  • 1 Post By kTaLgsTo
 Old 03-27-2018, 02:16 AM   #1
Poachersun's Avatar
Posts: 20   (View Stats)
Poachersun has a spectacular aura aboutPoachersun has a spectacular aura aboutPoachersun has a spectacular aura about
Default AEM Meth spray controller leaking
Hi Guys!
Just thought i would post here. Been having issues with knock, finally found my AEM controller randomly cutting out mid WOT! Scary shit. Finally got around to testing it and it's leaking pretty bad (used 25psi) so i have just emailed AEM.
anyone else had this? Also i am lucky it happened mid tune and we were safe tuning and i noticed the knock. Anyone non the wiser or fully tuned on high timing could have ZZB
Kinda scary. I will probably throw some Ethanol in tank as a safety precaution.
2010 Mazdaspeed 3
BNRS3, 3" HTP Intake, 3" DP + 3" xforce exhaust full decat, AEM 50/50 meth/water 500cc spray, CPE TMIC, CFM RMM, H&R springs, Versatuned, EBCS, GFB BOV, 3bar MAP, 93 pump, stock intake & exhaust manifolds.
380HP / 374 ftlb
Poachersun is offline   Reply With Quote
The Following User Says Thank You to Poachersun For This Useful Post:
BuddySpeed3 (03-27-2018)
 Old 03-27-2018, 04:54 AM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Need fail safes wen throwing meth at it....
Poachersun likes this.
The Following User Says Thank You to kTaLgsTo For This Useful Post:
 Old 03-27-2018, 05:17 AM   #3
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Yeah a fail safe for sure anytime aux fuel is needed for octane or power. I'm looking into the AEM wide band fail safe to trigger the Guardian Angel in the event of a lean AFR. It seems to be the simplest way to do it.
 Old 03-27-2018, 11:51 AM   #4
Poachersun's Avatar
Yeah. I assume the standard outputs wont cut it because as far as the controller is concerned you are not at full boost( even though you are). Because we kind of tuned around the fault without realising it didn't go too lean. But bats started too increase again and got small knock but sometimes as high as 2. So we kept dropping timing moving things around. It became frustrating for my tuner. A little dissapointed too as reading online sounds more common. And i am overseas so will be without the controller for probably months while they fix.
Sent from my SM-G955F using Tapatalk
2010 Mazdaspeed 3
380HP / 374 ftlb
 Old 03-27-2018, 04:05 PM   #5
Poachersun's Avatar
Small update. AEM are replacing the controller under warranty and sending a replacement. They answered very quickly and i am happy they are sorting this out for me.
2010 Mazdaspeed 3
380HP / 374 ftlb
pro fuel controller for meth MY DICK IS SMALL-beautfpowers@gmail.com MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 27 12-02-2015 08:07 PM
For the tuners..Meth mix..not spray shifter48 2010 MS3 - Fuel, Nitrous & Water Injection 8 02-04-2013 05:17 AM
Will adding meth/water spray give me any power gain? Sloane MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 4 11-30-2008 03:13 PM
Page generated in 0.25973 seconds with 22 queries
