![]() Join Date: Aug 2013 Location: Mentor, Ohio
(Thread Starter) | Not Ranked : 0 score This mod only helps if you are experiencing "boost blow out" despite what you are gapping your plugs to. The spring stretch mod does not do anything in my eyes, so I've seen bits and pieces of people putting solid copper in their coil packs to help the spark strength carried from the coil pack to the plug. Well let me tell you it is working great for me, no more blow out and here is how you do it! Step 1: go to Lowes or Home Depot and buy yourself a foot or two of 4 gauge solid copper wire (go to the wire cutting area in the electrical department) it was less than $3 dollars for two feet for me. Step 2: cut off a small section of the wire (to square it up to a nice flat surface I found that a brake line cutting tool works really well) Step 3: cut four pieces of copper to roughly 2.5" (doesn't have to be machine work tolerance but get it as close as you can) Step 4: pull your coil packs out of your car. Step 5: separate the boot from the coil pack. Step 6: pull the spring out (id recommend holding onto them just in case) Step 7: reinstall the boot Step 8: reinstall the coil packs (now at this point you need to check something, verify that the coil pack itself is close enough to the valve cover(where the screw goes) so when you tighten down the coil pack you wont crack it and vise versa if you put you coil pack on and the coil pack bottoms out where the screw goes, your copper is most likely too short) Step 9: start it up! (you may have a misfire, just track down the cylinder more than likely your copper is too short and just cut another piece!) Step 10: enjoy your boost without blow out any more!!!!
__________________ 2010 MS3 Black mica|Custom head gasket|Custom timing cover gasket|Keyed crank|Manley H-Beams|Manley 88mm Pistons|Supertech valve spring kit|Balance shaft delete|ACT 6 puck sprung clutch|Streetlite flywheel|PNP stock Intake manifold|PNP cylinder head by Realgib3|custom 4" intake pipe|HKS SSQV|CPE Stage 2 RMM|CPE TMM|CPE PMM|Custom Cat Back|Custom Long Downpipe|TRE 1045 FMIC|JBR oil catch can|Sonic Tuning coilovers|SS Brake lines|Blank rotors|hawk HPS pads|6th port w/ 2 2200 cc injectors|PTE DBB 6266 Gen 2 v-band all the things|Homemade Tubular Exhaust Manifold|Tuned by Realgib3|SP63 Aux Fan controller |
| The Following 15 Users Say Thank You to HOCKEYNUBE For This Useful Post: | 865ms3 (11-04-2015), Boost_creep (04-25-2016), Code Monkey (11-06-2015), impossible (06-10-2017), Jh8909 (12-19-2015), Mauro_Penguin (09-29-2015), mituc (07-07-2018), MS3Shadow (11-04-2015), nekret (09-30-2015), shaneski (10-01-2015), sho (12-19-2015), speedfreak44 (11-04-2015), SpeedRebirth (12-19-2015), Tommyspeed3 (08-27-2017), WetzMS3 (09-29-2015) |
| Not Ranked : 0 score Blowout is a cocksucker. Thanks for doing the write up. I had to hunt down the idea in whatever thread it was in once before.
(Thread Starter) | Not Ranked : 0 score I found it in a couple threads but I thought it should be centralized so more people can find it easier and have a full write up on it.
| The Following User Says Thank You to HOCKEYNUBE For This Useful Post: | WetzMS3 (09-29-2015) |
| Not Ranked : 0 score I believe this should be a sticky and a retardedly simple and cheap mod that can help everyone. |
| The Following 7 Users Say Thank You to Realgib3 For This Useful Post: | 865ms3 (11-04-2015), HOCKEYNUBE (11-04-2015), MD1032 (12-25-2015), MS3Shadow (11-04-2015), sho (12-19-2015), speedfreak44 (11-04-2015), WetzMS3 (11-04-2015) |
![]() Join Date: May 2011 Location: knoxville, TN
Rep Power: 1702 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,468
__________________ Brent Mazda Dragon Camp - Event Coordinator -Built Block-5858-Meth Dragon Slayer Setup FreekTuned ![]() |
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
| The Following 2 Users Say Thank You to MS3Shadow For This Useful Post: | 865ms3 (11-04-2015), speedfreak44 (11-04-2015) |
| Not Ranked : 0 score Tapa fail....I'll go be a noob somewhere else now
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score Any possible set back to this in the future?
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score I'll just fire up the time machine and find out.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
| The Following 3 Users Say Thank You to shaneski For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score the only set back I could possibly see is in like 100 years the copper will corrode if you don't put dielectric grease on the connections but honestly in my opinion, not a scientist, I think the copper will hold up as long if not longer than the stock springs that come in the coil packs.
Well, what i was thinking of was the resistants in the metal spring vs the cooper rod. I am sure its not that big of a deal but its something that i thought of.
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned | |
I change my plugs every 8k-10k miles (every other oil change or so) and gapped them to .025 (even on the k04) Put my 5862 on and ran a base map hitting 24ish psi for a little while with plugs that already had roughly 7k on them. Got some tuning down and was now targeting 28 psi, had to stop there because I was getting mad boost blowout. Changed the plugs out and gapped them to .022, still was getting blow out not as bad but was still getting some. So I found a picture and a comment buried on here in a build thread so I tried that (solid copper deal) After the solid copper deal I was able to bump the boost up to 32 psi (while the plugs were still gapped at .022) and had no issues Well after your comment above I wanted to see how much abuse 5k miles did at 32 psi to my plugs. it blew to gap open from .022 to .028 and I NEVER had an issue with blow out
__________________ 2010 MS3 Black mica|Custom head gasket|Custom timing cover gasket|Keyed crank|Manley H-Beams|Manley 88mm Pistons|Supertech valve spring kit|Balance shaft delete|ACT 6 puck sprung clutch|Streetlite flywheel|PNP stock Intake manifold|PNP cylinder head by Realgib3|custom 4" intake pipe|HKS SSQV|CPE Stage 2 RMM|CPE TMM|CPE PMM|Custom Cat Back|Custom Long Downpipe|TRE 1045 FMIC|JBR oil catch can|Sonic Tuning coilovers|SS Brake lines|Blank rotors|hawk HPS pads|6th port w/ 2 2200 cc injectors|PTE DBB 6266 Gen 2 v-band all the things|Homemade Tubular Exhaust Manifold|Tuned by Realgib3|SP63 Aux Fan controller | |
| The Following 2 Users Say Thank You to HOCKEYNUBE For This Useful Post: | speedfreak44 (12-24-2015), SpeedRebirth (12-24-2015) |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score Copper will have less resistance than the steel springs. Copper is an extremely good conductor
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
| Not Ranked : 0 score Will keep this thread in mind if i ever have a issue.
(Thread Starter) | Not Ranked : 0 score I mean its a 6-10 dolla mod, may as well get it out of the way if you have a BT or are planning on one. or save it for a rainy day mod.
No issue on ko4 running 22 psi and spraying meth. But will keep it for a "rainy" day like you said
| Not Ranked : 0 score So I got copper wire from lowes today and told the guy I wanted 4 gauge so he cuts me 2 feet. I get home with it and crossreference the item number and it comes up as 8 gauge. It looks identical in size to the above picture though so hoping he is wrong. Going to do this mod next sparkplug change just because I can.
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
| Not Ranked : 0 score Its 4 Gauge. I mic'd it. He put the wrong part number on the tag was all
| The Following 2 Users Say Thank You to speedfreak44 For This Useful Post: | Boost_creep (04-25-2016), Mauro_Penguin (04-25-2016) |
| Not Ranked : 0 score Also to clarify, cut these rods exactly 2.6" long and then take some sand paper and round the tips a little bit. Apply a little dielectric grease on the end going into the boot and the end touching the spark plug. 2.6" is perfect for the coil to still be able to seal the valvecover
| The Following 7 Users Say Thank You to speedfreak44 For This Useful Post: | Boost_creep (04-25-2016), ItsNox (04-25-2016), Mauro_Penguin (04-25-2016), MS3Shadow (04-25-2016), rymanmazda (09-06-2016), SpeedRebirth (04-27-2016), WetzMS3 (09-07-2016) |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score I have never seen #4 AWG solid wire and I'm an electrician that works in a wire making plant. #6 Is the largest solid wire I've seen. Anything above that is stranded. Send me a link. Are you sure that's not a copper ground rod?
__________________ 3rd rebuild on the way...maybe... |
| Not Ranked : 0 score Southwire (By-the-Foot) 4 Solid Bare Copper Wire-10644390 - The Home Depot
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
| The Following User Says Thank You to WetzMS3 For This Useful Post: | Cheapspeed (09-07-2016) |
| Not Ranked : 0 score He's correct I just looked it up myself. That's a serious grounding wire. Copper is excellent. Best conductor is silver. But that's a little more expensive.
| The Following User Says Thank You to Cheapspeed For This Useful Post: | WetzMS3 (09-07-2016) |
![]() | | #24 | ![]() |
Are there any known lessor quality vendors to avoid?
![]() | | #25 | ![]() |
| Not Ranked : 0 score I'm working in a plant who competes with Southwire. Copper wire is universally spec'd the same as far as resistance so our calculations can be accurate for code reasons. Copper pipe for plumbing is an alloy that is not as conductive. What he has is fine for the purpose.
| The Following 3 Users Say Thank You to Cheapspeed For This Useful Post: |
![]() | | #26 | ![]() |
Groans: 111
| Not Ranked : 0 score So the 4g copper rod is supposed to be 3/16 inches or 4.8-5mm in diameter, right? Did anyone try 6g (5/32"/4mm) diameter copper rod? It's pretty damn hard to source 5mm diameter copper solid wire in my area, they only sell it in 100 meters rolls and if I ask anyone on construction sites they all use multi-wire cables (with 3 to 5 5mm/0.1" diameter copper wires inside) because they are more flexible and less prone to issues with high temperature variations.
![]() | | #27 | ![]() |
Groans: 111
| Not Ranked : 0 score So the 4G cable is 5.19mm in diameter, and 21.15mm2 cross section surface. Around here we have cables rated by the section surface in mm2, so we have cables of 16, 25 or 35 mm2. This means the cross section diameter is 4.5mm/0.177", 5.64mm/0.22" or 6.68mm/0.26". So now my question for those who made this mod can you please tell me what are the restrictions when working with these coils? Is it the inside diameter of the coil, boot, or it's all about cross section?
![]() | | #28 | ![]() |
Groans: 111
| Not Ranked : 0 score Good. So I managed to source some 5mm diameter (4g basically) copper wire used in industrial power converters. The copper wire also has a pretty tough layer of enamel .
![]() | | #29 | ![]() |
| Not Ranked : 0 score i'm sceptic of this thing. Secondary voltage is very high, current is very low so the effect of a tiny resistance difference in that circuit would give marginal improvements. Power = (Volt x volt) / R You probably get less than 1 ohm reduction by doing this out of a total secondary circuit of few kilo-ohms....Does it really worth it ? IMo it could create more chances for problems if the rod isn't perfectly fitted with exact spark plug length ? (Air gap is a lot more résistive than a spring. One could probably get better results by improving 12v power and grounds to the coils instead...There you have low voltage high current and low circuit resistance.
![]() | | #30 | ![]() |
Groans: 111
| Not Ranked : 0 score All I can do is try, because I have some issues (spark blow-out) which people reported they solved with this change.
![]() | | #31 | ![]() |
| Not Ranked : 0 score ok but it may work just because you put new or different spark plugs too. the 12v 5-15A power and ground is carried out by, let say 18awg wires (0.75mm2) so enlarging them would have a 1000times more effects. I wonder if the igniter inside the coil would resist to more than 14-15v. So voltage booster exist for fuel pumps that could work the same to increase coil power.... just going from 14 to 16volts could give a 30% more power.
![]() | | #32 | ![]() |
| Not Ranked : 0 score looking for the boost a pump to give an exemple, i found that a module already exist to boost coils voltage to 18v PowerMAX V2 SparkMAX - Universal Splice In Ignition Booster - JMS
![]() | | #33 | ![]() |
Groans: 111
| Not Ranked : 0 score Problem persisted after replacing the spark plugs with new ones gapped a bit tighter (0.6mm instead of 0.65).
![]() | | #34 | ![]() |
Groans: 111
| Not Ranked : 0 score Ok, as far as I can tell the spark blow-out is gone.
![]() | | #35 | ![]() |
| Not Ranked : 0 score you mean that after installing the copper pins, it solved the issue ?
![]() | | #36 | ![]() |
Groans: 111
| Not Ranked : 0 score As far as I can tell yes, it's gone. I didn't even have to log that (didn't see much in the logs actually), the blow-out feels like an aggressive correction of some sort or like a gentle cut.
![]() | | #37 | ![]() |
| Not Ranked : 0 score I'm glad it works, but i'm still confused because the ohm law alone cannot explain why.
![]() | | #38 | ![]() |
![]() Join Date: Dec 2017 Location: Idaho
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
| Not Ranked : 0 score I agree with you in beefing up the delivery system to the coils would yeild far greater results. But maybe the coiled wire in the coil packs is the weakest link and that is really all that needs fixed?
__________________ 2011 MS3 Tech - 2008 Jeep Grand Cherokee CRD - 1989 Crown Vic LTD LX - 1985 Lincoln Town Car Signature The key to happiness is owning a car ridiculously slower than your 'fast' car. |
![]() | | #39 | ![]() |
Groans: 111
I went out yesterday for a joy ride and the car pulls as hard as it should, it's back below 4s for 60-100mph where it was before, although now it may pull just as hard but in significantly warmer weather now. So I can resume my quest of boosting up to 32PSI and trying to hit 500bhp on this setup.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() | | #40 | ![]() |
There is an inductive resistance value increasing with engine speed but it may also affect spark waveform. Electronics use coils to transform an high peak of short duration into a lower peak of more duration....We want the opposite here...
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
