![]() Join Date: Mar 2014 Location: Decatur, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
(Thread Starter) | Not Ranked : 0 score If you have a 2013 Speed3 with the technology package (which includes the touchscreen head unit), here’s how to remove it. It’s not hard, but it’s more involved than removing the regular Mazda3 radio. I hope the pictures help; photography is not my strong suit. ![]() The only tool you need is a medium Phillips screwdriver. Step 1: Pull straight out on the vent panel above the radio. Don’t pull on the vent grilles. Instead, grip the top edge with your fingernails and the bottom of one of the vents. It comes out pretty easy. Flip it up and either push it out of the way or remove the tweeter wiring harness to take it off completely. Remove the two screws holding the top of the radio in place. Do not attempt to remove the radio at this point. PLEASE NOTE: I took this picture when I was putting it back together; that's why the radio is pulled out. ![]() Step 2: Remove the passenger side scuff plate (not the one that says Mazdaspeed) by pulling it straight up. Step 3: Remove the passenger side lower trim piece by pulling out the one plastic fastener, pulling back the rubber seam, and popping it straight out. ![]() Step 4: Pull straight down on the dashboard undercover beneath the glove compartment. There are only two clips holding it on. ![]() Step 5: Open the glove compartment. On the right side, you will see one guide (foreground) and just below it, the stay damper. Unclip the stay damper from the glove compartment door. Then, pull up on both the left and right guides so as you lower the glove compartment door, they will pull straight out. ![]() Step 6: Pull straight out on the passenger side lower left panel. It will just pop off. ![]() Step 7: Remove the glove compartment. Unscrew the upper and lower screws and pull straight out toward you. Remove the glove compartment light so you can set the whole assembly aside. ![]() ![]() ![]() ![]() Step 8: Stick your head inside the gaping hole and look to your left. You will see two silver Phillips head screws connecting the radio to a bracket. Use a magnetized screwdriver to remove them. If they drop down, you’re going fishing. ![]() ![]() Step 9: In step 1, you removed the two screws at the top of the radio. Now that you have removed the bracket screws, you’re ready to pull the radio straight out toward you. Once you get it out far enough, you can remove the wiring harnesses and antenna. ![]() And that's it. Follow the instructions backward for reassembly/install. Please let me know if I need to make any edits. Last edited by ejb2112; 08-21-2015 at 06:54 AM. |
![]() Join Date: Mar 2015 Location: Norcross, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 45
| Not Ranked : 0 score Damn that looks like a lot!!! |
(Thread Starter) | Not Ranked : 0 score That's because I'm really anal about capturing all the detail. Everything in the how-to will take you maybe 15 - 20 minutes to do. It's very easy and straightforward. Wait...I just saw your location and it says Decatur. Me too (city of). More than happy to get together with you and go through it if you want. |
| The Following User Says Thank You to ejb2112 For This Useful Post: | Dommo14 (08-21-2015) |
Groans: 438
| Not Ranked : 0 score Only the 13's with a tech package came with this unit. 10-12 have the regular headunit. Pop off the vents, take out 2 screws, done. Seems they made it more of a pain to take this one out for some reason.
__________________ All good things must come to an end... |
| The Following User Says Thank You to g00s3y For This Useful Post: | prosper0 (01-14-2016) |
(Thread Starter) | Not Ranked : 0 score Well, shoot. Thanks, g00s3y. I couldn't edit the title but put a big disclaimer at the top of the thread. |
| Very helpful since I have the 2013 model with Tech. Sent from my HTC M9
![]() Join Date: Apr 2011 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
| Not Ranked : 0 score Navigation, average MPG, etc. will all still work. The only thing that won't work is the display music information.
__________________ Engine | GTX3067R | Cobb AP | Autotech Internals | HTP 3.5" Intake | M2 Long Downpipe | | ATP FMIC | Forge V1 | Grimmspeed EBCS | 3 BAR MAP | NGK Iridium IX | | Damond EGR Delete | JBR OCC | E33 Self Tune | DO7 Meth | Handling | Damond RMM | Damond PMM | JBR 88a TMM | JBR Shift Weight & Knob | | JBR Rear Sway Bar | Cobb Springs | |
![]() Join Date: Feb 2016 Location: Deland Flroida
Rep Power: 0 ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score Thanks I am going to be installing the backup camera and this will be a great help! |
| How to remove the oem stereo head unit | GhostInTheDarkness | MazdaSpeed 3 - How-To's | 12 | 05-04-2017 01:36 PM |
| Aftermarket head unit in a 2013 with tech | NCspecV81 | 2010 MS3 - Car Audio & Electronics | 4 | 12-15-2014 10:52 AM |
| 2010 MS3 Non-Tech Touchscreen Head Unit | khopwood77 | 2010 MS3 - Car Audio & Electronics | 19 | 01-03-2011 09:35 PM |
