> 2010 MS3 - Torque Specs & information
  • 1 Post By PaPaSpeed
 Old 09-25-2009, 09:32 PM   #1
Wrxified's Avatar
Posts: 235   (View Stats)
Wrxified is the leader of the worldWrxified is the leader of the worldWrxified is the leader of the worldWrxified is the leader of the worldWrxified is the leader of the worldWrxified is the leader of the worldWrxified is the leader of the worldWrxified is the leader of the worldWrxified is the leader of the worldWrxified is the leader of the worldWrxified is the leader of the world
Neutral  :  -1 score
Default Drain plug for oil?
Anyone know the torque spec on this? Gave it one slight grunt last night doing my first oil change. No leaks. Looks like an aluminum pan so I didn't want to go nuts on it.
2010 Velocity Red MS3
1979 280ZX
Wrxified is offline   Reply With Quote
 Old 10-17-2009, 04:52 PM   #2
redblur's Avatar
Posts: 1,083   (View Stats)
redblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the world
Groans: 46
Wrxified:
I usually just got a 1/4 turn after its tight, no need to go tighter as you mentioned its an aluminum pan.
Can I ask how much oil you added when you did your change? My 1st Gen used to take between 5.7 and 5.8 quarts.
TIA!
redblur is offline   Reply With Quote
The Following User Says Thank You to redblur For This Useful Post:
Wrxified (10-17-2009)
 Old 10-17-2009, 05:00 PM   #3
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
there is a tq spec guide in here somewhere that will tell you everything you need to know
 Old 10-17-2009, 05:10 PM   #4
Wrxified's Avatar
Originally Posted by redblur View Post
Wrxified:
TIA!
Thanks. I think that's about what I used almost 6 quarts counting the oil filter. I was surprised that it took so much when I read the manual.
1979 280ZX
The Following User Says Thank You to Wrxified For This Useful Post:
redblur (10-17-2009)
 Old 10-17-2009, 08:43 PM   #5
redblur's Avatar
Groans: 46
Thanks Wrxified!
 Old 10-17-2009, 10:44 PM   #6
PaPaSpeed's Avatar
Posts: 602   (View Stats)
PaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the worldPaPaSpeed is the leader of the world
Oil pan drain plug tightening torque
30-41 N·m {3.1-4.1 kgf·m, 23-30 ft.lbf}
Dubcnea likes this.
CP-E Nano, CP-E Turbo inlet, CP-E TurboBack, CP-E Full Control, CP-E CDFP, CP-E Standback, Cobb RSB, ETS TMIC, SU Boost Tubes, SU MM, SU Shifter Bushings, Forge BPV, Eibach Pro Kit, Saikou Michi OCC, Denso ITV 22, Redline Hood Lifts, Redline (shift boot, armrest, e-brake cover), Amsoil 5w-30, Amsoil 75w-90, TWM A-6, Black badges, SU black side markers, 40% Tint, Rota Torques Gunmetalic.
PaPaSpeed is offline   Reply With Quote
The Following 5 Users Say Thank You to PaPaSpeed For This Useful Post:
indianaryan (07-01-2010), makjur (04-27-2014), pinetar (05-05-2010), turbo test (10-15-2013), Wrxified (10-17-2009)
 Old 10-18-2009, 02:00 AM   #7
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
make sure u use the crush washer
MATT DAMOND (10-21-2009)
 Old 10-21-2009, 01:03 PM   #8
funny4life's Avatar
Posts: 13   (View Stats)
funny4life is an unknown quantity at this point
are u guys using synthetic oil when changing it at home?
funny4life is offline   Reply With Quote
 Old 10-21-2009, 01:19 PM   #9
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Yes. Always run synthetic on a forced induction engine.
this forum serves 2 purposes
 Old 10-21-2009, 01:21 PM   #10
Wrxified's Avatar
Yep. I run Royal Purple 5w-30.
1979 280ZX
 Old 01-03-2010, 02:33 PM   #11
Mister T's Avatar
Posts: 5   (View Stats)
Mister T will become famous soon enough
Mister T is offline   Reply With Quote
The Following User Says NO Thank You to Mister T For This Un-useful Post:
 Old 01-19-2010, 04:14 AM   #12
pennsargus's Avatar
Posts: 89   (View Stats)
pennsargus has much to be proud ofpennsargus has much to be proud ofpennsargus has much to be proud ofpennsargus has much to be proud ofpennsargus has much to be proud ofpennsargus has much to be proud ofpennsargus has much to be proud ofpennsargus has much to be proud ofpennsargus has much to be proud ofpennsargus has much to be proud of
yep full synthetic first oil change just perfomed at 1100 miles
pennsargus is offline   Reply With Quote
 Old 01-19-2010, 04:39 AM   #13
miguelbates's Avatar
Posts: 689   (View Stats)
miguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the world
tighten is a hard as you can. be sure to strip it. lol jk btw what's the oil filter type on the new speed3's?
miguelbates is offline   Reply With Quote
 Old 01-19-2010, 05:49 AM   #14
Dre
Dre's Avatar
Posts: 1,651   (View Stats)
Dre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the world
Groans: 48
Groaned at 16 Times in 14 Posts
It uses a cartridge oil filter.. i hope thats the answer you're looking for MB.. thats what they told me yesterday when i got it changed at the dealership.. Mobil 1 Syn..
"Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is."
-TTT
Dre is offline   Reply With Quote
The Following User Says Thank You to Dre For This Useful Post:
miguelbates (01-20-2010)
 Old 01-20-2010, 11:08 AM   #15
thank you! yes. i was just wondering if they still used that format of oil filter. thanks for the info.
The Following User Says Thank You to miguelbates For This Useful Post:
Dre (01-21-2010)
 Old 01-21-2010, 05:29 AM   #16
Dre
Dre's Avatar
Groans: 48
NP bruh!
-TTT
 Old 01-22-2010, 04:20 AM   #17
dre is your pic from overdrift?
 Old 01-22-2010, 05:04 AM   #18
Dre
Dre's Avatar
Groans: 48
LOLOL.. you fail at movies.. its from the first Fast and the Furious.. Thats teh part where they're racing in the desert against the white kid with ADD in the Jetta.. "Too soon junior"...
Then Michelle Rodriguez punches that one asian dood out.. God.. shes so hot.. i bet shes an absolute animal in the sack.. I even adore the semi-retarded looking eye she has..
-TTT
 Old 01-22-2010, 05:26 AM   #19
ROFLLLL dude have you even seen Overdrift? youtube it and you'll see why that pic reminds me of it. fucking hilarious! lol @ too soon junior.
 Old 01-27-2010, 12:36 PM   #20
letzleta's Avatar
Posts: 385   (View Stats)
letzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the worldletzleta is the leader of the world
Groans: 33
Dre, did you have to take the Mobil 1 to the dealer when they changed the oil?
I got free oil changes with the purchase of my new car, however, the salesman said they put semi synthetic in it. So the question is do I need to bring my own oil or is the dealer oil ok?
2010 Mazdaspeed 3 Tech - Sort of Fast
some stuff
2008 Triumph Daytona 675 - Actually Fast
GB Racing Slider Kit - DDM 35w 6000k HID - TechSpec Snakeskins
letzleta is offline   Reply With Quote
 Old 01-28-2010, 05:23 AM   #21
Dre
Dre's Avatar
Groans: 48
they had the mobil 1 synthetic there.. but id be surprised if they gave you the synthetic for free.. and make sure you tell them synthetic.. the guy almost put regular oil in there.. then had the nerve to tell me to bring it back after 3k miles after he put synthetic in.. at least 5k miles for me between oil changes on this bad boy..
-TTT
 Old 01-28-2010, 07:05 AM   #22
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
pretty sure they switched back to a normal spin on filter. someone with a gen2 ms3 verify this?
'08 CWP MS3 w/ T3 3071r
 Old 01-28-2010, 07:21 AM   #23
letzleta's Avatar
Groans: 33
Hopefully I will be able to just "upgrade" my free oil change to synthetic. The salesman told me they use a blend, but I have no idea how much he actually knows about the oil changes. I guess I will have to give the service department a call.
One other question, when did you guys do your first oil change? The dealer said to bring it in at 5000 miles, but I am not sure I feel comfortable with that. I have never let a brand new engine go much past 1000 miles without a change.
some stuff
 Old 01-28-2010, 10:20 AM   #24
Dre
Dre's Avatar
Groans: 48
uhh.. i have a gen2 ms3.. thats how i know
-TTT
 Old 01-28-2010, 11:21 AM   #25
Wrxified's Avatar
Dre - opt_ms3 is saying it's a spin on. You said the dealer told you it was a cartridge. They gave you the wrong info unless the cars sold in FL are different than what we're getting everywhere else. I've changed the oil 3x on my gen 2. It's a spin on oil filter like opt_ms3 stated.
1979 280ZX
 Old 01-28-2010, 01:27 PM   #26
Dre
Dre's Avatar
Groans: 48
wow.. id been had.. sorry opt..
-TTT
 Old 01-29-2010, 07:21 PM   #27
cymrujmc's Avatar
Posts: 33   (View Stats)
cymrujmc will become famous soon enoughcymrujmc will become famous soon enough
Just changed the oil for the 2nd time today - in about 25 degrees (alright I was in the garage, but the door was open) - it uses the ph9566 in fram. Not sure about other filter makes, but def spin-on. I'm surprised by how "light" the engine feels again, much smoother. Thought I'd just been getting used to the car's power, but it definitely felt sluggish before the change (after 5k) compared to after. Maybe that fuel dilution problem? Used 5W-30 full synth mobil1 at 1500, then tried 0W-30 full synth mobil1 today. Anyone have any thoughts on the 0W-30?
cymrujmc is offline   Reply With Quote
 Old 01-29-2010, 07:50 PM   #28
Wrxified's Avatar
Without a doubt in your head. If your car felt sluggish just before an oil change and then you somehow picked up noticeable power then I feel sorry for your engine. Fuel dilution is something that will only be noticed over an extended period (many oil changes) eventually creating measureable wear on internal engine components. We're talking like 50k+ miles. I know the feeling you're referring to and would explain it to the same feeling you get after you ate well for the day and then worked out. Your not faster, you just feel good because you took care of yourself (car in this case).
The 0w means you have a thinner oil at start up temps so it's great oil for cars like yours and mine in the northern states during the winter months. Other than that it's still a 30 weight oil at normal engine temps.
1979 280ZX
cymrujmc (01-30-2010)
 Old 05-05-2010, 02:39 PM   #29
Lateapex36's Avatar
Posts: 36   (View Stats)
Lateapex36 will become famous soon enough
I changed mine at 500 miles to castrol syntec 5W30. The oil that comes from the factory has all kinds of assembly lube and such in it so swapping it out before 5000 is a good idea
Lateapex36 is offline   Reply With Quote
 Old 06-03-2010, 12:31 PM   #30
deyomatic's Avatar
Posts: 206   (View Stats)
deyomatic has a brilliant futuredeyomatic has a brilliant futuredeyomatic has a brilliant futuredeyomatic has a brilliant futuredeyomatic has a brilliant futuredeyomatic has a brilliant futuredeyomatic has a brilliant futuredeyomatic has a brilliant futuredeyomatic has a brilliant futuredeyomatic has a brilliant futuredeyomatic has a brilliant future
My dealer told me to do the first change at 1500 miles. I've only got about 200 right now, though. Just for future referrence, how difficult is this filter to access? I imagine it's not visible unless you're under the car or the answer to "spin-on vs. cartridge style" would not have even come up.
Thanks.
deyomatic is offline   Reply With Quote
 Old 06-03-2010, 01:00 PM   #31
PaPaSpeed's Avatar
Thanks.
Easy access.
 Old 06-03-2010, 01:45 PM   #32
cesaros's Avatar
Posts: 1,261   (View Stats)
cesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the world
Groans: 106
Groaned at 53 Times in 41 Posts
Thanks.
very easy. In the 2010 the undercarriage splash guard has an opening in it to access your Spin-on filter.
cesaros is offline   Reply With Quote
 Old 06-08-2010, 03:21 PM   #33
snailD's Avatar
Posts: 3,039   (View Stats)
Thanks.
nah its like right in your face
 Old 01-07-2011, 02:34 PM   #34
wormfighter's Avatar
Posts: 9   (View Stats)
wormfighter is on a distinguished road
That's all I will ever run in any of my vehicles.
wormfighter is offline   Reply With Quote
The Following User Says NO Thank You to wormfighter For This Un-useful Post:
wolly6973 (01-12-2011)
 Old 01-29-2011, 02:18 AM   #35
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Originally Posted by monicachenny View Post
im a newbie here! happy to know you!nice forum!
its looks so good!celebrity dresses amamzing!
wa, it looks so interesting! i like it ~
Fuck off doucher!
Sent from my iPhone using lame ass Tapatalk
 Old 04-02-2011, 09:54 AM   #36
Blck350z's Avatar
Posts: 8   (View Stats)
Blck350z will become famous soon enough
Hey guys, new to mazda's..... does anyone use Motul 8100 x-lite??? or any other motul brand, that's what I use to use in my two previous cars and it's actually a
true synthetic.....
Blck350z is offline   Reply With Quote
K04 oil feed line & oil drain line NJSPEED3 MazdaSpeed 3/6 - Turbo Induction 12 09-14-2009 10:46 AM
Magnetiic Oil drain plug Jarods7920 MazdaSpeed 6 - Engine, Transmission & Driveline 21 08-20-2009 06:44 AM
Magnetic Drain Plug KayWhy MazdaSpeed 3 - Engine, Transmission & Driveline 7 04-11-2009 12:45 AM
Magnetic Drain Bolt. Yes or No? desertrat Mazdaspeed3/6 General Discussion 14 10-09-2008 06:19 PM
Source of Battery Drain, Tire Valve Cap, Replacing A Brake Light: Mike Allen's Weekly Online Auto Clinic Haltech Automotive News 0 09-19-2008 02:30 PM
Page generated in 0.55659 seconds with 39 queries
