> 2010 MS3 - Car Audio & Electronics
Like Tree5Likes
 Old 03-19-2015, 08:28 AM   #41
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
They didn't do that when I had to send my GM5163 I got for this car, back about a year ago. My gf bought it, not sure if it was the actual EONON site or not. CD got stuck in there 2 days after I installed it. She emailed them about the problem and within an hour they had responded and sent a prepaid label for us to ship it back. She didn't have to provide any information of our order.
Also, to anyone who gets this unit. Do yourself a favor, read up on this thread. Will make the unit even better after installing upgraded firmware/rom/etc... - HuiFei - 2 DIN Pure Android 4.2.2/4.4.2/4.4.… | Android Development and Hacking | XDA Forums
 Old 03-19-2015, 11:27 AM   #42
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Just wanted to double check since on their site they say 32GB maximum, that is just for the SD card slot right, you are actually using a 128GB USB drive for all of your music with out any issues? Are you able to play movies from it also? Does the radio lights adjust with your headlights? I've read a few complaints about them staying on all the time and the screen not dimming. I've also read about issues with not being able to lock doors with the keyfob for a period of time after shutting off the car. Have you had any issue like that?
On Order:
Coming Soon:
DIY Projects:
 Old 03-20-2015, 01:02 PM   #43
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
Ordered one of these bad boys.
 Old 03-24-2015, 07:10 AM   #44
g00s3y's Avatar
Groans: 438
Got it yesterday, just connected it, played around with it for a bit, then threw a custom 4.4.2 on there. So much quicker, responsive overall. Haven't really done anything else to it yet. Going to head out and finish connecting/placing everything in a little bit.
 Old 03-24-2015, 07:40 AM   #45
CHUNKYBOWSER's Avatar
Posts: 209   (View Stats)
CHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the worldCHUNKYBOWSER is the leader of the world
I installed it yesterday, the bottom of my air vents are sticking out a little so it looks like I'll have to pull out the panel and the HU and try to realign everything. Kind of a pain. Other than that, once I get all the software set up to my liking this will definitely be a good buy.
Engine
| GTX3067R | Cobb AP | Autotech Internals | HTP 3.5" Intake | M2 Long Downpipe |
| ATP FMIC | Forge V1 | Grimmspeed EBCS | 3 BAR MAP | NGK Iridium IX |
| Damond EGR Delete | JBR OCC | E33 Self Tune | DO7 Meth |
Handling
| Damond RMM | Damond PMM | JBR 88a TMM | JBR Shift Weight & Knob |
| JBR Rear Sway Bar | Cobb Springs |
CHUNKYBOWSER is offline   Reply With Quote
 Old 03-24-2015, 12:49 PM   #46
Feline Führer
neganox's Avatar
Where are you all getting the 4.4.x rom at?
I'm dumb. Found it.
 Old 03-24-2015, 01:58 PM   #47
g00s3y's Avatar
Groans: 438
Ok, I must be stupid also, because I can't get my sub working with just the headunit and attachments. I had to use the PAC and hook that up in between the OEM wiring and 5163 wiring. Which, while it works, is more wiring and stuff than I would like sitting behind the headunit.
So who can show me why I'm an idiot that can't get a simple sub/amp working. Amp is fine and turns on, I just get no response from the sub. Throw the PAC in between and everything is fine...
 Old 03-24-2015, 03:14 PM   #48
What's wrong with having that much wiring? Just stuff it out of the way as much as possible.
I'm having a new problem, my front passenger speakers are only playing at half the loudness of the others. Its not the HU's fault, I tested the other outputs. Any idea what would cause reduced volume?
Engine
Handling
 Old 03-25-2015, 05:12 PM   #49
Well I fixed the speaker problem, just needed to reconnect the harness. Unfortunately I've found a single dead pixel on my screen. Anybody else have any? I hate dead pixels but I can probably deal with it.
Engine
Handling
 Old 03-26-2015, 05:35 AM   #50
g00s3y's Avatar
Groans: 438
I don't want all that extra wiring back there because the SWC don't work with both connected, and too much noise from plastic hitting metal/other plastic.
 Old 03-26-2015, 07:35 AM   #51
How is the amp connected to the HU? The sub out RCA cable?
Engine
Handling
 Old 03-26-2015, 10:26 AM   #52
Porterhouse07's Avatar
Posts: 221   (View Stats)
Porterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond reputePorterhouse07 has a reputation beyond repute
Groaned at 6 Times in 4 Posts
Originally Posted by FatalSinz View Post
I'm not sure if i'm publicly allowed to post links to webpages with the .img contents. I'll toss you a PM.
Any chance i can get the links and the how-to also? I ordered this unit yesterday.
GT3071R | HTP 3" Intake | Magnaflow CBE | Grimmspeed EBCS | Bosch 3 Bar MAP | AP v3
CS HPFP Internals | CS Catted DP | CS RMM | TR6 FMIC w/ JBR Piping | HKS SSQV4 BPV
CS SSP | Swift Springs | DM Stage 3 OCC and PCV Plate | EBC Slotted Rotors w/ Yellowstuff Pads | NGK Iridium
Freektuned 350/365
Porterhouse07 is offline   Reply With Quote
 Old 03-26-2015, 02:09 PM   #53
g00s3y's Avatar
Groans: 438
Right now I have it connected to the PAC device in-between the headunit cabling & OEM wiring. Everything is working right now, had to flash a different rom, the one i flashed didn't have swc working correctly. The sub also works with the way it is right now, but eh...
When I had it connected with just the headunit, I had it connected to the rear out L/R. I am going to have to get a Y cable I guess because the sub-out on this one is a single RCA connection. I feel like an idiot because I'm sure it's something minor I'm missing. Yes I have the remote wire for the amp hooked up also.
I posted the link to the XDA thread above.
mazda-speed-3 likes this.
 Old 03-26-2015, 02:12 PM   #54
Oh I see. I must have overlooked it the first time through. Thanks
Freektuned 350/365
 Old 03-27-2015, 06:34 PM   #55
Feline Führer
neganox's Avatar
Which ROM are you all using? There appear to be a plethora of ROMs listed for different model numbers.
 Old 03-29-2015, 08:33 AM   #56
paul.ball.566's Avatar
Posts: 3   (View Stats)
paul.ball.566 is an unknown quantity at this point
@FatalSinz, I do not have enough posts on the forum to PM you. Could you send me the links and instructions for how to install KitKat on this head unit please.
paul.ball.566 is offline   Reply With Quote
 Old 03-29-2015, 11:45 AM   #57
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Look at the link to the XDA forums above.
 Old 03-29-2015, 11:55 AM   #58
GCPhotographers's Avatar
Posts: 1,198   (View Stats)
Besides that Eonon offers a video install guide.
2012 Black MazdaSpeed3
Fuel: 91 & 93 Octane /
COMING SOON
 Old 03-30-2015, 04:39 AM   #59
Feline Führer
neganox's Avatar
Got my unit upgraded to 4.4.4. Setting the DPI in the build.prop file to 180 makes everything a lot nicer.
 Old 03-30-2015, 04:53 AM   #60
I wasnt talking about the radio install. But thanks anways
Freektuned 350/365
 Old 03-31-2015, 08:09 AM   #61
g00s3y's Avatar
Groans: 438
Ok, so no matter what I tried, I could not get my sub working with this headunit wiring only. Tried rear out/sub out/aux out, nothing. Remote wire hooked up, amp turns on, but nothing happening with the sub. Hook up the MAZ PAC device in between, and connect the sub there, everything is perfect.
So anyone else who isn't using just the bose system have this wired up and working with a different amp/sub?
 Old 04-01-2015, 07:18 PM   #62
Just got hit with a $26 duty bill from Fedex. :/
Engine
Handling
 Old 04-01-2015, 07:21 PM   #63
jdmage_mx5's Avatar
Me too, I just never paid it. We shall see how long it takes before they notice LOL.
 Old 04-02-2015, 03:11 PM   #64
g00s3y's Avatar
Groans: 438
Same here, I never got one the last time I ordered the GM5163... I'm not going to pay it either.
 Old 04-02-2015, 03:17 PM   #65
FatalSinz's Avatar
Posts: 70   (View Stats)
FatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond reputeFatalSinz has a reputation beyond repute
Well, i guess the downside is that although the shipping is free, the duty isn't.
JBR Rear Sway Bar / JBR Short Shifter Plate / JBR Shifter Bushings / JBR Small Battery Box / JBR 3.5” Wide Path Intake / JBR 88A RMM / Bosch 3Bar Map Sensor / Bosch PNP Harness / CS Turbo / Purple Drank Tune / Ultimate Racing Catted DP / Ultimate Racing Test Pipe / NGK6510 Spark Plugs / Damond Oil Catch Can / Grimmspeed 3 Port EBCS / Autotech HPFP / Braided SS 5AN Fluid Lines / Treadstone TR8 FMIC / CX Racing FMIC Piping / Vibrant Couplers / Koni STR.T / H&R Springs / Forge V1 BPV / CS STI Front Lip / 17x9+35 XXR 968 / 245/45/17 / Potenza RE760 / 94 Octane + 4 Gal E85
FatalSinz is offline   Reply With Quote
 Old 04-10-2015, 08:30 AM   #66
geekd4d's Avatar
Posts: 46   (View Stats)
geekd4d is just really nicegeekd4d is just really nicegeekd4d is just really nicegeekd4d is just really nicegeekd4d is just really nice
Which rom did you go with?
Mine is set to arrive Monday and that pretty much the first thing I am going to do once I verify it works out of the box. So far I've seen 4 roms, each with their own issues. (for Kitkat 4.4.4)
I'm going to pick up an External mic for this unit as well as I've seen the horror stories on xda about it.
geekd4d is offline   Reply With Quote
 Old 04-10-2015, 10:39 AM   #67
Feline Führer
neganox's Avatar
I haven't had issues with the mic.
FileMirror for HuiFei-Units
Grab whatever device yours is. Settings -> About Device will show you what 3 letter variant you have. I think mine was KDL.
I went back to the 240 dpi since the bluetooth apps and radio apps didn't look correct with the smaller dpi.
I'm going to give Malaysk's roms a shot since they appear to be kept more up to date.
 Old 04-10-2015, 11:04 AM   #68
Yatta's Avatar
Posts: 1,862   (View Stats)
so, I have a 2012 with Bose, Eonon page states no Bose... for those running this, what works?
 Old 04-13-2015, 07:23 AM   #69
geekd4d's Avatar
Have to solder in rca jacks for it to work. see above posts.
I'm going to try to document my install as well this week if I have time to actually install mine in my 2012 W/Bose. (Came saturday, a day earlier than expected.. I was just up a mountain riding all weekend)
Edit:
Was thinking of the GM thread..
Here are the install pics from that thread
 Old 04-13-2015, 08:21 AM   #70
Feline Führer
neganox's Avatar
I have a 2013 w/ bose, but also have a PAC MAZ device for the sub I was running like @g00s3y; I'll try to disconnect this weekend and see if the sub still works. Everything works fine with the bose amp etc. etc.
 Old 04-13-2015, 09:16 AM   #71
Yatta's Avatar
the phone buttons? I’ve read the thread a few times and have seen elsewhere that some phone functions do not work, I daily drive and wheel controls for the phone are pretty important.
thank you.
 Old 04-13-2015, 10:24 AM   #72
Feline Führer
neganox's Avatar
Phone buttons also work. The headunit comes with an OEM integration box. The software also has an app to allow for button mappings / learning. Additionally this is the only headunit I've ever had work with phonebook syncing.
 Old 04-13-2015, 05:36 PM   #73
geekd4d's Avatar
How did you get the Phone pickup and Hangup buttons to work? Canbus box is hooked up, all others work except this. Even Eonon has said the phone buttons do not work.
 Old 04-13-2015, 05:59 PM   #74
Feline Führer
neganox's Avatar
I'll have to check again. I swore they worked. Maybe I made it up.
Easter Bunny (04-15-2015), geekd4d (04-14-2015)
 Old 04-14-2015, 06:12 AM   #75
g00s3y's Avatar
Groans: 438
Ok, so i'm sending my unit back. No matter what, if my car sits for a day, the battery is dead. The sub out would not work no matter what, had to have the PAC in between. I updated the MCU and firmware, and was able to get the wifi to start working because that wasn't working from the start. I also noticed that the fader really doesn't work, I could put it all the way to the rear, and still full volume from the front speakers.
I've checked everything, and have come to the conclusion that it's the headunit, I'm just guessing I got a dud. I tried different roms/kernels and nothing got it all to work correctly.I put the stock one back and everything is fine, put the 5163 in, car is dead the next morning.
That $350 will now go towards the big turbo fund.
 Old 04-14-2015, 07:09 AM   #76
jdmage_mx5's Avatar
...I put the stock one back and everything is fine, put the 5163 in, car is dead the next morning. That $350 will now go towards the big turbo fund.
So now we know, if you want this radio don't buy the cheap one from eBay.
 Old 04-14-2015, 07:28 AM   #77
g00s3y's Avatar
Groans: 438
They are all the same, coming out of the same factory in china. Then whoever gets them, puts their own touch on it and sells it.
I also gave a low offer, not expecting them to accept $350, and also think I got a returned unit because of that. Based upon the fact there were still numbers in the BT phonebook when I got it. Not saying if I paid full price, $398.89, it would have been different, but it's a possibility.
 Old 04-14-2015, 06:53 PM   #78
geekd4d's Avatar
Have any chance to check?
Ive gone through KLD and KGL Roms (All while running the 2.40 MCU) and its made no difference.
Also, You wouldn't happen to have torque working would you? I cant get my adaptor to connect. (even tried the MCU Xposed module) Would be nice to have it all on screen vs the small screen on the AP.
I'm thinking we need a dedicated Help Thread for this unit Specific to our Speed as not everyone here is ready for the mass thread at XDA.
 Old 04-14-2015, 07:18 PM   #79
superman's Avatar
Posts: 288   (View Stats)
superman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond repute
I didn't get a duty fee. It's hit or miss I think. Torque pro is awesome, but the mazdaspeed plugin occasionally stops working and has to be re-installed.
Do you guys have issues with ipod connectivity? My ipod only connects 75% of the time and its really slow.
Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff
superman is offline   Reply With Quote
 Old 04-15-2015, 06:07 AM   #80
Feline Führer
neganox's Avatar
Phone buttons don't work... and I can't get them to program via the app. I have a obd2 to usb cable sitting in the garage I'm going to try with torque. Torque with bluetooth works, but is flaky.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f434/eonon-ga5163-review-184655/
Eonon GA5163 Review This thread Refback 07-01-2015 10:12 AM
Eonon GM5163 Review - 2012 with Bose bitburner 2010 MS3 - Car Audio & Electronics 194 12-18-2018 07:43 AM
Eonon GM5151 Atomic41 MazdaSpeed 3/6 - Car Audio & Electronics 14 03-27-2015 06:47 AM
Eonon D5115Z - Quick review TheRealDefman 2010 MS3 - Car Audio & Electronics 3 01-21-2013 09:47 PM
Page generated in 0.56862 seconds with 32 queries
