> 2010 MS3 - How-To's
 Old 10-30-2011, 05:34 PM   #1
Ex_WRX_driver's Avatar
Posts: 719   (View Stats)
Ex_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the worldEx_WRX_driver is the leader of the world
Default How To: rear wiper delete
This is something I did with my integra back in the day.
1: remove lower hatch plastics
2: remove wiper arm(10mm nut)-
3: remove wiper motor. Unplug wire harness and remove the 3 10mm bolts-
4: pull out rubber grommet-
5: put plastics back on hatch.
6: TO BE CONTINUED. I need to go to lowes to find the right grommet to put in the hole. Thinking its a 7/8s. Until then I just put tape over the hole. Below is a pic that gives an idea of what it will look like when complete.
2011 Liquid Silver
Corksport SRI/TIP/AIRBOX
Ultimate Racing catback
JBR stage 2 shift kit
SURE RMM
Ex_WRX_driver is offline   Reply With Quote
The Following User Says Thank You to Ex_WRX_driver For This Useful Post:
SWAY (10-30-2011)
 Old 10-30-2011, 05:44 PM   #2
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
Groans: 266
I got my rubber piece on ebay, but it was for a gen one so it was to big. I just cut it down then used some weather striping glue to seal it up.
DONOTBUGME is offline   Reply With Quote
 Old 10-30-2011, 05:46 PM   #3
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
Groaned at 30 Times in 25 Posts
i dont get why you guys remove it......dont look any cleaner IMO
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
 Old 10-30-2011, 05:48 PM   #4
G26
G26's Avatar
Posts: 2,988   (View Stats)
G26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the worldG26 is the leader of the world
Groans: 39
IMO, the hatch looks weird with no wiper. Also, out of anything to do to the outside of this car, or any hatchback, this is probably of the lowest of the low priority ever.
Doesn't look cleaner, it looks like something is missing that should be there.
2011 MS3 / Fully Bolted / 290whp - 320wtrq ~ Sold
2010 Accord Coupe EX-L V6 ~ Current ~ K&N SRI / 4300k HIDs
G26 is offline   Reply With Quote
The Following User Says Thank You to G26 For This Useful Post:
J-Liss (10-30-2011)
 Old 10-30-2011, 05:52 PM   #5
Big Titty Sucker
BLK_MS3's Avatar
Posts: 1,612   (View Stats)
BLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the world
Groans: 139
It looks a LITTLE cleaner, but with mine being my daily driver I need the wiper. Lots of water builds up back there.
BLK_MS3 is offline   Reply With Quote
 Old 10-30-2011, 05:55 PM   #6
J-Liss's Avatar
Groans: 81
doesnt even look a ounce cleaner
2004 mazda 3-Daily
2008 mazda 6-Wife
 Old 10-30-2011, 05:57 PM   #7
Its not for everyone, it always just bugged me being there so I took it off.
2011 Liquid Silver
SURE RMM
The Following 2 Users Say Thank You to Ex_WRX_driver For This Useful Post:
SLOWHATCH (10-31-2011), SWAY (10-30-2011)
 Old 10-30-2011, 06:36 PM   #8
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I think the fact that the rear end is completely symmetrical makes it a lot cleaner.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 10-30-2011, 06:37 PM   #9
SWAY's Avatar
Posts: 2,517   (View Stats)
SWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the world
Groans: 190
Groaned at 60 Times in 43 Posts
Took mine off and looks way better and I can see out of my back window 100 percent of the time
~2011 Liquid Silver MS3~ ---->> ZZB
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
SWAY is offline   Reply With Quote
 Old 10-31-2011, 11:44 AM   #10
All done. Used a 7/8 Nylon plug from lowes(2 pack-1.39).
2011 Liquid Silver
SURE RMM
 Old 10-31-2011, 12:06 PM   #11
myslow1's Avatar
Posts: 355   (View Stats)
myslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the world
neat! I find myself using my rear wiper quite frequently though...
Daily - 2007 True Red Mazdaspeed3 GT.
Jack Stand Race Car - 1991 Aquamarine Pearl MR2.
myslow1 is offline   Reply With Quote
 Old 10-31-2011, 01:53 PM   #12
DONOTBUGME's Avatar
Groans: 266
it looks way better, Looks like a damn mini van with it. Plus I live in CA, so nce for a rear wiper.
 Old 10-31-2011, 01:56 PM   #13
wankular's Avatar
Posts: 4,343   (View Stats)
Took mine off a long time ago. I barely use my front wipers in the desert.
True story: It rained the other day and I forgot how to fucking turn them off. Kept twisting the knob instead of flipping the entire stalk. Felt like a complete retard.
2009 MS3 sport MGM
The Following 3 Users Say Thank You to wankular For This Useful Post:
AZSPEED3 (11-01-2011), SLOWHATCH (10-31-2011), zxhoya (01-28-2012)
 Old 10-31-2011, 01:56 PM   #14
2011speed's Avatar
Posts: 1,497   (View Stats)
plain looks good, but that just looks TOO plain. Never thought id say this but i think it would look better with a blacked out mazda emblem back on there lol....
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
The Following User Says Thank You to 2011speed For This Useful Post:
Broxer (10-31-2011)
 Old 10-31-2011, 02:08 PM   #15
Big Titty Sucker
BLK_MS3's Avatar
Groans: 139
How you fill the holes in your trunk? I just noticed this...
 Old 10-31-2011, 02:12 PM   #16
Welded up by body shop.
2011 Liquid Silver
SURE RMM
 Old 10-31-2011, 02:25 PM   #17
jimmy's Avatar
Posts: 234   (View Stats)
jimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond reputejimmy has a reputation beyond repute
This reminds me of when guys would run a single wiper up front like the touring cars. I bet it made driving in heavy rain a pain.
2010 LSM MS3 w/ Tech: Cobb AP, CorkSport SRI/TIP, JBR 80d RMM, JBR SSP, JBR SSB, JBR heavy knob, RallyArmor mudflaps, DDM 5k HIDs, Lamin-X fogs.
jimmy is offline   Reply With Quote
 Old 10-31-2011, 07:02 PM   #18
Big Titty Sucker
BLK_MS3's Avatar
Groans: 139
Actually a lot of race cars run one big wiper. It works well and saves a little weight.
But, that is RACE CAR.
Whoa. I'd have left the emblem LOL.
I'm guessing maybe you had damage back there?
Last edited by BLK_MS3; 10-31-2011 at 07:02 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-31-2011, 08:00 PM   #19
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
I guess you missed the 2 threads where he keeps getting rear ended by fords? lol. That sucks, but at least he hasn't been hurt and pretty sure he made some profit from selling his UR catback.
I also have the option to delete the rear emblems at a body shop for next to nothing, but agree it would look too plain. The wiper delete just adds to the plain-ness lol.
Might look much better with a really dark tint job on rear window, and all other windows for that matter. IMO.
 Old 11-01-2011, 07:54 AM   #20
Vater's Avatar
Posts: 1,004   (View Stats)
Vater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the worldVater is the leader of the world
Doesn't look bad, but I would never do this. Oddly, my rear wiper actually wipes water off the rear window somewhat frequently.
Is there a how-to on getting the rear wiper intermittent setting to be slower? I'd be up for that.
NoVA's first pu
2010 Mazdaspeed3 Sport | Black Mica w/ Tech Package
__________________________________________________ _______________________________________________
| JBR SSP Stage 2 | JBR 88 duro RMM | Sure Aeros SRI | HTP TIP | DDM HID lows | Corksport LED fogs |
| FIAMM low tone Freeway Blaster | Kumho Ecsta LE Sport (stock wheels) | Black 16x7 Flik FTDs (winter) |
______________________________| 215/55/R16 Falken Eurowinters (winter) |____________________________
Vater is offline   Reply With Quote
 Old 11-01-2011, 02:23 PM   #21
Big Titty Sucker
BLK_MS3's Avatar
Groans: 139
+1 to that. I was just thinking that the other day.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/how-rear-wiper-delete-95778/
Rear window wiper delete This thread Refback 01-03-2012 08:52 AM
Windsheild Wiper Delete nicho1987 Appearance - BLACK 15 11-16-2010 09:14 PM
MGM_GT3's Thread... EVO X wheels , MZ3 wing , Wiper Delete MGM_GT3 Members Rides Gallery 4 07-28-2010 01:54 AM
Rear wiper Ftaz1 Mazdaspeed3/6 General Discussion 4 06-24-2009 11:58 AM
Page generated in 0.40511 seconds with 32 queries
