 Old 06-16-2013, 02:02 PM   #1
MPS_Fan's Avatar
Posts: 436   (View Stats)
MPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the world
Groaned at 17 Times in 8 Posts
Default HPFP Hardline cracked and leaking!!
Today after a long trip i could smell some gas. I checked everything in the engine bay and noticed that the fuel hardline from the HPFP had a small hole where fuel was coming out. Its a very small crack, don´t know how this line can break. I towed the car home and looking now for the part number of the line, does anybody know it?
Does anybody also know how to change this line. From looking intothe engine bay, it seem like a painful job swap this piece of shit out.
Edit:
Found a how to for swapping:
how to high pressure fuel line porting
But still need part number.
MPS_Fan is offline   Reply With Quote
The Following User Says Thank You to MPS_Fan For This Useful Post:
atvfreek (06-19-2013)
 Old 06-16-2013, 02:59 PM   #2
twenty5psi's Avatar
Posts: 213   (View Stats)
twenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the worldtwenty5psi is the leader of the world
L3K9-13-290A
WVspeed6 likes this.
2013 MS3 VRM w/Tech
-unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings
FlowTuned 2 Gallon E85 blend 307whp/336wtq
twenty5psi is offline   Reply With Quote
The Following User Says Thank You to twenty5psi For This Useful Post:
kritz (06-16-2013)
 Old 06-16-2013, 03:02 PM   #3
MPS_Fan's Avatar
Thanks, wanted to order it in germany, but it costs here 240$, WTF !?!?!?!
Ordered at Onlinemazdaparts, for 136$ shipped to germany...
 Old 06-16-2013, 03:08 PM   #4
twenty5psi's Avatar
Not the most fun job, but it's do-able. You'll have to take off part of the intake at least, the line has brackets holding it that you have to undo(you'll see on the new part.) You can sneak it out from underneath the EGR pipe though.
2013 MS3 VRM w/Tech
 Old 06-16-2013, 03:15 PM   #5
ms3rick's Avatar
Posts: 2,959   (View Stats)
Jb weld!!!
All kidding aside, glad you didn't go boom! Good luck with install!
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
The Following User Says NO Thank You to ms3rick For This Un-useful Post:
Hoyoman (06-19-2013)
 Old 06-16-2013, 03:26 PM   #6
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Pics of crack. Can see if we can source one here for you if you'd like. Do you have a MK1 or MK2? Also can see if a mate of mine has one floating around in the UK. Let me know.
Nator is what it does.
 Old 06-16-2013, 03:32 PM   #7
Should have posted a wanted-to-buy, I have a spare lying around, good luck with install.
 Old 06-16-2013, 03:41 PM   #8
MPS_Fan's Avatar
I need it within next few days, because my car is DD. So you would have to ship it via express... That would cost about the same.
My car could have start burning, because fuel was spraying directly on my exhaust mani. Its a part that should never fail, because it could end with ZZB.
Its all the same with the car manufacturer, using cheap ass China shit everywhere they can.
Code Monkey (06-16-2013)
 Old 06-16-2013, 04:23 PM   #9
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
Mine cracked at the rail side and I had fuel running on the tranny. Swap isn't too bad, hardest part for me was getting that housing or shielding by the rail off cause I couldn't see the bolts. But I think all I took off was intake up to inlet. Definately doable just take your time.
 Old 06-19-2013, 01:08 PM   #10
MPS_Fan's Avatar
I attached a picture of the crack.
Like you see it cracked directly where it bends. Since I only have 15k miles and never touched this line, it looks like a material fault.
I needed only 45mins to remove this part, you don´t have to drain coolant or do another crazy things like in the how to. I only removed TMIC, Battery+Tray, Intake (TIP still inside). Thats all! You just need some good tools and a good feeling, because some bolts are hidden.
I hope my new part will arrive tomorrow!
The Following 4 Users Say Thank You to MPS_Fan For This Useful Post:
atvfreek (06-19-2013), KevMS6 (06-20-2013), PapaBruno (12-20-2016), [R]usty (06-19-2013)
 Old 06-19-2013, 01:28 PM   #11
atvfreek's Avatar
Posts: 7,787   (View Stats)
That is exactly where mine cracked as well. I had about 38k miles on my car at the time.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
Sergeant_M (10-05-2014)
 Old 06-19-2013, 01:31 PM   #12
Did you guys have all the bolts holding it in place and bracing?
 Old 06-19-2013, 01:45 PM   #13
MPS_Fan's Avatar
Yes!
I think its cheap galvaniced steel made in china. It cracked directly where its most stressed during bending procedure. The wall thickness of the line is good, but the material is probaly shit...
@Lex
If onlinemazdaparts shipped the part yesterday like they told, i should rock that bitch tomorrow again. Will send you logs from last revision
Lex (06-19-2013)
 Old 06-19-2013, 01:47 PM   #14
Yes!
I think its cheap china galvaniced steel. It cracked directly where its most stressed during bending procedure. The wall thickness of the line is good, but the material is probaly shit...
This is a major safety hazard. This could easily trigger a recall. I would take it to the dealer and make a case if you have the time since if that line is untouched it can happen on stock cars.
atvfreek (06-19-2013), MPS_Fan (06-19-2013)
 Old 06-19-2013, 01:50 PM   #15
atvfreek's Avatar
Yup everything was in tact on mine. I have a friend at Mazda, so mine was taken in and fixed at Mazda under warranty, as no "performance/aftermarket parts" made it fail.
This is a major safety hazard. Especially with the high pressure fuel vapor that was going into the engine bay while the engine was running.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
Lex (06-19-2013), MPS_Fan (06-19-2013)
 Old 06-19-2013, 01:51 PM   #16
MPS_Fan's Avatar
The line sprayed fuel directly on my exhaust header. The car could have start burning!
Lex (06-19-2013)
 Old 06-19-2013, 01:55 PM   #17
Post a picture of the line and its location and where it cracked in the engine bay if you can. We can do a warning and people can look it over and take it into dealers if any cracking is seen.
 Old 06-19-2013, 01:59 PM   #18
atvfreek's Avatar
In the picture that is posted above, that is the bend that goes up to the HPFP. Mine cracked at the same bend, but was spraying toward the battery. I'm trying to find the pic of mine and when I find it, I will post it as well.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 06-19-2013, 02:00 PM   #19
MPS_Fan's Avatar
I attached a picture where you can see the whole line. It cracked in direction to the engine.
maybe i should send the picture directly to mazda. I was thinking about towing the car to mazda dealer, but didn´t want to pay for towing it to dealer. so decited to fix it by myself.
The Following 2 Users Say Thank You to MPS_Fan For This Useful Post:
atvfreek (06-19-2013), Lex (06-19-2013)
 Old 06-19-2013, 02:07 PM   #20
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
I have had mine crack twice when I owned a MS6, both were near the rail where the 1/4 line goes into the larger end/flange. Definitely not good to happen when you are out of town with no Nator people around in the middle of nowhere.
 Old 06-19-2013, 02:12 PM   #21
x09MS3GT's Avatar
Posts: 409   (View Stats)
x09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the world
Groaned at 92 Times in 11 Posts
Just going out on a limb here, but pulling this line out of the way in order remove the CDFP and install FP internals, could cause stress in that region if you bend it down enough no ?
Its certainly a possibility.
--Cobb Sri--Cobb Tip--Cobb Airbox--Cobb Fmic--Cobb Bpv--Cobb Turbo-back----Cobb V3 Ap--Cobb Rmm--Jbr Pmm--Jbr Tmm--Cobb Sts----6510's--Autotech's--KW V2'S--Jbr Fsb--Jbr Rsb--STOPTECH Sport Kit--E30 FREEKTuned --
x09MS3GT is offline   Reply With Quote
 Old 06-19-2013, 02:22 PM   #22
MPS_Fan's Avatar
if that would be the cause, it should have break much sooner. I´m with AT Internals since 12k miles and 2 years.
Did not applied any pressure on line, since it lines up perfectly without force if you do the install correct.
I have many years mechanic experience, so it was no install error
 Old 06-19-2013, 04:19 PM   #23
atvfreek's Avatar
It's always a possibility. However my internals were in since my car had 5k miles. So it went 30+k miles and almost 3 years. But it doesn't mean it wasn't stressed from the internals install
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 06-19-2013, 04:28 PM   #24
This is a good reason to be careful during the internals install. I think we will have a hard time finding a car without internals that this has happened to simply because internals are something everyone puts in.
The pressure spikes in the line from normal operation do affect it as they create vibrations and resonances. So a weak point can crack at a much later time.
The failure here is pretty serious as it can cause a pretty bad fire.
 Old 06-19-2013, 04:37 PM   #25
blackms3_71's Avatar
Posts: 2,250   (View Stats)
So are you saying that by installing internals is the risk or by having the internals in and running 1750 psi is putting greater stress on that line?
 Old 06-19-2013, 05:04 PM   #26
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
@Tokay444
@SilverDemon
Looks like it work hardened and fractured to me, but that is not a area where it should work harden from vibration or heat expansion/contraction. That should be mostly at the ends of the line.
It also looks worn in that area, maybe the material was or got too thin and the metal itself failed.
This doesnt seem like the normal CDFP hard line failure to me.
2006 Mazdaspeed 6
The Following 2 Users Say Thank You to 06Speed6 For This Useful Post:
atvfreek (06-19-2013), SilverDemon (06-19-2013)
 Old 06-19-2013, 07:15 PM   #27
SilverDemon's Avatar
Posts: 3,034   (View Stats)
That crack does not look like to me that it was from removing the pump by bending the line out of the way. I would think a crack would develop on the inside or outside of the bend.
I am curious, were the bolts that affixes the clamp on the hard line tight?
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 06-19-2013, 08:36 PM   #28
skeeter149's Avatar
Groans: 91
mine cracked at the round part that connects to the rail with the two bolt holes. where it comes out. never touched that side prior, only the other side to do internals 3 times. cracked just opposite the o ring.
 Old 06-19-2013, 10:53 PM   #29
Hard to say at the moment what the root cause is.
Maybe not a bad idea to loosen the line a little when maneuvering it to install the HPFP just to avoid any stresses.
Was the line rubbing against anything at that point? That area looks scuffed up.
 Old 06-20-2013, 12:31 AM   #30
MPS_Fan's Avatar
It looks scufffed because I sanded some material down to check it for bubbles. The line itself was looking perfectly fine when I removed it.
 Old 06-20-2013, 07:03 AM   #31
kritz's Avatar
Groans: 95
I located one for you in the UK Klaus, I sent your contact info to him. His name is Ross.
Sent from fastest ko4 Pu!
 Old 06-20-2013, 07:45 AM   #32
MPS_Fan's Avatar
Got your mail. Thanks!!!
 Old 06-26-2013, 06:55 PM   #33
Oni
Oni's Avatar
Posts: 565   (View Stats)
I use quarter inch stainless steel tubing like this on PD pumps at work and the stuff is rated for 5000 psi. We blow heads off piston pumps when the relief valves fail and never see tubing rupture. It's connected with compression fittings like this and usually under a lot more stress over time. My vote is poor material quality, same as the cheap ass Mazda bolts.
Sent from my iPad using Tapatalk HD
'12 Velocity Red Mica MS3
Cobb AP V3 // Autotech Fuel Pump Internals // HTP 3" // UR Catted V2 DP // UR Resonated TP // UR Resonated CBE // GrimmSpeed EBCS // CP-E TMIC // GFB Respons BPV // JBR Trilogy 88/80/80 // Corksport Hood Struts // Prosport EVO Boost Gauge w/ block8head vent pod // E30 Freektune
Installing Soon : Stratified GA // Bosch 3 Bar Map w/ PNP Harness
Oni is offline   Reply With Quote
 Old 07-03-2013, 07:46 PM   #34
Renn's Avatar
Posts: 97   (View Stats)
Renn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant futureRenn has a brilliant future
Absolutely this should be a recall. There was a very similar recall (faulty fuel line in the engine compartment) to a batch of 300Z's in the 80's, one of which I bought used - unaware of the recall. Car ended up immolating itself.
Renn is offline   Reply With Quote
 Old 06-20-2014, 07:17 PM   #35
Snotrocket's Avatar
Posts: 900   (View Stats)
Snotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the world
Has there been any updates to this? A fix? An aftermarket solution?
2010 MS3 Black
395whp/386wtq
| Molnar Rods | CP-e Stage 2 Pistons | Much Head Work | ATP GTX3076 | Tial 38mm EWG | HTP 4 Inch Intake | BSD | Passenger and Rear MM | Denso ITV22's | OCC | Ultimate Racing TBE | Tredstone TR8C FMIC | Tial BPV | Autotech Internals | Grimmspeed ECBS 3 port | Te37 Volks| 245/45/17 Dunlop zzi tires| Cobb AP Self Street Tuned | Sonic Tuning Coilovers | Stoptech breaks and slotted roters
Snotrocket is offline   Reply With Quote
 Old 06-20-2014, 07:19 PM   #36
No.
 Old 06-20-2014, 08:51 PM   #37
Snotrocket's Avatar
No.
Seems like this should be the next order of business.
I blew mine today, very Frustrated.
I'm sure I'll run into this problem again down the road.
2010 MS3 Black
395whp/386wtq
The Following User Says Thank You to Snotrocket For This Useful Post:
Code Monkey (06-20-2014)
 Old 06-20-2014, 09:05 PM   #38
I should probably send my cracked line to Mazda.
Snotrocket likes this.
Snotrocket (06-20-2014)
 Old 10-05-2014, 01:43 AM   #39
Sergeant_M's Avatar
Posts: 504   (View Stats)
Sergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the world
Same thing happened to me last night. Was having trouble finding the leak until it got dark out and I hit it with the flashlight. It's pissing all over the side of the engine. Can anyone provide some guidance on the best place to source this part?
Sergeant_M is offline   Reply With Quote
 Old 10-05-2014, 01:59 AM   #40
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
Onlinemazdaparts.com
The Following User Says Thank You to Hargarbl For This Useful Post:
Leaking hpfp dyin hawaiian MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 10 02-06-2013 09:00 PM
Page generated in 0.56189 seconds with 38 queries
