 Old 05-14-2011, 01:46 PM   #1
spoof3r's Avatar
Posts: 260   (View Stats)
spoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the world
Default Issue with HPFP AutoTech Internals
So I finally stocked my car out and took it to the dealer. I get this sound only during a true cold start (usually after its been off for the night or in the cold for a good amount of time.) When I rev it up to about 3000RPM's you can really start to hear it. Otherwise you can only hear it for a few seconds just after you start the car.
The dealer said "Hey yeah the problem is with your HPFP. We'll take it out and give you a new one". I didn't even think to consider the HPFP so told them right away that I couldn't be without my car and would need to reschedule a time for it to be serviced. Thank goodness they didn't throw away the old pump with my beautiful autotech internals!
Anyways, I have the rattle noise like everybody else does, but how about this sound? I'm assuming it's okay and just another set of noisy internals, especially because of fuel requests during a cold start, but just want to see what all of you think.
2010 Mazdaspeed3 - Garrett GT3076R Turbo, SteedSpeed Manifold, Tial 38mm External Wastegate w/ Dump Tube, ATP Big MAF Housing, ATP 3" TIP/Intake, HKS SSQV BOV, Ultimate Racing FMIC, Ultimate Racing Catless DP, CS Test pipe, CS Catback Exhaust, Autotech HPFP Internals, Hallman Pro Boost Controller, Cobb AccessPORT, BC Coilovers, DDM 8000k HID's, Red Brake Calipers w/ Decals, Custom Smoked Headlights, Smoked Taillights, 18% Window Tint.
2011 Mazda2 Sport - OEM Fog Lights, OEM Touring Rear Spoiler, Sport Edition F2 Silver Wheels, Green Brake Calipers, 18% Window Tint,
Social Engineering - Because there is no patch for human stupidity.
spoof3r is offline   Reply With Quote
 Old 05-14-2011, 02:27 PM   #2
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Interesting...Dont know if you had time to pull the Pump out yet....Maybe you had a shim come out?
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
 Old 05-14-2011, 02:39 PM   #3
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
I heard somewhere, either here or on vdub forums (when I was researching autotech internals) that the autotechs have an issue with chewing up the cam follower...?
TRADED : 07 MS3 GT Silver... fully bolted w/K04
CURRENT : 06 MS6 GT Silver....
KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6
Fatguy729 is offline   Reply With Quote
 Old 05-14-2011, 02:41 PM   #4
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
That isn't an issue on our cars. Our Cam follower is a different material than whats run in in the VW. Its a common upgrade for VW owners.
Spoofmastafly is offline   Reply With Quote
The Following 2 Users Say Thank You to Spoofmastafly For This Useful Post:
Fatguy729 (05-14-2011), rfinkle2 (05-14-2011)
 Old 05-14-2011, 04:59 PM   #5
spoof3r's Avatar
My main concern is whether or not I should be concerned about this issue. It is only during cold starts and hardly does it unless I give it some gas, which leads me to believe that it is nothing to worry about.
 Old 05-14-2011, 05:25 PM   #6
Fatguy729's Avatar
Groans: 82
Well first off, I never rev my engine like that till its warm... And personally I would be concerned about that sound. How's your fuel pressure look in curiosity? Did you make sure everything was CLEAN? And make sure you swap internals before you take it to the dealership! Oh, and take pictures of them/ look for signs of wear.
 Old 05-14-2011, 09:12 PM   #7
spoof3r's Avatar
I had a very repututable tuning shop do the work. I will be asking them about This issue though. For the record I don't Rev it before it's warm either but noticed it through simple experimentation after hearing it in the first place ;-)
Last time I checked my fuel pressure was fine. Holds like 18xx psi at WOT. I've heard I should see 19xx or even 20xx but I am also at 5800ft elevation...
 Old 05-14-2011, 09:15 PM   #8
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
Groans: 266
I didnt start getting high 18-19-20 till i was stage 2
DONOTBUGME is offline   Reply With Quote
 Old 05-15-2011, 12:42 PM   #9
spoof3r's Avatar
I'm going to do my GT3076R build here and then after my tune I'll see what the situation is. If I'm not going above 19xx I may do something about it.
 Old 05-15-2011, 12:52 PM   #10
Fatguy729's Avatar
Groans: 82
I would aty least take the pump apart and look for signs of wear/problems
The Following User Says Thank You to Fatguy729 For This Useful Post:
DingoDave (05-18-2011)
 Old 05-15-2011, 12:59 PM   #11
m4tic's Avatar
Posts: 4,928   (View Stats)
did the shop know what they were doing? or did they just follow the instructions like you could have done easily?
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 08-14-2011, 07:23 AM   #12
RMCAT's Avatar
Posts: 170   (View Stats)
RMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond repute
I heard the exactly same sound when I cold started my car yesterday.It's been a week since I installed my KMD v2.1 internals and car seems to hold pressure just fine.
||Cobb AP(DJ tuned)||Cobb SRI||Cobb TIP||Cobb FMIC||Cobb SW||KMD v2.2 HPFP||Catted TBE(TurboXS DownPipe+Vibrant DPback)||TurboXS Hybrid BOV||Fortune Auto Coilovers||Powergrid Endlinks||Eibach Camber Kit||CPE RMM||Denso ITV22||STRI DSD 60mm Boost Gauge||5000K HID Fogs||Lamin-x Foglight Tints||Speedy Lite-Fin 18x7.5||General UHP 235/40/18||ADR 17x7(Winter)||Nextmod GV front Lip/spoiler Lip||AutoEXE Carbon Fiber Shifter Knob||Carbon Fiber Ebrake Cover||TWM Bushings||TWM Shift/Ebrake Boots||
RMCAT is offline   Reply With Quote
 Old 10-03-2017, 05:34 PM   #13
DoubleL's Avatar
Posts: 2   (View Stats)
DoubleL is an unknown quantity at this point
Default Knock type sound from HPFP area
Doing my build at the shop, after blowing a piston land out, i was warned to upgrade my HPFP. So im doing that now. Luckily the head Mazda (i work at chevy) didnt mind letting me borrow the special tools and his knowledge. He mentioned the fuel pressure relief valve goes bad and makes a knocking type sound. Might be that. I should finish my car tomorrow. Cylinder wall wasn't scratched. So put new pistons and bearings. Just got my autotech FP kit today. Last thing i was waiting for! I'm scared, nervous, excited, happy..... Wish me luck
DoubleL is offline   Reply With Quote
First AP Log. Autotech FP Internals Installed spoof3r 2010 MS3 - ECU Computer Tuning 23 07-08-2013 08:11 PM
Autotech Internals PapaSmurf 2010 MS3 - Fuel, Nitrous & Water Injection 240 07-25-2012 10:59 AM
autotech hpfp internals installed speedms6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 45 07-15-2012 06:59 AM
Anyone want in on Autotech internals? OneBAMFpog 2010 MS3 - Fuel, Nitrous & Water Injection 545 09-30-2011 09:49 AM
Anyone interested in Autotech Internals? OneBAMFpog MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 31 06-02-2011 03:50 AM
Page generated in 0.36580 seconds with 27 queries
