> 2010 MS3 - Car Audio & Electronics
 Old 05-19-2016, 03:59 AM   #1
Evo2speed3's Avatar
Posts: 27   (View Stats)
Evo2speed3 has a spectacular aura aboutEvo2speed3 has a spectacular aura aboutEvo2speed3 has a spectacular aura about
Default Added a sub and amp to the Bose system
I just installed a Rockford Fosgate P3 12" sub box and Precision Power Sedona 850x1 amp to the stock Bose system in my 2013 Speed3. It was so easy to do with the tips from this forum. I used a Rockford 4ga wiring kit and a PAC AOEM2 loc. Took a couple of hours for the install. It hits so hard even with the bass at 0 on the stock head unit. I'm very impressed so far.
2013 Mazdaspeed 3
GTX3071r turbo, Freektuned- APv2, HTP 3" intake, Cobb BPV, Street Unit TMIC, CP-E DP, Ultimate Racing Exhaust, CP-E rear mount, JBR passenger/trans mounts, Autotech FP internals, Grimmspeed EBCS, H&R Springs, Akebono Euro pads, TSW Nurburgring Wheels on Nitto NT555 225/40/18 tires, Nokya hyper yellow fog lights, WC Lathewerks custom titanium shift knob
Evo2speed3 is offline   Reply With Quote
 Old 05-24-2016, 05:33 PM   #2
Thetal1's Avatar
Posts: 17   (View Stats)
Thetal1 is an unknown quantity at this point
Are you planning on upgrading the door speakers?
Daily 2011 Speed3: ALL STOCK
The Project 1995 LS swap Camaro: CAMONLY
Thetal1 is offline   Reply With Quote
 Old 05-25-2016, 03:36 AM   #3
Evo2speed3's Avatar
Maybe down the road. The highs are decent, but they can't keep up with all of that bass. If I do, I will upgrade the Bose amp too.
2013 Mazdaspeed 3
 Old 05-25-2016, 06:26 PM   #4
Thetal1's Avatar
I was thinking the same thing once I put my sub in but after a few months it sounded blah just really bass heavy. I was going to upgrade the amp but I am doing the doors first. Probably some jbl components of infinity since they match the ohm of the factory speakers.
 Old 05-25-2016, 06:43 PM   #5
Evo2speed3's Avatar
I am not sure what highs I want to go with. I used to like Boston Acoustics, Focal, and MB Quart in my previous stereos back in the 90's. I'm not sure what's decent anymore.
Here's a link to my review of this sub box on Crutchfield. (Same user name)
Rockford Fosgate P3-1X12 Punch P3 ported enclosure with 12" sub at Crutchfield.com
2013 Mazdaspeed 3
Last edited by Evo2speed3; 05-25-2016 at 06:43 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-26-2016, 05:34 PM   #6
Thetal1's Avatar
there was another speed owner who wrote a review on the sub. sounds like its pretty good. im surprised you said it was better than the sundown sub. i have always wanted to go with a more competition sub just so i can see what its all about but i dont have the means of making a custom box for them.
 Old 09-13-2016, 10:18 PM   #7
smurfspeed3's Avatar
Posts: 3   (View Stats)
smurfspeed3 is an unknown quantity at this point
I know its been a few months since you did the install but where did you run the power wire through? I most likely missed the thread where someone talks about this but i have a DC audio sub that I am dying to install all ready and haven't really found a clear answer.
smurfspeed3 is offline   Reply With Quote
 Old 09-14-2016, 12:05 AM   #8
Jhaupfear's Avatar
Posts: 30   (View Stats)
Jhaupfear is an unknown quantity at this point
Behind the glove box, in the firewall, there is a plastic or rubber cap a couple of inches wide. Im assuming this was for the steering column in the left side drive models. Pop it out, drill a hole, grommet if you want, and run wire down pass. Side door molding. There is a writeup on here with pictures somewhere
Jhaupfear is offline   Reply With Quote
 Old 09-14-2016, 12:19 AM   #9
I actually just found it haha. Thanks for answering so quickly though! I just got my ms3 a few weeks ago and miss the bass that i had before i sold my truck and took the sub out.
 Old 09-14-2016, 12:42 AM   #10
Jhaupfear's Avatar
No prob. Listen to this guy about the PAC AOEM2 loc. Its the only way to go, I tried multiple options before i got that and was never happy with the output. Bose or not, use that PAC AOEM2 loc.
 Old 12-15-2016, 03:09 AM   #11
bruce_G's Avatar
Posts: 5   (View Stats)
bruce_G is an unknown quantity at this point
it sounds so great to upgrade a sub and amp, I'd like to add it to my car too, hope it works perfectly.
bruce_G is offline   Reply With Quote
 Old 01-13-2017, 11:35 PM   #12
ajw85's Avatar
Posts: 35   (View Stats)
ajw85 has a spectacular aura aboutajw85 has a spectacular aura about
It looks like there are only 4 outputs on the loc, what do you do if you want to run an amp on the door speakers and a sub?
ajw85 is offline   Reply With Quote
 Old 01-13-2017, 11:42 PM   #13
You use one set of outputs for the sub amp and the other pair of outputs for the speaker amp. It tells you on the loc which output is for front and rear.
No volume from OE Bose system mertz 2010 MS3 - Car Audio & Electronics 15 05-18-2014 11:40 PM
Add EQ to factory Bose System? my2k13speed3 2010 MS3 - Car Audio & Electronics 12 12-27-2013 06:28 PM
Active Sub added to BOSE System KRheeder 2010 MS3 - Car Audio & Electronics 6 04-19-2013 07:49 AM
BOSE SYSTEM QUESTION BROXN 2010 MS3 - Car Audio & Electronics 16 02-27-2011 11:45 AM
Better Bose system! _Toxic_ 2010 MS3 - Car Audio & Electronics 2 03-23-2010 11:24 AM
Page generated in 0.30811 seconds with 26 queries
