 Old 07-04-2018, 03:54 PM   #1
achulz's Avatar
Posts: 94   (View Stats)
achulz has a spectacular aura aboutachulz has a spectacular aura aboutachulz has a spectacular aura about
Default What Do I Need for E85?
I want to make absolutely sure I have everything I need before I put E85 in my tank. I am going big turbo with the BNR S4 and I am aiming for 360-380WHP, I thought about meth injection but I think E85 would be a better route, as I did some research and there are actually quite a few ethanol stations near my home in Houston and the city I work at in Louisiana. So if I need to refuel, it's a little bit longer of a drive but I'm good.
I have Corksport HPFP internals, and obviously I have an Accessport for tuning (I was already running a 21 PSI tune when my K04 hot side oil seals blew out). Is that really all I need?
And can I expect that amount of power with E85 and the S4? I've seen 350WHP on 93, so I'm assuming E85 will open a lot of doors.
achulz is offline   Reply With Quote
 Old 07-04-2018, 05:11 PM   #2
Solarsurge's Avatar
Posts: 577   (View Stats)
I seriously hope you're not talking about going full E85 with absolutely no supporting mods other than a turbo. Am I reading that right?
 Old 07-04-2018, 06:27 PM   #3
achulz's Avatar
No.
CS HPFP, JBR 3.5" intake, 3" catless DP and 3" straight pipe, C-PE TMIC, CS 3.5 bar MAP sensor, Grimmspeed 3-port EBCS, GFB TMS Respons BPV set at 50/50. Fully bolted with the S4 turbo.
I'm wondering what else I need, I heard about the 'black death' thing with the HPFP so I'm figuring if E30 or (maybe) 50/50 would be a better idea and if there's anything else I can add in to make the car more ethanol friendly, as I read I can still reach MBT with the mix and the effects are less present.
 Old 07-04-2018, 06:37 PM   #4
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Tires.
I wouldn't be worried about how much WHP you gain since ETH brings on the torque. You can get close to 400 lb of torque on a stock turbo with a e85 mix and blow your rods faster then a virgin busts a nut from a hookers bj while shes tripping on ecstasy.
Have a toon that brings the power on easy in the first 2 gears and don't boost like a fuck nut in 5th+ If done right e85 will increase the life of the motor if done wrong you will blow the motor and get built and go faster. I run a eth mix and always have my meth kit ready that i can turn on when i need it incase i have to switch to a 93 toon on a long trip.
If you go with a 1:2 mix of e85:93 you will get close to MBT and stave off "Black Death" anything more like 50/50 you will need to clean the pump or occasionally run a tank or 2 of 93 to keep the pump ok.
I will take this moment to ask.... what are your goals with this car?
MECP
2012 BM
Rfinkle tune in progress
 Old 07-04-2018, 06:43 PM   #5
Solarsurge's Avatar
Originally Posted by achulz View Post
No.
OK, thank god lol. Yea, there's pretty substantial testing that shows there's virtually nothing to be gained by going above 50% ethanol and, in most cases, it causes more harm than good on our platform. 50/50 mix is the max I'd personally run. But you are fuel limited to 380ish HP no matter how you go unless you upgrade the stock in-tank fuel pump or add another tank with PI.
 Old 07-04-2018, 07:18 PM   #6
achulz's Avatar
Tires.
I want to keep the stock motor. Bolt ons are okay in terms of cost, rebuilding the engine or getting a long block is not something I want for this car. If I'm going to spend that kind of money I don't want to spend it on a FWD car. The whole reason I got it was because one, I've liked the car ever since I was a kid and two, so I can fly past Mustangs and see the look on their face when a Japanese hatchback passes their American muscle. If I were to spend any money on a built motor it would be an STI, as much as I like this car I like the STI a whole lot more, it's been my dream car ever since I could remember. This car is just a stepping stone for me to get into tuning and really modifying for power gains. And for the record I really do love this platform the more I get into it. It has its problems but overall it's a great motor.
It is still my daily though, so I would like to keep the power well within the limits of the stock block to increase longevity. If running ethanol gets me too close to the limit then I will stick with plain old 93. But I'd like to make enough power, like I mentioned before, to fly past Mustangs. I know it's more than possible with the S4, as I was already pretty damn close with my K04.
The only reason I am going big turbo is because my K04 blew up and the S4 is the same cost as a new K04 from Mazda. I will be working with Purple Drank for my tune, I keep hearing great things about them and I like how they keep the low end torque down to spare the connecting rods.
 Old 07-04-2018, 07:23 PM   #7
achulz's Avatar
I think I'll go for E30 mix. Keep it safe on the HPFP and Stratified has great instructions on how to mix for E30. I am going to get it tuned with Purple Drank though, Stratified kind of let me down with the speed of service and took a whole week to reply to literally any questions I had.
Page generated in 0.43148 seconds with 21 queries
