> 2010 MS3 - Car Audio & Electronics
 Old 12-07-2010, 06:17 AM   #1
ebnash's Avatar
Posts: 244   (View Stats)
ebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond repute
Default Coolant Temp Switch for Gauge
I just received my Prosport water temp and boost gauges so I will be working on that this weekend. Just curious if anyone has tried tapping into the harness for the coolant temp switch that is already mounted on our engines. This sends a signal to the computer and allows us to read water temp through OBD-II, but I was thinking I may just be able to rob that signal for my electrical gauge.
Has anyone tried this? I am not a fan of splicing into the radiator hose because it is not an accurate reading...
Erik
Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies...
ebnash is offline   Reply With Quote
The Following User Says Thank You to ebnash For This Useful Post:
miataman2 (08-07-2017)
 Old 12-07-2010, 07:25 AM   #2
treyclash's Avatar
Posts: 592   (View Stats)
treyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond repute
Groaned at 321 Times in 98 Posts
not sure about that... maybe someone else will chime in pretty soon. plz post pics of everything mounted and what all u did. this will be something ill b looking into very soon. havent heard anywere about tapping the harness so you may b the first guinne pig.
2010 Mazdaspeed 3 Liquid Silver.
Performance: -K&N SRI. -CP TP. -Forge BPV.
Interior: -DashDaq.
Exterior: -Rally Armor Mud Flaps. - Xenon 35w 6000.
treyclash is offline   Reply With Quote
 Old 12-07-2010, 07:41 AM   #3
fishin53's Avatar
Posts: 1,721   (View Stats)
fishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the worldfishin53 is the leader of the world
Groans: 44
If you can figure this out, then you are a god. I wanna figure this out. How about tapping into the wire that connects to warning lights in the gauges?
2010 Black Mica Speed3 SOLD
2005 Jeep Wrangler X Impact OrangeSOLD
2015 Subaru XV Crosstrek Tangerine Orange Pearl
fishin53 is offline   Reply With Quote
 Old 12-07-2010, 08:09 AM   #4
ebnash's Avatar
I am pretty sure that the idiot light is a digital output, so it only triggers when a defined temperature is reached. The coolant temp switch should send an analog signal to the computer, so I am hoping I can just tap into this signal for the gauges.
I may not be doing this this week since I have not received my dual vent pod yet, but when I do, I will take pictures of the whole attempt and post them with a write if it is successful.
Erik
treyclash (12-07-2010)
 Old 12-07-2010, 08:42 AM   #5
treyclash's Avatar
Erik
good shit thank you. this is going to be very interesting. i ussually sense major fail but for some reason i see success in your future. like i siad this would b the shit to do.
Interior: -DashDaq.
 Old 12-07-2010, 09:08 AM   #6
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Erik
The coolant temp sensor is just a thermistor, connected to the ECM, and the sensor ground, as the temp goes up the resistance goes down... The OEM guage may not be a direct display of the sensor output, but sensor itself is accurate and not just for an on/off idiot light..
You can not connect your aftermarket gauge to the OEM sensor.. You'll just end up with a useless guage, and throw off the ECM as well..
Your gauge should have come with it's own sending unit, you need to use it..
 Old 12-07-2010, 10:56 AM   #7
ebnash's Avatar
I agree with you on how the coolant temp sensor works, but the sending unit that comes with the gauge is the same principal. As temp fluctuates, resistance changes and the gauge resolves that with a needle movement. I believe the temp sensor (electrical, not mechanical) that comes with the gauge operates using the same physics, but it is very possible that the resistance calibration is different between the 2 units. I am also not sure if tapping into that wire will disrupt the signal to the ECU, but this is why I plan to try it and see if it works out. I also have a spare coolant temp sensor is case the wire tap upsets the ECM signal.
Unless someone else has actually attempted this with fail, it is all based on theory, correct? I make no claims of success until it is done.
Hopefully someone speaks up if they have failed with this experiment. My only other option is going to be to buy a spare water outlet and see if I can drill/tap a port for the sensor that comes with the gauge, but this will require draining the coolant to install and I would like to avoid going there unless I have to...
I will do without a dedicated gauge before I splice into a coolant hose to get an inaccurate reading of engine water temp.
 Old 12-07-2010, 11:00 AM   #8
m4tic's Avatar
Posts: 4,928   (View Stats)
im thinking there is no OEM gauge for 2010+
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 12-07-2010, 11:21 AM   #9
Groans: 60
Did not know that...
Regardless, don't mess with the OEM sending unit...
 Old 01-20-2011, 09:04 AM   #10
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
well, where are the pics?
2010 Black Mica
rghispanic88 is offline   Reply With Quote
Trouble code ? (Inconsistant coolant temp.) boostjunky MazdaSpeed 3/6 - Turbo Induction 1 07-11-2010 03:52 PM
Need help diagnosing weird coolant temp readings Addikted To Boost MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-09-2009 09:17 PM
water temp gauge Doc-1 MazdaSpeed 3 - Engine, Transmission & Driveline 12 08-03-2009 10:48 AM
Oil Temp gauge kingpin748 MazdaSpeed 3/6 - Car Audio & Electronics 6 02-16-2009 07:08 PM
Page generated in 0.31482 seconds with 25 queries
