> 2010 MS3 - Car Audio & Electronics
 Old 05-10-2017, 02:32 PM   #1
modusoperandi's Avatar
Posts: 309   (View Stats)
modusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond repute
Default Prosport Oil Temp Gauge Install Questions
Trying to wire up & install my Prosport oil temp gauge & have seen a few threads of prior installs people have done on the genjuans. My concerns are using add circuit fuses that are rated for 10A & plugging into the fuse connections listed that are 15A. Also the gauge requires a 12V power source, I'm not entirely too saavy with the electrical side of the car so just seeing what some other genpu owners have done on their installs.
modusoperandi is offline   Reply With Quote
 Old 05-10-2017, 07:55 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
12 amps sounds really high for a single gauge.
I would never use an additional 10 amps of current from a fuse tap. If you need more than 3-5 amps use the fuse tap to trigger a relay and pull the load directly from the battery.
 Old 05-10-2017, 08:00 PM   #3
I had written amps over volts. I had another member explain some of the basics & said it should function properly.
ProSport Gauge Install Help airhunt2 MazdaSpeed 3/6 - Car Audio & Electronics 6 01-24-2013 09:23 AM
Prosport Gauge Install SJP0tato MazdaSpeed 3/6 - Turbo Induction 16 01-17-2010 10:40 PM
Page generated in 0.23879 seconds with 21 queries
