![]() Join Date: Sep 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
(Thread Starter) | Not Ranked : 0 score I'm trying to decide whether a 235/40/18 has more fender clearance or a 245/35/18 has a less likely chance of rubbing. I've decided on a set of wheels that are 18x9.5 +38. Now to fit this on a 2012; I'm wanting to go with the 245/35 series but if a 235/40 series is going to rub less then ill deal with the stretch. The tire calculator points to the 245/35 being smaller in every area except width. Would the smaller height give me a better advantage of fitting these wheels? I ran 18x9 +35 with 245/35/18's in the past with no issues so I'm leaning towards the 245/35's. A second example that I've ran on this car are Evo x wheels 18x8.5 +38 with 245/40's. These had more rubbing issues than my 18x9 +35 with 245/35's. But I've never tried any wheels with 235/40 so that's my long lost question. Which works best? Rear fenders are rolled and bumper tabs are shaved off. I'm lowered on Sonic tuning coilovers but its more of a spring drop height. Front camber is -1.4 and rear is -2.3. Thanks
__________________ 2012 Black Mica Speed 3 300whp-341wtq tuned by John @ Tork Motorsports (2/4/14) Stock K04/PTP Internals/CP-E TMIC/Sure Full 3" Intake with 3" MAF Housing/ATP Long Catless DP/UR CBE/Sonic Tuning Coilovers / 18x9 +35 RPF1 SBC |
(Thread Starter) | Not Ranked : 0 score 70 views and not a single insight huh. I thought this was the number one Mazdaspeed tech site? Please though don't be shy.
![]() Join Date: Mar 2017 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 61
Groaned at 18 Times in 8 Posts
245/45 would not fit on my stock car (rubbing) So just go for 235/40
__________________ Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop JBR: rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter To install: downpipe, Damond EGR delete | |
Groans: 211
| Not Ranked : 0 score Well maybe if you did your research you wouldn't be asking this question for the 1,000th time its been asked on this lame forum buddy. LOTS of tire fitment threads have been posted.
![]() Join Date: Mar 2013 Location: Accokeek MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 81
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Dude check out the wheel fitment thread you will find your answers there.
__________________ 2013 LSM w/tech Cobb AP V3, CBE CS Turbo tuned by PD Corksport Catted DP/HPFP Internals JBR FMIC Pipe Kit w/TR8 CP-E TIP/3.5" Intake DM OCC/TMM Forge V2 BPV Bilstein B8 w/Swift springs Wilwood 6 pot BBK EBC RedStuff rear pads Konig Hypergram 18x8.5" |
| Tire Rubbing - Spacer Fix? | kurieren | MazdaSpeed 3/6 - Suspension & Brakes | 3 | 10-03-2015 07:00 PM |
| Fender Well Rubbing?? | Smadginader | CX-7 > Wheels, Tires, Brakes & Suspension | 0 | 08-02-2012 10:18 AM |
| Tire wear-Alignment or rubbing? | sideslide4life | MazdaSpeed 3/6 - Wheels & Tires | 38 | 06-12-2012 07:05 PM |
| tire rubbing | maddocx240 | Mazdaspeed3/6 General Discussion | 21 | 12-06-2011 11:48 AM |
| Coilover rubbing against tire. | SketchyMark | 2010 MS3 - Suspension & Brakes | 29 | 11-09-2011 05:56 PM |
