> 2010 MS3 - Car Audio & Electronics
 Old 06-28-2018, 01:15 PM   #1
jl449's Avatar
Posts: 65   (View Stats)
jl449 is a glorious beacon of lightjl449 is a glorious beacon of lightjl449 is a glorious beacon of lightjl449 is a glorious beacon of lightjl449 is a glorious beacon of lightjl449 is a glorious beacon of light
Default Bluetooth module issues 2010
Has anybody experience blue tooth module failure? I have a 2010 MS3 (build date 11/09). Last week my blue tooth stop broadcasting... lost connection. Used multiple phones and Mazda doesn't appear. I think its the blue tooth module. Does the stock radio have built in blue tooth or does it use the blue tooth module that is located behind the glove box?
I ended up purchasing a BT unit thru flea bay . It had a different part # -- BBM566DHXA vs BBM466DHXA which I had. The seller told me the 566 is compatible with my year model. Hope so!
jl449 is offline   Reply With Quote
 Old 06-29-2018, 09:49 AM   #2
monkey1911's Avatar
Posts: 14   (View Stats)
monkey1911 is an unknown quantity at this point
The BT in my 2010 Tech is separate from the Bose headunit. It's located somewhere near/above the glovebox. (actually need to find it and attach a wire to it for my steering wheel controls.)
monkey1911 is offline   Reply With Quote
 Old 07-01-2018, 01:36 PM   #3
desync0's Avatar
Posts: 51   (View Stats)
desync0 is a splendid one to beholddesync0 is a splendid one to beholddesync0 is a splendid one to beholddesync0 is a splendid one to beholddesync0 is a splendid one to beholddesync0 is a splendid one to behold
Should be behind/above the glovebox next to the satellite radio receiver
desync0 is offline   Reply With Quote
 Old 07-02-2018, 02:55 PM   #4
jl449's Avatar
Finally removed the glove box and located the bluetooth module. now waiting for the replacement unit...
2010 MS3 - Android Bluetooth DELAY! GitDat 2010 MS3 - Car Audio & Electronics 23 08-30-2011 08:48 AM
IPhone bluetooth audio & 2010 MS3 Ironside 2010 MS3 - Car Audio & Electronics 78 04-21-2011 08:06 PM
2010 MS3/ Android Bluetooth FridayGt 2010 MS3 - Car Audio & Electronics 12 08-02-2010 09:51 PM
bluetooth issues gwangsun 2010 MS3 - Troubleshoot/Diagnostics 2 12-31-2009 02:18 PM
Jabra BT8040 Bluetooth Headset (Stereo Bluetooth Capable) $49.99 Haltech Hot Deals Section 0 04-08-2008 12:50 PM
Page generated in 0.23768 seconds with 22 queries
