> 2010 MS3 - Wheels & Tires
Like Tree13Likes
  • 1 Post By rgz
  • 4 Post By dbrier
  • 1 Post By dbrier
  • 1 Post By dbrier
  • 4 Post By SmoothVanilla
  • 1 Post By BigK
  • 1 Post By clintosaraus
 Old 09-30-2011, 10:25 AM   #1
2011speed's Avatar
Posts: 1,497   (View Stats)
Default stock height/aftermarket wheels
Ive made my decision to not fuck wit the suspension on my pu, not into the whole herrafrush thing anyway.
Just wanna see some speeds with aftermarket wheels but still on stock ride heights. Please include the wheel n tire specs.
So far I'm thinkin about rota boosts 18x8.5 wit a -35 offset on 235 tires wit a little meatier profile to cover up the gap
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
 Old 11-10-2011, 01:31 PM   #2
shittles's Avatar
Posts: 10   (View Stats)
shittles is infamous around these parts
Groaned at 17 Times in 3 Posts
Boost are for 5th Gen Civics 9" or GTFO... that = what this idiot says on every wheel thread.
shittles is offline   Reply With Quote
 Old 11-10-2011, 10:36 PM   #3
rgz
rgz's Avatar
Posts: 397   (View Stats)
rgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the worldrgz is the leader of the world
going wider tire isn't going to reduce any of the hideous gap unless you go a taller profile tire. Either way, you should at least get some swift springs.
specvspeedfreak likes this.
rgz is offline   Reply With Quote
The Following User Says Thank You to rgz For This Useful Post:
rfinkle2 (07-09-2012)
 Old 11-10-2011, 11:35 PM   #4
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
aftermarket wheels on stock suspension look stupid.
The Following 5 Users Say Thank You to specvspeedfreak For This Useful Post:
ezpotato (06-19-2013), InFeXIoN (11-11-2011), rfinkle2 (07-09-2012), thems3driver (10-13-2014), wake2011 (03-25-2013)
 Old 11-11-2011, 12:10 AM   #5
2011speed's Avatar
As u can see i said fatter profile tire.
And considering the speeds aren't too tall stock height, supermarket wheels look decent
FreeKtuned
fitty fitty
 Old 11-11-2011, 12:22 AM   #6
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
I'm the same way as you.
I live in a pretty hilly area, and the ramps around here can get pretty primal.
I wish I could, but I can't afford any kind of drop. I scrape being cautious enough as it is, everyone thinks I'm making a wrong turn when I go diagonal into a parking lot lol
Koni FSD's when the time comes, with stock springs since that's what they're designed for.
Though new wheels is pretty low on my list of mods, need to get the reliability and efficiency mods in first. Wheels are pretty aesthetic to me.
And it'd be way cheaper to have OEM wheels re-done in whatever color/finish i like in the mean time.
2011speed (11-11-2011)
 Old 07-09-2012, 03:21 PM   #7
eugenes18t's Avatar
Posts: 55   (View Stats)
eugenes18t is the leader of the worldeugenes18t is the leader of the worldeugenes18t is the leader of the worldeugenes18t is the leader of the worldeugenes18t is the leader of the worldeugenes18t is the leader of the worldeugenes18t is the leader of the worldeugenes18t is the leader of the worldeugenes18t is the leader of the worldeugenes18t is the leader of the worldeugenes18t is the leader of the world
Groaned at 13 Times in 2 Posts
I would love to see what 19s would look like with stock height.
I thing the drag dr-31 might give the car a clean oem look.
eugenes18t is offline   Reply With Quote
 Old 07-09-2012, 06:58 PM   #8
Big Titty Sucker
BLK_MS3's Avatar
Posts: 1,612   (View Stats)
BLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the world
Groans: 139
But then a taller profile makes the whole damn car sit higher....not good either.
BLK_MS3 is offline   Reply With Quote
 Old 07-09-2012, 07:11 PM   #9
Wide tire man
dbrier's Avatar
Posts: 957   (View Stats)
dbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the worlddbrier is the leader of the world
OK, here you go. My car is still stock.
Kosei K3, 18x8.5, +50, 245/40/18 tires
2012 Crystal White Pearl Mazdaspeed3
Cobb AccessPort, Autotech HPFP internals, Corksport Stage II intake with TIP and airbox, Corksport rear camber arms, Corksport catted test pipe, Denso ITV22 plugs, JBR rear sway bar and HD mounts, CP-e stage II rear motor mount, Mazda5 rear brake upgrade, Bilstein struts, Eibach pro springs.
Too many wheels & tires to list.
dbrier is offline   Reply With Quote
The Following User Says Thank You to dbrier For This Useful Post:
sarm1084 (04-22-2018)
 Old 07-09-2012, 08:57 PM   #10
jeoje's Avatar
Posts: 180   (View Stats)
jeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the worldjeoje is the leader of the world
Looks really good to me. No fender roll required?
2011 Liquid Silver Metallic MAZDASPEED3 -Traded...
Cobb AP | Autotech Internals | UR Catted DP | UR Resonated TP | UR CBE | Cobb TIP | CP-E Xcel Nano | CP-E RMM | JBR TMM & PMM | JBR OCC S2 | JBR SSP S2 | JBR EGR Delete | NGK Iridium IX
2015 Volkswagen Golf R - DCC, no mods
jeoje is offline   Reply With Quote
 Old 07-10-2012, 04:22 AM   #11
Wide tire man
dbrier's Avatar
I'm not sure. I rolled my fenders to clear my race wheels/tires. It looks like they might fit without a roll. The +50 offset helps and I don't have any strut rub issues, but it is close in the front.
Here's why I rolled the fenders. Also on stock suspension.
Rota Grid. 17x9, +42, 3mm spacer in the front, rear fenders rolled, 265/40/17 Star Spec tires.
sarm1084 likes this.
 Old 08-08-2012, 08:43 PM   #12
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
Looks a little wide to me...
 Old 08-09-2012, 05:12 AM   #13
Wide tire man
dbrier's Avatar
They are.
When they wear out, they will be replaced with 255/40/17 tires and I'll remove the spacers in the front. That should get them back in line with the fenders.
 Old 06-18-2013, 01:50 PM   #14
SmoothVanilla's Avatar
Posts: 200   (View Stats)
SmoothVanilla has a reputation beyond reputeSmoothVanilla has a reputation beyond reputeSmoothVanilla has a reputation beyond reputeSmoothVanilla has a reputation beyond reputeSmoothVanilla has a reputation beyond reputeSmoothVanilla has a reputation beyond reputeSmoothVanilla has a reputation beyond reputeSmoothVanilla has a reputation beyond reputeSmoothVanilla has a reputation beyond reputeSmoothVanilla has a reputation beyond reputeSmoothVanilla has a reputation beyond repute
Enkei Raijin 18x8 +45 offset. I love the look of them. Could lower the car but I have no fucks to give about it so..
2013 RAM sport
SOLD 2012 Mazdaspeed3 with tech pkg
JBR 88 Chromoly RMM/JBR Rear sway bar//JBR sri//Magnaflow cbe//35-20 tint//3M Smoked headlights,Tail lights,fogs and turn signals//CS led DRL//CS interior led kit//CS led fogs//MarkII Sharkfin//OEM Rainguards//Rally Armor UR mudflaps//Weathertech floor liners//GTA ipod kit//Passport 9500ix Hardwired//TWM replacement SS with A6 knob in gunmetal//RedlineGoods shift boots//Enkei Raijin 18x8 in matte black//
SmoothVanilla is offline   Reply With Quote
The Following User Says Thank You to SmoothVanilla For This Useful Post:
 Old 06-18-2013, 08:41 PM   #15
doctavus's Avatar
Posts: 1,728   (View Stats)
@Smooth
Are they factory tire specs? 225/40/18 ?
 Old 06-18-2013, 10:46 PM   #16
^^^yes factory tire size. Honestly in person unless the sun is shining blindly into the wheel wells it looks pretty decent as far as gap goes.
2013 RAM sport
 Old 06-19-2013, 07:39 PM   #17
Kvo_8's Avatar
Posts: 97   (View Stats)
Kvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant futureKvo_8 has a brilliant future
@SmoothVanilla Looks clean. The wheel gap isn't bad at all being on stock springs
Kvo_8 is offline   Reply With Quote
 Old 06-19-2013, 10:08 PM   #18
thanks. Like I said it could look better if lowered, but the winters and roads here suck shit so I compromise.
2013 RAM sport
 Old 06-25-2013, 01:21 AM   #19
BigK's Avatar
Posts: 4   (View Stats)
BigK will become famous soon enoughBigK will become famous soon enough
Not sure if you can get these in the US Inovit ST15 18x8" ET45 w/Goodyear ASY 2 225/40R18
I can go any lower because of Speed Humps and ramps I already scrape on. Bilstein B6 dampers for me when my shocks die.
2010 UK Mazda 3 MPS Mk2 l Sure Aeros SRI & Sidewinder TIP, Self Tuned on Cobb AP, Brembo GT Brake Kit, HKS Legamax Exhaust, Autotech HPFP, Ross27 Decat, Whiteline RARB, ITV22's, HEL braided lines, SURE S3 Track REM, Inovit ST15 18x8 ET45 w/Goodyear Asy 2's (Summer) Stock rims w/Pirelli SottoZero 240 Serie 2 (Winter)
BigK is offline   Reply With Quote
The Following User Says Thank You to BigK For This Useful Post:
 Old 07-31-2013, 12:06 PM   #20
[]V[]addog's Avatar
Posts: 42   (View Stats)
[]V[]addog has a spectacular aura about[]V[]addog has a spectacular aura about
great idea for a thread! hopefully some more people can keep sharing!
[]V[]addog is offline   Reply With Quote
 Old 09-15-2014, 01:50 AM   #21
pandita's Avatar
Posts: 989   (View Stats)
pandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the world
I have a strong interest in this as well. Post more pics people n_n
2013 CWP:
FREEKTUNE OTS
Cobb AP
Corksport Sri/Tip/Internals/Test Pipe/Rear Motor Mount/Solid Shifter Bushings/Cat Back Exhaust
Rally Armor Mudflaps/HIDS/Yellow Fogs/OEM Window Visors/Super Cool JDM Axela Badge
Enkei Rpf1/Bilstein Struts+Swift Springs
90 Miata:
DDM Intake, Megan Coilovers, Flyin Miata Sways/Master Cylinder Brace,
Corksport Radiator Panel, EGR Rollbar, Enkei RPF1's, 16° timing advance, Foamectomy
pandita is offline   Reply With Quote
 Old 09-17-2014, 12:06 AM   #22
clintosaraus's Avatar
Posts: 22   (View Stats)
clintosaraus is a jewel in the roughclintosaraus is a jewel in the roughclintosaraus is a jewel in the roughclintosaraus is a jewel in the rough
Stock suspension 17x9.75 +25 with 255/40 no roll required
2010 ms3
V3 AP
Cobb SRI
JBR RSB
17x9.75 +25 XXr 530 wrapped in 255/40 dunlop direzza z2 for autox
clintosaraus is offline   Reply With Quote
The Following User Says Thank You to clintosaraus For This Useful Post:
 Old 09-17-2014, 12:18 AM   #23
kby
kby's Avatar
Posts: 653   (View Stats)
kby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the worldkby is the leader of the world
kby is offline   Reply With Quote
 Old 09-17-2014, 12:24 AM   #24
There will be no barfing around speeds unless its the speed protege. Plus thats my autox setup, maximum traction
2010 ms3
V3 AP
Cobb SRI
JBR RSB
 Old 09-17-2014, 02:12 AM   #25
pandita's Avatar
I don't think it's horrible. It's probably just the offset and width that make them look a little funky, but if it's an autoX setup then who cares what it looks like.
2013 CWP:
FREEKTUNE OTS
Cobb AP
90 Miata:
 Old 09-17-2014, 02:49 AM   #26
It will look better when I get my coilovers and alignments parts
2010 ms3
V3 AP
Cobb SRI
JBR RSB
 Old 04-22-2018, 03:35 PM   #27
sarm1084's Avatar
Posts: 11   (View Stats)
sarm1084 is on a distinguished road
Groaned at 5 Times in 2 Posts
Did you roll fenders?
Sent from my VS985 4G using Tapatalk
Future
Gen1 Owner,... Hopefully! lol
sarm1084 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to sarm1084 For This Un-useful Post:
Hoyoman (04-22-2018), JSmith (04-22-2018), Thor Hammer (04-23-2018)
 Old 04-22-2018, 03:51 PM   #28
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Considering; he hasnt been online since September 2017, this is a 4 year thread res for a stupid question that you could/should have just PM'd about (if at all), and you quoted some photo-bucket blocked pics...take your groan and GTFO.
255/40/17 17x9 43mm offset. will it rub with stock height and fenders rolled? kobeballer96 MazdaSpeed 3/6 - Wheels & Tires 1 02-28-2011 03:33 PM
Stock tpms with aftermarket wheels? YZF-R6 2010 MS3 - Wheels & Tires 4 01-29-2011 07:51 PM
How To: Retain stock shift height with TWM short shifter retrobmx63 MazdaSpeed 3 - How-To's 12 06-18-2010 04:59 AM
Will SPC links be ok at stock ride height thanotosq MazdaSpeed 3/6 - Suspension & Brakes 12 04-21-2009 07:58 PM
One-lug aftermarket wheels for the masses Haltech Automotive News 0 04-11-2008 05:11 PM
Page generated in 0.48842 seconds with 40 queries
