> 2010 MS3 - How-To's
Like Tree23Likes
 Old 10-09-2013, 01:02 PM   #81
JgamB's Avatar
Posts: 2,566   (View Stats)
Pretty sure the consensus was 2012 and newer *and* build dates in the calendar year 2012 only. My '13 shows no signs of SWAS (verified by log) using the press n hold for 6 seconds.
manila (10-09-2013)
 Old 10-09-2013, 01:11 PM   #82
manila's Avatar
Posts: 1,767   (View Stats)
I remember seeing this about certain 12's and their build dates.
In a log, what are things to look for (signs) of SWAS kicking in?
I'm assuming boost and AFR.
'12 MS3 Black Mica w/ Tech
 Old 10-09-2013, 01:17 PM   #83
JgamB's Avatar
That is the extent of what I've heard, not sure about retarding spark advance. I didn't have an AP when I first experienced SWAS, but it was blatant enough intervention that I certainly didn't need a log to feel the difference.
The logs I took with it disabled maintained full boost, 18.5* timing, and 11.8-12.0 AFRs as I was thrashing my way around highway underpass U-turn lanes. I brought my wife along to scare the shit out of her, was good times.
 Old 10-09-2013, 01:23 PM   #84
manila's Avatar
Exactly what I needed to know, thanks
Should of setup a GoPro lol
 Old 10-09-2013, 01:31 PM   #85
GODspeed7's Avatar
Posts: 3,456   (View Stats)
This trick only works for 2012-2013 cars
2012 Mazdaspeed3 Black Mica
 Old 10-09-2013, 02:11 PM   #86
lk250f's Avatar
Posts: 253   (View Stats)
lk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the world
I am so glad to have seen that holding it disables it. Rather not hack up my new car.. SWAS is a bitch
2013 CWP Mazdaspeed3
lk250f is offline   Reply With Quote
 Old 10-09-2013, 02:48 PM   #87
manila's Avatar
I haz 2012. What's the build date on your 12'?
 Old 10-09-2013, 03:18 PM   #88
Polish_Eagle's Avatar
Posts: 408   (View Stats)
1. turn car on like normal
2. Hold dsc off button for around 10s
3. release button
4. I push it a second time to verify it stays off because if you do it properly it won't cut off until you turn the car off
Too bad that doesn't work on the '11 without tech package. Holding it just makes the everything permanently on until you restart the car. Pulling the plug is the only solution for '11 without tech package.
 Old 10-10-2013, 04:20 PM   #89
GODspeed7's Avatar
August of 2011 I think... I bought it November 2011
 Old 10-10-2013, 05:40 PM   #90
manila's Avatar
Mine was in July
Does holding the DSC/Trac button disable SWAS for you?
 Old 11-04-2013, 07:18 PM   #91
Just another experience.
After reading here I was under the impression that on my 2013, holding the dsc button for ten or so seconds until the light won't turn off, would disengaged swas.
While tuning with @rfinkle2, after adding enough power, it became evident in logs and vd that swas was still active.
I have since disconnected the connector itself, as detailed in post #15 . It took all of 10 minutes and two screwdrivers.
HawkeyeGeoff likes this.
HawkeyeGeoff (12-06-2013), rfinkle2 (11-05-2013)
 Old 11-08-2013, 12:37 PM   #92
esms3's Avatar
Posts: 52   (View Stats)
esms3 has much to be proud ofesms3 has much to be proud ofesms3 has much to be proud ofesms3 has much to be proud ofesms3 has much to be proud ofesms3 has much to be proud ofesms3 has much to be proud ofesms3 has much to be proud ofesms3 has much to be proud ofesms3 has much to be proud of
So I did this just today, it works but my car is still running very rich when it should be targeting 11.7-8 during WOT but it dips down to 9 during WOT should i just add an on and off switch by cutting the white wire. I have a 2012 speed! this is annoying me haha
esms3 is offline   Reply With Quote
 Old 11-08-2013, 12:46 PM   #93
I am actually experiencing the same issue at the moment.
Rob seems to have figured out why and sent me a revised map this morning. If it resolves the issue, I'll let you know and have Rob explain the solution better than I can. Unfortunately, I'm stuck behind a fucking desk for a while yet. But I plan to get logs this evening.
EDIT- This issue is occuring on my e85 mix map.
@rfinkle2
 Old 11-08-2013, 12:58 PM   #94
JgamB's Avatar
Do me a favor and plug your SWAS back up after Rob has resolved your AFR issue. You'd be the first person I've seen with a '13 that wasn't turning it completely off with the 6s hold, and if you're still getting sub 10 AFRs with it disconnected, there's no way you can correlate the two.
 Old 11-08-2013, 01:03 PM   #95
I planned on it, partly out of curiosity, and partly to add information here. There are alot of varying opinions and experiences in this thread. It makes it tough to determine the correct solution. So more info could be helpful to others in the future.
I do plan to run it unplugged regularly. My dumb ass doesn't like to have to remember to hold that damn button.
And FWIW, I always had to hold mine for 10-12 seconds for it to take.
 Old 11-08-2013, 01:16 PM   #96
JgamB's Avatar
Non-tech?
 Old 11-08-2013, 01:24 PM   #97
Non-tech?
Correct
 Old 11-08-2013, 01:49 PM   #98
2eatV8everyday's Avatar
Posts: 302   (View Stats)
2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world2eatV8everyday is the leader of the world
Groaned at 6 Times in 2 Posts
Just an FYI, when doing 3rd gear logs, even with disabling traction control or DSC/SWAS completely, because of the amount of wheel spin I would get (even a minor amount), it would cause my car to run rich, hitting around 10.2 - 10.8 AFR right around where the wheel spin would kick in.
I validated that wheel spin was the culprit. I tested the logic of doing a 4th gear pull, which would have almost no wheel spin, turned off traction control completely, and went WOT around 2500 RPMs. My AFRs were near perfect, between 11.5-11.7 under full boost.
I also tried doing a 3rd gear log to see if this would change my AFRs in 3rd, and with it on or off, I got close to the same rich AFRs
Stocked Out with my Cock out
2eatV8everyday is offline   Reply With Quote
 Old 11-08-2013, 01:53 PM   #99
Which method did you use to disable it completely?
My logs have all been done with 4th gear pulls, no wheelspin except the few times roads were wet and I was being impatient.
 Old 11-08-2013, 02:27 PM   #100
Sorry I meant to say stability control and not SWAS. From my understanding, holding down the button for 6 seconds disables stability control and traction control completely.
 Old 11-09-2013, 08:32 AM   #101
Well, @rfinkle2 resolved my rich condition issues via ATR. I will let him explain it, so I don;t sound like an ass-hat attempting to.
I will reconnect SWAS and try the button method again after Rob finishes revisions on my e85 map. I'll update my findings on the button vs. connector disconnects then.
rfinkle2 (11-09-2013)
 Old 11-09-2013, 08:38 AM   #102
Wetzms3 is being nice. It was a major derp on my part and I overscaled his maf curve like a dunce.
WetzMS3 likes this.
 Old 11-09-2013, 08:41 AM   #103
Well I'm headed out for those test logs now. So we should be able to answer the disconnect questions in a few days.
JgamB (11-09-2013), rfinkle2 (11-09-2013)
 Old 11-18-2013, 09:26 AM   #104
Hess22's Avatar
Posts: 31   (View Stats)
Hess22 is just really niceHess22 is just really niceHess22 is just really niceHess22 is just really niceHess22 is just really nice
Orange clip check
2013 SILVER PU CS SRI// CS TIP// CS SSP// CXRACING FMIC// Forge BPV// COBB AP// AT Internals// NGK Iridium Plugs// CNT DOWNPIPE// CUSTOM CATBACK// SOME CORN!
Hess22 is offline   Reply With Quote
 Old 12-05-2013, 07:26 AM   #105
manila's Avatar
@WetzMS3; Any update?
 Old 12-05-2013, 07:32 AM   #106
My bad, I've been meaning to do it, but just haven't gotten around to it. I'm putting in a new tmic tomorrow night, then revising maps with Rob. So I'll have to get logs in this weekend. I'll bring a screwdriver and reconnect it for a pass or two then.
manila (12-05-2013), rfinkle2 (12-05-2013)
 Old 12-05-2013, 08:01 AM   #107
nybe0010's Avatar
Posts: 276   (View Stats)
nybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the worldnybe0010 is the leader of the world
Groaned at 3 Times in 1 Post
I have a non tech 11. So what's the difference between pushing and shutting dsc off vs. holding it, since that doesn't disable swas? is there a different mode between pushing it off vs holding? When i hold it in the dsc off indicator comes on ,then after the 10 sec. (seems like a long ass 10 sec. Lol) it shuts off. You said that makes everything permanently on did you mean off? my car drives like the dsc is off even though the indicator light for it is not on. Freek said I was getting some erratic afr's on my 3rd gear logs and swas was freeking out. we were going to start from 4th gear to avoid some torque steer and wheel spin. he just sent me a map so we could try and get some clean logs, and then it fucking snowed so now I have all winter to decide if I'm going to do a toggle switch or just unplug come spring...
11' Black Mica MS3 ATK Reman Long Block iMOTO Shift Forks LuK Clutch Fidanza Flywheel
GC+Koni Coilovers CNT CBE JBR Trilogy Mounts Forge V1 BPV CPE SafeSeals Block8Head Dual Vent Pod Blowshift Boost / OP
nybe0010 is offline   Reply With Quote
 Old 12-05-2013, 08:12 AM   #108
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Let me save you LOTS of frustration and time: Disconnect SWAS and be happy. Drive MS3 the way it was meant to be driven! No artificial barriers!
rfinkle2 and kritz like this.
Silver 2007 Speed3 GT
The Following 3 Users Say Thank You to HawkeyeGeoff For This Useful Post:
nybe0010 (12-05-2013), rfinkle2 (12-05-2013), WetzMS3 (12-05-2013)
 Old 12-05-2013, 08:53 AM   #109
nybe0010's Avatar
haha alright fair enough that will be first on my list after winter. Still curious if there a difference though between holding and pressing dsc?
 Old 12-05-2013, 09:09 AM   #110
manila's Avatar
Default SWAS - DISCONNECT ON A GEN2
I unplugged SWAS, but my clip was red color not orange.
My BSM/AFS lights are blinking constantly while driving. The light closest to the top on the RPM cluster stays lit too.
I have a 12' tech
Sent from tappin them titties
 Old 12-06-2013, 07:10 AM   #111
I have a 12' tech
Ze' 2010 does not blink. Just sits there with the power steering + traction control lights on. I have grown accustom to those being lit up...as well as my check engine light for the DP lol. I have a christmas tree dash.
JTMS3 (12-06-2013), manila (12-06-2013), rfinkle2 (12-06-2013)
 Old 12-06-2013, 07:17 AM   #112
Geoff, if you have codes, I can kill them for you. I'm always concentrating on the tables and forget the code deletes.
manila (12-06-2013)
 Old 12-06-2013, 07:21 AM   #113
Oh nice! I just have the typical DP ones. When my car comes out after the winter, I will let you know which codes need to be masked. Can the power steering + traction control lights be masked as well?
 Old 12-06-2013, 07:25 AM   #114
Only with tape... lol
The Following User Says Thank You to Polish_Eagle For This Useful Post:
 Old 12-06-2013, 07:26 AM   #115
Homer Simpson Style.
Whatever, I like them anyway!
 Old 12-06-2013, 07:34 AM   #116
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
Maybe I missed this along the way, but if you unplug the orange plug does your PS still work? I accidentally disabled my PS while driving once and it was a bit heavy for my girl arms.
The Following User Says Thank You to Mike@Stratified For This Useful Post:
 Old 12-06-2013, 07:36 AM   #117
I lost PS on my 13 when I disconnected it. Not the end of the world.
Mike@Stratified (12-06-2013), rfinkle2 (12-06-2013)
 Old 12-06-2013, 07:42 AM   #118
The power steering will only go out intermittently for a few seconds in parking lot speeds (1-5 mph). I've never had it go out while not moving.
To me it's not a big deal, but it bothers some people. I say its totally worth it to have no SWAS .
JTMS3 (12-06-2013), Mike@Stratified (12-06-2013), rfinkle2 (12-06-2013)
 Old 12-06-2013, 08:25 AM   #119
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
I have a 12' tech
The wireing on 12 are a bit different for the tech package and the blind spot and turning lights use the same plug. If it bothers you u can simply just add a switch on the wire only for the swas.
I'm planning to do this for @killer-ms3; since his dash looks like Santas enchanted forest.
TEAM LUXURY
manila (12-06-2013)
 Old 12-06-2013, 08:27 AM   #120
killer-ms3's Avatar
Posts: 1,187   (View Stats)
killer-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the world
Groans: 32
Non-hialeahians wont know what santa's enchanted forest is lmao @Sid3wayS;
Nator FL, bitch
GTX3071 EWG w/ Supporting Mods and some Mef
Tuned by THE FREEK
killer-ms3 is offline   Reply With Quote
I need SWAS pictures! mexicant MazdaSpeed 3/6 - ECU Computer Tuning 33 10-26-2016 07:23 PM
SWAS on 2010 harryclay 2010 MS3 - ECU Computer Tuning 20 03-21-2016 04:11 PM
The disconnect of connected cars Haltech Automotive News 0 05-03-2010 07:20 AM
Toyota's U.S.-Japan disconnect Haltech Automotive News 0 03-01-2010 10:10 PM
swas sensor help! madvillain Mazdaspeed3/6 General Discussion 1 01-20-2009 04:15 PM
Page generated in 0.63481 seconds with 35 queries
