| I have candy in my van ![]() Join Date: Apr 2009 Location: Chicago, IL
Rep Power: 2810 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,091
Groans: 70
(Thread Starter) | Neutral : +8 score HOW-TO MAZDASPEED3 REPLACE CLUTCH This was done on a genpu, the gen1 requires the exactly the same procedures. This is meant to be a helpful walk through for doing a clutch swap on a MS3. This job should be performed ONLY BY PROFFECIONAL EXPERIENCED TECHNICIANS. I’m not liable for any mistakes you make, following this guide, which is probably not 100% accurate. This is probably a 12hr job according to Mazda, but it can be accomplished in <5hrs if you know what you’re doing. Tools Required: Socket Wrenches Socket Sizes Used Most: 10mm 12mm 14mm 17mm 19mm 21mm 24mm Ratcheting Wrenches(not necessary, but helpful): 10mm 12mm 14mm 17mm Torque Wrenches A Decent Screwdriver Set Pry-Bars Very Tall Jack Stands or a Lift Transmission or Motorcycle Jack Good Set of Pliers Various Pieces of Wood Hammers Other Miscellaneous Hardware: Brake-Clean Grease Thread-Lock New Flywheel Bolts New Trans Fluid Rags, Towels, etc. Coat Hangers, Rope, Wire, etc. Drain Pan Die-Grinder Air Tools, Impact Guns Piece of cardboard, and marker(to keep track of bolts) Recommended to Replace: Flywheel Bolts Driveshaft Seals Driveshaft C-Clip(only 1) First, start by jacking the car in the air, or using a lift if you have one. Begin by removing the undertray, front wheels, intake, battery, battery box, ECU, basically everything above the transmission. Remove the brackets for the wiring harness and shift cables on the top of the trans, there is 3 brackets show here, all are being held on by 2 bolts IIRC: Unbolt the coolant hard pipe running above the trans, as to access the trans bolts later, it’s held on by one 10mm nut on the front of the engine above the starter, and one 10mm bolt above the bellhousing towards the back of the engine: Unclip the electrical connectors from the trans, located on a bracket on the front of the engine: Remove the slave cylinder, from the bellhousing, two 12mm bolts, no need to remove the slave from the fluid line: Next, drain all the trans fluid. Crack the fill plug first, just to make sure it will come out later. The fill plug is located on the front of the trans and, drain plug is located on the side of the trans, shown here Fill: Drain: Now begin tearing into the brakes and suspension. Remove the front calipers, held on by two 17mm bolts, and remove the rotors. Hang the calipers by the springs with some rope/wire. Now remove the tie-rod safety pin then the 14mm nut: Put the nut on the stud, and whack the nut till the tie rod is free from the knuckle: Remove the upper sway-bar end-link nut, remove the end-link from the strut and put the nut on it, so you don’t lose it(14mm and some metric hex key size… I just zip these off with an impact, since they’re usually rusted to shit and don’t want to come off. If all else fails, cut the end-link off and buy new ones): Remove the lower ball-joint bolt nut(14mm): Remove the strut bolt(17mm): It’s now time to free the strut from the knuckle. First take out a big hammer and pound on the knuckle shown here: Do this until the knuckle moves down about 1cm. This will allow you now to pry the knuckle open and slide it off the strut. It needs to go down about 1cm, because the strut has a protruding piece of metal as to align it in the knuckle. Now you take some random piece of metal roughly ¼” thick and place it where the strut bolt goes. I’ve used this tiny wrench for my air grinder, as well as big washers, or pieces of metal I have laying around. Thread in the strut bolt the opposite way so it can press up against the piece of metal, effectively prying the knuckle open: Take a pry bar and pry down on the knuckle to free it from the strut: Thanks Daniel “silvapain” for this trick Now it’s time to separate the lower ball joint from the knuckle. I’m sure with Mazda’s special tool, or a ball joint separator, it would be easier, but it can be done pretty simply with other methods. With the bolt out, the ball joint should come right out of the knuckle, but it being a very tight fit and some corrosion can lead to it being a bit difficult. Support the hub with a jack-stand. Then take a hammer and start pounding on the lower control arm, around where the ball joint is. Work at it till the ball joint is almost free. Use a pry bar, or lift up on the knuckle, to remove the knuckle. Now that the hub/knuckle assembly is removed from the surrounding suspension components, it’s time to remove the axles. We’ll start with the right axle, there is a joint shaft bracket that needs to be unbolted from the block, held in by 3 bolts. Here’s a better pic of the joint shaft bracket, and it’s location: Now the axle can be removed from the transmission. It helps to have a friend hold the axle level, while you can pry the axle out. The prying actions is as goes: use a pry bar, and with a jerking motion pry against the raised edge of the axle, in short bursts, to literally pop the axle out of the trans. Once the axle/hub assembly is removed, from the trans, set it aside. Do the same on the left side of the vehicle, and pop the axle out. Some people say it’s not necessary to remove the subframe to pull the trans. It honestly does not need to be removed, I’ve done a clutch job before with the subframe in place. However, you will save yourself many hours of frustration, by removing it. Why? A portion of the subframe site right underneath the differential, and you’ll spend more time trying to wiggle the trans out of a very tight space. Plus the subframe takes 15min to remove. Begin with the cross bar behind the subframe, IIRC this is where the bolts are located. The 14mm bolts shown in green, the 14mm nuts shown in yellow, and the one 10mm bolt that supports the fuel line shield portion of the cross bar in red: Unhook the rubber exhaust hangers that connect the exhaust to the subframe, location in green: Remove the heat shield on the powersteering rack(red arrow), three 10mm bolts. Then unbolt the powersteering rack from the subframe, three 19mm bolts(shown in green): Here’s a pic of how to get the center bolt, from the rear of the car: Here’s a pic from the shop manual: Now with the rack unbolted, use bungee cords or zip ties, to secure the rack to the exhaust so it doesn’t fall with the subframe. Unbolt the RMM from the trans: Now it’s time to unbolt the subframe from the car. CAUTION! The subframe is heavy, support it on jacks/jackstands and have a friend on each side ready to pull it out, once unbolted from the vehicle. There are 4 main bolts(front 19mm, rear 17mm), indicated in this pic: Use extensions through the holes in the LCAs to get at the front two bolts: Remove the 12mm bolts of the support brackets, shown in green, then remove the 17mm subframe bolt, shown in red. Do the same on the other side. Now that the subframe is detached from the vehicle, lower it slowly, making sure everything is disconnected, and move it from underneath the vehicle. You’ll have to move the FSB/endlinks and tie-rods around so they don’t get caught up on each other. Time to remove the trans mount. First support the engine as well as trans with whatever methods you have, leave room to remove the lover bellhousing bolts later, or skip a few steps, and pull out the lower bolts now: This car had a CP-E trans mount at the time of this install. If you have a different aftermarket mount, refer to the supplier instructions, on how to remove it. Here’s how to remove the OEM mount. Begin with the battery support, held in by two 10mm bolts(pink), and four 17mm bolts(blue). Next remove the 17mm bolt(red), and pull out the top portion of the mount. Unbolt the three 17mm bolts/nuts(green), and remove the lower portion of the mount. For better pics, refer to Jamie’s site: http://jamesbaroneracing.com/support...structions.pdf Now it’s time to remove the eleven 14mm bolts securing the bellhousing to the block: Some are hard to get at, so use extensions, and swivel sockets: Keep the bolts organized as you remove them, so you know where they go upon re-installing: Yay! Now with all the bellhousing bolts removed, it’s time to get this extremely heavy trans out of the way. Being by lowering the jacks supporting the motor and the trans, in conjunction, to clear the trans from the frame. Use a pry bar to pry the trans away from the block, do this evenly around the bellhousing: Keep working the trans away from the engine, by pulling it from the wheel well on left side of the car. Once the input shaft is slid out from the clutch assembly, and the trans is free from everything, lower the trans from the car: Slide the trans from underneath the car, to access the clutch assembly: Now it’s time to remove the six 10mm pressure plate bolts. If you intend on re-using the stock PP, follow these steps. If not, impact it off. First insert the clutch alignment tool into the center of the clutch assembly, and remove the bolts in a crisscross sequence, to properly release tension of the PP. Bolts shown in red: Pull away the clutch PP, to access the flywheel. Use a 12mm socket to remove the 6 flywheel bolts(these bolts are not intended to be re-used due to the factory applied thread lock): Here’s the rear main seal, inspect it for leaks, replace if necessary: Remove and replace the throw-out bearing, first by unclipping the clutch fork from the ball stud of the trans assembly, by pulling or pushing on this spring: INSTALLATION PROCEDURES AND TQ SPECS: Install the new bearing, clean/grease where it connects to the fork, clean/grease the ball stud for the fork, and clean/grease the input shaft: Install the flywheel along with new bolts. Use either the Mazda SST, or a pry bar, to lock the FW in place: Install the clutch disc, according to the writing on the actual disc not the shop manual(it’s backwards), and pressure plate using the alignment tool, torque the pressure plate down in the sequence shown here: Remove the alignment tool. Now install the transmission. Jack it up underneath the car, once the input shaft is lined up, slide the trans towards the block making sure the input shaft goes into the clutch assembly without binding. With the input shaft in, push and lift the trans towards the block, align the holes on the trans to the alignment tabs on the block(blue arrows): With the trans lined up and on the block, begin threading in the bolts, get them all hand tight, then tighten in a crisscross pattern down to spec: From here, install is reverse of removal. Here are some important TQ specs: That’s it folks! Thanks to @Ckmazdaspeed3 for this bitch of a how to, and having to do this 3 times. Thanks to @silvapain for taking away time from his family to help with the install. It took me twice as long to write this guide as it toke us to do this job. Why did it take us 3 times? Well, we installed the clutch properly the first time, got everything back together and the car would not go into gear properly, as if the clutch was not disengaging properly with the pedal depressed. I thought the clutch disc was installed backwards, because I was tired and forgot to check the orientation it was installed. We pulled everything back apart, and installed the clutch disc according to the shop manual. Same problem, but not as bad, the car would engage 1st gear, and other gears at very low RPM(below 2000k). Pulled everything back apart, found the clutch was engaging due to the disc being backwards, and the tighter clearances between the disc and FW. The springs on the clutch disc were acting as the friction material, rubbing against the FW, around the mounting bolts(shown below). We took the new assembly and the OEM assembly, bolted/torqued the PP to the FW on my counter, to find that the new PP was not set properly, by the PP fingers not being at the same height. It was a self-adjusting-PP, where it needs to be set to the new components, in a press. We installed the OEM components, and the car drove perfectly fine. The reason the clutch slipped in the first place… the rear main seal was leaking near where the oil pan gasket and the seal meet. Fun pics!!!
__________________ Current Fail: 2008 Mazda5 DD/Mazdaspeed5 BT project Last edited by MATT DAMOND; 10-10-2012 at 04:02 PM. |
| The Following 120 Users Say Thank You to MATT DAMOND For This Useful Post: | 802MS3 (12-23-2017), 86AmishMs3 (01-14-2012), ak_spray (07-13-2012), alien_sporez (01-14-2012), Alpha (02-10-2012), altaprecision (01-04-2015), Arnie1229 (03-03-2015), atvfreek (03-13-2013), Bap (06-04-2014), bertrand_CX_7 (01-14-2012), Bexar (06-26-2017), BigBoostMS3 (02-17-2014), bigwavedave33 (07-19-2014), bmfms3 (02-25-2012), brandon3212 (04-14-2015), breakfstincluded (02-01-2012), Broxer (04-03-2012), CaptainCode (04-22-2015), Cataphract_40 (01-14-2012), Ckmazdaspeed3 (01-13-2012), Dano (02-09-2013), Dash08 (09-12-2012), dereeek (01-14-2012), DingoDave (02-03-2013), Domino81 (01-14-2012), EdgeAutosport.com (11-02-2012), Element23 (02-04-2016), Elusivellama (01-22-2014), FistPump20fo7 (05-07-2013), Fonsi (10-05-2018), forcedinduktion (02-01-2012), Funkster777 (06-10-2013), GLORIFIEDBOZO (04-01-2012), goHAMM (09-30-2014), GregScuba (07-10-2015), hartlch (09-29-2012), J-Liss (03-09-2012), JacksonMS30 (02-10-2012), Jason43 (04-01-2014), JDR767 (12-29-2016), jeopardy98 (04-19-2013), JewBagel254 (04-05-2015), JLee1469 (01-14-2012), jman46 (02-23-2012), JMEngineer (02-04-2016), Jra2011speed3 (12-19-2012), JSmith (04-06-2015), JTMS3 (10-15-2012), kmac (01-14-2012), kritz (02-01-2012), Livingframe (07-02-2015), LumberJack (08-21-2017), Majin~Nieve (11-30-2013), Manny (01-14-2012), Mattyhawk1 (08-24-2015), McGee (04-01-2012), Mchart (09-12-2012), meelo88 (04-02-2013), MicaBlackMS6 (01-14-2012), Micha (05-26-2012), mituc (10-14-2013), modusoperandi (04-18-2017), MS3-a(sore)ASS-rex (01-14-2012), ms3blackmica (03-13-2013), MS3CB (08-09-2013), MS6 P.C. (04-20-2018), Nliiitend1 (01-14-2012), Novej (01-15-2012), nybe0010 (05-08-2013), Oliverms3 (02-10-2012), Onelovesoccer (03-09-2012), p057 (01-14-2012), predapio (01-14-2012), Pseud0logik (03-13-2013), Raider (01-14-2012), rghispanic88 (01-14-2012), RhoadBlock (01-14-2012), robry (03-12-2012), Roddiy (05-06-2013), roguemazda (06-04-2016), ruthless013 (03-09-2012), Sacrilicious (01-14-2012), sarm1084 (12-19-2018), Sasuke-kun (10-24-2018), ScarMS3 (01-14-2012), Sid3wayS (01-14-2012), siegsuwa (12-04-2013), silvapain (01-14-2012), SJP0tato (01-14-2012), skeeter149 (01-14-2012), skeurton (10-10-2012), Skyman88 (08-04-2013), slickety (03-24-2016), someguy (12-30-2013), speed23 (01-14-2012), stevenlapensee (02-10-2014), Strangel (01-22-2015), superq7 (01-14-2012), taf0422 (01-14-2012), tastysi2004 (03-08-2013), tddvrrn (01-14-2012), ThOrZwAr (06-09-2016), TiGraySpeed6 (01-14-2012), Tokay444 (07-13-2014), Tomas (01-14-2012), TriO (01-14-2012), TWOptSL0W (07-12-2013), uncorked11 (01-14-2012), Vader (03-09-2012), voodoo2crue (02-13-2016), vtdone (11-17-2014), VulgarKyle (02-19-2013), WAHBAM (10-01-2012), wankular (02-02-2012), xI Leveler Ix (09-09-2012), Z32_MS3 (05-01-2014), zatara (01-14-2012), ZetaDrift (05-08-2014), Ziggo (01-14-2012), zpele (03-09-2012) |
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
| Not Ranked : 0 score You forgot the alternative for putting the tranny back... Get a big black guy to bench press it into place. Matt, you look really creepy (like a child molester) in those last photos. Great write up. I hope you can make it to the motor install! |
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | MATT DAMOND (01-14-2012) |
| Not Ranked : 0 score This is an epic thread! Holy shit! The detail is amazing. Think it's the same for gen1? |
| The Following User Says Thank You to Raider For This Useful Post: | MATT DAMOND (01-14-2012) |
![]() Join Date: Nov 2010 Location: Lake Carmel, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 773
| Not Ranked : 0 score Pick of his head coming through the battery hole in the car, only thing I can think of is the Shining. Duper detailed write-up. Thank you for taking the time to do it. I can't say I'll ever have to do this, but I like to think that eventually I may need to. And this'll really come in handy.
__________________ 2010 Mazdaspeed 3 Black Mica CorkSport SRI/ TIP-- CorkSport TMIC-- Cobb DP-- CorkSport CBE-- Cobb AP Stratified Lex Tune-- Autotech Internals-- Denso ITV22's-- JBR EGR Blockoff-- JBR OCC-- JBR 88 Chrome-Molly RMM-- JBR 80 PMM-- JBR 88 TMM-- Corksport Skidplate-- JBR RSB Red JBR shift knob-- VG Sharkfin--CS LED interior lights-- Hardwired Valentine 1 Radar detector-- 5K HID lows-- 3K HID Fogs-- 30% tint front, 20% tint rear |
| The Following 2 Users Say Thank You to zatara For This Useful Post: | Arnie1229 (03-03-2015), MATT DAMOND (01-14-2012) |
| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 ![]() Thanks: 2,634
Groans: 220
| Not Ranked : 0 score i would never attempt this myself but now i appreciate the intense work that goes into this job. fantastic write up as always and thanks for the contributions over the years!!!!
__________________ |
| The Following 2 Users Say Thank You to p057 For This Useful Post: | Alpha (10-19-2012), MATT DAMOND (01-14-2012) |
![]() Join Date: Oct 2009 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,684
| Not Ranked : 0 score Fuck me, epic write-up. I always considered a clutch replacement as too difficult to DIY, but your write-up shows it's not hard... just long and tedious. I think I could tackle this now if I took my time and had some NATOR assistance.
__________________ ● 2011 Jaguar XFR ● Full Resonator Delete ● Mina Cat-Back Exhaust ● Staggered Giovanna Portofinos ● ● 2010 Mazdaspeed 3 - GONE ● |
| The Following User Says Thank You to alien_sporez For This Useful Post: | MATT DAMOND (01-14-2012) |
| Not Ranked : 0 score I'm thinking the same thing. A trip to Harbor Freight for some more tools first, though. |
| The Following User Says Thank You to Raider For This Useful Post: | Bap (06-04-2014) |
![]() Join Date: Nov 2008 Location: Fitchburg, Mass.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 118
| Not Ranked : 0 score Awesome write up! This will come in handy down the road. Thank you!! |
| The Following User Says Thank You to RedBliss For This Useful Post: | MATT DAMOND (01-14-2012) |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
Groans: 105
| Not Ranked : 0 score I'm sorry if I didn't catch it but what kind of clutch did you try to install and it didn't work? Couldn't believe the markings from the disc springs! I take it that whole clutch is fukt now?
__________________ 2012 WRX HB w/mudflaps yo! |
| The Following User Says Thank You to spnkr21 For This Useful Post: | MATT DAMOND (01-14-2012) |
Groans: 134
The damage was superficial and the parts were sent back to EM and the pressure plate was reset. My motor blew a couple of weeks ago and is being built right now so we will see if this works when I put the new motor in (arp studs, k1 rods, wiseco pistons and port and polished head). Anybody that is intimidated by this (not talking about u spnkr) if you have time and patience, and some help and beer, give it a try. I had never even worked on a car before just over a year ago. And when we took out my motor I was able to do almost everything (taking the tranny out is the hardest part) after doing this with Matt and silvapain a few months ago. | |
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | tddvrrn (01-14-2012) |
Rep Power: 394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,114
| Not Ranked : 0 score THANK YOU VERY MUCH! This will be helpfull to Lot of bronnies like me. Always something I wanted to do for my self. Please keep up with the Great work. This will make our forum a unique Mazda ressource out there. TYVM!
__________________ 2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII. Pending install: JB EGR block plate Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness. 2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system. |
| The Following User Says Thank You to bertrand_CX_7 For This Useful Post: | MATT DAMOND (01-14-2012) |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score Awesome, eagle motorsports organic?
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
| The Following User Says Thank You to 86AmishMs3 For This Useful Post: | Ckmazdaspeed3 (01-14-2012) |
| Not Ranked : 0 score Great write up. I don't know about dropping the engine cradle though. I didn't do that and things worked out fine. Edit: Now that I read this in more detail dropping the sub frame seems like a good idea. I do remember I suffered intensely trying to wiggle the gear box out of there. I like the idea of using zip ties to keep the steering rack in place. Fucking win. Just a couple of notes from my experience: 1. The passenger side axle does not need to be pried out. It slides out easily. 2. The driver's side axle has a snap ring which keeps it pretty tight in place. I used a chisel and with the flat side against the CV joint and the shaft against the gear box tapped it out. You can also hit it with a bar and hammer through the passenger side of the gear box once that shaft is of. I tried that and wasn't successful so I used the chisel.
__________________ Last edited by Tomas; 01-14-2012 at 08:55 AM. |
| The Following User Says Thank You to Tomas For This Useful Post: | MATT DAMOND (01-14-2012) |
![]() Join Date: Jul 2011 Location: Chattanooga, Tn
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groaned at 6 Times in 3 Posts
| Not Ranked : 0 score Amazing write up guys. Info will be handy next weekend as Nator TN/KY will be doing this on a MS3 and a MS6. How much more difficult will a 6 be versus the 3? thanks.
__________________ [SIGPIC][/SIGPIC] 2006 Mazdaspeed6 BCM GT MODS : Cobb AP // Cobb SF // Sure TIP // JBR RMM // JBR SSB // JBR SSP // Magnaflow CBE // MSR 045 18 X 8 +35 // ACT ZX5-HDG6 // M2 3" catless DP // AT HPFP Internals // NGK's -- FREEKTUNE in progress Having a 12 second Honda is just like coming out of the closet; You're going to surprise a bunch of people, but in the end you're still gay. |
Groans: 134
| Not Ranked : 0 score @Tomas Silvapains advice worked great for me a couple weeks ago when I pulled my motor (this was the only major hang up). Just grab the axle on either side of the cv and make a few sharp jerks... Comes out in under 5 seconds for the driver side axle. I know u don't need to know how, just saying the easy way I did it.
I think it is the same for gendone, but I'm positive that the hardest parts (suspension and tranny itself) are the same. Last edited by Ckmazdaspeed3; 01-14-2012 at 09:08 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following 2 Users Say Thank You to Ckmazdaspeed3 For This Useful Post: | MATT DAMOND (01-14-2012), Tomas (01-14-2012) |
| Not Ranked : 0 score excellent write-up! Thanks for the blood, cursing & effort that you've shared! I'm taking away the opinion to treat this as several smaller easier jobs, rather than one big badass mutha of a job. Before you know it, the trans is on the floor. I'm also glad to see the info on what NOT to do regarding the clutch parts assembly on the car. THAN YOU for sacrificing the time to do the job three times & get it straight, and share with us what didn't work and why! That info is worth it's weight in gold, just as much as the rest of the write-up.
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | MATT DAMOND (01-14-2012) |
Groans: 136
| Not Ranked : 0 score Excellent write-up Matt.
| The Following User Says Thank You to silvapain For This Useful Post: | MATT DAMOND (01-14-2012) |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
| Not Ranked : 0 score great write up! it's peeps like you that make this forum the best. real info, bitches!
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to tddvrrn For This Useful Post: | MATT DAMOND (01-14-2012) |
![]() ![]() Join Date: Jul 2008 Location: Old Bridge NJ
Rep Power: 22834 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,276
Groans: 309
| Not Ranked : 0 score Wow, great write up. In your experience is this as hard as an intake install? That intake was a bitch.
__________________ Dash08: I don't see the whole pedophile thing, But Predapio is a dirty old bastard. So, I wouldn't rule it out entirely. That's also why he fits in here. We're all a bunch of filthy, perverted, arrogant, pessimistic, self-righteous assholes who find entertainment at other peoples expense. What a lovable bunch we are!! |
| The Following 2 Users Say Thank You to predapio For This Useful Post: | MATT DAMOND (01-14-2012), MS3-a(sore)ASS-rex (01-14-2012) |
![]() Join Date: May 2011 Location: Orlando, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,305
Groans: 386
| Not Ranked : 0 score hehe he's riding a tranny. good write up though.
__________________ BNR3-FREEK-PU-398HP I lost track of the mods in my car. |
| The Following User Says Thank You to dereeek For This Useful Post: | MATT DAMOND (01-14-2012) |
![]() Join Date: Aug 2009 Location: Trevose, PA
Rep Power: 7488 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,940
Groans: 224
| Not Ranked : 0 score Kick ass Matt! Excellent write-up. God you're one sexy ginger
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA |
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | MATT DAMOND (01-14-2012) |
![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks |
| The Following 8 Users Say Thank You to Cataphract_40 For This Useful Post: | alien_sporez (01-16-2012), Ckmazdaspeed3 (01-14-2012), forcedinduktion (02-01-2012), MATT DAMOND (01-14-2012), Micha (05-26-2012), Raider (01-16-2012), rghispanic88 (01-14-2012), WAHBAM (10-01-2012) |
![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 2506 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,527
| Not Ranked : 0 score Holy fuck, I had no idea a clutch swap was so involved.
__________________ ![]() Anthony D. Christiano - Co-Owner at Inspiration Studios Photography 2008 CosmicBlue Mazdaspeed3 294whp/335wtq - Stock K04 370whp/370wtq - BNR stage 3 FreekTuned, BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, Devil's Own Meth Injection D10 Nozzle, 3-Bar Map & Plug & Play Connector, PTP Injector Seals & Studs, KritzSpeed 3-Port BCS, Sure Return, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back, CP-E FMIC, TWM STS, TWM A6 Leopard Shift Knob, TWM Leather Shift Boot, AutoTech Fuel Pump Internals, JBR trinity, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 + 5/16" spacer (ET40), SPC camber arms, Cobb Rear Sway Bar, Nitto NT05 235/40/18 (front) BF Goodrich g-Force Sport 235/40/18 (rear), MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() | | #24 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score holy Jesus h Christ you don't have to pull the k frame lol good write up though
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
![]() | | #25 | ![]() |
![]() Join Date: Apr 2010 Location: Miami FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,836
Groans: 263
| Not Ranked : 0 score awesome write up. funny too.
__________________ 2010 Black Mica 2004 EVO 8 Green Monster The "7up" |
![]() | | #26 | ![]() |
![]() Join Date: Jun 2011 Location: Epping, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 36
| Not Ranked : 0 score Wow great work! Nice write up!
__________________ Cobb SRI Cobb BPV SURE TIP SURE RMM KMD Internals SU Test Pipe JBR Stage 2 FREEKTOONZ |
![]() | | #27 | ![]() |
Groans: 40
| Not Ranked : 0 score bottom pinch bolt, axle nut, pry down on A arm, and pull out on the knuckle, pull the axle out, out of the knuckle then pop it out of the trans , and the hole damn thing can hang their and leave the k frame in much easier...
| The Following User Says Thank You to rigor For This Useful Post: | EdgeAutosport.com (11-02-2012) |
![]() | | #28 | ![]() |
![]() Join Date: Jul 2011 Location: Clarksville, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,279
| Not Ranked : 0 score @Raider pulled mine out yesterday and everything was the same for a Genwon. @MATT DAMOND big thanks for the write up it's awesome and @silvapain for the trick with the struts. Thanks again guys this worked out great.
__________________ "Intelligence isn't the ability to store information, but to find it" - Albert Einstein "When I read about the evils of drinking, I quit reading" - Henry Youngman |
| The Following 2 Users Say Thank You to GLORIFIEDBOZO For This Useful Post: | Ckmazdaspeed3 (01-16-2012), silvapain (02-03-2012) |
![]() | | #29 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score Great write up and epic pics |
![]() | | #30 | ![]() |
![]() Join Date: Nov 2010 Location: Acworth, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 387
| Not Ranked : 0 score Wow just Wow Can't wait to do this project
__________________ 2007 Mazdaspeed 3 400.32whp 375.14wtq (STD) BNR STAGE 3 Stratified by Lex ![]() Of all the military achievements I've accomplished my first 10 years of service (made MSGT/E-7 at age 29), the one that makes me most proud is simply being able to serve my country during her darkest hour...NEVER FORGET those who made the ultimate sacrifice doing the same....I SALUTE ALL OUR FALLEN ![]() ![]() ![]() |
![]() | | #31 | ![]() |
Groans: 70
| Not Ranked : 0 score Sorry Matt I couldn't help myself.... |
| The Following User Says Thank You to forcedinduktion For This Useful Post: | alien_sporez (02-09-2012) |
![]() | | #32 | ![]() |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score Matt you're wearing $25 mechanic gloves and $5 sandals I has confused.
![]() | | #33 | ![]() |
Has his priorities in order
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq | |
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | Alpha (02-10-2012) |
![]() | | #34 | ![]() |
Groans: 40
| Not Ranked : 0 score if you pull the k frame you have to have your alignment done jfyi
![]() | | #35 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score Shit gets DONE in that garage man! Badass! I literally laughed out loud when I saw that Matt D SRI pic lol
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() |
![]() | | #36 | ![]() |
![]() Join Date: Nov 2009 Location: PLAINEDGE, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 364
| Not Ranked : 0 score thanks a shit-ton for this stellar write up. r&r of this tranny looks significantly more of a pain in the ass compared to a honda b-series, which i've done several times. i don't think i'll be dropping the ms3 tranny onto my chest like i did the honda. trannys dropping on my chest. thats right i said it.
__________________ 2010 Black Mica Mazdaspeed3 2009 Black Cherry CX-9 AWD 1997 Classic Red Miata [SIGPIC][/SIGPIC] |
![]() | | #37 | ![]() |
Groans: 136
| Not Ranked : 0 score Here is an alternative method for reinstalling the transmission on the engine: Instead of using a jack to lift the transmission back into place, use a cherry picker and a strap. I believe thanks go out to @GLORIFIEDBOZO for this idea.
| The Following 4 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #38 | ![]() |
![]() Join Date: Mar 2008 Location: Chicago
Rep Power: 4020 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,876
| Not Ranked : 0 score So did Clint's clutch go smoothly/as planned yesterday? Sorry I couldn't make it down...
__________________ Stance is not a verb. 2008 MS3 GT 2016 MX-5 Club |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | silvapain (04-01-2012) |
![]() | | #39 | ![]() |
Groans: 136
That reminds me: another thing to note on the clutch install is to use Moly Grease or similar high-temp grease on the collar for the throwout bearing. DO NOT USE WHITE LITHIUM GREASE as it cannot withstand the temperatures, and will eventually turn into a gummy substance that will bind the TOB. We believe this was the issue with @phate's clutch getting harder to press and he went through the gears at WOT. Tapadatass
__________________ | |
| The Following 2 Users Say Thank You to silvapain For This Useful Post: | GLORIFIEDBOZO (04-03-2012), Nliiitend1 (04-01-2012) |
![]() | | #40 | ![]() |
__________________ "Intelligence isn't the ability to store information, but to find it" - Albert Einstein "When I read about the evils of drinking, I quit reading" - Henry Youngman | |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/how-mazdaspeed3-replace-clutch-102245/ | ||||
| What Did You Do To Your Car Today? - Page 389 | This thread | Refback | 10-11-2015 05:13 PM | |
| HOW-TO: MAZDASPEED3 REPLACE CLUTCH - Mazdaspeed Forums | This thread | Refback | 11-28-2014 05:00 AM | |
| HOW-TO: MAZDASPEED3 REPLACE CLUTCH - Mazdaspeed Forums | This thread | Refback | 11-28-2014 04:58 AM | |
| Rok - build and boost my MZ3 2006 - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 01-08-2014 05:48 PM | |
| Bryan's Message Board | This thread | Refback | 07-23-2013 11:59 AM | |
| Clutch write up. - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 05-24-2013 07:23 AM | |
| 4th Gear Temporary Power Reduction - Page 4 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 04-18-2012 05:40 PM | |
| how to replace pcv value for gen 1 ms3? | boostedms3 | MazdaSpeed 3 - How-To's | 17 | 10-14-2012 01:25 PM |
| clutch vibration at top of clutch PLEASE HELP | livetoskate06 | MazdaSpeed 3 - Engine, Transmission & Driveline | 84 | 03-06-2010 06:53 PM |
| Replace Air Filter | Campo | MazdaSpeed 3/6 - Turbo Induction | 12 | 02-09-2010 11:39 AM |
| How do i replace my fogs? | speedster 3 | Mazdaspeed3/6 General Discussion | 16 | 11-02-2008 06:34 PM |
