> 2010 MS3 - Car Audio & Electronics
Like Tree5Likes
 Old 09-15-2015, 07:23 AM   #241
ArmanRus's Avatar
Posts: 1,566   (View Stats)
Groans: 42
Originally Posted by RhINoX^ View Post
Hey, I have a quick question. I just installed ga5163f. It was plug and play but it does not sound right. Volume it's really sensitive and loud even on 1. Also don't think the sub woofer is on. My car has Bose system, so do I need to splice up Rca outs?
Thanks
@aromig; mentioned that it's supposed to work correcrly out of the box. Maybe there's a setting that turns the feature ON/OFF? Otherwise, contact Eonon. They reply reasonably quick.
 Old 09-15-2015, 07:30 AM   #242
Yeah, it's supposed to work with the Analog Bose System.
From the m3f forums that they are on.
Originally Posted by EononCarDVD
yes if you have the Analog bose system, you don’t have to do the RCA soldering mod at all, very easy to connect
Eonon GA5163F thread
 Old 09-15-2015, 10:41 AM   #243
RhINoX^'s Avatar
Posts: 101   (View Stats)
RhINoX^ is a name known to allRhINoX^ is a name known to allRhINoX^ is a name known to allRhINoX^ is a name known to allRhINoX^ is a name known to allRhINoX^ is a name known to all
Thanks guys. I am really a noob, but feels like I am experiencing same issue like everyone else. Need to splicethose RCAs. System works, but not properly. Messaged Eonon and will wait for their response.
Smiley
Cobb AP V2 Stratified // Cobb RSB // AT Internals // CP-e Stage 2 RMM // CS DRL // Eonon GA5163f // ETS TMIC // Cobb Airbox // Itv 22
RhINoX^ is offline   Reply With Quote
 Old 09-15-2015, 12:50 PM   #244
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Is there an option for Bose other then Analog in our cars? I was reading their whole line about how the steering wheel controls for bluetooth will work if the controls are part of the same line as volume and we have to check each car to see if it is that way. I don't see how that could be different from one car to the next. just like the Bose, I wonder if this is going to end up being an advertised feature that doesn't actually work just like the steering wheel control features they advertise.
On a side note, it looks like on that other forum they are putting together a group buy for the radio, no mention on what the discount price will be yet.
On Order:
Coming Soon:
DIY Projects:
f150turbo (03-02-2016)
 Old 09-18-2015, 12:03 PM   #245
RhINoX^'s Avatar
Update..
Heard back from Eonon, there is no other way to make the unit work properly, but splicing up RCAs.
They consider it plug and play for Bose system. Which it is, but sounds loud and horrible. So I did the RCAs and I am happy with the sound. That how it should have been pre wired from the factory. Overall happywith the unit, but a lot to be desired.
Smiley
 Old 10-12-2015, 09:10 AM   #246
JSM3377's Avatar
Posts: 17   (View Stats)
JSM3377 has a spectacular aura aboutJSM3377 has a spectacular aura aboutJSM3377 has a spectacular aura about
@aromig;
Any update on getting the phone SWC to work?
JSM3377 is offline   Reply With Quote
The Following User Says Thank You to JSM3377 For This Useful Post:
Kawiralph (05-29-2016)
 Old 10-14-2015, 08:05 AM   #247
geekd4d's Avatar
Posts: 46   (View Stats)
geekd4d is just really nicegeekd4d is just really nicegeekd4d is just really nicegeekd4d is just really nicegeekd4d is just really nice
Originally Posted by JSM3377 View Post
@aromig;
Its not possible with these units.. period.
geekd4d is offline   Reply With Quote
 Old 02-01-2016, 06:50 PM   #248
case6's Avatar
Posts: 150   (View Stats)
case6 has a reputation beyond reputecase6 has a reputation beyond reputecase6 has a reputation beyond reputecase6 has a reputation beyond reputecase6 has a reputation beyond reputecase6 has a reputation beyond reputecase6 has a reputation beyond reputecase6 has a reputation beyond reputecase6 has a reputation beyond reputecase6 has a reputation beyond reputecase6 has a reputation beyond repute
Sorry to rez this old thread, but it makes more sense than to start a new one.
Anyone have the upgraded D5163Z Headunit from the older D5163F one? Reading through this thread and it seems like a decent aftermarket unit with minor issues if any. Any input on the upgraded unit is welcome!
case6 is offline   Reply With Quote
 Old 02-24-2016, 07:09 PM   #249
freality's Avatar
Posts: 1   (View Stats)
freality is an unknown quantity at this point
Originally Posted by aromig View Post
Amazon.com: PAC RP4-MZ11 Radio Replacement Interface for Mazda Vehicles With Built In Pre Programmed Steering Wheel Control Retention and Navigation Outputs: Car Electronics
Just ordered this mf, others have had luck with it for different head units. Retains all swc (including phone buttons), stock mic, and allows programmable lcd screen text. Bonus, it allows for Bose amp customization: stock amp gain, centerpoint on/off, centerpoint gain, balance/fader. Wonder if it swallows.
"The RP4-MZ11 interface allows the replacement of a factory radio in select Mazda vehicles with MS-CAN radios. Using this interface will retain factory features such as steering wheel controls (SWC), programming of the clock on the OEM LCD screen, vehicle information on the OEM LCD screen and the BOSE amplifier when the original radio is removed. Use of this interface also allows you to program two radio functions to each SWC button by using short press long press dual command functionality. The RP4-MZ11 also provides data bus driven outputs such as retained accessory power (RAP), vehicle speed sensor (VSS), illumination, reverse trigger and parking break."
I'll update when it's in.
Did you have some success with the GA5163F + RP4-MZ11?
freality is offline   Reply With Quote
 Old 02-29-2016, 09:10 AM   #250
Nitro's Avatar
Posts: 229   (View Stats)
Nitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond reputeNitro has a reputation beyond repute
My D5163 has stopped reading micro SD cards and the bluetooth is not usable for phone calls. Should I just scrap this unit? I contacted Eonon last year when the bluetooth was the only problem and they basically told me to buy a new unit! I had heard there was a new firmware update but they offered no assistance. Thoughts?
COBB AP : JBR 3 Inch Full Intake : CORKSPORT TMIC : AUTOTECH INTERNALS : JBR SSP
CPE Full RMM : Cobb Catted DOWNPIPE : BNR S3 : KW V1 Coilovers : Klutch SL18 Rims
Guardian Angel : Stratified 3 Port : Michelin PSS 235/40/18 : SNOW PERFORMANCE : E85
Stratified Tune
Nitro is offline   Reply With Quote
 Old 07-06-2016, 01:17 AM   #251
ghajar77's Avatar
ghajar77 is an unknown quantity at this point
Hi.
I want buy a ga5163f .
Is it good for my mazda3 or other brand like pioneer is better ?
Is quality ok ?
Is touch and screen ok ?
Is funection fast and ok ?
فرستاده شده از HTC One_M8ِ من با Tapatalk
ghajar77 is offline   Reply With Quote
 Old 07-07-2016, 09:24 AM   #252
iamareios's Avatar
Posts: 79   (View Stats)
iamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to beholdiamareios is a splendid one to behold
Originally Posted by ghajar77 View Post
Hi.
Is quality ok ?
I have had mine for a year or so. It was very buggy straight out of the box, but it comes rooted already being android. Once you tweak android a bit to your liking, the operating system is manageable. But honestly for sound this thing sucks in comparison to sound quality with an alpine or pioneer deck. The original bose optional equipment sounded better in my opinion. This is even after replacing the original amplifier with a better one to power all the speakers. It just doesn't sound good. However I keep it because I'm an android fan boy and I use google maps, waze, and google play music frequently. It's nice having it all integrated into the car. Not to mention I originally bought it to use with the Torque app to monitor boost and other essentials right there on the screen.
(PD tuned) 397hp/358tq 91/100% meth
BNR S4, XS v3 manifold, CNT dp, OBX cbe, JBR ebcs, AUTOTECH hpfp, PnP/vtcs del. manifold, SU TMIC, HTP 3.5" intake, Synapse DV, D10 100% meth kit, Damond OCC VTA, AFR failsafe, Bilstein b8's/Cobb springs, stuff
iamareios is offline   Reply With Quote
 Old 06-12-2019, 08:24 AM   #253
kelbrant's Avatar
kelbrant has a little shameless behaviour in the past
Default Newbie looking to root, please help!
Hello, I came across your posts regarding updating your eonon head unit. I have been trying to do this fore the past month and just suck at figuring it out. What files/rom/mcu/software etc....I have no idea what I need and saw that you said that sending you a PM would be best because the links get deleted. I know this is old but I really hope you get this email and could give me some direction. Thank you for being active and posting about this!!!!!
kelbrant is offline   Reply With Quote
The Following User Says NO Thank You to kelbrant For This Un-useful Post:
Db09ms3 (06-12-2019)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f434/eonon-ga5163-review-184655/
Eonon GA5163 Review This thread Refback 07-01-2015 10:12 AM
Eonon GM5163 Review - 2012 with Bose bitburner 2010 MS3 - Car Audio & Electronics 194 12-18-2018 07:43 AM
Eonon GM5151 Atomic41 MazdaSpeed 3/6 - Car Audio & Electronics 14 03-27-2015 06:47 AM
Eonon D5115Z - Quick review TheRealDefman 2010 MS3 - Car Audio & Electronics 3 01-21-2013 09:47 PM
Page generated in 0.34735 seconds with 32 queries
