> 2010 MS3 - Car Audio & Electronics
  • 1 Post By RhRU
 Old 12-17-2018, 07:17 AM   #1
RhRU's Avatar
Posts: 8   (View Stats)
RhRU will become famous soon enough
Default Mazda 3 2010 woth BOSE and Eonon GA9163K no soun
I installed the eonon radio and everthing works like the commands, it tunes in the radio stations,finds the usb but there is no sound. Did anybody had this problem?
RhRU is offline   Reply With Quote
 Old 12-29-2018, 09:58 AM   #2
Yllib30's Avatar
Posts: 10   (View Stats)
Yllib30 will become famous soon enough
Di you fixed? Having the same problem
Yllib30 is offline   Reply With Quote
 Old 12-29-2018, 12:28 PM   #3
RhRU's Avatar
Yeah Actually I did.
After a investigation I came across the forums that the Bose amp needs the have the "amp remote" wire turned on. (most frequently it is the blue wire with white stripes).
I double checked my cables (for bose you need to plugin in the audio cables with the little box (cricut protection box) attached to it.
I checked the voltage of the remote amp wire and it was "dead".
So One of the options is that the amplifier wire is not turned on.
So Go to your equalizer(either from radio/music or settings/car infotainment/sound)
In the lower left corner you will see the icon with 5 dots.
It opens another menu. There is a option Examp that is turned off. Turn it on and: Let there be rock!
Yllib30 likes this.
The Following User Says Thank You to RhRU For This Useful Post:
Yllib30 (12-29-2018)
 Old 01-02-2019, 07:28 AM   #4
payandplay's Avatar
Posts: 1   (View Stats)
payandplay is an unknown quantity at this point
Hi Friend,
I am about to get such device. I am a bit concern about the quality of the built in amp. Can you please share your feedback about audio quality of any type of audio format you played?
Overall is this device good improvement over stock head unit?
Thank you in advance.
payandplay is offline   Reply With Quote
 Old 12-29-2018, 12:57 PM   #5
Yllib30's Avatar
Dude thanks!! It work!!!!
 Old 01-02-2019, 06:44 PM   #6
aeonpsych's Avatar
Posts: 53   (View Stats)
aeonpsych is a jewel in the roughaeonpsych is a jewel in the roughaeonpsych is a jewel in the rough
I have eonon for non bose 2008 speed 3. Sound great, looks great. Loads a tad slow I have last years model, not the latest eonon unit, so can't speak if they improved it.
Only issue I have is it sounds like the bluetooth codec in this unit transmits music at like 60 kbs. I can hear a lack of audio quality using bluetooth streaming, that isn't present using the exact same audio file from SD card, or on a different bluetooth receiver. Bluetooth phone calls sound as expected, using the built in mic. I didn't even hook up the wired extension one that came with it.
Also, my AUX jack is defective, so I can't even speak as to the performance of this on the unit. I should just get an aux to rca cable and replace it, but I'm too lazy, plus been waiting to pull out the dash again until I go subs (if I do)
Installation took about 1 hour start to finish. Another 30 minutes to install the backup cam.
aeonpsych is offline   Reply With Quote
 Old 01-14-2019, 05:07 PM   #7
Adamxx6's Avatar
Posts: 43   (View Stats)
Adamxx6 will become famous soon enoughAdamxx6 will become famous soon enough
random question for you guys. i installed this headunit the other day, everything works fine except my upper led display constantly says navi system. is that normal for you?
Adamxx6 is offline   Reply With Quote
 Old 03-24-2019, 08:24 PM   #8
Sonofnothing's Avatar
Posts: 33   (View Stats)
Sonofnothing is on a distinguished road
Thanks for this. I purchased a new Eonon navi unit because the 2013 variant was sluggish and just awful to deal with. This one is great, connects to BT quickly, and now I finally have sound!
Let me ask, is there another way to EQ the car, though? This version of the head unit does not have a dedicated subwoofer EQ, so when you engage LOUD, the sub is full throttle. Lets just say this Bose system sucks ass, as we all know already...
'13 ms3 * 72k * FREEKtuned * Accessport v3 * COBB SRI/TI * Autotech HPFP * ETS TMIC * CS fully mounted * CS short shift plate/bushings * Goodyear Eagle F1 Asymmetric 3 * dash designs suede * weather tech floor mats.
Sonofnothing is offline   Reply With Quote
 Old 03-25-2019, 06:35 AM   #9
LorenzoDM01's Avatar
Posts: 17   (View Stats)
LorenzoDM01 can only hope to improve
Thanks was also following this
LorenzoDM01 is offline   Reply With Quote
 Old 04-22-2019, 05:46 PM   #10
vsmap2001's Avatar
vsmap2001 is an unknown quantity at this point
Has anyone been able to get the Speak, Pick up and Hang up button on the steering wheel to work?
vsmap2001 is offline   Reply With Quote
 Old 11-02-2019, 06:30 AM   #11
Diagro's Avatar
Diagro is an unknown quantity at this point
Hello,
To have the phone buttons working you need to connect the SW1 wire to a certain cable on the BT module found under the glove box.
I believe its a blue wire. I cannot recall 100%
Then you go into the button section and relearn all the buttons so that it detects your input.
Diagro is offline   Reply With Quote
 Old 12-03-2019, 03:02 AM   #12
RhRU's Avatar
To anyone who is intersted in buying this unit.
Sound is perfect (Another one bites the dusts is clean).
Only problem with this unit is the built in microphone. You have to tweak it pretty hard in order to not get an echo and that the other guy hears you.
That being said-the tweaks need basically a factory reset all the time until you get your "perfect" micboost.
Other than that device is great.
Regarding the call and hangup buttons out of the box they are not supported. I am not sure about re-wiring
 Old 12-03-2019, 09:37 AM   #13
tripppleP's Avatar
Posts: 97   (View Stats)
I have the 9363 or 9163 version. The unit works ok. The sound is definitely not like the oem headunit. The whole thing is glitchy but good enough to keep it. The downside is it shits off about once a week and needs to be reset to alleviate the blank screen. I have read thisnis common with Eonon.
The only reason I got the unit was for a screen for the reverse cam which works well. Otherwise I would have returned it and stayed stock.
2010 Black MazdaSpeed 3
80k+ miles
CS RMM
Damond PMM
Autotech HPFP
JBR solid shift bushing
DM short shift plate
HPS SRI
G-plus TIP
CP-e TMIC
AP V3 Stage 1 +SF
 Old 12-03-2019, 10:10 AM   #14
RhRU's Avatar
I have this unit for a year now, and I am in my car at least 2 hours a day. Never had this problem at all.Maybe it is from a unit to unit kind of thing?
 Old 12-03-2019, 08:20 PM   #15
tripppleP's Avatar
Must be. I would say every 2-3 days my unit's screen turns blank and needs to be reset. Today I pulled in for gas, turned the car off and back on, and the screen went blank and the unit had to be reset to return back on.
When I email the company they reply with a list of 10 things to do in broken English. I kind of want to return the unit or exchange it. I can't see paying $300 for an item like this and have it blank out every couple of days.
80k+ miles
CS RMM
Damond PMM
Autotech HPFP
HPS SRI
G-plus TIP
CP-e TMIC
AP V3 Stage 1 +SF
 Old 12-03-2019, 10:58 PM   #16
RhRU's Avatar
Stupid queation. Is your car voltage and current stable?
That sound to me like the voltage is dropping for some reason and it is messing with the headunits capacitors.
Or the headunit capacitors aren't good.
 Old 12-04-2019, 05:31 AM   #17
tripppleP's Avatar
I don't know how to check that. There are no other current electrical issues with the car. How would I find out if there is an issue with the car?
Also, when I google the issue it seems I am not the only one with this issue. I think there is even a review on amazon about the same thing. I also seen an advertisement for a business that is specific to the issue. So that makes me think its less likely the car and more so the head unit. I would still investigate the car if I new how.
80k+ miles
CS RMM
Damond PMM
Autotech HPFP
HPS SRI
G-plus TIP
CP-e TMIC
AP V3 Stage 1 +SF
 Old 12-04-2019, 05:41 AM   #18
RhRU's Avatar
Simplesti thing is maybe to find an andoid app that shows yo the current. Other than that you would need a measuring device connected to the cables to see the stability of the voltage itself.
small offtopic:
Also tripppleP since I cannot send PM's just yet. Can you look at this thread?
MS3 2010 Armrest small try
Yes this is normal. No worries about it. Basically the car is "adapting" to the new system and it registers it as a nav device
Last edited by RhRU; 12-04-2019 at 05:41 AM. Reason: MSF Database - Automerged Doublepost
Eonon GM5163 Review - 2012 with Bose bitburner 2010 MS3 - Car Audio & Electronics 194 12-18-2018 07:43 AM
Bose amp dead in my 2010 Mazda 3 Dregs78 2010 MS3 - Car Audio & Electronics 5 06-29-2016 04:04 AM
how to install eonon d5102 with bose + aftermarket sub jack_hammer MazdaSpeed 3 - How-To's 3 08-18-2014 11:05 AM
Eonon D5151 with Bose in 07 GT. help! Duckz28 MazdaSpeed 3/6 - Car Audio & Electronics 5 02-14-2014 09:19 AM
Koolertron/Eonon with bose soundsystem connection matte08 MazdaSpeed 3/6 - Car Audio & Electronics 31 10-24-2013 10:52 PM
Page generated in 0.38215 seconds with 29 queries
