![]() | | #41 | ![]() |
![]() Join Date: Feb 2016
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
![]() | | #42 | ![]() |
![]() Join Date: Dec 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 15
Groaned at 14 Times in 6 Posts
| Not Ranked : 0 score You left something unplugged you got all these codes out of no where. Did you check to see that you removed and re installed the right fuses ? Check the connection by the fuel pump ? Do you have a fuel monitor device like a gauge or accessport ? Most likely forgot make sure the connector to the fuel pump is properly connected.
__________________ Corksport hpfp- Corksport long catted downpipe-Ultimate racing catback- tr6 front mount intercooler w/ cx racing piping- Jbr 3.5 tru wide path aluminum intake- Jbr 3port bcs- Jbr rear and passenger mount-Bosch 3 BAR MAP sensor- Jbr shifter bushings- Matt Damond shift plate- |
![]() | | #43 | ![]() |
(Thread Starter) | Not Ranked : 0 score Were checking all the fuses and connections right now |
![]() | | #44 | ![]() |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score Better question is, why even remove any fuses in the first place? If you're that worried about the electrics, disconnect the fucking battery. Those codes don't make any sense at all to me: P0171: This is an intake leak. You probably broke something or left something disconnected. I don't know why you even removed the intake. P0089: Your spill valve is fucked, or not operating properly, or the "cylinder" of the fuel pump internals is installed upside-down. You are not building above in-tank fuel pump pressures. P0192: This sensor is literally on the other side of the engine and I have no idea WTF is going on here. Maybe a bad fuse.
__________________ 2007 Mazdaspeed3 GT |
| The Following 2 Users Say Thank You to MD1032 For This Useful Post: | InkedInspector (06-30-2016), KiwiFlavor (06-30-2016) |
![]() | | #45 | ![]() |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 | |
| The Following 5 Users Say Thank You to KiwiFlavor For This Useful Post: | brandonf (07-05-2016), g00s3y (06-30-2016), InkedInspector (06-30-2016), monkey.bones.007 (06-30-2016), WetzMS3 (07-01-2016) |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well we took everything out and found out what happened. I'll post a pic. It basically broke on me |
![]() | | #47 | ![]() |
Oh noes...
| The Following User Says Thank You to KiwiFlavor For This Useful Post: | monkey.bones.007 (06-30-2016) |
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah it cracked and broke off |
![]() | | #49 | ![]() |
| Not Ranked : 0 score Make sure u don't have any broken pieces in the pump before you put it back , make sure it's completely clean. Never seen internals break like that. Probably had the retaining clip on loose. ?
![]() | | #50 | ![]() |
(Thread Starter) | Not Ranked : 0 score No it was on tight we made sure. I don't know how this happened. I lost out on a lot of money |
![]() | | #51 | ![]() |
Groans: 143
| Not Ranked : 0 score When you disassembled it, were the keepers still where they were supposed to be? edit: It's not that bad. Autotech will warranty them.
| The Following User Says Thank You to MD1032 For This Useful Post: | KiwiFlavor (06-30-2016) |
![]() | | #52 | ![]() |
| Not Ranked : 0 score Call them up and get your money back. Get some corksport internals.
| The Following User Says Thank You to rocknrolla47 For This Useful Post: | uh60gunner209 (06-30-2016) |
![]() | | #53 | ![]() |
Hopefully it's not #inb4installererror .
| The Following 2 Users Say Thank You to KiwiFlavor For This Useful Post: | MD1032 (06-30-2016), speed3okie (06-30-2016) |
![]() | | #54 | ![]() |
(Thread Starter) | Not Ranked : 0 score They were done right. Never seen this happen before |
| The Following User Says Thank You to kryskunka For This Useful Post: | KiwiFlavor (06-30-2016) |
![]() | | #55 | ![]() |
| Not Ranked : 0 score Are they used or new ?
![]() | | #56 | ![]() |
![]() Join Date: Jan 2012 Location: Queens, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score Were the internals torqued correctly? (35~40 ft/lbs) |
![]() | | #57 | ![]() |
(Thread Starter) | Not Ranked : 0 score They're used. Had 20k miles on then. |
| The Following User Says NO Thank You to kryskunka For This Un-useful Post: | Vansquish (06-30-2016) |
![]() | | #58 | ![]() |
![]() | | #59 | ![]() |
| Not Ranked : 0 score I don't think you can get them warrantied. Why did the guy sell them ? 20k miles on them and he sold them, that right there is a red flag. Unless he was parting out a good used mazdaspeed. Never buy used parts that are important motor components especially when they have to do with fueling.
![]() | | #60 | ![]() |
(Thread Starter) | Not Ranked : 0 score The guy sold then because he was parting out his mazdaspeed3. I just found out his mazdaspeed3 was a track car and he sold them to me |
![]() | | #61 | ![]() |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score they were either disassembled or reassembled wrong. Ive never seen anything like that before. any marks on it around the cracked area?
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
| The Following 3 Users Say Thank You to mxlplx71 For This Useful Post: |
![]() | | #62 | ![]() |
(Thread Starter) | Not Ranked : 0 score Were putting back the stock internals back in. Hopefully everything goes back to normal No there were absolutely no marks around the cracked area Last edited by kryskunka; 06-30-2016 at 09:15 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #63 | ![]() |
| Not Ranked : 0 score That sucks man now u have to repeat the process. Get some corksport internals , u won't look back. They come with new parts so u don't have to reuse stock components.
| The Following User Says NO Thank You to rocknrolla47 For This Un-useful Post: | g00s3y (06-30-2016) |
![]() | | #64 | ![]() |
(Thread Starter) | Not Ranked : 0 score This is what it looked like when we took it out |
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score I put the stock internals back in and now we have the same 3 check engine lights as before |
![]() | | #66 | ![]() |
| Not Ranked : 0 score That doesn't look like auto tech retainers. The autotechs retainers have 2 little clips you put on. That looks like the stock retainer clip. Clear the codes and wait to see if they come back.
__________________ Corksport hpfp- Corksport long catted downpipe-Ultimate racing catback- tr6 front mount intercooler w/ cx racing piping- Jbr 3.5 tru wide path aluminum intake- Jbr 3port bcs- Jbr rear and passenger mount-Bosch 3 BAR MAP sensor- Jbr shifter bushings- Matt Damond shift plate- Last edited by rocknrolla47; 06-30-2016 at 09:24 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #67 | ![]() |
| Not Ranked : 0 score Those clips are in there in the picture
| The Following User Says Thank You to KiwiFlavor For This Useful Post: | mxlplx71 (06-30-2016) |
![]() | | #68 | ![]() |
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
| Did you bother to clear the codes after you reinstalled the stock internals?
![]() | | #69 | ![]() |
| Not Ranked : 0 score Hmm idk I think that's the stock tap style clip
![]() | | #70 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm getting the car taken to the dealership. The car is still under warranty so they'll just give me a whole new pump I guess |
![]() | | #71 | ![]() |
| Not Ranked : 0 score I dont recall my stock one having clips.. EDIT: Anyway, OP good luck man. This sucks big donkey balls
| The Following User Says Thank You to KiwiFlavor For This Useful Post: | monkey.bones.007 (07-01-2016) |
![]() | | #72 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah I tried clearing the codes. They kept coming back the same ones. |
![]() | | #73 | ![]() |
Lol my fault I see them now , screen was too dimmed.
__________________ Corksport hpfp- Corksport long catted downpipe-Ultimate racing catback- tr6 front mount intercooler w/ cx racing piping- Jbr 3.5 tru wide path aluminum intake- Jbr 3port bcs- Jbr rear and passenger mount-Bosch 3 BAR MAP sensor- Jbr shifter bushings- Matt Damond shift plate- | |
| The Following User Says Thank You to rocknrolla47 For This Useful Post: | KiwiFlavor (06-30-2016) |
![]() | | #74 | ![]() |
Groans: 143
| Not Ranked : 0 score The keeper on the top in that photo is not seated all the way. That is probably the source of the failure.
![]() | | #75 | ![]() |
(Thread Starter) | Not Ranked : 0 score Since this car is still under warranty. The dealership should just put in a new fuel pump and the fuel pump sensors. And then I'll just have to buy new high pressure fuel pump internals again sadly :// I don't think this car is safe to drive though at the moment Last edited by kryskunka; 06-30-2016 at 10:00 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #76 | ![]() |
What are your mods? If you're stock, you should be OK with the stock fuel pump.
![]() | | #77 | ![]() |
| Not Ranked : 0 score Well good luck with your car op. Hopefully some easy fixes
![]() | | #78 | ![]() |
(Thread Starter) | Not Ranked : 0 score The car is bone stock still. But the same thing keeps happening. It's idling badly, turbo is not getting boost, barely any acceleration what so ever. Barely any power feels like |
![]() | | #79 | ![]() |
| Not Ranked : 0 score How does the fuel pump sound is it ticking normally ?
![]() | | #80 | ![]() |
| Not Ranked : 0 score Install your stocker back on. Also you said you still have a warranty, bring it back to the dealership.
| KDM Internals | soaringeagle129 | Mazdaspeed3/6 General Discussion | 6 | 02-07-2012 02:13 PM |
