> 2010 MS3 - Wheels & Tires
  • 2 Post By Oshiguru
 Old 05-10-2019, 05:25 AM   #1
eliwwjd's Avatar
Posts: 518   (View Stats)
Default Decision to make on tire size
Im about to be done with my contis extreme contact sport tires and i need to change tires soon. At the moment im on oem size 225/40 R18 but was considering on a tire that would fill a little bit more the area without the need to lower springs and also get better acceleration, grip and traction. My friend recommended me 235/40, get a little wider and at the same time a slight higher sidewall. The other size i though about was 225/45 but not sure if this size would look good. Im so undecided here!
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
 Old 05-10-2019, 09:32 AM   #2
Bertospeed3's Avatar
Posts: 149   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
Tire size wont reduce wheel gap much. You'd have to modify the suspension.
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
Bertospeed3 is offline   Reply With Quote
 Old 05-10-2019, 10:37 AM   #3
ThorOtheBIG's Avatar
Posts: 56   (View Stats)
ThorOtheBIG has a spectacular aura aboutThorOtheBIG has a spectacular aura aboutThorOtheBIG has a spectacular aura about
It's simple. Do the math.
225/40 = 5.625 Stock tire sidewall height
235/40 = 5.875 Friend's recommendation
225/45 = 5 The tires that you are looking at
So, it seems like your friend recommended tires that are taller than stock, which means it would "fill" the gap more. The tires you are looking at are very short, meaning your tires will appear smaller (more gap). I'd listen to your friend.
Also, Bertospeed3 is right.
Personally, I put some slightly wider and taller tires on my Mazda5. It helped grip, but reduced MPG by, idk, 5%?
ThorOtheBIG is offline   Reply With Quote
 Old 05-10-2019, 10:52 AM   #4
Oshiguru's Avatar
Posts: 102   (View Stats)
Oshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to all
You don't divide. The second number is the aspect ratio which is a percentage of the first number that determines the sidewall height. Think of tire 1's sidewall as 40% of 225, tire 2 is 40% of 235, and tire 3 is 45% of 225. The 225/45 is the tallest of all the three.
https://www.willtheyfit.com/index.ph...7-5&offset2=52
@OP
It also depends on what wheels you have and what tire you go with. Some tires run wider than others. I went from 225/40 on a 18x9 to a 245/40 and the wheel gap difference is minimal. It did "fill the gap" because the old tires were stretched and the new ones are not.
https://i.imgur.com/ejjxfgK.jpg 225 Michelin PSS
https://i.imgur.com/5pjgFZE.jpg 245 Michelin PS4S
Same wheels
deeAYEennENNwhy and b.hog like this.
Oshiguru is offline   Reply With Quote
The Following User Says Thank You to Oshiguru For This Useful Post:
ThorOtheBIG (05-10-2019)
 Old 05-10-2019, 11:14 AM   #5
Oh boy. That's right. HAHA! What an asshole *points to self*
More coffee for me.
Let's try this again.
225 * .4 = 90mm Stock tire sidewall height
235 * .4 = 94mm Friend's recommendation
225 * .45 = 101.25mm The tires that you are looking at
See if you can do a 235/45.
235 * .45 = 105.75mm
 Old 05-10-2019, 01:51 PM   #6
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
are you sure a taller tire will help these things?
94 M
MS6
IS350
 Old 05-10-2019, 03:39 PM   #7
Posts: 2,237   (View Stats)
a taller tire to fill the gap may also rub on the inner fender front. unless you do it by the ratio (45 instead of 40) but at some response loss. Your speedo will also be underrated and gears will get taller to make the car accelerate slower....
Probably not the best option ever....
 Old 05-10-2019, 08:47 PM   #8
eliwwjd's Avatar
So you mean 225/45 not the right choice? go instead with 235/40?
My friend has the 235/40 size on his car and i asked him if he noticed any changes in gas, road noise and acceleration differences and he said it felt same as oem size. This size is not suppose to run on fender.
 Old 05-10-2019, 09:27 PM   #9
Posts: 2,827   (View Stats)
It’s far more important that you get the best tire design and compound than obsess over trying to go wider and have less support on your rims or taller and lose gearing and induce speedometer error.
Get the best stock size tire you can afford: Extreme Performance rated summer tire or UHP all season.
My choice for a summer tire was the Extreme Performance rated Yokohama Advan Neova AD-08R. Very close to race rubber but with long life and very good wet traction as well. Michelin Pilot Sport 4S is the clear choice in the Max Performance category which gives up a little dry grip for a little better wet performance.
My UHP all season choice would be Michelin Pilot Sport A/S 3+, or the Conti DWS 06 you may be running now.
 Old 05-10-2019, 10:45 PM   #10
Oshiguru's Avatar
I'm guessing you're on stock wheels.
IMO. stay with 225/40 but get a stickier compound. Maybe one of the ones mentioned above. I generally noticed the stickier my tires, the worse my mileage and road noise got; but thats a small sacrifice for grip
 Old 05-14-2019, 08:13 AM   #11
Carskick's Avatar
Posts: 315   (View Stats)
Carskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond repute
On stock Gen 2 wheels, 225 is a good width. Go too wide and you can have rollover. 235 max, IMHO. If want more lateral grip, go wider wheels. Otherwise, stay stock size and stickier compound will be the easiest fix. Stickier compounds tend to get worse MPG as generally have a higher rolling resistance.
The Contintental ExtremeContact Sports are pretty sticky. Not quite R rubber, but on par with Michelin PSS. I run the same tires as 245/40/18, but they're on 8.5" wide wheels.
As others mentioned, the larger the diameter of the tire, the more it will create speedo error and widen gear ratios. My Gen 1 speedo was always about 2MPH over reality, with 245/40, the slightly larger sized made it basically dead on.
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
Carskick is offline   Reply With Quote
 Old 05-16-2019, 05:42 AM   #12
eliwwjd's Avatar
Thanks to all those who have kindly shared their opinions and suggestions.
By any chance is there any member here who has 235/40 R18 tires mounted on stock rims and oem suspension that can kindly share some pictures? Thanks in advance for your help!
 Old 05-16-2019, 10:34 AM   #13
My old stock setup. Only difference is I was running 25mm spacers but that should not make a difference in what you're looking for.
CP-e TMIC
JBR 88 Duro RMM
The Following User Says Thank You to Bertospeed3 For This Useful Post:
eliwwjd (05-16-2019)
 Old 05-16-2019, 04:04 PM   #14
eliwwjd's Avatar
Dam! it looks really good! Thanks for kindly sharing. How did it perform in comparison with 225/40?
 Old 05-16-2019, 04:24 PM   #15
eliwwjd's Avatar
I sent you a PM but not sure if you got it. Let me know if you did. Thanks guy
 Old 06-15-2019, 10:45 AM   #16
eliwwjd's Avatar
Once again thanks to all the great members here who have kindly shared your thoughts and helped me decided. Here is the thing, Continental is giving me a 60 days trial so i can test the tires. The manager told me to try them(do not track them) if i don't like them, i can return them. I'm going to try 235/40 to see how car behaves, if not i can go back to 225/40.
They also gave me a warranty wear out credit of almost $300 because my tires lasted 15K miles so shipped to P.R. we are talking about $600 for all 4 and thats not bad, these tires here cost over $200 a piece.
Some of you mentioned here "response loss" but theorically a wider tire is suppose to give you better acceleration and grip right? so that been said anybody here with stock rims that have gone to 235/40 experienced any response loss? because from what some people have told me is they felt as oem and didn't noticed any response loss and what continental told me is that the difference between 225/40 vs. 235/40 is very minimal practically un-noticable but i always like to see from users what has been the real life experience
 Old 06-15-2019, 02:06 PM   #17
Braking might be a tiny bit shorter 235mm vs 225mm same tire, otherwise.
Acceleration might be a tiny bit slower with the same 40 aspect ratio profile, because it will be a little taller, effectively making gearing a little bit taller. Speedo will be off a little.
Unless rims are widened, slightly wider tires otherwise identical may handle worse, as they tend to roll over easier and weight more.
 Old 06-15-2019, 02:28 PM   #18
eliwwjd's Avatar
Well acceleration is suppose to improve technically because you get better grip with a wider tire, think about it why do drag strip cars have installed wider tires.
Handling does improve according to a few who haved made the change to 235's, in a sense they are still a low profile tire so no roll over takes place, at least according to the few that have made the change. Tire weight is very relative because for instance conti extreme contact weight 21 pounds which is less weight then the majority of the tires on the market. I used an oem size tire made by bridgestone which weight 25 pounds.Trust me that is one of the things i look into, weight. This tire is the one of the least that weights, so more weight isn't an issue for me considering the tire ill be using. Will see when i get the tires what happens. Height adjustment from one to the other is .2 to .3 inches, thats barely nothing
 Old 06-15-2019, 09:05 PM   #19
Carskick's Avatar
Taller gears will give worse acceleration, assuming you have traction. Will 235 give you more grip than 225 on stock wheel? Maybe. Depends on which tire. But a wider wheel is needed to fully take advantage of it. A lot of variables. As others said, compound will likely matter most to determine traction/grip.
 Old 06-15-2019, 11:29 PM   #20
Your preconceived bias is showing. With respect, you are minimizing the very real negatives and maximizing trivial, if existent, positives.
Taller tires is taller gearing, which is slower acceleration. Fact. Period.
Wider tires does not mean better handling, especially on stock rims. Weight will go up. That is more unsparing weight, the worst kind. The outside and inside edges will have less support and will tend to roll in corners, causing the opposite side to lift away from the pavement if not supported by a similarly wider rim.
Wider may not actually put more rubber in contact with the road. These are not drag slicks. Actually taller will put more rubber in contact than wider. The contact patch is small, but it goes all the way around as the tire rotates, that is why drag tires tend to be tall, but the gears are shortened to compensate for this, which you are not.
There is extremely robust research on effect of height and width on contact patch and traction.
You get far more grip from softer tread compound and less voids in the treads than from increasing width. If you want more grip go with dedicated Extreme Performance summer tires in stock width to match your rims.
It seems you are seeking approval of an already made decision regardless of the facts. That is called confirmation bias. Confirmation bias is the tendency to search for, interpret, favor, and recall information in a way that confirms one's preexisting beliefs or hypotheses. It is a type of cognitive bias and a systematic error of inductive reasoning. In short, because you want it to be true, therefore it is true.
For what it is worth, Car and Driver, not too long ago, published an article that showed that wider, heavier tires, even if the same height, often produce slower lap times unless rims are widened too, as the wider tires roll laterally on the rims in cornering.
Look, if you want 10mm wider tires that are also taller because they look good or may fill out your wheel wells a bit more (the original purpose of your post), go for it. It will make you happy. Just don’t expect us to validate a performance gain.
The Following 3 Users Say Thank You to MSMS3 For This Useful Post:
Carskick (06-16-2019), hartlch (06-16-2019), Jeff23spl (06-17-2019)
 Old 06-17-2019, 07:57 AM   #21
You also need to separate handling feel VS faster lap time....
smaller sidewall gives more feedback into the steering wheel but it isn't giving the best traction contact with the road. Manufacturer don't increase wheel size for handling but to fit larger brakes....
Need to make decision! need some advice eliwwjd 2010 MS3 - Turbo Induction 30 03-02-2014 07:37 PM
Need quick advise on tire size and rim size setup sensui MazdaSpeed 3/6 - Wheels & Tires 1 03-18-2011 12:10 PM
Report: Honda slashes board size to speed decision making Haltech Automotive News 0 02-23-2011 02:20 PM
MS6 or MS3 Help me make my decision. Godofelru Mazdaspeed3/6 General Discussion 8 12-02-2008 02:10 PM
Page generated in 0.42901 seconds with 28 queries
