> 2010 MS3 - Torque Specs & information
Like Tree23Likes
 Old 08-02-2011, 12:44 PM   #41
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
I think it's this one
My Ebay DP
 Old 08-02-2011, 12:57 PM   #42
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
The CS DP comes with a nice, stainless antifouler. I didnt use that shit because the AP lets you disable that faggot CEL anyway.
403whp/451ft/lb Dry Shot
 Old 08-02-2011, 02:29 PM   #43
ChimmyChong's Avatar
Posts: 592   (View Stats)
ChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the world
Groans: 39
For gen2
If your 2nd o2 bung is far away from the exhaust stream (built with a anitfouler/spacer) you will get CEL's
P0137: Oxygen O2 Sensor Low Voltage (Bank1, Sensor2)
*** You will get around .0V - .1v causing the Lean code from not heating up properly
P0139: Oxygen Sensor Circuit Slow Response (Bank1, Sensor2)
*** /\ Same /\
P2096: Post catalyst fuel trim system too lean
*** /\ Same /\ Im running pig rich at idle at around 13.8-14.0 also when cruising
You need to get a bung welded directly onto the exhaust so the o2 sensor actually sits in the stream. This will get rid of the possible three CEL's and you will just get one for having no cats (which can be tuned out via ATR).
I just got my new bung welded on yesterday. The bung cost me $11 at a local performance shop. The welding (mig) cost $50 from Midas (i have friends there).
I have the ebay catless DP and I know that other Pu's running more reputable brands are running into the same issue even with a catted DP like @akbrazil running a catted UR DP.
Source: Check Engine Light (P2098)
2010 Liquid Silver MS3
// BNR S3 // 3Bar Map+MJ Harness // JBR 3.5" WP // CS TMIC // KMD HPFP // 3" Catless DP/RP // TS Dual Port // Cobb AP // GS 3 port EBCS // ITV-22's // MD OCC // JBR Small Battery Tray //
// JBR Dog Bone RMM // JBR Heavy Knob // JBR Solid Shifter Bushings // JBR Short Shifter Plate // JBR RSB // JBR 80D PMM // 15mm Front // 10mm Rear // SPC Rear Camber Arms // Sonic Tuning Coilovers //
// 6K HID // 35% tint // 12"RF with Infinity Amp // MZ Front Lip // 17x8 Enkei RPF1's //
ChimmyChong is offline   Reply With Quote
The Following User Says Thank You to ChimmyChong For This Useful Post:
zxhoya (09-28-2011)
 Old 08-02-2011, 02:39 PM   #44
lax22pearl's Avatar
Posts: 186   (View Stats)
lax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond reputelax22pearl has a reputation beyond repute
I have a first Gen btw and im getting a cel for both sensors. Would the first one need a defouler also?
Sorry just noticed this was in the sec Gen section. I searched and found thisndidnt realize it
08 CWP MS3 GT -- CP-E Nano SRI-PG TIP-Turbosmart BPV-Ebay 3" catless DP-Cobb AP-TurboXS FMIC-KMD FP Internals-Medieval RMM-TWM STS-Redline Goods Shift/E-Brake boot and armrest cover-BC Coilovers-Advan SA3R 18x9.5 +22-Federal595 215/35/18
lax22pearl is offline   Reply With Quote
 Old 08-02-2011, 02:40 PM   #45
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
Just curious... with an extended bung, does the CEL come up right away? The original UR downpipe had an extended bung that caused problems. I have the revised one which places the sensor directly in the exhaust stream. 100 miles so far and no CEL.
Sent from my DROIDX using Tapatalk
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
 Old 08-02-2011, 03:03 PM   #46
Groans: 39
Not instantly but after a drive cycle or two... Mine took awhile to actually pop up. Once it did it would come back pretty fast after clearing the DTC's. you have to actually reset your ecu (unplug battery) after fixing the issue.
I think your fine as long as the 2nd O2 is in the exhaust stream.
skeurton (08-02-2011)
 Old 08-02-2011, 04:05 PM   #47
dr_banano's Avatar
Posts: 502   (View Stats)
dr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the worlddr_banano is the leader of the world
Groaned at 22 Times in 8 Posts
but with the cobb donwpipe i wont be facing cel;s or will i???
Dr_banano
Car: Mazdaspeed3 2010 VRM- BNR S3 Turbo*FreekTuned*363HP 360TQ-DDM 6000k ,tinted 5%,K&N short ram - COBB AP V3 - COBB XLE bpv - JBR SSP stage 2 - JBR billet 80 RMM - JBR heavy shift knob - cp-e fuel pump - COBB inlet -COBB downpipe - COBB CBE - ETS TMIC black- FALKEN AZENIS tires - NGK LTR7IX-11 plugs - Corksports led kit - Corksport fog led kit.-Aeroforce gauges dual with blockhead dual gauge pod- CS boost tube -KNIGHTSPORTS REAR BUMPER - GS EBCS - 3 Bar Map - mgp brake calipers- corksport rear bumper lights - TWM short shifter - JBR TB/IM TI - EGR block - Njspeed pnp IM - K&W V3 coilover - Rear Carbon Fiber Spoiler - corksport hood scoop - WORK wheels 18 x 9.5 + 38 rear and 18 x 8 +38 front
ptp studs/seals pending
mazda 323 2002 hiboost turbo 1.6L-Automatic- Wife's car
dr_banano is offline   Reply With Quote
 Old 08-02-2011, 04:07 PM   #48
adlpb's Avatar
Groans: 669
No, Cobb does not give you a CEL
 Old 08-03-2011, 11:30 PM   #49
stang9779's Avatar
Posts: 1,066   (View Stats)
stang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the worldstang9779 is the leader of the world
Its pretty much like the others have said. its doable on raps or stands and takea a long time. take your time and walk away if you have too. You don't want to mess anything up, it's not that hard just takes a lot of time. get a buddy for help and have some beers. make it fun time will go faster.
If it was to through CEL you can just go into ATR and make your map where it wont come on again. This is done under edit--advanced engine parameters-- toggles. Just take out the P0421 and wont come up again. AP is the master of all for our cars.
2010 MS3 Velocity Red w/ Tech Package
Custom FreekTune e85 mix
GTX3071r - Cobb AP - CP-e Big TIP, XcelXL - Hallman PRO RX MBC - Steedspeed exhaust manifold - CS TMIC, CBE, Air Box, Interior LED kit, Mud Flaps - JBR EGR Block off, 88D RMM, 80D PMM, 88D TMM, HSK, RSB, SSP - KMD V2.1 internals - CNT DP - Forge BPV V2 - MD OCC - TWM FSS - NGK LTR7IX-11 - Konig Kilograms 18x8 +45 on 245/40zr18 Hankook V12's - H&R sport springs - SPC RC kit - Aeroforces Dual gauges - DDM tunning HID 35w 6000k - 20% black window tint, clear bra
Future Mods DO stage 2 WMI, Intake manifold of some type.
stang9779 is offline   Reply With Quote
The Following User Says Thank You to stang9779 For This Useful Post:
Scribbles (10-07-2011)
 Old 08-04-2011, 09:38 AM   #50
dr_banano's Avatar
well having a storm and downpipe havnt recieved it yet cause of the delay so no installing downpipe this weekend but i changed the spark plugs ngk step colder ill take some logs tonight and see
Dr_banano
 Old 08-04-2011, 06:20 PM   #51
dr_banano's Avatar
well seems stuff changed got home and look what i found ill see if i can installed it tomorow in the shop cause i dont have a o2 sensor key yet also a question about the xle bpv should i touch the spring or leave it as it comes ????
Dr_banano
 Old 08-05-2011, 08:01 AM   #52
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
I would leave the spring alone personally. Ive got the CPE catted dp and still used two defoulers for the downstream o2 sensor. Havent got a cel yet.
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
 Old 08-05-2011, 02:17 PM   #53
Bishounen0205's Avatar
Posts: 116   (View Stats)
Bishounen0205 is the leader of the worldBishounen0205 is the leader of the worldBishounen0205 is the leader of the worldBishounen0205 is the leader of the worldBishounen0205 is the leader of the worldBishounen0205 is the leader of the worldBishounen0205 is the leader of the worldBishounen0205 is the leader of the worldBishounen0205 is the leader of the worldBishounen0205 is the leader of the worldBishounen0205 is the leader of the world
Just curious about something. I'm waiting to install my downpipe since I want someone with experience to help me out on the install, but people that their o2 sensors have stripped, why not find a tap and die kit and rethread the o2 sensor? I haven't heard of anyone trying it on these cars, any reason why? I've seen it on a few Lexus and Subaru boards, just wondering if any of you guys knew why
Bishounen0205 is offline   Reply With Quote
 Old 08-05-2011, 04:11 PM   #54
I think you would have to see a stripped o2 sensor out of a mzr to realize it's more difficult than just rethreading it. They get pretty damn tore up.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 08-05-2011, 04:25 PM   #55
Lol thanks for the reply, yea I've never done a downpipe on a speed3 so I'm not to familiar with it, that's why I'm waiting to find someone that's willing to help me out. I've seen the o2 sensors for sale on street unit, does anyone know the difference between the first gen and 2nd gen primary o2 sensors? They sell them separate for each gen and the 2nd gen is almost $400 while the 1st gen is only about $200
 Old 08-05-2011, 04:46 PM   #56
skeurton's Avatar
Yup, they are different, as seen here:
http://www.mazdaspeedforum.org/forum/foru...-sensor-84333/
I bought a gen2 one from onlinemazdaparts.com as backup for when I installed my downpipe, just in case it got stripped. Luckily, I didn't encounter any such problems and it came out fairly easy, so I was able to re-use it. The one I bought is now up for sale in the FS section in case anyone needs it and wants to save some money.
2011 MAZDASPEED 3
 Old 08-05-2011, 05:38 PM   #57
warlord's Avatar
Posts: 756   (View Stats)
I installed my cp-e down pipe on wednesday.. O2 sensors...no problem. Manifold flange bolts...no problem. Manifold lower heat shield....major pain in the ass. Matter of fact all the heat shields were a pita. They all have to be removed to get the stock dp out of the car. Cp-e instuctions say that you can turn the stock dp a certain way and remove it from the car with the shields on. I fucked with it for over an hour then just removed the shields. Took me almost eight hours to do this install on ramps in a 95 degree garage. Going to a stage 2 map is totally worth it though. Pic is how I mounted the pre-cat O2 wire so it doesn't lay on the new dp.
2014 IS350 (sold)
2013 MS3 Stage2 E85 (sold)
2011 MS3 Stage2 (sold)
warlord is offline   Reply With Quote
The Following User Says Thank You to warlord For This Useful Post:
skeurton (08-05-2011)
 Old 08-05-2011, 06:30 PM   #58
skeurton's Avatar
LOL. Same for me. That lower heat shield is a bitch. That was honestly the hardest part. Also, getting the stock DP mounting bracket out from underneath the car was a pain in the ass. I had to use all sorts of swivel and wobble sockets to get to the one bolt. But it did make getting the DP out a breeze.
2011 MAZDASPEED 3
 Old 08-06-2011, 08:28 AM   #59
dr_banano's Avatar
so you must take the lower sheild of the cat from the dowpipe to take it out??
Dr_banano
 Old 08-06-2011, 09:17 AM   #60
warlord's Avatar
The upper and lower manifold heat shields have to be removed to access the dp flange bolts. The two heat shields that are attached to the dp itself plus the bracket that attaches the dp to the car have to be removed so the dp can be removed from the underside of the car. Like Skurton said, your going to need a wobble socket and different socket extentions to gain access to all these different bolts. You won't have straight access to most of them. Wear gloves too. My hands looked like I stuck them in a fish tank full of Piranha after the install.
2014 IS350 (sold)
The Following 3 Users Say Thank You to warlord For This Useful Post:
bertrand_CX_7 (08-22-2011), Keemo577 (08-25-2011), skeurton (08-06-2011)
 Old 08-07-2011, 11:13 AM   #61
I was able to get my dp off without removing the heat-shields on it. But im gen1 so that could be the difference there.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 08-07-2011, 08:09 PM   #62
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
damn, how lucky
i have a theory, maybe u have small hands, which tell me u are a midget. makes perfect sense, LOL
vella22 likes this.
2010 Black Mica
rghispanic88 is offline   Reply With Quote
 Old 08-07-2011, 08:15 PM   #63
adlpb's Avatar
Groans: 669
Originally Posted by rghispanic88 View Post
damn, how lucky
vella22 likes this.
The Following User Says Thank You to adlpb For This Useful Post:
 Old 08-10-2011, 03:43 PM   #64
Eh. 6'0 260lbs. Big ass midget. If only i had their strength... It was a BITCH getting the dp to line up with the turbo though, i needed a second set of hands for that.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 08-10-2011, 04:19 PM   #65
f-castrillo's Avatar
Posts: 1,342   (View Stats)
f-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the worldf-castrillo is the leader of the world
A second set of hands definitely helps the install. I'm a noob when it comes to doing installs, and even brought a friend, and it took us 9 hours lol. The most time consuming parts were removing the heat shields (we couldn't even get the first shield off without removing the rear TMIC mounting bracket), having to run to the store for an 8mm wrench (between all the toolsets we had, we only had as small as a 10mm lol), and the process of guiding the old DP out and the new DP in. Lining up with the turbo wasn't a problem, and we were able to get all but one of the bolts torqued down properly. The remaining nut is so close to the bellmouth flange opening, that it's impossible to get a socket seated on it, and because of the tight area it's in, you can really only turn it 1/16th at a time with the proper sized wrench.
This is for the CNT catted DP, by the way, so other downpipes may have better clearance for tightening that nut. It's easily visible on stands, without having to remove any of the chassis braces, so I may get it up on stands or a ramp and spend an hour tightening it further lol.
Oh, and PB blaster is your friend. I bought two cans just in case, and I nearly went through the entire first can. The O2 sensors took some force with the breaker bar to loosen, but once the initial loosening was done, spray the shit out of the bolt/threads and slowly work the fluid in by tightening/loosening until it comes out easy.
(310whp, 341 ft/lb wtq) 91 octane + 100% methanol
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // Ultimate Racing Test Pipe // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
f-castrillo is offline   Reply With Quote
The Following 2 Users Say Thank You to f-castrillo For This Useful Post:
wankular (08-25-2011), zxhoya (09-19-2011)
 Old 08-25-2011, 02:31 PM   #66
Keemo577's Avatar
Posts: 69   (View Stats)
Keemo577 has a reputation beyond reputeKeemo577 has a reputation beyond reputeKeemo577 has a reputation beyond reputeKeemo577 has a reputation beyond reputeKeemo577 has a reputation beyond reputeKeemo577 has a reputation beyond reputeKeemo577 has a reputation beyond reputeKeemo577 has a reputation beyond reputeKeemo577 has a reputation beyond reputeKeemo577 has a reputation beyond reputeKeemo577 has a reputation beyond repute
I recently installed a CP-e catless DP and got a cell as soon as I stepped on it a bit.
As for PB Blaster.. the SHIT. I soaked my bolts a week in advance and the day prior, and they all came out like butter. Only ones that gave me Hell were the bolts connecting the DP to the midpipe. I didn't soak those till the install.
Keemo577 is offline   Reply With Quote
The Following User Says Thank You to Keemo577 For This Useful Post:
zxhoya (09-19-2011)
 Old 08-26-2011, 03:08 PM   #67
mrQQ's Avatar
Posts: 1,164   (View Stats)
hm, are we sure about these part numbers from Bosch? rockauto.com gives completely different part numbers for bosch part for narrow band o2 sensor (3 different ones actually..)
mrQQ is offline   Reply With Quote
 Old 10-05-2011, 08:08 PM   #68
dr_banano's Avatar
well began this night ripping apart for the downpipe install, sensors out both no problem, upper manifold sheild out, i just had a problem with the last bolt it came round headed of the shield that covers the bolts of the downpipe to the maniflod, i stripped the head of one of them and now dont know how the hell totake it off so i couldnt get to the 5 bolts to pb blast them sh..t ill try tomorow with a pressure rench see if it does it
Dr_banano
 Old 10-06-2011, 08:24 AM   #69
dr_banano's Avatar
so do i have to take the downpipe shields, or did some one manage to take the downpipe without removing them,...is it doable...also how you guys manage to take the lowe bolts of the lower maniflod shield with a socket from under the car???
Dr_banano
 Old 10-06-2011, 08:38 AM   #70
zatara's Avatar
Posts: 1,505   (View Stats)
zatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the worldzatara is the leader of the world
Was that english?
zatara is offline   Reply With Quote
The Following 2 Users Say Thank You to zatara For This Useful Post:
Chimmike (10-21-2011), zpele (10-09-2011)
 Old 10-06-2011, 09:00 AM   #71
Mine came out without having to remove the shields that attach to the downpipe itself. Wiggle twist pull repeat... Wait a sec... And the lower manifold shield? The shield underneath the exhaust manifold? I dont even remember that thing but im confident if i had to take it off it came out from the top.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
The Following User Says Thank You to thatsmrgimp2u For This Useful Post:
dr_banano (10-06-2011)
 Old 10-06-2011, 06:53 PM   #72
dr_banano's Avatar
nothing still second intent and couldnt take that bolt out tomorow iam gonna rip it off but manage to pb blast the downpipe to manifold bolts but really they are a pita i didnt thought to be facing this sh...t at all ...
Dr_banano
 Old 10-07-2011, 11:26 AM   #73
foodtime's Avatar
Posts: 225   (View Stats)
What will happen if I drive with the heat shields off for about 5 miles. I plan to remove the shields at home and then the DP at the shop. I want to prevent from people staring at me while on the lift. I want to be in and out
 Old 10-07-2011, 01:21 PM   #74
wankular's Avatar
Posts: 4,343   (View Stats)
The car will be a little warm, that's all. The 02 sensors are actually easier to get out when the car is warm so the five miles is a good idea.
2009 MS3 sport MGM
The Following User Says Thank You to wankular For This Useful Post:
rfinkle2 (10-07-2011)
 Old 10-07-2011, 06:41 PM   #75
Airman3454's Avatar
Posts: 567   (View Stats)
Airman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the world
Dont be stressing about the O2 sensors. I was worried also until I read few how-to's and learned to spray EVERYTHING with some pb blaster repeatedly.
Drive to wherever you are removing the DP and allow the car to cool down but not totally. Spray the DP bolts and heatshield bolts with pb blaster, wait 15 minutes then slowly work them back and forth until you get them all out.
I didnt have a single problem with the heatshield bolts and I only had problems with one of the studs on the flange. Instead of the nut coming off it backed the whole stud out. All I did was apply thread sealant to all bolts, rebolt the aftermarket DP on and drove it for a while to burn off any residual PB or sealant.
Feel free to pm me if you need any other help.
Airman3454 is offline   Reply With Quote
 Old 10-07-2011, 10:51 PM   #76
dr_banano's Avatar
well i did the install all good thanks god,i took the stock downpipe with the shields really easy peace of cake,. my only problem was with one of the studs of the flang while installing them one of them the bolt wasnt straight and it got stuck ,so when taking it out the stud came out with it so i got a spacer and put it and problem solved thanks god ..all seems good
thatsmrgimp2u likes this.
Dr_banano
 Old 10-08-2011, 03:02 PM   #77
adlpb's Avatar
Groans: 669
Glad it all worked out for you
dr_banano likes this.
dr_banano (10-09-2011)
 Old 10-08-2011, 03:08 PM   #78
I love me some Dr. Banano posts.
atvfreek (10-08-2011), dr_banano (10-09-2011), InFeXIoN (02-04-2012)
 Old 10-08-2011, 03:28 PM   #79
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
Just did the second dp install on my car last night. I went from Catted cobb (donated to James Barone because of all he has done for me) and pit on a cnt catless. The funny thing is that the second dp you do on your car is a joke. If we were trying to hurry we probably could have done it in under an hour...top o2 sensor just twisted right out by hand lol (joels was the same when we switched out his turbo).
And heat shields? My car had heat shields? Haha.
dr_banano and rfinkle2 like this.
Ckmazdaspeed3 is offline   Reply With Quote
The Following 3 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
atvfreek (10-08-2011), dr_banano (10-09-2011), rfinkle2 (10-08-2011)
 Old 10-08-2011, 03:34 PM   #80
adlpb's Avatar
Groans: 669
I love me some Banano's
Fixed
The Following 3 Users Say Thank You to adlpb For This Useful Post:
need hlp after installing SU BPV camdensms6 MazdaSpeed 6 - Engine, Transmission & Driveline 3 11-02-2009 02:54 PM
help on installing MBC tburton101 MazdaSpeed 3 - How-To's 1 08-27-2009 02:35 PM
Page generated in 0.57815 seconds with 40 queries
