> 2010 MS3 - How-To's
Like Tree18Likes
 Old 09-08-2013, 07:22 AM   #81
08cosmic3's Avatar
Posts: 2,920   (View Stats)
This switch is low profile and looks OEM. It can be purchased at Radio Shack for a couple bucks and has worked well for me. Gen 1
Mase (09-09-2013)
 Old 09-08-2013, 07:30 AM   #82
Tribalic One's Avatar
Posts: 7   (View Stats)
Tribalic One will become famous soon enough
That's one of the switches I'm looking at. Trying to decide if I want a nice "factory" looking switch next to the DSC button, or go the eccentric route and get the locking, bomb bay door switch.
Tribalic One is offline   Reply With Quote
 Old 09-08-2013, 11:28 AM   #83
Brennan's Avatar
Posts: 220   (View Stats)
Brennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the world
Awesome. Post up pics of the install. Do you plan on hooking it up near the TCS button?
Check a few posts up for pics of the install. I mounted it on the underside of the steering wheel on the left side.
'10 Velocity Red Mica MS3 with Tech
Performance: JBR SSP + Bushings, JBR 80a RMM, Ebay TP, CS SRI + TIP, AP (Self Tooned @18.5 PSI), MD OCC, CP-e HPFP, ITV22s, EGR delete, Forge V1 BPV, Ford Motorcraft Tranny Fluid
Other: DDM 6000k HID Lows, CS LED Fogs, CS Interior/Plate LEDs, RallyArmor Flaps, 34/17 Tint, Heavy Knob, Rockford Fosgate PRIME R500-1 Amp + Alpine SWR1242D 12" Sub + PAC AOEM-MAZ2
Future/wishlist: Driver mod, CS TMIC (on the way!), CS turbo-back, H&R Coilovers
Check out the Gen2 "ECU Computer Tuning" sticky on software that will trim/highlight your AP datalogs!
Brennan is offline   Reply With Quote
 Old 09-14-2013, 09:04 PM   #84
ape_ck's Avatar
Posts: 18   (View Stats)
ape_ck will become famous soon enough
Read the entire thread and see only one mention about a power steering problem. I noticed the PS goes dead with quick turns of the wheel. Normal?
ape_ck is offline   Reply With Quote
 Old 09-14-2013, 09:42 PM   #85
pingaboo's Avatar
Posts: 188   (View Stats)
pingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the worldpingaboo is the leader of the world
Groaned at 30 Times in 4 Posts
happens to me too, and mentioned several times in another thread.
I eat rice for breakfast
pingaboo is offline   Reply With Quote
 Old 10-13-2013, 10:24 AM   #86
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
Installed a switch yesterday similar in design to what @08cosmic3; used mounted under the steering column so it was somewhat out of sight if the car goes back to the dealer. I went the unlighted route since the LED would only illuminate when the switch it 'On' which is all the time.
Rather than install the switch inline with the SB (Sky Blue) wire I chose the P (Pink) because it's the ground for the SWAS switch rather than input power. I'm not a Mazda tech and I've never dealt with a steering angle sensor before but as has been mentioned on the Gen1's and some Gen2's the power steering drops off at slow speeds and I figured power going in and possibly going out elsewhere via a different connector for that system would be good to maintain.
That said when it came to the ops check I noted much the same as everyone else but I need to perform some additional checks.
  • When in the 'On' position everything is a-okay
  • If selected 'OFF' prior to starting you get the steering wheel and skid lights and the DSC switch does not function at all.
  • If selected 'OFF' after the car is started the same lights as above come on and the DSC switch has no affect.
  • When switching from the 'OFF' position to 'ON' while running the lights stayed on. (I need to perform and extended ops check to verify because I would expect the skid light to go out)
  • If the DSC switch is 'OFF' prior to switching 'OFF' the SWAS I got the steering wheel and DSC lights and no skid light. (One has to assume traction control isn't operating regardless)
  • In the 'OFF' position I did not experience and drop in power steering performance, mind you I checked it in my garage with a painted floor and on my concrete driveway but all was good.
  • I did not check the various buttons on the steering wheel that might be affected (volume, mode, etc) but I'll check today.
  • On my brief drive to dinner I noted no appreciable difference in performance but with wif and sleeping 7 mon old in the car it was a no-no, will check today.
  • Lastly I have not taken any logs yet.
Pics just for good measure.
Edit.....added pic that @El_Diablo; originally loaded in post #60 to keep all the pertinent info in one location for those interested in adding a switch.
Mauro_Penguin likes this.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
Last edited by ibcrusn; 10-13-2013 at 07:21 PM. Reason: Added pic for wiring diagram
ibcrusn is offline   Reply With Quote
The Following 6 Users Say Thank You to ibcrusn For This Useful Post:
El_Diablo (10-13-2013), Mase (10-13-2013), Mauro_Penguin (10-14-2013), Polish_Eagle (07-12-2014), speedaholic (04-01-2014), triphop631 (02-27-2014)
 Old 10-13-2013, 04:38 PM   #87
ibcrusn's Avatar
Update....
After a day of driving around and trying different configurations I can verify a few things.
  • With SWAS 'OFF' there is no affect on the power steering.
  • Switching the SWAS back 'ON' while driving will not reengage the steering sensor or DSC (wheel spin regardless)
  • Relative to the previous statement to reengage the SWAS and traction control the ignition must be cycled.
  • All steering wheel buttons function normally (caveat....I do not have the Tech package YMMV)
  • Still no logs, maybe when I start on my tune.
'10 VRM MS3
Sir Henry Royce
The Following 4 Users Say Thank You to ibcrusn For This Useful Post:
El_Diablo (10-13-2013), Mase (10-13-2013), Mauro_Penguin (10-14-2013), Quigs (10-14-2013)
 Old 10-14-2013, 09:38 AM   #88
kbz0129's Avatar
Posts: 986   (View Stats)
Got this code short after installing the swas switch. I cleared it last night, just wondering how i triggered it? C1938 - Invalid Steering Wheel Angle Sensor ID
 Old 10-14-2013, 10:57 AM   #89
ibcrusn's Avatar
It's been mentioned in previous posts that the angle sensor will trigger a code. From what I gather because I haven't hooked up my AP the codes will go away when the switch is reset and the car is cycled off and back on. I'll try and verify this week.
'10 VRM MS3
Sir Henry Royce
The Following User Says Thank You to ibcrusn For This Useful Post:
 Old 10-14-2013, 03:14 PM   #90
Quigs's Avatar
Posts: 1,152   (View Stats)
Threw a switch on to a buddies 1st gen today. Findings were similar to what was posted above. We put the switch on the ground so that no other systems should be affected since there was some speculation about steering wheel controls not working and whatnot after tapping in to the power.
For reference, on his 2007 yellow/blue is power, brown is ground, and the other two wires are signal wires.
I'll let @BigO; chime in with the differences with the system deactivated. DSC can still be toggled on and off via the factory switch, but as already stated the ignition needs to be cycled in order to re-activate SWAS.
No engine codes (dash light anyway) showed up while we were testing. Did not have AccessPORT on though, so no idea on the pending code. I will assume that the code is there though, just not enough to throw a light.
2009 Mazdaspeed3
2000 Mazda Miata MX-5
NASA TTE build ongoing
The Following User Says Thank You to Quigs For This Useful Post:
Mauro_Penguin (10-15-2013)
 Old 01-23-2014, 03:30 PM   #91
08cosmic3's Avatar
I only engage SWAS when I'm on the interstate in the rain. Always hated how the car would stumble on hard acceleration so this mod is cheap and a no brainer.
 Old 02-19-2014, 12:34 AM   #92
chochoky86's Avatar
Posts: 34   (View Stats)
chochoky86 will become famous soon enough
After reading this whole thread Im just wondering, I have a 2013 with tech package I read on some post that holdidng the button for 5-10 sec will disable swas and saw some other post that it didnt does anybody know if I will have to install the switch to completely disable swas or just holding the button for 5-10 sec is good enough
Thanks
chochoky86 is offline   Reply With Quote
 Old 02-19-2014, 01:48 AM   #93
JgamB's Avatar
Posts: 2,566   (View Stats)
Thanks
Start car, hold down DSC for an 8 count. Let go. Press it again - nothing should happen, and the traction control light should remain lit until you turn the car off again. This kills DSC and SWAS, verified by AP log and anyone with a clue how their car feels when neutered.
If you've never driven with it off, I'd find a parking lot and relearn the limits of your adhesion while cornering and applying power.
The Following 3 Users Say Thank You to JgamB For This Useful Post:
chochoky86 (02-19-2014), Mauro_Penguin (02-20-2014), Yatta (03-27-2014)
 Old 02-19-2014, 07:16 AM   #94
Monforte88's Avatar
Posts: 324   (View Stats)
Monforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the worldMonforte88 is the leader of the world
does this work for the gen 1 also? Thinking of putting in the switch though.
2007 mazdaspeed 3. SRI\ TIP\ Forge v2\ Auto Tech HPFP\Ebat Catless DP\ Test Pipe\ CP-e Cat back\ 88a RMM \ Shift Plate\ JBR Short throw shifter\ solid shifter bushings\ #Bakerytuned 18PSI.
Monforte88 is offline   Reply With Quote
 Old 02-19-2014, 07:34 AM   #95
Quigs's Avatar
No, this does not work for Gen 1. That's what this thread is for - detailing how to install a switch for those of us not lucky enough to have SWAS be deactivated via factory switch.
2009 Mazdaspeed3
The Following 2 Users Say Thank You to Quigs For This Useful Post:
JgamB (02-19-2014), Mauro_Penguin (02-20-2014)
 Old 02-19-2014, 08:19 AM   #96
chochoky86's Avatar
Ok then Ive been doing it right, thanks a lot I was kind of confused on the 2013 if it needed the switch or not
Sent from my SAMSUNG-SGH-I537 using Tapatalk
 Old 02-27-2014, 05:34 AM   #97
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Originally Posted by ibcrusn View Post
Update....
Any updates?
Pickles Tune in progress
 Old 02-27-2014, 06:24 AM   #98
ibcrusn's Avatar
Any updates?
Not really.....
  • With SWAS 'OFF' there is no affect on the power steering. That's a negative, if you crank the wheel quickly or have to turn left then right quickly while travelling at slow parking lot speeds the pump doesn't keep up. Other than that I notice no difference in normal operation. I don't care enough when I drive to try and figure out a way to fake out the PS pump to increase pressure/flow, might have to look through the W/D ans see if it would be easy on the '10+ cars.
  • Switching the SWAS back 'ON' while driving will not reengage the steering sensor or DSC (wheel spin regardless). No change.
  • Relative to the previous statement to reengage the SWAS and traction control the ignition must be cycled. No change, still requires the switch to be flipped and cycle the ignition.
  • All steering wheel buttons function normally (caveat....I do not have the Tech package YMMV). No new issues.
  • Still no logs, maybe when I start on my tune. I haven't started a tune yet I was waiting on parts, prolly in the next month or two.
'10 VRM MS3
Sir Henry Royce
The Following 3 Users Say Thank You to ibcrusn For This Useful Post:
himurax13 (02-27-2014), Mauro_Penguin (02-27-2014), Quigs (02-27-2014)
 Old 02-28-2014, 02:06 PM   #99
triphop631's Avatar
Posts: 1,191   (View Stats)
triphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the worldtriphop631 is the leader of the world
Groans: 30
So all I have to do is tap into the ground for this?
Sent from my SCH-I545 using Tapatalk
I haz Partz!!!!!!!!!!
triphop631 is offline   Reply With Quote
 Old 02-28-2014, 04:33 PM   #100
bigdog's Avatar
Posts: 441   (View Stats)
bigdog is the leader of the worldbigdog is the leader of the worldbigdog is the leader of the worldbigdog is the leader of the worldbigdog is the leader of the worldbigdog is the leader of the worldbigdog is the leader of the worldbigdog is the leader of the worldbigdog is the leader of the worldbigdog is the leader of the worldbigdog is the leader of the world
Triphop, it would appear that behavior is the same if you tap into the feed or the ground.
2011 MS3:
Cobb SRI, JBR RMM, JBR RSB, CorkSport SSP
bigdog is offline   Reply With Quote
The Following User Says Thank You to bigdog For This Useful Post:
triphop631 (02-28-2014)
 Old 02-28-2014, 05:16 PM   #101
triphop631's Avatar
Groans: 30
Cool, doing this tomorrow.
Sent from my GT-P5210 using Tapatalk
 Old 03-23-2014, 09:05 PM   #102
ABOSWORTH's Avatar
Posts: 467   (View Stats)
I've been using this method for a couple months now on my 2012. Does this method totally disable SWAS on 12 non-tech package as well? I have read through a number of threads and can't really get a definitive answer, though your post is the first I've seen that confirmed with logs.
I was doing an oil change tonight and decided to pull the SWAS connection from under the steering column to see if I could feel a difference between holding the button.
I always hold the button when I start the car so I'd just assume leave it unplugged but I'm thinking I might not pass inspection with the two lights lit up. Not that it's hard to pop the connector back in or wire a switch like the thread indicates. If holding the button truly disables SWAS, I'll probably just go back to doing that.
 Old 03-23-2014, 10:06 PM   #103
JgamB's Avatar
The consensus appears to be cars *built* in 2012 and newer have the same ECU behavior for disabling SWAS with the press and hold method. A dozen or so people contributed to the last thread regarding this question, and it would take a lot more to isolate when the programming changed.
I tested this with several 2nd and 3rd gear hard corners, with all of the 2nd gear underpass u-turn lane runs resulting in roasted tires and hitting boost/timing/WGDC targets as normal, and no anomalies noted for 3rd gear high speed lane change maneuvers and swerving either.
If I insulted anyone by saying you're basically a retard if you can't feel the difference, I apologize. It's very obvious on a corn tuned K04 when you're making full power, not so much on an OTS map.
ABOSWORTH (03-24-2014), kornybun (04-14-2014)
 Old 03-24-2014, 06:30 AM   #104
ABOSWORTH's Avatar
Yeah, I saw people talking about the build date. Mine was built in 2012. I can definitely feel a difference holding the switch as opposed doing nothing but the butt dyno can't tell the difference between SWAS unplugged and the "hold the button down" method. I've got an AP coming today so I will be able to log soon enough.
The Following User Says Thank You to ABOSWORTH For This Useful Post:
Digital_Jedi (03-26-2014)
 Old 03-26-2014, 10:35 AM   #105
Digital_Jedi's Avatar
Posts: 570   (View Stats)
Digital_Jedi is the leader of the worldDigital_Jedi is the leader of the worldDigital_Jedi is the leader of the worldDigital_Jedi is the leader of the worldDigital_Jedi is the leader of the worldDigital_Jedi is the leader of the worldDigital_Jedi is the leader of the worldDigital_Jedi is the leader of the worldDigital_Jedi is the leader of the worldDigital_Jedi is the leader of the worldDigital_Jedi is the leader of the world
@ABOSWORTH; definitely post logs up, it would be very helpful for the 12-13s!
2013 Mazdaspeed: Velocity Red Mica, Tech Package.
CS RMM, TMM insert, SRI,TIP, Autotech Internals, UR Res TP,COBB AP, Forge V1 BPV
CP-E TMIC,JBR boost and recirculation tubes
3-Port Ebcs
Koni yellows and Eibach Springs
3M 35% tint and Clear Bra
FREEKTUNED
Digital_Jedi is offline   Reply With Quote
 Old 03-26-2014, 12:39 PM   #106
ABOSWORTH's Avatar
My AccessPort and internals just came in yesterday. I'll be installing the internals and marrying the AP this weekend so I'll post up some logs soon.
 Old 03-26-2014, 02:25 PM   #107
himurax13's Avatar
Groans: 255
Silly question but can I unplug one of the ABS sensors to get the same effect as pulling the plug in the steering wheel on a 2011 Tech?
 Old 03-27-2014, 07:32 AM   #108
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Groans: 171
Probably not. You'd end up having no ABS, and SWAS still in full effect. I think? It wouldn't have any effect on the boost safe limit when turning, it would just let you wheel spin from lack of ABS speed sensor input.
speeed (03-27-2014)
 Old 03-27-2014, 07:40 AM   #109
ibcrusn's Avatar
^^^ Agreed. At least on my 2010 with SWAS turned off I still have ABS.
'10 VRM MS3
Sir Henry Royce
 Old 03-27-2014, 11:56 AM   #110
himurax13's Avatar
Groans: 255
Well it worked during a dyno day so I doubt the SWAS was in full effect.
I can tell you that on my 2010 the switch killed my SWAS, power steering, traction control, and ABS.
 Old 03-27-2014, 12:08 PM   #111
ibcrusn's Avatar
Do you have the tech package? The ABS part surprises me because I specifically checked that during a snow storm just to see if disabled that system and it didn't.
The other systems have been impacted by disconnecting the SWAS.
'10 VRM MS3
Sir Henry Royce
 Old 03-27-2014, 03:45 PM   #112
Groans: 171
@himurax13; that is surprising to hear. I have a 2012 non tech, just put in a SWAS switch this week. I still need more time to observe what might happen. We did try to put a switch on another local nator members car, his was a 2012 tech package, and he threw an extra code from unplugging the harness. I thought that was interesting also.
Our wiring harness is also different. The wires didn't match what Ibcrusn posted. On both of our 2012 ' s the ground was a brown wire and I think it was the second or third pin in. So who knows if there is any logic difference also?
 Old 03-27-2014, 03:49 PM   #113
himurax13's Avatar
Groans: 255
Yes, I do have the Tech Package.
My brakes lock up when I have the switch on and they don't when I have the switch turned off and cycled.
I wonder if a rheostat or some capacitor can be used instead of an actual switch to fool the SWAS that the steering wheel is neutral at all times.
SLOWHATCH (03-29-2014)
 Old 03-28-2014, 03:35 AM   #114
bigdog's Avatar
Pretty sure this has been talked about before but don't think anyone has tried 'tricking'the sensor. I am curious about this as issue. Your abs isn't working and you don't have an abs light on? Also everyone that is having issues installed a switch on the ground instead of the feed? I do not have this problem. The only irritating part that I get is the lack of the power steering which is very annoying during Autox.
Sent from my GT-N5110 using Tapatalk
2011 MS3:
 Old 03-28-2014, 05:10 AM   #115
himurax13's Avatar
Groans: 255
Originally Posted by SLOWHATCH View Post
Meh, for some reason I thought most switches had 3 pins.
So would I need to run a ground wire? This is the part I was confused about. And thanks, I was able to wire a meth kit but this has me baffled lol.
Well I cut the blue wire like in the original post. I don't get a brake warning light either. If you go deep into the brakes, like when bedding in new pads, you will be able to tell the ABS is simply not working. If you are at highway speeds, it is hard to feel.
 Old 03-31-2014, 05:36 PM   #116
calizoomzoom's Avatar
Posts: 684   (View Stats)
calizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the world
Groans: 47
on my 12 w/ tech i noticed i only had one blue wire and it was iin the middle, so i figured that wasnt it. it also had a white one.. OPs plug didnt have any white wires. But the rest of the wire colors were the same. Mine ended up being the white wire.
Made a switch, put it underthe steering column,no more flashing lights
calizoomzoom is offline   Reply With Quote
The Following 3 Users Say Thank You to calizoomzoom For This Useful Post:
kornybun (04-14-2014), Mase (04-01-2014), Mauro_Penguin (04-01-2014)
 Old 04-01-2014, 07:14 AM   #117
Mase's Avatar
Posts: 1,282   (View Stats)
Mase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the worldMase is the leader of the world
Groans: 143
Groaned at 14 Times in 14 Posts
They must have pulled a switch on us!
2014 Mazda 6 Grand Touring. Bone stock...
Old car: 2011 Speed 3 /w Tech Pkg. Cobb AP, CPE DP & CBE, JBR Whale Penis Intake, SSP, Motor Mount Trio, and Heavy Shift Knob /w silver vein!, Autotech internals, KSport Konrol Pro Coilovers, Corksport Interior LED's, LED Foglights and LED Rear Bumper Lights. Freek Tuned 50/50 e85
Mase is offline   Reply With Quote
The Following 3 Users Say Thank You to Mase For This Useful Post:
calizoomzoom (04-01-2014), himurax13 (04-05-2014), Mauro_Penguin (04-01-2014)
 Old 04-02-2014, 05:04 AM   #118
PoetryInMotion's Avatar
Posts: 171   (View Stats)
PoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond reputePoetryInMotion has a reputation beyond repute
@Mase; Come on man that was terrible
2013 GenPU
PoetryInMotion is offline   Reply With Quote
The Following User Says Thank You to PoetryInMotion For This Useful Post:
Mase (04-02-2014)
 Old 04-04-2014, 08:08 PM   #119
ABOSWORTH's Avatar
I'm set to take some logs tomorrow with SWAS unplugged and the button holding method. Will a second gear pull suffice or should I do first and second?
Current Mods
 Old 04-04-2014, 11:32 PM   #120
JgamB's Avatar
2nd gear for sure - you'll hit redline in 1st within a handful of cells. It was difficult enough to capture in 2nd gear, I should've done it with my 93 tune or an OTS map.
Mauro_Penguin (04-05-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/how-install-switch-swas-enable-disable-102406/
Club323F ? View topic - Bj DSC This thread Refback 09-21-2015 01:37 PM
Reedy's Engine Rebuild Bonanza! - Page 25 This thread Pingback 09-15-2015 10:03 PM
swas switch ? Mazda MPS Owners Club This thread Refback 03-18-2015 12:43 PM
SWAS switch This thread Refback 05-27-2014 01:20 PM
Mazdaspeed 3 2nd gen !!!!!!!! This thread Refback 11-21-2013 05:41 AM
Elektronik und ECU - [3 BK] DSC, Tracktionskontrolle komplett ausschalten This thread Refback 06-27-2013 02:39 AM
Elektronik und ECU - [3 BL] ESP deaktivieren This thread Refback 02-25-2013 07:23 AM
[3 BK] esp komplett off - Elektronik und ECU - mazda-mps.de This thread Refback 11-02-2012 06:20 AM
[3 BL] ESP deaktivieren - Elektronik und ECU - mazda-mps.de This thread Refback 10-21-2012 08:50 PM
Mazda MPS Owners Club • View topic - Holding back This thread Refback 07-07-2012 04:24 AM
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 05-18-2012 01:04 AM
Random MS3 Chat Thread - Page 79 This thread Refback 05-07-2012 01:34 PM
Time To Go Forged - Page 18 This thread Refback 03-30-2012 08:52 PM
SWAS - DISCONNECT ON A GEN2 Monotonous ONE 2010 MS3 - How-To's 160 10-07-2018 09:17 PM
I need SWAS pictures! mexicant MazdaSpeed 3/6 - ECU Computer Tuning 33 10-26-2016 07:23 PM
SWAS - How to disable Dano MazdaSpeed 3/6 - ECU Computer Tuning 208 06-09-2016 08:21 PM
SWAS on 2010 harryclay 2010 MS3 - ECU Computer Tuning 20 03-21-2016 04:11 PM
swas sensor help! madvillain Mazdaspeed3/6 General Discussion 1 01-20-2009 04:15 PM
Page generated in 0.63000 seconds with 40 queries
