![]() | | #161 | ![]() |
![]() Join Date: Apr 2014 Location: Ripley, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 78
| Not Ranked : 0 score
__________________ (SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc. 2017 Mazda CX-3 Meteor Gray |
![]() | | #162 | ![]() |
| Not Ranked : 0 score Well, issue solved I guess. I drove the car today with the switch off and the light cleared itself after driving a little ways. I did not try the factory DSC switch after that because a call came through and I got distracted. I will try that on my way home. We will see.
![]() | | #163 | ![]() |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score Probably a bad connection in there somewhere. Did you solder and heat shrink the joints or just tape them together? I'd expect this problem to return if you didn't do anything to fix it. |
![]() | | #164 | ![]() |
| Not Ranked : 0 score Checked the connections and they seem fine. One the light went out, the DSC switch started working and all was fine. It was just strange. It like there is a lull for the computer to recognize all is back to normal. I am experimenting to see how repeatable it is. If it is random, I will take it all back apart and maybe try a different switch along with re-doing the connections.
![]() | | #165 | ![]() |
![]() Join Date: Jul 2015 Location: Columbia, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score So I'm pretty new to the MS3 world. bought used '13 with tech package. turbo died almost immediately after purchase and so Corksport turbo was installed. I'm still in tuning stages (with Will from Purple Drank who is awesome) but I was honestly feeling unimpressed with all the "upgrades" so far. (intake, fuel pump internals, accessport, colder plugs, and of course the turbo itself). Car was feeling more prone to stumble and fuel-cut. Didn't feel the same smooth powerful feeling as it did when it was stock. Probably due to the added power creating more torque steer events that the computer was constantly intervening. made the car fee LESS powerful except in a straight line in higher gears on the highway. I was considering adding a switch to the pink wire or the sky-blue wire as mentioned in the posts above --but in my 2013 with tech package it appears all I need to do is hold down the stability control button for 8 seconds and voila! car is completely different now and wants to tear the rubber off the tires all the time. I want to thank those who pointed out about the button-holding strategy. simple but amazing. |
| The Following User Says Thank You to brucetopping For This Useful Post: | JgamB (12-15-2015) |
![]() | | #166 | ![]() |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score Once you get tired of depressing the button every time you start the car... KP Technologies Item FM20
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
| The Following User Says Thank You to JgamB For This Useful Post: | brucetopping (12-16-2015) |
![]() | | #167 | ![]() |
| Not Ranked : 0 score I'm intrigued by idea of the KP technologies product. sounds perfect. I feel embarrassed to ask this question: how do I wire it up? is it similar to the walk-thru at the beginning of this thread? from reading the manual that comes with the KP technologies product it says: "1. Black – Ground – Connect this wire to a suitable ground source, at switch if possible. 2.Orange – Switch In/Out – Connect this wire to the (-) output of the switch. 3.Yellow – Ignition Power – Connect this wire to a true ignition signal that reads 12vdc when the key is both in the ‘ON’ and ‘CRANK’ position. This wire can typically be found in the vehicles main ignition harness, near the ignition key cylinder, at the fuse box, or at the brake pedal. Remember to verify with a voltage meter. " (so I think I can handle the ground wire - I just feel intimidated about step 2 and 3 without a picture or walk-through.) |
![]() | | #168 | ![]() |
| Neutral : +1 score
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
| The Following 2 Users Say Thank You to JgamB For This Useful Post: | brucetopping (12-23-2015), SKiZZ (02-09-2016) |
![]() | | #169 | ![]() |
| Not Ranked : 0 score Will from Purple Drank tuning was telling me that "there will be a point where the 8 second button press will not work" once I cross a certain threshold of torque. though if it is still working for you with all the mods in your sig it would seem it should work for my less modded car. hmm. I'm running corksport turbo and supporting bolt ons. |
![]() | | #170 | ![]() |
| Not Ranked : 0 score I guess 390wtq isn't enough, keep trying. And tell Will that Jason said he's a choad swilling clown and I can produce a better tune with my ass after a few Murican light beers.
![]() | | #171 | ![]() |
| Not Ranked : 0 score I'll let him know to watch out for your ass after its had a few light beers... lol |
![]() | | #172 | ![]() |
![]() Join Date: Nov 2011 Location: edgewood md
Rep Power: 2429 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,644
Groans: 391
Groaned at 75 Times in 49 Posts
with love, daddy drank
__________________ moore automitive 4/13/13 515whp 511 tq Mason Dixon Raceway 11.289 @125 1.845 60' Killah Built Powered By Purple Drank | |
| The Following User Says Thank You to Captain KR For This Useful Post: | nindoja (12-23-2015) |
![]() | | #173 | ![]() |
![]() Join Date: Nov 2014 Location: Falls Church
Rep Power: 0 ![]() ![]() Thanks: 3
| Not Ranked : 0 score I was browsing all of the tons of SWAS threads and this one seemed the most detailed for the Gen2. I was wondering if anyone found a way to trick the swas sensor without just disabling everything. I looked at the diagrams on Page 2, and it seems like there are 4 signal wires coming from the Swas itself, do we know which affect power steering and which are used for traction control? If we could isolate the traction one, would it be possible to put a diode between the traction control line and the ground (pink), with a breakdown voltage of .75, preventing the swas from sending a voltage higher than the 'steering wheel centered' voltage?
__________________ 2011 Silver Speed3 JBR RMM | JBR OCC | JBR SRI | JBR Rear Sway Bar | Moog Endlinks Corksport HPFP internals | AP | UR Catted Test Pipe | CBE |
![]() | | #174 | ![]() |
![]() Join Date: Jan 2014 Location: Germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 133
| Not Ranked : 0 score To clarify this: When disabling the SWAS with a switch, does this disable the AFS too on a tech-packaged gen2?
__________________ 2012 Mazdaspeed 3 CS SRI, BNR S1, CS TMIC w/ Boost Tubes, GrimmSpeed EBCS, CS RMM, Stratified tuned, Cobb DP, 3" Catback, H&R coilovers, Tanabe strut & other parts |
![]() | | #175 | ![]() |
![]() Join Date: Oct 2013 Location: Ponder, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 454
__________________ Current 2017 Ford Fusion Sport - TT AWD V6 Upgraded LED lighting, Steeda Oil Catch Catch SOLD 2012 LSM Tech - 11/17/17 | |
![]() | | #176 | ![]() |
![]() Join Date: Sep 2012 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 158
| Not Ranked : 0 score The engineer in me really wants to tap into those lines, figure out what the signals are for 0 degrees steering, then just create an emulator that constantly tells the ECU that the steering is at the neutral point. Unfortunately it's just not a high enough priority to do any part of that. My tune has SWAS disabled sufficiently for track use and that's all I need. If someone happens to know the signals maybe I'll get motivated enough to take it the rest of the way...
__________________ Corksport: SRI & TIP, Strut Tower Brace, Coilovers CP-e: RMM JBR: Rear Sway Bar (with Moog End Links) TWM: Full Replacement Shifter Cobb: AP AutoTech: HPFP Internals Ebay: Test Pipe |
![]() | | #177 | ![]() |
Here is the post regarding that How to: Install a switch for SWAS enable/disable
![]() | | #178 | ![]() |
| Not Ranked : 0 score Oh shit! I missed that when I read through all this previously. Maybe I'll add that to my winter project list. Although if it's a straight DC voltage that's really easy to emulate. But my guess is that it's s square wave with varying duty cycles. That would show up as a DC voltage on a multimeter and would require an oscilloscope to get the actual signal.
![]() | | #179 | ![]() |
![]() Join Date: Jun 2012 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
For me it's now moot because Versa Tuner has a means to disable the torque limiting aspect without messing up the power steering, so for now I leave it switched to normal mode and have zero issues.
__________________ '10 VRM MS3 3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3 Strive for perfection in everything. Take the best that exists and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough. Sir Henry Royce | |
![]() | | #180 | ![]() |
![]() Join Date: Apr 2016 Location: Slc, Ut
Rep Power: 0 ![]() Thanks: 4
| Not Ranked : 0 score I have been debating doing this for a few weeks and finally took the dive today. However, it looks like I have a shit ton more wires on that white plug than others. Is it just the angle I am looking at it compared to others? 2011 speed 3, non tech I believe. I have the little 3 or 4 inch screen with nav but a very basic stereo system. Any help would be appreciated. |
![]() | | #181 | ![]() |
![]() | | #182 | ![]() |
| Not Ranked : 0 score I'm Ok went to do swas switch today and ran into a snafu, I don't have a sky blue wire or a pink wire wtf? Which one do I cut?this is on a 2012 Tech package
__________________ Current 2017 Ford Fusion Sport - TT AWD V6 Upgraded LED lighting, Steeda Oil Catch Catch SOLD 2012 LSM Tech - 11/17/17 Last edited by El Beaner; 01-22-2017 at 02:15 PM. |
![]() | | #183 | ![]() |
Sent from my Pixel XL
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
![]() | | #184 | ![]() |
| Not Ranked : 0 score Have you done this on yours? From reading, the tech package can cause wire colors to be different than standard model?
![]() | | #185 | ![]() |
![]() Join Date: Feb 2018 Location: Burlington, NC
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score Did you ever find out which color wire it was for the 2012 tech package car? I have the same car and would like to know as well. Comparing the plugs with the initial post pictures I would guess the white wire would be the white one but again I'm not sure. |
![]() | | #186 | ![]() |
![]() Join Date: May 2012 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 62
| Not Ranked : 0 score I have the 2012 tech and did this recently. I cut the wire as shown (blue, I think) and lost power steering at slow speeds as well as the ability to connect Bluetooth devices and my headlights don't turn with the car anymore. Also, the switch does nothing so I may have screwed up the connections there. Sent from my Pixel XL using Tapatalk
__________________ 12' black mica w/tech: BNR S4 V2; CM STG 2 WMI; DAMOND TB SPACER; GUARDIAN ANGEL V3; KOZMIC OCC; CP-E SAFE SEALS; DAMOND EGR DELETE; WHITEWIDOW INTAKE GASKET; Cobb AP V3 CP-E Xcel XL SRI; CP-E 4" TIP; CP-E Catted DP; CP-E Cat-back exhaust; CP-E TMIC; Cobb BPV; JBR EBCS; Cobb RMM; CorkSport HPFP internals; JBR turbo hoses; NGK (6510) LTR7IX-11 Iridium IX Spark Plugs; JBR short shifter; JBR Small battery tray; Optima 51r Battery Rice--CorkSport interior lights and carbon fiber hood scoop ETH/METH tune by Stratified in progress |
![]() | | #187 | ![]() |
![]() Join Date: Dec 2017 Location: Idaho
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
| Not Ranked : 0 score I don't think this is a good idea in the first place, but if I were to do this, I would take the extra time and put a switch in to connect all the steering angles to appear at center position. This way you don't get nerfed in a corner, but you also will not get any dash lights... Just my two cents...
__________________ 2011 MS3 Tech - 2008 Jeep Grand Cherokee CRD - 1989 Crown Vic LTD LX - 1985 Lincoln Town Car Signature The key to happiness is owning a car ridiculously slower than your 'fast' car. |
![]() | | #188 | ![]() |
| Not Ranked : 0 score After reading up more on this I think I'm just gonna leave it as is. I read earlier that if you hold the traction control button down for 8 seconds it disables swas and other traction bs. I tried it last night and WOW what a difference! I just wanted that extra bit of power for autocross tomorrow and this button technique will work wonders for sure. |
![]() | | #189 | ![]() |
![]() Join Date: Dec 2016 Location: DFW, Tx
__________________ Built motor w/ Manley rods & Mahle 4032 pistons,BNR S4v2, 3.5" JBR tru-wide, XS power V3 exhaust mani, ST intake mani, CNT catless dp, Magnaflow 3" exhaust, autotech hpfp, Coolingmist progressive (lots of methanol), Cobb FMIC, Cobb RMM, DM PMM, JBR shifter w/ Maisonvi knob, 255/35/18 Pilot Super Sports, Bilstein coilovers (f), Bilstein cartridges in (r) with BC linear spring conversion, GFB valve w/ a GA, Versatune so I can be a rebel, just a little north of 500whp. And Yeah, that`s Steve Vai playing my arm in my avatar. | |
![]() | | #190 | ![]() |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score The switch is where its at. You want it fully disabled this is not an area to try and trick the ecu. If the ecu thinks the car is going straight and you start to slip in a turn it will freak out and brake the wrong wheel and fuck you. As far as the wire i would trust pin position over wire color.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
![]() | | #191 | ![]() |
__________________ Current 2017 Ford Fusion Sport - TT AWD V6 Upgraded LED lighting, Steeda Oil Catch Catch SOLD 2012 LSM Tech - 11/17/17 | ||
| SWAS - DISCONNECT ON A GEN2 | Monotonous ONE | 2010 MS3 - How-To's | 160 | 10-07-2018 09:17 PM |
| I need SWAS pictures! | mexicant | MazdaSpeed 3/6 - ECU Computer Tuning | 33 | 10-26-2016 07:23 PM |
| SWAS - How to disable | Dano | MazdaSpeed 3/6 - ECU Computer Tuning | 208 | 06-09-2016 08:21 PM |
| SWAS on 2010 | harryclay | 2010 MS3 - ECU Computer Tuning | 20 | 03-21-2016 04:11 PM |
| swas sensor help! | madvillain | Mazdaspeed3/6 General Discussion | 1 | 01-20-2009 04:15 PM |
