> 2010 MS3 - How-To's
 Old 01-23-2016, 02:29 PM   #1
StevenPThomas's Avatar
Posts: 201   (View Stats)
StevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant futureStevenPThomas has a brilliant future
Groaned at 9 Times in 5 Posts
Default Rear Bumper Removal on Gen 2 Speed 3
I've looked and cannot find a how to for removing the rear bumper so I can paint the valence.
StevenPThomas is offline   Reply With Quote
 Old 01-23-2016, 03:54 PM   #2
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
I don't think I've seen a how-to for that here either. The folks that are VIP have access to download their respective model's service manual which provides the steps to remove/install body parts. You'll likely get some good props should you choose to create a how-to for the bumper cover removal/install and paint prep should you consider it.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
 Old 01-23-2016, 05:39 PM   #3
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
I painted the valance without removing the bumper. Just tape off and do a good job with your prep work you'll be fine no need to remove entire bumper.
Edit: this was on my vrm 12' I had before my silver 13'
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 01-23-2016, 05:50 PM   #4
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
http://support.corksport.com/instruc...-8-060-WEB.pdf
Your clips will go to shit and your bumper will stick out at the corners by your rear qtr panels.
MECP
2012 BM
Rfinkle tune in progress
 Old 01-23-2016, 09:09 PM   #5
Just paint it on the car.
front bumper removal? Sampson0519 2010 MS3 - How-To's 9 12-20-2014 01:10 PM
Looking for a Gen 2 rear bumper cover removal how to. ep87 Gen2 MS3 General Discussion 2 09-11-2012 06:28 PM
How to: CX-7 Rear Bumper Removal Raider CX-7 > How-To's 3 02-28-2011 02:34 PM
Rear Bumper Removal ?? damianinpa MazdaSpeed 6 - How-To's 1 12-16-2010 04:39 PM
How To: CX-7 Front Bumper Removal Raider CX-7 > How-To's 0 11-04-2010 09:45 AM
Page generated in 0.26025 seconds with 24 queries
