - Holding back This thread Refback 07-07-2012 04:24 AM
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 05-18-2012 01:04 AM
Random MS3 Chat Thread - Page 79 This thread Refback 05-07-2012 01:34 PM
Time To Go Forged - Page 18 This thread Refback 03-30-2012 08:52 PM
SWAS - DISCONNECT ON A GEN2 Monotonous ONE 2010 MS3 - How-To's 160 10-07-2018 09:17 PM
I need SWAS pictures! mexicant MazdaSpeed 3/6 - ECU Computer Tuning 33 10-26-2016 07:23 PM
SWAS - How to disable Dano MazdaSpeed 3/6 - ECU Computer Tuning 208 06-09-2016 08:21 PM
SWAS on 2010 harryclay 2010 MS3 - ECU Computer Tuning 20 03-21-2016 04:11 PM
swas sensor help! madvillain Mazdaspeed3/6 General Discussion 1 01-20-2009 04:15 PM
Page generated in 0.65403 seconds with 39 queries
