> 2010 MS3 - How-To's
Like Tree13Likes
 Old 09-29-2015, 03:19 PM   #1
HOCKEYNUBE's Avatar
Posts: 144   (View Stats)
HOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the worldHOCKEYNUBE is the leader of the world
Default How To: Solid Copper Coil Pack Spring Replacment
THIS IS NOT A PERFORMANCE MOD!!!
This mod only helps if you are experiencing "boost blow out" despite what you are gapping your plugs to.
The spring stretch mod does not do anything in my eyes, so I've seen bits and pieces of people putting solid copper in their coil packs to help the spark strength carried from the coil pack to the plug. Well let me tell you it is working great for me, no more blow out and here is how you do it!
Step 1: go to Lowes or Home Depot and buy yourself a foot or two of 4 gauge solid copper wire (go to the wire cutting area in the electrical department) it was less than $3 dollars for two feet for me.
Step 2: cut off a small section of the wire (to square it up to a nice flat surface I found that a brake line cutting tool works really well)
Step 3: cut four pieces of copper to roughly 2.5" (doesn't have to be machine work tolerance but get it as close as you can)
Step 4: pull your coil packs out of your car.
Step 5: separate the boot from the coil pack.
Step 6: pull the spring out (id recommend holding onto them just in case)
Step 7: reinstall the boot
Step 8: reinstall the coil packs (now at this point you need to check something, verify that the coil pack itself is close enough to the valve cover(where the screw goes) so when you tighten down the coil pack you wont crack it and vise versa if you put you coil pack on and the coil pack bottoms out where the screw goes, your copper is most likely too short)
Step 9: start it up! (you may have a misfire, just track down the cylinder more than likely your copper is too short and just cut another piece!)
Step 10: enjoy your boost without blow out any more!!!!
2010 MS3 Black mica|Custom head gasket|Custom timing cover gasket|Keyed crank|Manley H-Beams|Manley 88mm Pistons|Supertech valve spring kit|Balance shaft delete|ACT 6 puck sprung clutch|Streetlite flywheel|PNP stock Intake manifold|PNP cylinder head by Realgib3|custom 4" intake pipe|HKS SSQV|CPE Stage 2 RMM|CPE TMM|CPE PMM|Custom Cat Back|Custom Long Downpipe|TRE 1045 FMIC|JBR oil catch can|Sonic Tuning coilovers|SS Brake lines|Blank rotors|hawk HPS pads|6th port w/ 2 2200 cc injectors|PTE DBB 6266 Gen 2 v-band all the things|Homemade Tubular Exhaust Manifold|Tuned by Realgib3|SP63 Aux Fan controller
HOCKEYNUBE is offline   Reply With Quote
The Following 15 Users Say Thank You to HOCKEYNUBE For This Useful Post:
865ms3 (11-04-2015), Boost_creep (04-25-2016), Code Monkey (11-06-2015), impossible (06-10-2017), Jh8909 (12-19-2015), Mauro_Penguin (09-29-2015), mituc (07-07-2018), MS3Shadow (11-04-2015), nekret (09-30-2015), shaneski (10-01-2015), sho (12-19-2015), speedfreak44 (11-04-2015), SpeedRebirth (12-19-2015), Tommyspeed3 (08-27-2017), WetzMS3 (09-29-2015)
Page generated in 0.63458 seconds with 34 queries
